5647 connectés
  Linux et OS Alternatifs
  Installation
  Machine win2k invisible après maj noyau MDK 9.2
n°583685
kafifi
Posté le 01-11-2004 à 23:41:57  profilanswer
Bonsoir,
Sur une Mandrake 9.2, après mise à jour du noyau (2.4.26) et compilation, je ne vois plus le second PC Win2k. En revanche, je vois bien le troisième, sous Linux.
J'ai revérifié les paramètres de compilation, en vain. Ci-joint mon fichier de compilation. Pourriez-vous y jeter un oeil et m'aider à trouver le pb ?
D'avance merci.
# Automatically generated make config: don't edit
CONFIG_X86=y
# CONFIG_SBUS is not set
CONFIG_UID16=y
# Code maturity level options
# CONFIG_EXPERIMENTAL is not set
# Loadable module support
CONFIG_MODULES=y
CONFIG_MODVERSIONS=y
CONFIG_KMOD=y
# Processor type and features
# CONFIG_M386 is not set
# CONFIG_M486 is not set
# CONFIG_M586 is not set
# CONFIG_M586TSC is not set
# CONFIG_M586MMX is not set
# CONFIG_M686 is not set
# CONFIG_MPENTIUMIII is not set
CONFIG_MPENTIUM4=y
# CONFIG_MK6 is not set
# CONFIG_MK7 is not set
# CONFIG_MK8 is not set
# CONFIG_MELAN is not set
# CONFIG_MCRUSOE is not set
# CONFIG_MWINCHIPC6 is not set
# CONFIG_MWINCHIP2 is not set
# CONFIG_MWINCHIP3D is not set
# CONFIG_MCYRIXIII is not set
# CONFIG_MVIAC3_2 is not set
CONFIG_X86_WP_WORKS_OK=y
CONFIG_X86_INVLPG=y
CONFIG_X86_CMPXCHG=y
CONFIG_X86_XADD=y
CONFIG_X86_BSWAP=y
CONFIG_X86_POPAD_OK=y
# CONFIG_RWSEM_GENERIC_SPINLOCK is not set
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
CONFIG_X86_L1_CACHE_SHIFT=7
CONFIG_X86_HAS_TSC=y
CONFIG_X86_GOOD_APIC=y
CONFIG_X86_PGE=y
CONFIG_X86_USE_PPRO_CHECKSUM=y
CONFIG_X86_F00F_WORKS_OK=y
CONFIG_X86_MCE=y
# CONFIG_TOSHIBA is not set
# CONFIG_I8K is not set
# CONFIG_MICROCODE is not set
# CONFIG_X86_MSR is not set
# CONFIG_X86_CPUID is not set
CONFIG_NOHIGHMEM=y
# CONFIG_HIGHMEM4G is not set
# CONFIG_HIGHMEM64G is not set
# CONFIG_HIGHMEM is not set
# CONFIG_MATH_EMULATION is not set
# CONFIG_MTRR is not set
# CONFIG_SMP is not set
# CONFIG_X86_UP_APIC is not set
# CONFIG_X86_TSC_DISABLE is not set
CONFIG_X86_TSC=y
# General setup
CONFIG_NET=y
CONFIG_PCI=y
# CONFIG_PCI_GOBIOS is not set
# CONFIG_PCI_GODIRECT is not set
CONFIG_PCI_GOANY=y
CONFIG_PCI_BIOS=y
CONFIG_PCI_DIRECT=y
CONFIG_ISA=y
CONFIG_PCI_NAMES=y
# CONFIG_EISA is not set
# CONFIG_MCA is not set
CONFIG_HOTPLUG=y
# PCMCIA/CardBus support
CONFIG_PCMCIA=y
CONFIG_CARDBUS=y
# CONFIG_TCIC is not set
# CONFIG_I82092 is not set
# CONFIG_I82365 is not set
# PCI Hotplug Support
CONFIG_SYSVIPC=y
