5952 connectés
  Linux et OS Alternatifs
  Installation
  Mariadb refuse de se lancer après l'installtion
n°1444792
dicapino
Posté le 19-02-2020 à 11:00:01  profilanswer
Bonjour à tous.
Je dois mettre en place une base de données sous debian 10.
Après l'installation de mariadb-server (qui semble bien se passer), j'ai une première erreur:
root@sgpia:~# mysql -u root
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
Je me suis donc rendu compte que le service ne se lance pas:
[....] Restarting mysql (via systemctl): mysql.serviceJob for mariadb.service failed because the control process exited with error code.
See "systemctl status mariadb.service" and "journalctl -xe" for details.
 failed!
Voici le statut du service:
* mariadb.service - MariaDB 10.3.22 database server
   Loaded: loaded (/lib/systemd/system/mariadb.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Wed 2020-02-19 09:57:12 UTC; 1min 48s ago
     Docs: man:mysqld(8)
           https://mariadb.com/kb/en/library/systemd/
  Process: 15973 ExecStartPre=/usr/bin/install -m 755 -o mysql -g root -d /var/run/mysqld (code=exited, status=0/SUCCESS)
  Process: 15974 ExecStartPre=/bin/sh -c systemctl unset-environment _WSREP_START_POSITION (code=exited, status=0/SUCCESS)
  Process: 15976 ExecStartPre=/bin/sh -c [ ! -e /usr/bin/galera_recovery ] && VAR= ||   VAR=`/usr/bin/galera_recovery`; [ $? -eq 0 ]   && systemctl set-environment _
  Process: 16024 ExecStart=/usr/sbin/mysqld $MYSQLD_OPTS $_WSREP_NEW_CLUSTER $_WSREP_START_POSITION (code=exited, status=226/NAMESPACE)
 Main PID: 16024 (code=exited, status=226/NAMESPACE)
Feb 19 09:57:12 sgpia systemd[1]: Starting MariaDB 10.3.22 database server...
Feb 19 09:57:12 sgpia systemd[1]: mariadb.service: Main process exited, code=exited, status=226/NAMESPACE
Feb 19 09:57:12 sgpia systemd[1]: mariadb.service: Failed with result 'exit-code'.
Feb 19 09:57:12 sgpia systemd[1]: Failed to start MariaDB 10.3.22 database server.
Je suis donc à la recherche de solution.
Merci pour vos contributions.
Message édité par dicapino le 19-02-2020 à 11:01:58
n°1444993
capitaine_​sylvain
Posté le 24-02-2020 à 14:30:17  profilanswer
systemctl status donne rarement de détail
Fait plutot journalctl -xe et regarde les message d'erreurs (liés à mysql, parce que ya de tout dedans)
Regarde les logs de mysql aussi.
T'as ptete une table à reparer suite à une coupure.
  Installation
Lancer une appli avec les droits root au démarrageImpossible de lancer Linux
Lancer Midori au demarrage ?Utilité d'un SSD pour MariaDB ?
centos7 lancer un script au démaragelancer un bash avec php-apache
PC refuse de démarrare - Ubuntu + newbie insideCluster MariaDB ? Percona ? Mysql ?
lancer un programme automatiquementSe lancer dans Debian
Plus de sujets relatifs à : Mariadb refuse de se lancer après l'installtion
