9824 connectés
  Linux et OS Alternatifs
  Installation
  installation driver ati
n°879798
alex7532
Posté le 21-01-2007 à 12:33:37  profilanswer
bonjour, j'ai installé les drivers ati 8.32.5 sur ubuntu 6.10 en kernel 2.6.20-5 mais quand je tape fglrxinfo je vois bien que ça n'a pas marché je ne comprends pas :
Xlib:  extension "XFree86-DRI" missing on display ":0.0".
display: :0.0  screen: 0
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.2 (1.5 Mesa 6.5.1)
n°879801
ffomnislas​h
Posté le 21-01-2007 à 12:41:59  profilanswer
donne les résultats de
cat /Var/log/Xorg.0.log | grep EE
cat /Var/log/Xorg.0.log | grep WW
n°879803
alex7532
Posté le 21-01-2007 à 13:04:02  profilanswer
alex7532@edubuntu-asus-alex:~$ cat /Var/log/Xorg.0.log | grep EE
cat: /Var/log/Xorg.0.log: Aucun fichier ou répertoire de ce type
alex7532@edubuntu-asus-alex:~$ cat /Var/log/Xorg.0.log | grep WW
n°879807
Velhcro
Cosworth Addicted
Posté le 21-01-2007 à 13:17:02  profilanswer
ne mets pas de majuscule à "/var" ;)
n°879808
alex7532
Posté le 21-01-2007 à 13:17:42  profilanswer
voila :
alex7532@edubuntu-asus-alex:~$ cat /var/log/Xorg.0.log | grep EE
        (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(II) Loading extension MIT-SCREEN-SAVER
(EE) fglrx(0): Failed to initialize GPS!
(EE) AIGLX: Screen 0 is not DRI capable
(EE) xf86OpenSerial: Cannot open device /dev/wacom
(EE) Error loading keymap /var/lib/xkb/server-0.xkm
alex7532@edubuntu-asus-alex:~$ cat /var/log/Xorg.0.log | grep WW
(WW) The directory "/usr/share/X11/fonts/misc" does not exist.
(WW) The directory "/usr/share/X11/fonts/cyrillic" does not exist.
(WW) The directory "/usr/share/X11/fonts/100dpi/" does not exist.
(WW) The directory "/usr/share/X11/fonts/75dpi/" does not exist.
(WW) The directory "/usr/share/X11/fonts/Type1" does not exist.
(WW) The directory "/usr/share/X11/fonts/100dpi" does not exist.
(WW) The directory "/usr/share/X11/fonts/75dpi" does not exist.
(WW) `fonts.dir' not found (or not valid) in "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType".
(WW) fglrx: No matching Device section for instance (BusID PCI:6:0:1) found
(WW) fglrx(0): Failed to open DRM connection
(WW) fglrx(0): Failed to open DRM connection for driver fglrx.
(WW) fglrx(0): ***********************************************
(WW) fglrx(0): * DRI initialization failed!                  *
(WW) fglrx(0): * (maybe driver kernel module missing or bad) *
(WW) fglrx(0): * 2D acceleraton available (MMIO)             *
(WW) fglrx(0): * no 3D acceleration available                *
(WW) fglrx(0): ********************************************* *
(WW) fglrx(0): Option "VendorName" is not used
(WW) fglrx(0): Option "ModelName" is not used
(WW) fglrx(0): Textured Video not supported without DRI enabled.
(WW) fglrx(0): Video Overlay not supported on AVIVO based graphics cards. For XVideo support use Option "TexturedVideo".
Message édité par alex7532 le 21-01-2007 à 13:19:41
n°883208
alex7532
Posté le 01-02-2007 à 19:48:52  profilanswer
alors personne ne sait ???
n°883222
Adamaru
geek un jour, geek toujours !
Posté le 01-02-2007 à 21:05:26  profilanswer
si, moi j'ai deja eut les memes problemes:
tu a quelle carte ATI ? ( le model )
pour ma part jai du: install depuis le .run ensuite tu fais:
cd /lib/modules/fglrx/build_mod/
./make.sh
cd ..
./make_install.sh
et tu relance, vérifie si dans ton noyau a la compilation tu a desactivé le module "direct rendering manager"
apres cette manip ca marche chez moi
blackpearl:/home/chr0nos# glxinfo | grep rendering
direct rendering: Yes
blackpearl:/home/chr0nos# fglrxinfo
OpenGL vendor string: ATI Technologies Inc.