# CONFIG_BSD_PROCESS_ACCT is not set
CONFIG_SYSCTL=y
CONFIG_KCORE_ELF=y
# CONFIG_KCORE_AOUT is not set
CONFIG_BINFMT_AOUT=y
CONFIG_BINFMT_ELF=y
CONFIG_BINFMT_MISC=y
# CONFIG_OOM_KILLER is not set
CONFIG_PM=y
# CONFIG_APM is not set
# ACPI Support
CONFIG_ACPI=y
CONFIG_ACPI_BOOT=y
CONFIG_ACPI_BUS=y
CONFIG_ACPI_INTERPRETER=y
CONFIG_ACPI_EC=y
CONFIG_ACPI_POWER=y
CONFIG_ACPI_PCI=y
CONFIG_ACPI_SLEEP=y
CONFIG_ACPI_SYSTEM=y
CONFIG_ACPI_AC=y
# CONFIG_ACPI_BATTERY is not set
# CONFIG_ACPI_BUTTON is not set
# CONFIG_ACPI_FAN is not set
# CONFIG_ACPI_PROCESSOR is not set
# CONFIG_ACPI_ASUS is not set
# CONFIG_ACPI_TOSHIBA is not set
# CONFIG_ACPI_DEBUG is not set
# CONFIG_ACPI_RELAXED_AML is not set
# Memory Technology Devices (MTD)
# CONFIG_MTD is not set
# Parallel port support
# CONFIG_PARPORT is not set
# Plug and Play configuration
CONFIG_PNP=y
CONFIG_ISAPNP=y
# Block devices
CONFIG_BLK_DEV_FD=y
# CONFIG_BLK_DEV_XD is not set
# CONFIG_BLK_CPQ_DA is not set
# CONFIG_BLK_CPQ_CISS_DA is not set
# CONFIG_BLK_DEV_DAC960 is not set
# CONFIG_BLK_DEV_LOOP is not set
# CONFIG_BLK_DEV_NBD is not set
# CONFIG_BLK_DEV_RAM is not set
# CONFIG_BLK_STATS is not set
# Multi-device support (RAID and LVM)
# CONFIG_MD is not set
# Networking options
CONFIG_PACKET=y
# CONFIG_PACKET_MMAP is not set
# CONFIG_NETLINK_DEV is not set
# CONFIG_NETFILTER is not set
# CONFIG_FILTER is not set
CONFIG_UNIX=y
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
# CONFIG_IP_ADVANCED_ROUTER is not set
# CONFIG_IP_PNP is not set
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE is not set
# CONFIG_IP_MROUTE is not set
# CONFIG_INET_ECN is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_VLAN_8021Q is not set
# CONFIG_IPX is not set
# CONFIG_ATALK is not set
# Appletalk devices
# CONFIG_DECNET is not set
# CONFIG_BRIDGE is not set
# QoS and/or fair queueing
# CONFIG_NET_SCHED is not set
# Network testing
# CONFIG_NET_PKTGEN is not set
# Telephony Support
# CONFIG_PHONE is not set
# ATA/IDE/MFM/RLL support
CONFIG_IDE=y
# IDE, ATA and ATAPI Block devices
CONFIG_BLK_DEV_IDE=y
# Please see Documentation/ide.txt for help/info on IDE drives
# CONFIG_BLK_DEV_HD_IDE is not set
# CONFIG_BLK_DEV_HD is not set
CONFIG_BLK_DEV_IDEDISK=y
CONFIG_IDEDISK_MULTI_MODE=y
# CONFIG_IDEDISK_STROKE is not set
# CONFIG_BLK_DEV_IDECS is not set
CONFIG_BLK_DEV_IDECD=y
# CONFIG_BLK_DEV_IDETAPE is not set
# CONFIG_BLK_DEV_IDEFLOPPY is not set
# CONFIG_IDE_TASK_IOCTL is not set
# IDE chipset support/bugfixes
CONFIG_BLK_DEV_CMD640=y
