11209 connectés
  Linux et OS Alternatifs
  Installation
  pd installation mplayer +debian
n°328205
The Dml
pouet.. pouet ...
Posté le 21-09-2003 à 16:46:27  profilanswer
:hello: ! je suis entaint d essayer d installer mplayer a partir des source mais lors de l etape du make all j ai ce message
dmlpc2:/usr/share/mplayer-1.0pre1# make
gcc -c -O4 -march=athlon-xp -mcpu=athlon-xp -pipe -ffast-math -fomit-frame-pointer -D_REENTRANT -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64 -Ilibmpdemux -Iloader -Ilibvo  -I/usr/include/gtk-1.2 -I/usr/include/glib-1.2 -I/usr/lib/glib/include  -I/usr/include/SDL -D_REENTRANT -I/usr/X11R6/include    -o mplayer.o mplayer.c
In file included from mplayer.c:47:
libvo/font_load.h:5:31: freetype/freetype.h: No such file or directory
libvo/font_load.h:39: error: syntax error before "FT_Face"
libvo/font_load.h:39: warning: no semicolon at end of struct or union
libvo/font_load.h:40: warning: data definition has no type or storage class
libvo/font_load.h:61: error: syntax error before '}' token
libvo/font_load.h:61: warning: data definition has no type or storage class
libvo/font_load.h:63: error: syntax error before '*' token
libvo/font_load.h:63: warning: data definition has no type or storage class
libvo/font_load.h:82: error: syntax error before '*' token
libvo/font_load.h:82: warning: data definition has no type or storage class
libvo/font_load.h:83: error: syntax error before '*' token
libvo/font_load.h:85: error: syntax error before '*' token
libvo/font_load.h:86: error: syntax error before '*' token
libvo/font_load.h:98: error: syntax error before '*' token
libvo/font_load.h:98: warning: data definition has no type or storage class
make: *** [mplayer.o] Error 1
une idée pour me faire avancer ?
n°328207
mirtouf
Light is right !
Posté le 21-09-2003 à 16:50:30  profilanswer
n°328211
The Dml
pouet.. pouet ...
Posté le 21-09-2003 à 17:00:32  profilanswer
meci bcp mais tu pourrait me dire le pb que j ai ? car je voit pas quoi faire ... meme avec ce site ...
n°328246
Niala
Posté le 21-09-2003 à 19:00:32  profilanswer
Il te manque comme il dit freetype.h. Sans doute qu'il te manque le -dev de libfreetype.
Fais dpkg -S freetype.h et ensuite apt-get install le résultat de la commande
hmm mais simple question à part:
Pourquoi t'installe pas directement mplayer avec apt  :??: . Justement rajoute le lien que t'as donné mirtouf dans ton sources.list et ensuite apt-get install mplayer
n°328491
The Dml
pouet.. pouet ...
Posté le 22-09-2003 à 08:58:56  profilanswer
Salut !
en fait c que je tentait l install a partir du tuto de trustonme.net.Je vais tenter ton truc et si ca ne marche pas je tenterai avec le apt :) !
thx
n°328495
Niala
Posté le 22-09-2003 à 09:51:37  profilanswer
bah je te dirai que si t'as pas de besoin particulier passe par apt.
 Réserve la compilation a des besoins spécifiques ou quand le logiciel nécessite pas en .deb
n°328506
Humidifier
Posté le 22-09-2003 à 10:29:32  profilanswer
dpkg -S freetype.h
libfreetype6-dev: /usr/include/freetype2/freetype/freetype.h
libfontconfig1-dev: /usr/include/fontconfig/fcfreetype.h
En unstable:
http://packages.debian.org/cgi-bin [...] tories=yes
usr/X11R6/include/X11/Xft/XftFreetype.h       libdevel/xlibs-dev
usr/include/fontconfig/fcfreetype.h       libdevel/libfontconfig1-dev
usr/include/freetype/freetype.h        oldlibs/libttf-dev
usr/include/freetype2/freetype/freetype.h      libdevel/libfreetype6-dev
usr/share/doc/grass/html/d.text.freetype.html      science/grass
usr/share/doc/pike7.4-doc/html/reference/ex/predef_3A_3A/Image/FreeType.html doc/pike7.4-reference
usr/share/doc/texmf/help/Catalogue/entries/freetype.html    doc/tetex-doc
Message édité par Humidifier le 22-09-2003 à 10:35:06
Debian Sid up-to-date
n°328508
philou_a7
\_o< coin ! >o_/
Posté le 22-09-2003 à 10:46:19  profilanswer
ca parait evident : il te demande freetype.h, tu installes donc libfreetype6-dev, qui est le seul package qui corresponde ;)
pour l'unstable y a aussi oldlibs/libttf-dev, mais "oldlibs" donc bon... ;)
n°328581
lucaramel
Posté le 22-09-2003 à 15:51:17  profilanswer
Ne perds pas ton temps à essayer de compiler mplayer. Tu trouveras des paquets tout propres sur http://twolife.org .
n°328742
The Dml
pouet.. pouet ...
Posté le 22-09-2003 à 20:01:45  profilanswer
je vous remerci beaucoup du coup de main, ca marche impec !!  :jap:  :jap:
  Installation
problème d'installation de guipod sous KDE...BeWan ADSL USB st sur Linux Debian
debian woody : stable ?? bug ou mauvaise config ??installation polices true type
nostalsgie sans passer par mplayer ?Debian testing et libxrender
petit problème avec une debian 3 : phpA7N8X Deluxe > Installation Debian Woody et carte réseau
[rezolu] nforce2 et mandrake 9.1 : pb d'installation du chip réseau
Plus de sujets relatifs à : pd installation mplayer +debian