OpenGL renderer string: RADEON 9600 Generic
OpenGL version string: 2.0.6286 (8.33.6)
n°883500
alex7532
Posté le 02-02-2007 à 19:24:05  profilanswer
ma carte est une ati radeon x1900xtx et ta manip ne marche pas : erreur de build quand je fais ./make.sh
[quote]/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:70: warning: (near initialization for ‘FGLDRM_proc_list’)
/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:72: warning: braces around scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:72: warning: (near initialization for ‘FGLDRM_proc_list’)
/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:72: warning: initialization from incompatible pointer type
/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:72: warning: excess elements in scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:90: error: expected ‘)’ before ‘*’ token
/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:144: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:174: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:213: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:269: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:292: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:339: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:362: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:409: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:432: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:466: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:480: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/drm_proc.h:537: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:353: error: storage class specified for parameter ‘drm_proclist’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:353: error: parameter ‘drm_proclist’ is initialized
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:365: error: storage class specified for parameter ‘firegl_stub_list_t’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:366: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘firegl_stub_list’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:368: error: storage class specified for parameter ‘firegl_stub_root’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:369: error: storage class specified for parameter ‘firegl_minor’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:372: error: expected declaration specifiers or ‘...’ before ‘device_t’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:375: error: storage class specified for parameter ‘firegl_drm_stub_info_t’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:376: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘firegl_stub_info’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:378: error: storage class specified for parameter ‘__ke_pte_phys_addr_str’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:381: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:386: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:397: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:398: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:399: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:400: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:401: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:402: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:403: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:408: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:414: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:422: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:432: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:437: error: expected declaration specifiers or ‘...’ before ‘poll_table’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:438: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:455: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:459: error: storage class specified for parameter ‘firegl_interrupt_file_ops’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:459: error: parameter ‘firegl_interrupt_file_ops’ is initialized
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:460: error: ‘firegl_interrupt_open_wrap’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:461: error: ‘firegl_interrupt_read_wrap’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:462: error: ‘firegl_interrupt_release_wrap’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:463: error: ‘firegl_interrupt_poll_wrap’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:464: error: ‘firegl_interrupt_write_wrap’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:467: error: parameter ‘firegl_proc_list’ is initialized
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:469: warning: braces around scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:469: warning: (near initialization for ‘firegl_proc_list’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:469: warning: initialization from incompatible pointer type
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:469: error: ‘drm_name_info_wrap’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:469: warning: excess elements in scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:470: warning: braces around scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:470: warning: (near initialization for ‘firegl_proc_list’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:470: warning: initialization from incompatible pointer type
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:470: error: ‘drm_mem_info_wrap’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:470: warning: excess elements in scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:471: warning: braces around scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:471: warning: (near initialization for ‘firegl_proc_list’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:471: warning: initialization from incompatible pointer type
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:471: error: ‘drm_mem_info1_wrap’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:471: warning: excess elements in scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:472: warning: braces around scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:472: warning: (near initialization for ‘firegl_proc_list’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:472: warning: initialization from incompatible pointer type
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:472: error: ‘drm_vm_info_wrap’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:472: warning: excess elements in scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:473: warning: braces around scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:473: warning: (near initialization for ‘firegl_proc_list’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:473: warning: initialization from incompatible pointer type
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:473: error: ‘drm_clients_info_wrap’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:473: warning: excess elements in scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:474: warning: braces around scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:474: warning: (near initialization for ‘firegl_proc_list’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:474: warning: initialization from incompatible pointer type
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:474: error: ‘firegl_lock_info_wrap’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:474: warning: excess elements in scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:475: warning: braces around scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:475: warning: (near initialization for ‘firegl_proc_list’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:475: warning: initialization from incompatible pointer type
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:475: error: ‘firegl_umm_info_wrap’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:475: warning: excess elements in scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:480: warning: braces around scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:480: warning: (near initialization for ‘firegl_proc_list’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:480: warning: initialization from incompatible pointer type
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:480: error: ‘firegl_bios_version_wrap’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:480: warning: excess elements in scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:481: warning: braces around scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:481: warning: (near initialization for ‘firegl_proc_list’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:481: warning: initialization from incompatible pointer type
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:481: warning: excess elements in scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:482: warning: braces around scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:482: warning: (near initialization for ‘firegl_proc_list’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:482: warning: initialization from incompatible pointer type
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:482: warning: excess elements in scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:485: error: expected ‘)’ before ‘*’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:550: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:574: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:598: error: storage class specified for parameter ‘firegl_stub_fops’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:598: error: parameter ‘firegl_stub_fops’ is initialized
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:600: error: ‘firegl_stub_open’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:603: error: expected declaration specifiers or ‘...’ before ‘device_t’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:604: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:623: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:640: error: expected declaration specifiers or ‘...’ before ‘device_t’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:641: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:675: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:684: error: storage class specified for parameter ‘fglrx_pci_table’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:684: error: parameter ‘fglrx_pci_table’ is initialized