# CONFIG_BLK_DEV_CMD640_ENHANCED is not set
# CONFIG_BLK_DEV_ISAPNP is not set
CONFIG_BLK_DEV_IDEPCI=y
# CONFIG_BLK_DEV_GENERIC is not set
CONFIG_IDEPCI_SHARE_IRQ=y
CONFIG_BLK_DEV_IDEDMA_PCI=y
# CONFIG_BLK_DEV_OFFBOARD is not set
# CONFIG_BLK_DEV_IDEDMA_FORCED is not set
CONFIG_IDEDMA_PCI_AUTO=y
# CONFIG_IDEDMA_ONLYDISK is not set
CONFIG_BLK_DEV_IDEDMA=y
# CONFIG_BLK_DEV_ADMA100 is not set
# CONFIG_BLK_DEV_AEC62XX is not set
# CONFIG_BLK_DEV_ALI15X3 is not set
# CONFIG_BLK_DEV_AMD74XX is not set
# CONFIG_BLK_DEV_ATIIXP is not set
# CONFIG_BLK_DEV_CMD64X is not set
# CONFIG_BLK_DEV_TRIFLEX is not set
# CONFIG_BLK_DEV_CY82C693 is not set
# CONFIG_BLK_DEV_CS5530 is not set
# CONFIG_BLK_DEV_HPT34X is not set
# CONFIG_BLK_DEV_HPT366 is not set
CONFIG_BLK_DEV_PIIX=y
# CONFIG_BLK_DEV_NS87415 is not set
# CONFIG_BLK_DEV_PDC202XX_OLD is not set
# CONFIG_BLK_DEV_PDC202XX_NEW is not set
CONFIG_BLK_DEV_RZ1000=y
# CONFIG_BLK_DEV_SC1200 is not set
# CONFIG_BLK_DEV_SVWKS is not set
# CONFIG_BLK_DEV_SIIMAGE is not set
# CONFIG_BLK_DEV_SIS5513 is not set
# CONFIG_BLK_DEV_SLC90E66 is not set
# CONFIG_BLK_DEV_TRM290 is not set
# CONFIG_BLK_DEV_VIA82CXXX is not set
# CONFIG_IDE_CHIPSETS is not set
CONFIG_IDEDMA_AUTO=y
# CONFIG_IDEDMA_IVB is not set
# CONFIG_DMA_NONPCI is not set
# SCSI support
# CONFIG_SCSI is not set
# Fusion MPT device support
# CONFIG_FUSION_BOOT is not set
# CONFIG_FUSION_ISENSE is not set
# CONFIG_FUSION_CTL is not set
# CONFIG_FUSION_LAN is not set
# I2O device support
# CONFIG_I2O is not set
# Network device support
CONFIG_NETDEVICES=y
# ARCnet devices
# CONFIG_ARCNET is not set
CONFIG_DUMMY=m
# CONFIG_BONDING is not set
# CONFIG_EQUALIZER is not set
# CONFIG_TUN is not set
# CONFIG_NET_SB1000 is not set
# Ethernet (10 or 100Mbit)
CONFIG_NET_ETHERNET=y
# CONFIG_HAPPYMEAL is not set
# CONFIG_SUNGEM is not set
# CONFIG_NET_VENDOR_3COM is not set
# CONFIG_LANCE is not set
# CONFIG_NET_VENDOR_SMC is not set
# CONFIG_NET_VENDOR_RACAL is not set
# CONFIG_DEPCA is not set
# CONFIG_HP100 is not set
# CONFIG_NET_ISA is not set
CONFIG_NET_PCI=y
# CONFIG_PCNET32 is not set
# CONFIG_AMD8111_ETH is not set
# CONFIG_ADAPTEC_STARFIRE is not set
# CONFIG_APRICOT is not set
# CONFIG_CS89x0 is not set
# CONFIG_TULIP is not set
# CONFIG_DE4X5 is not set
# CONFIG_DGRS is not set
# CONFIG_DM9102 is not set
CONFIG_EEPRO100=y
