3994 connectés
  Linux et OS Alternatifs
  Installation
  libz.so.1 and gentoo 64
n°1077468
janpepu
ne suze que si on s'en sert
Posté le 28-09-2008 à 04:03:53  profilanswer
Bonjour
j'ai besoin d 'une librairie 32 bits pour faire fonctionner un plugin
ldd -d -r /***/extensions/dbi.mysql.ext.so
Code :
  1. linux-gate.so.1 =>  (0xffffe000)
  2.         libz.so.1 => not found  Voila le probleme
  3.       libpthread.so.0 => /lib32/libpthread.so.0 (0xf7d25000)
  4.         libdl.so.2 => /lib32/libdl.so.2 (0xf7d21000)
  5.         libm.so.6 => /lib32/libm.so.6 (0xf7cfb000)
  6.         libc.so.6 => /lib32/libc.so.6 (0xf7bca000)
  7.         /lib/ld-linux.so.2 (0x56555000)
emerge zlib
Code :
  1. No package files given... Grabbing a set.
  2. --- replaced obj /usr/share/man/man3/zlib.3.bz2
  3. --- replaced dir /usr/share/man/man3
  4. --- replaced dir /usr/share/man
  5. --- replaced obj /usr/share/doc/zlib-1.2.3-r1/algorithm.txt.bz2
  6. --- replaced obj /usr/share/doc/zlib-1.2.3-r1/README.bz2
  7. --- replaced obj /usr/share/doc/zlib-1.2.3-r1/FAQ.bz2
  8. --- replaced obj /usr/share/doc/zlib-1.2.3-r1/ChangeLog.bz2
  9. --- replaced dir /usr/share/doc/zlib-1.2.3-r1
  10. --- replaced dir /usr/share/doc
  11. --- replaced dir /usr/share
  12. --- replaced obj /usr/lib64/libz.so
  13. --- replaced obj /usr/lib64/libz.a
  14. --- replaced dir /usr/lib64
  15. --- replaced obj /usr/include/zlib.h
  16. --- replaced obj /usr/include/zconf.h
  17. --- replaced dir /usr/include
  18. --- replaced dir /usr
  19. --- replaced obj /lib64/libz.so.1.2.3
  20. --- replaced sym /lib64/libz.so.1
  21. --- replaced sym /lib64/libz.so
  22. --- replaced dir /lib64
  23. >>> Regenerating /etc/ld.so.cache...
  24. >>> Original instance of package unmerged safely.
  25. >>> Regenerating /etc/ld.so.cache...
  26. >>> sys-libs/zlib-1.2.3-r1 merged.
Comment faire pour installer une librairie 32 bits de zlib ?
Message édité par janpepu le 28-09-2008 à 04:05:54
n°1077476
Tom_
Posté le 28-09-2008 à 11:08:31  profilanswer
Il faut que installe emul-linux-x86-baselibs ;) Regarde cette page : http://www.gentoo.org/proj/en/base [...] ontent.xml
n°1077489
janpepu
Posté le 28-09-2008 à 12:54:56  profilanswer
et ?
n°1077495
Tom_
Posté le 28-09-2008 à 13:55:22  profilanswer
Les ebuilds emul-linux-x86* permettent aux utilisateurs de Gentoo 64 bits d'avoir des libraires 32 bits. Cette page détaille le "contenu" de ces ebuilds ... et cest là qu'on s'appercoit que emul-linux-x86-baselibs permet d'obtenir les libraires 32 bits de zlib. ;)
n°1077498
janpepu
Posté le 28-09-2008 à 14:07:57  profilanswer
en effet merci beaucoup
  Installation
Probleme crontab (gentoo)Gentoo sur PowerPC : Airport absent de lspci
-march=core2, est-il reservé Gentoo 64 bits ?wifi sous Gentoo avec DWL-G510
Pas de son alors que tout a l'air ok {Gentoo & ALC658D}[Gentoo][Xorg] Problème de configuration avec le pilote i810 ( 82845G/
Carte reseau RTL8139 sur livecd Gentoo :oexiste t-il un kmail spécifique a kde-4 ? [Gentoo]
comment compiler gcc en 64 bits :'( [Gentoo] [Résolu]Gentoo 2008_beta2 kde 4 only compilé via gcc-4.3 -march=core2[Résolu]
Plus de sujets relatifs à : libz.so.1 and gentoo 64