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:686: warning: braces around scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:686: warning: (near initialization for ‘fglrx_pci_table’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:687: error: field name not in record or union initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:687: error: (near initialization for ‘fglrx_pci_table’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:687: warning: initialization makes pointer from integer without a cast
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:688: error: field name not in record or union initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:688: error: (near initialization for ‘fglrx_pci_table’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:688: warning: excess elements in scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:688: warning: (near initialization for ‘fglrx_pci_table’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:689: error: field name not in record or union initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:689: error: (near initialization for ‘fglrx_pci_table’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:689: warning: excess elements in scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:689: warning: (near initialization for ‘fglrx_pci_table’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:690: error: field name not in record or union initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:690: error: (near initialization for ‘fglrx_pci_table’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:690: warning: excess elements in scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:690: warning: (near initialization for ‘fglrx_pci_table’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:691: error: field name not in record or union initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:691: error: (near initialization for ‘fglrx_pci_table’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:691: warning: excess elements in scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:691: warning: (near initialization for ‘fglrx_pci_table’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:692: error: field name not in record or union initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:692: error: (near initialization for ‘fglrx_pci_table’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:692: warning: excess elements in scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:692: warning: (near initialization for ‘fglrx_pci_table’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:694: warning: braces around scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:694: warning: (near initialization for ‘fglrx_pci_table’)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:694: warning: excess elements in scalar initializer
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:698: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:712: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:746: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:780: error: storage class specified for parameter ‘fglrx_pci_driver’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:780: error: parameter ‘fglrx_pci_driver’ is initialized
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:784: error: ‘fglrx_pci_probe’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:786: error: ‘fglrx_pci_suspend’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:787: error: ‘fglrx_pci_resume’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:796: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:885: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:915: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:915: error: ‘init_module’ defined both normally and as an alias
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:915: error: expected declaration specifiers before ‘;’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:916: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:916: error: ‘cleanup_module’ defined both normally and as an alias
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:916: error: expected declaration specifiers before ‘;’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:922: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:935: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:941: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:949: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:955: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:960: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:984: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:991: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:996: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1001: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1007: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1013: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1019: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1024: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1029: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1034: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1044: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1049: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1054: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1095: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1107: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1112: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1119: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1130: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1135: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1144: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1149: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1154: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1159: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1164: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1169: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1176: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1181: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1188: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1193: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1229: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1234: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1242: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1247: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1252: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1257: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1266: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1287: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1383: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1392: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1403: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1408: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1413: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1418: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1423: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1428: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1435: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1440: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1445: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1450: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1455: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1460: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1465: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1472: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1477: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1482: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1487: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1497: error: storage class specified for parameter ‘PFNMLOCK’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1498: error: storage class specified for parameter ‘PFNMUNLOCK’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1502: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1517: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1532: error: storage class specified for parameter ‘PFNMODIFYLDT’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1535: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1556: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1561: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1568: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1677: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1693: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1709: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1714: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1719: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1744: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1749: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1754: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1763: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1775: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1795: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1806: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1811: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1816: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1821: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1826: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1831: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1835: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1839: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1844: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1849: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1854: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1859: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1864: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1869: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1874: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1879: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1884: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1893: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1908: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1922: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1942: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1964: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1978: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1987: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:1996: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2002: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2008: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2020: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2025: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2030: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2035: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2040: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2045: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2050: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2055: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2075: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2107: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2122: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2199: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2222: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2227: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2232: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2237: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2242: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2247: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2252: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2257: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2262: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2273: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2286: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2291: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2296: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2301: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2306: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2311: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2316: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2323: error: storage class specified for parameter ‘cpus_waiting’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2326: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2341: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2377: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2386: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2395: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2404: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2436: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2441: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2446: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2451: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2456: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2461: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2466: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2471: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2477: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2482: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2487: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2492: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2500: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2505: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2510: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2515: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2520: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2525: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2530: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2538: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2543: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2562: error: storage class specified for parameter ‘irq_handler_func’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2565: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2573: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2581: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2609: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2615: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2632: error: storage class specified for parameter ‘mem_map_t’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2633: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘*’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2638: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘do_vm_nopage’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2674: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘do_vm_shm_nopage’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2760: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘do_vm_dma_nopage’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2800: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘do_vm_kmap_nopage’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2838: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘do_vm_pcie_nopage’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2890: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘do_vm_gart_nopage’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2913: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘vm_nopage’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2950: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘vm_shm_nopage’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2964: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘vm_dma_nopage’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2972: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘vm_kmap_nopage’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2980: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘vm_pcie_nopage’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:2987: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘vm_gart_nopage’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3075: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3080: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3085: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3090: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3099: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3111: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3135: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3162: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3178: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3180: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3182: error: storage class specified for parameter ‘vm_ops’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3182: error: parameter ‘vm_ops’ is initialized
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3184: error: ‘vm_nopage’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3185: error: ‘ip_drm_vm_open’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3186: error: ‘ip_drm_vm_close’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3200: error: storage class specified for parameter ‘vm_shm_ops’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3200: error: parameter ‘vm_shm_ops’ is initialized
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3202: error: ‘vm_shm_nopage’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3207: error: storage class specified for parameter ‘vm_pci_bq_ops’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3207: error: parameter ‘vm_pci_bq_ops’ is initialized
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3209: error: ‘vm_dma_nopage’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3214: error: storage class specified for parameter ‘vm_ctx_ops’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3214: error: parameter ‘vm_ctx_ops’ is initialized
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3221: error: storage class specified for parameter ‘vm_pcie_ops’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3221: error: parameter ‘vm_pcie_ops’ is initialized
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3223: error: ‘vm_pcie_nopage’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3228: error: storage class specified for parameter ‘vm_kmap_ops’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3228: error: parameter ‘vm_kmap_ops’ is initialized
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3230: error: ‘vm_kmap_nopage’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3235: error: storage class specified for parameter ‘vm_gart_ops’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3235: error: parameter ‘vm_gart_ops’ is initialized
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3237: error: ‘vm_gart_nopage’ undeclared (first use in this function)
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3244: error: storage class specified for parameter ‘vm_agp_bq_ops’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3244: error: parameter ‘vm_agp_bq_ops’ is initialized
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3264: error: expected ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘{’ token
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3450: error: parameter ‘__ke_agp_try_unsupported’ is initialized
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3453: error: storage class specified for parameter ‘__fgl_agp_init’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3454: error: storage class specified for parameter ‘__fgl_agp_cleanup’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3455: error: storage class specified for parameter ‘__fgl_agp_try_unsupported’
/lib/modules/fglrx/build_mod/2.6.x/firegl_public.c:3456: error: storage class specifie
Message édité par alex7532 le 02-02-2007 à 19:30:12
n°883523
Amonchakai
Posté le 02-02-2007 à 20:23:22  profilanswer
   moi j'ai eu le même problème sur ma edgy, et donc j'ai regardé du côté de ma bible (le wiki d'ubuntu) et j'ai trouvé ça :
http://doc.ubuntu-fr.org/fglrx?s=carte%20ati
   et ça te redirige vers la solution du problème :
http://doc.ubuntu-fr.org/fglrx?s=c [...] eration_3d paragraphe "DRI ou accélération 3D"
   et ensuite chez moi ça marche :D
n°883535
alex7532
Posté le 02-02-2007 à 20:43:41  profilanswer
Je pense que c'est mon noyau qui n'est pas encore pris en charge par le pilote puisque je viens de réussir a faire marcher l'accélération 3D sur le 2.6.17 :D
Message édité par alex7532 le 02-02-2007 à 20:43:55
n°883536
Adamaru
Posté le 02-02-2007 à 20:54:31  profilanswer
ca m'intrigue quand même que le noyau ne gere pas car ma 9600 pro tourne impec sous le  2.6.19.2 :/
rhalala le jour ou ati se décidera a arreter de faire des drivers de m......
par contre je ne vois pas trop d'ou viens l'erreur, donc dans le doute je m'abstiendrais de dire une ânerie :)
  Installation
installation driver wifi sur edubuntu 6.10[résolu:)]installation driver imprimante Canon laser couleur
Installation driver ati X700 sous linux[Ubuntu] Pb au démarrage après installation du driver Nvidia
ajouter driver pendant l installation de debian, comment faire ?installation de driver ATI sur SUSE 10 [resolu]
pb installation driver ati et libstdc!!!!![Ubuntu 5.04] Installation nouveau driver IPW2200
Installation driver NVIDIA sur redhat 8installation driver ati 8.12.10 sur kernel 2.6.11.8 : erreur agp3.c
Plus de sujets relatifs à : installation driver ati