# CONFIG_EEPRO100_PIO is not set
# CONFIG_E100 is not set
# CONFIG_FEALNX is not set
# CONFIG_NATSEMI is not set
# CONFIG_NE2K_PCI is not set
# CONFIG_8139TOO is not set
# CONFIG_SIS900 is not set
# CONFIG_EPIC100 is not set
# CONFIG_SUNDANCE is not set
# CONFIG_TLAN is not set
# CONFIG_VIA_RHINE is not set
# CONFIG_WINBOND_840 is not set
# CONFIG_NET_POCKET is not set
# Ethernet (1000 Mbit)
# CONFIG_ACENIC is not set
# CONFIG_DL2K is not set
CONFIG_E1000=y
# CONFIG_E1000_NAPI is not set
# CONFIG_NS83820 is not set
# CONFIG_HAMACHI is not set
# CONFIG_R8169 is not set
# CONFIG_SK98LIN is not set
# CONFIG_TIGON3 is not set
# CONFIG_FDDI is not set
# CONFIG_PPP is not set
# CONFIG_SLIP is not set
# Wireless LAN (non-hamradio)
# CONFIG_NET_RADIO is not set
# Token Ring devices
# CONFIG_TR is not set
# CONFIG_NET_FC is not set
# Wan interfaces
# CONFIG_WAN is not set
# PCMCIA network device support
CONFIG_NET_PCMCIA=y
# CONFIG_PCMCIA_3C589 is not set
# CONFIG_PCMCIA_3C574 is not set
# CONFIG_PCMCIA_FMVJ18X is not set
CONFIG_PCMCIA_PCNET=y
# CONFIG_PCMCIA_AXNET is not set
# CONFIG_PCMCIA_NMCLAN is not set
# CONFIG_PCMCIA_SMC91C92 is not set
# CONFIG_PCMCIA_XIRC2PS is not set
# CONFIG_PCMCIA_XIRCOM is not set
# CONFIG_PCMCIA_XIRTULIP is not set
CONFIG_NET_PCMCIA_RADIO=y
CONFIG_PCMCIA_RAYCS=y
# CONFIG_PCMCIA_NETWAVE is not set
# CONFIG_PCMCIA_WAVELAN is not set
# Amateur Radio support
# CONFIG_HAMRADIO is not set
# IrDA (infrared) support
# CONFIG_IRDA is not set
# ISDN subsystem
# CONFIG_ISDN is not set
# Old CD-ROM drivers (not SCSI, not IDE)
# CONFIG_CD_NO_IDESCSI is not set
# Input core support
CONFIG_INPUT=m
# CONFIG_INPUT_KEYBDEV is not set
# CONFIG_INPUT_MOUSEDEV is not set
# CONFIG_INPUT_JOYDEV is not set
CONFIG_INPUT_EVDEV=m
CONFIG_INPUT_UINPUT=m
# Character devices
CONFIG_VT=y
CONFIG_VT_CONSOLE=y
CONFIG_SERIAL=y
# CONFIG_SERIAL_CONSOLE is not set
# CONFIG_SERIAL_EXTENDED is not set
# CONFIG_SERIAL_NONSTANDARD is not set
CONFIG_UNIX98_PTYS=y
CONFIG_UNIX98_PTY_COUNT=256
# I2C support
# CONFIG_I2C is not set
# Mice
# CONFIG_BUSMOUSE is not set
CONFIG_MOUSE=y
CONFIG_PSMOUSE=y
# CONFIG_82C710_MOUSE is not set
# CONFIG_PC110_PAD is not set
# CONFIG_MK712_MOUSE is not set
# Joysticks
# CONFIG_INPUT_GAMEPORT is not set
# CONFIG_INPUT_SERIO is not set
# Joysticks
# CONFIG_INPUT_IFORCE_USB is not set
# CONFIG_QIC02_TAPE is not set
# CONFIG_IPMI_HANDLER is not set
# Watchdog Cards
# CONFIG_WATCHDOG is not set
# CONFIG_SCx200 is not set
# CONFIG_AMD_RNG is not set
# CONFIG_INTEL_RNG is not set
# CONFIG_HW_RANDOM is not set
# CONFIG_AMD_PM768 is not set
# CONFIG_NVRAM is not set
# CONFIG_RTC is not set
# CONFIG_DTLK is not set
# CONFIG_R3964 is not set
# CONFIG_APPLICOM is not set
# Ftape, the floppy tape device driver
# CONFIG_FTAPE is not set
CONFIG_AGP=y
