4599 connectés
  Linux et OS Alternatifs
  Installation
  Installation de KDE3.
n°226504
mexx20
Posté le 20-02-2003 à 21:07:23  profilanswer
J'ai rajouté la ligne suivante dans mon "/etc/apt/sources.list" comme indiqué sur le site "www.kde.org"
# deb http://download.kde.org/stable/3.1/Debian stable main
J'ai ensuite tapé la ligne de commande suivante :
apt-get update && apt-get install arts kdelibs kdebase kdenetwork kdepim kdegraphics
L'installation ne se lance pas. Pouvez-vous me dire si j'ai oublié une étape ? Merci. Voici les messages d'erreurs :
Hit http://security.debian.org stable/updates/main Packages
Hit http://download.kde.org stable/main Packages
Hit http://download.kde.org stable/main Release
Hit http://security.debian.org stable/updates/main Release
Reading Package Lists... Done
Building Dependency Tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
Sorry, but the following packages have unmet dependencies:
  arts: Depends: libartsc0 (>= 1.1.0-0woody4) but it is not going to be installed
        Depends: libarts1 (>= 1.1.0-0woody4) but it is not going to be installed
  kdebase: Depends: kappfinder (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: kate (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: kcontrol (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: kdebase-bin (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: kdebase-kio-plugins (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: kdeprint (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: kdesktop (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: kfind (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: khelpcenter (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: kicker (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: klipper (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: kmenuedit (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: konqueror-nsplugins (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: konqueror (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: konsole (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: kpager (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: kpersonalizer (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: ksmserver (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: ksplash (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: ksysguard (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: ktip (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: kwin (>= 4:3.1.0-0woody2) but it is not going to be installed
           Depends: libkonq4 (>= 4:3.1.0-0woody2) but it is not going to be installed
  kdegraphics: Depends: kamera (>= 4:3.1.0-0woody2) but it is not going to be installed
               Depends: kcoloredit (>= 4:3.1.0-0woody2) but it is not going to be installed
               Depends: kdegraphics-kfile-plugins (>= 4:3.1.0-0woody2) but it is not going to be installed
               Depends: kdvi (>= 4:3.1.0-0woody2) but it is not going to be installed
               Depends: kfax (>= 4:3.1.0-0woody2) but it is not going to be installed
               Depends: kghostview (>= 4:3.1.0-0woody2) but it is not going to be installed
               Depends: kiconedit (>= 4:3.1.0-0woody2) but it is not going to be installed
               Depends: kmrml (>= 4:3.1.0-0woody2) but it is not going to be installed
               Depends: kooka (>= 4:3.1.0-0woody2) but it is not going to be installed
               Depends: kpaint (>= 4:3.1.0-0woody2) but it is not going to be installed
               Depends: kpovmodeler (>= 4:3.1.0-0woody2) but it is not going to be installed
               Depends: kruler (>= 4:3.1.0-0woody2) but it is not going to be installed
               Depends: ksnapshot (>= 4:3.1.0-0woody2) but it is not going to be installed
               Depends: kuickshow (>= 4:3.1.0-0woody2) but it is not going to be installed
               Depends: kview (>= 4:3.1.0-0woody2) but it is not going to be installed
               Depends: kviewshell (>= 4:3.1.0-0woody2) but it is not going to be installed
               Depends: libkscan1 (>= 4:3.1.0-0woody2) but it is not going to be installed
  kdelibs: Depends: kdelibs4 (>= 4:3.1.0-0woody5) but it is not going to be installed
           Depends: kdelibs-bin (>= 4:3.1.0-0woody5)
  kdenetwork: Depends: kdenetwork-kfile-plugins (= 4:3.1.0-0woody2) but it is not going to be installed