CONFIG_AGP_INTEL=y
CONFIG_AGP_I810=y
CONFIG_AGP_VIA=y
CONFIG_AGP_AMD=y
# CONFIG_AGP_AMD_K8 is not set
CONFIG_AGP_SIS=y
CONFIG_AGP_ALI=y
# CONFIG_AGP_SWORKS is not set
# CONFIG_AGP_NVIDIA is not set
# CONFIG_AGP_ATI is not set
# Direct Rendering Manager (XFree86 DRI support)
CONFIG_DRM=y
# CONFIG_DRM_OLD is not set
# DRM 4.1 drivers
CONFIG_DRM_NEW=y
CONFIG_DRM_TDFX=y
# CONFIG_DRM_GAMMA is not set
# CONFIG_DRM_R128 is not set
CONFIG_DRM_RADEON=y
CONFIG_DRM_I810=y
CONFIG_DRM_I810_XFREE_41=y
# CONFIG_DRM_I830 is not set
# CONFIG_DRM_MGA is not set
# CONFIG_DRM_SIS is not set
# PCMCIA character devices
# CONFIG_PCMCIA_SERIAL_CS is not set
# CONFIG_SYNCLINK_CS is not set
# CONFIG_MWAVE is not set
# Multimedia devices
CONFIG_VIDEO_DEV=m
# Video For Linux
# CONFIG_VIDEO_PROC_FS is not set
# Video Adapters
# CONFIG_VIDEO_PMS is not set
# CONFIG_VIDEO_CPIA is not set
# Radio Adapters
# CONFIG_RADIO_CADET is not set
# CONFIG_RADIO_RTRACK is not set
# CONFIG_RADIO_RTRACK2 is not set
# CONFIG_RADIO_AZTECH is not set
# CONFIG_RADIO_GEMTEK is not set
# CONFIG_RADIO_GEMTEK_PCI is not set
# CONFIG_RADIO_MAXIRADIO is not set
# CONFIG_RADIO_MAESTRO is not set
# CONFIG_RADIO_SF16FMI is not set
# CONFIG_RADIO_SF16FMR2 is not set
# CONFIG_RADIO_TERRATEC is not set
# CONFIG_RADIO_TRUST is not set
# CONFIG_RADIO_TYPHOON is not set
# CONFIG_RADIO_ZOLTRIX is not set
# File systems
# CONFIG_QUOTA is not set
# CONFIG_AUTOFS_FS is not set
CONFIG_AUTOFS4_FS=y
CONFIG_REISERFS_FS=y
# CONFIG_REISERFS_CHECK is not set
# CONFIG_REISERFS_PROC_INFO is not set
CONFIG_EXT3_FS=y
CONFIG_JBD=y
# CONFIG_JBD_DEBUG is not set
CONFIG_FAT_FS=y
CONFIG_MSDOS_FS=y
# CONFIG_UMSDOS_FS is not set
CONFIG_VFAT_FS=y
# CONFIG_CRAMFS is not set
CONFIG_TMPFS=y
CONFIG_RAMFS=y
CONFIG_ISO9660_FS=y
# CONFIG_JOLIET is not set
# CONFIG_ZISOFS is not set
# CONFIG_JFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_VXFS_FS is not set
CONFIG_NTFS_FS=y
# CONFIG_HPFS_FS is not set
CONFIG_PROC_FS=y
CONFIG_DEVPTS_FS=y
# CONFIG_QNX4FS_FS is not set
# CONFIG_ROMFS_FS is not set
CONFIG_EXT2_FS=y
# CONFIG_SYSV_FS is not set
CONFIG_UDF_FS=y
# CONFIG_UFS_FS is not set
# CONFIG_XFS_FS is not set
# Network File Systems
# CONFIG_CODA_FS is not set
CONFIG_NFS_FS=y
CONFIG_NFS_V3=y
CONFIG_NFSD=y
# CONFIG_NFSD_V3 is not set
CONFIG_SUNRPC=y
CONFIG_LOCKD=y
CONFIG_LOCKD_V4=y
CONFIG_SMB_FS=y
CONFIG_SMB_NLS_DEFAULT=y
CONFIG_SMB_NLS_REMOTE="cp437"
CONFIG_SMB_UNIX=y
CONFIG_NCP_FS=y
# CONFIG_NCPFS_PACKET_SIGNING is not set
# CONFIG_NCPFS_IOCTL_LOCKING is not set
# CONFIG_NCPFS_STRONG is not set
# CONFIG_NCPFS_NFS_NS is not set
# CONFIG_NCPFS_OS2_NS is not set
# CONFIG_NCPFS_SMALLDOS is not set
CONFIG_NCPFS_NLS=y
# CONFIG_NCPFS_EXTRAS is not set
# CONFIG_ZISOFS_FS is not set
# Partition Types
CONFIG_PARTITION_ADVANCED=y
# CONFIG_ACORN_PARTITION is not set
# CONFIG_OSF_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_ATARI_PARTITION is not set
# CONFIG_MAC_PARTITION is not set
CONFIG_MSDOS_PARTITION=y
# CONFIG_BSD_DISKLABEL is not set
# CONFIG_MINIX_SUBPARTITION is not set
# CONFIG_SOLARIS_X86_PARTITION is not set
# CONFIG_UNIXWARE_DISKLABEL is not set
# CONFIG_SGI_PARTITION is not set
# CONFIG_ULTRIX_PARTITION is not set
# CONFIG_SUN_PARTITION is not set
# CONFIG_EFI_PARTITION is not set
CONFIG_SMB_NLS=y
CONFIG_NLS=y
# Native Language Support
CONFIG_NLS_DEFAULT="iso8859-1"
# CONFIG_NLS_CODEPAGE_437 is not set
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
# CONFIG_NLS_CODEPAGE_850 is not set
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
# CONFIG_NLS_ISO8859_1 is not set
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
# CONFIG_NLS_UTF8 is not set
# Console drivers
CONFIG_VGA_CONSOLE=y
# CONFIG_VIDEO_SELECT is not set
# Sound
CONFIG_SOUND=y
# CONFIG_SOUND_ALI5455 is not set
# CONFIG_SOUND_BT878 is not set
# CONFIG_SOUND_CMPCI is not set
# CONFIG_SOUND_EMU10K1 is not set
# CONFIG_SOUND_FUSION is not set
# CONFIG_SOUND_CS4281 is not set
# CONFIG_SOUND_ES1370 is not set
CONFIG_SOUND_ES1371=y
# CONFIG_SOUND_ESSSOLO1 is not set
# CONFIG_SOUND_MAESTRO is not set
# CONFIG_SOUND_ICH is not set
# CONFIG_SOUND_SONICVIBES is not set
# CONFIG_SOUND_TRIDENT is not set
# CONFIG_SOUND_MSNDCLAS is not set
# CONFIG_SOUND_MSNDPIN is not set
# CONFIG_SOUND_VIA82CXXX is not set
# CONFIG_SOUND_OSS is not set
# CONFIG_SOUND_AD1980 is not set
# CONFIG_SOUND_WM97XX is not set
# USB support
CONFIG_USB=y
# CONFIG_USB_DEBUG is not set
# Miscellaneous USB options
# CONFIG_USB_DEVICEFS is not set
# CONFIG_USB_BANDWIDTH is not set
# USB Host Controller Drivers
CONFIG_USB_UHCI_ALT=y