              Depends: kdict (= 4:3.1.0-0woody2) but it is not going to be installed
              Depends: kget (= 4:3.1.0-0woody2) but it is not going to be installed
              Depends: kgpgcertmanager (= 4:3.1.0-0woody2) but it is not going to be installed
              Depends: kit (= 4:3.1.0-0woody2) but it is not going to be installed
              Depends: kmail (= 4:3.1.0-0woody2) but it is not going to be installed
              Depends: kmailcvt (= 4:3.1.0-0woody2) but it is not going to be installed
              Depends: knewsticker (= 4:3.1.0-0woody2) but it is not going to be installed
              Depends: knode (= 4:3.1.0-0woody2) but it is not going to be installed
              Depends: korn (= 4:3.1.0-0woody2) but it is not going to be installed
              Depends: kpf (= 4:3.1.0-0woody2) but it is not going to be installed
              Depends: kppp (= 4:3.1.0-0woody2) but it is not going to be installed
              Depends: krdc (= 4:3.1.0-0woody2) but it is not going to be installed
              Depends: krfb (= 4:3.1.0-0woody2) but it is not going to be installed
              Depends: ksirc (= 4:3.1.0-0woody2) but it is not going to be installed
              Depends: kxmlrpc (= 4:3.1.0-0woody2) but it is not going to be installed
              Depends: libkdenetwork2 (= 4:3.1.0-0woody2) but it is not going to be installed
  kdepim: Depends: kalarm (>= 4:3.1.0-0woody2) but it is not going to be installed
          Depends: kalarmd (>= 4:3.1.0-0woody2) but it is not going to be installed
          Depends: kandy (>= 4:3.1.0-0woody2) but it is not going to be installed
          Depends: karm (>= 4:3.1.0-0woody2) but it is not going to be installed
          Depends: knotes (>= 4:3.1.0-0woody2) but it is not going to be installed
          Depends: korganizer (>= 4:3.1.0-0woody2) but it is not going to be installed
          Depends: kaddressbook (>= 4:3.1.0-0woody2) but it is not going to be installed
          Depends: kpilot (>= 4:3.1.0-0woody2) but it is not going to be installed
          Depends: ksync (>= 4:3.1.0-0woody2) but it is not going to be installed
          Depends: libkcal2 (>= 4:3.1.0-0woody2) but it is not going to be installed
          Depends: libkgantt0 (>= 4:3.1.0-0woody2) but it is not going to be installed
E: Sorry, broken packages
n°226536
mexx20
Posté le 20-02-2003 à 22:43:24  profilanswer
up .
n°226546
eL_Shaman_​__
Plop.
Posté le 20-02-2003 à 23:32:47  profilanswer
Passe en Debian Unstable, c'est plus simple.
n°226564
mexx20
Posté le 21-02-2003 à 01:39:36  profilanswer
Peux-tu me dire en deux mots comment faire pour passer du stade stable au stable unstable ?
J'ai essayé de remplacer toutes les occurences du mot stable par unstable dans mon fichier sources.list mais au moment de faire une update de la base de donnée d'apt on me signale des erreurs (404, not reachable, ... ).
n°226568
eL_Shaman_​__
Plop.
Posté le 21-02-2003 à 02:20:53  profilanswer
Dans  /etc/apt/sources.list:
deb http://ftp.fr.debian.org/debian unstable main contrib
deb http://ftp.fr.debian.org/debian unstable non-free
deb http://ftp.fr.debian.org/debian-non-US unstable/non-US main
deb http://ftp.fr.debian.org/debian-non-US unstable/non-US contrib
deb http://ftp.fr.debian.org/debian-non-US unstable/non-US non-free
deb-src http://ftp.fr.debian.org/debian unstable main contrib
deb-src http://ftp.fr.debian.org/debian unstable non-free
deb-src http://ftp.fr.debian.org/debian-non-US unstable/non-US main
deb-src http://ftp.fr.debian.org/debian-non-US unstable/non-US contrib
deb-src http://ftp.fr.debian.org/debian-non-US unstable/non-US non-free
Ensuite, tu tappes:
apt-get update
apt-get dist-upgrade
Tant que j'y suis, pour le JAVA, ces lignes fonctionnent bien:
deb http://www.tux.org/pub/java/debian sid main non-free
deb-src http://www.tux.org/pub/java/debian sid main non-free
n°227118
mexx20
Posté le 22-02-2003 à 05:08:39  profilanswer
Un tout tout grand merci à toi !
  Installation
installation gatos[Debian Sarge]Problème d'installation d'openoffice
Installation de kde 3.1[HELP] Installation debian & Diverses questions installation Linux
Comment recuperer les packages d'installation sous MDK 9 ?[debian] Probleme d'installation vmware (directory of C header)
Traduc d'un manuel d'installation d'un chip de Carte graphique[ OpenMandriva ] <= Mandriva <= Mandrake
Linux : installation d'imprimante PSMKDE3: Red Hat 7.2 et MDK 8.2 INSTALLATION ??? C ' ici ...
Plus de sujets relatifs à : Installation de KDE3.