# CONFIG_USB_OHCI is not set
# USB Device Class drivers
# CONFIG_USB_AUDIO is not set
# CONFIG_USB_MIDI is not set
#   SCSI support is needed for USB Storage
# CONFIG_USB_ACM is not set
# CONFIG_USB_PRINTER is not set
# USB Human Interface Devices (HID)
# CONFIG_USB_HID is not set
# CONFIG_USB_KBD is not set
# CONFIG_USB_MOUSE is not set
# CONFIG_USB_AIPTEK is not set
# CONFIG_USB_WACOM is not set
# CONFIG_USB_KBTAB is not set
# CONFIG_USB_POWERMATE is not set
# USB Imaging devices
# CONFIG_USB_DC2XX is not set
# CONFIG_USB_SCANNER is not set
# USB Multimedia devices
# CONFIG_USB_IBMCAM is not set
# CONFIG_USB_KONICAWC is not set
# CONFIG_USB_OV511 is not set
# CONFIG_USB_PWC is not set
# CONFIG_USB_SE401 is not set
# CONFIG_USB_STV680 is not set
# CONFIG_USB_DABUSB is not set
# USB Network adaptors
# USB port drivers
# USB Serial Converter support
# CONFIG_USB_SERIAL is not set
# USB Miscellaneous drivers
# CONFIG_USB_AUERSWALD is not set
# CONFIG_USB_TIGL is not set
# CONFIG_USB_LCD is not set
# Support for USB gadgets
# CONFIG_USB_GADGET is not set
# Bluetooth support
# CONFIG_BLUEZ is not set
# Kernel hacking
# CONFIG_DEBUG_KERNEL is not set
CONFIG_LOG_BUF_SHIFT=0
# Cryptographic options
# CONFIG_CRYPTO is not set
# Library routines
CONFIG_CRC32=y
# CONFIG_ZLIB_INFLATE is not set
# CONFIG_ZLIB_DEFLATE is not set
n°583844
Dark_Schne​ider
Close the World, Open the Net
Posté le 02-11-2004 à 13:38:56  profilanswer
en pingant ton PC win2k par l'IP cela marche ?
Mandriva : parce que nous le valons bien ! http://linux-wizard.net/index.php
n°584138
kafifi
Posté le 02-11-2004 à 20:49:48  profilanswer
Oui, le ping fonctionne de chaque côté. Un détail important que j'ai omis de préciser.
La machine Linux incriminée est équipée d'un mobilerack, ce qui fait que j'alterne entre 2 disques dur (cela me permet de faire des essais de configs).
disque 1 :
tout fonctionne à la perfection.
disque 2 :
je vois bien le PC Linux, mais pas le Win2k.
En revanche, de l'environnement Win2k, je vois parfaitement la machine Linux (et j'accède d'ailleurs à la partition partagée).
Je suis sensé avoir déroulé les mêmes installations sur les 2 disques : mdk 9.2 + passage noyau 2.4.22 => 2.4.26 + paramétrage et compilation. Mais visiblement, j'ai du merdouiller lors de la seconde installation, vu que je n'ai pas le même résultat...
Espérant que ces précisions vous aideront dans le diagnostique.
Message édité par kafifi le 02-11-2004 à 20:50:37
n°584145
Dark_Schne​ider
Posté le 02-11-2004 à 20:57:28  profilanswer
tu devrais l'activer vue que précédemment tu as :
et
CONFIG_SMB_NLS=y
que donne la commande :
findsmb
http://lea-linux.org/reseau/samba.html#connexion_smb
n°584155
kafifi
Posté le 02-11-2004 à 21:21:00  profilanswer
et
CONFIG_SMB_NLS=y
findsmb
Je ne vois que les 2 machines Linux du LAN.
Celle à pb (192.168.200.2) et la distante (192.168.200.11)
toutes deux sur le même workgroup que l'ensemble du LAN évidemment.
PS : je modifie de suite les 2 paramètres que tu as évoqués, je recompile et je poste le résultat dans la foulée.
Message édité par kafifi le 02-11-2004 à 21:22:13
n°584157
Dark_Schne​ider
Posté le 02-11-2004 à 21:25:11  profilanswer
il y a un serveur wins sur ton réseau ?
un "smclient -L IPduwin2k" donne koi ?
n°584172
kafifi
Posté le 02-11-2004 à 21:49:55  profilanswer
Il n'y a pas de seveur wins, car la machine win2k n'est qu'une workstation.
smbclient -L 192.168.200.1
me donne :
added interface ip=192.168.200.2 bcast=192.168.200.255 nmask 255.255.255.0
session request to 192.168.200.1 failed (Called name not present)
session request to 192 failed (Called name not present)
PS : la reconpilation avec la modif des 2 paramètres ne change rien.
Message édité par kafifi le 02-11-2004 à 21:50:28
n°584173
kafifi
Posté le 02-11-2004 à 21:52:45  profilanswer
me donne :
PS : la recompilation avec la modif des 2 paramètres ne change rien.
Désolé, je n'avais pas vu la suite... En tapant le password,  je vois tous les répertoires partagés de mon serveur.
Message édité par kafifi le 02-11-2004 à 22:06:04
n°584383
Dark_Schne​ider
Posté le 03-11-2004 à 12:11:22  profilanswer
donc c'est un pb de nom NETBIOS.
il te faut un serveur WINS ou alors tu remplis les fichiers lmhosts
n°584757
kafifi
Posté le 03-11-2004 à 21:45:42  profilanswer
Il s'agit d'une machine Win2k Workstation donc (sauf erreur) pas de serveur wins dispo.
Donc je viens de :
1/ ajouter au fichier /etc/samba/lmhosts la ligne "192.168.200.1 pcserver"
2/ Arrêter puis rédémarrer le service samba.
3/ Lancer recherche nouveaux serveurs.
=> toujours rien !
PS : je viens de relancer la machine avec l'autre hdd.
J'ai vérifier les fichiers /etc/hosts et /etc/samba/lmhosts
aucun ne fait apparaître la ligne "192.168.200.1 pcserver"
Pourant, je vois immédiatement le pc win2k, je ne comprends pas...
As-tu une idée ??
Merci.
Message édité par kafifi le 03-11-2004 à 22:02:58
n°585068
Dark_Schne​ider
Posté le 04-11-2004 à 15:11:58  profilanswer
firewall ?
commande : iptables -L
n°585274
kafifi
Posté le 04-11-2004 à 21:26:35  profilanswer
firewall ?
je n'ai pas sélectionné le firewall à l'install :
iptables -L     =>    command not found
Bon tant pis, je vais essayer de redérouler une install neuve pas à pas en revérifiant mes notes.
Merci pour ton aide en tous les cas.
A+
  Installation
Mdk 10.0 => 10.1 Upgrademultiboot mandrake win2k ?
pb NFS et mdk 10.1 official (résolu, boulet inside...)[QoS] Problème avec un nouveau noyau
[Problem MDK résolu ] Nforce2 module apu : inconnue2 gateway par défaut sur 1 machine
Icone imprimante dans la Systray [mdk 10.1]ATI Radeon 9800 Pro sous [MDK 9.1] ou [RH9]
mdk 10.x et questions diverses![Résolu] Raie verte et mdk 10
Plus de sujets relatifs à : Machine win2k invisible après maj noyau MDK 9.2
