3825 connectés
  Linux et OS Alternatifs
  Installation
  [SATA-RAID] Installation sur P4G8X Deluxe (controlleur Sil3112A)
 Page :   1  2
Page Précédente
n°248597
ethernal
Chercheur de vérité...
Posté le 13-04-2003 à 12:52:57  profilanswer
Installation de Linux sur une MB Asus P4G8X Deluxe avec un controlleur SATA RAID Silicon Image 3112A (en RAID0).
Code :
  1. Credits :
  2. Special thx to BeAsh
  3. Sources :
  4. Silicon Image 3112 : http://12.24.47.40/display/2/kb/article.asp?aid=10041
  5. Linux ATA Developpment : http://www.linuxdiskcert.org/
  6. RAID : http://people.redhat.com/arjanv/pd [...] howto.html
  7. Gentoo's Forum : http://forums.gentoo.org/viewtopic.php?t=46042
  8. DMA info : http://forums.gentoo.org/viewtopic.php?t=63442
  9. Product description :
  10. http://www.siimage.com/products/overview_sii3112.asp
  11. ########
  12. # Boot #
  13. ########
  14. # Find a bootable CD with a >2.4.20 kernel or create it...
  15. # An easy way is to use MDK 9.1 inst CD
  16. # Hit F1, choose boot mode
  17. rescue
  18. # load your keyboard spec
  19. loadkeys /usr/lib/kbd/keymaps/i386/azerty/be-latin1.maps.gz
  20. # load your nic (mine is on the mb)
  21. modprobe bcm5700
  22. # configure your network (192.168.1.11 is my gateway) and DNS
  23. ifconfig eth0 192.168.1.9 up
  24. route -add default gw 192.168.1.11 netmask 0.0.0.0 dev eth0
  25. echo -e "nameserver 212.100.160.51" > /etc/resolv.conf
  26. echo -e "nameserver 212.100.160.52" >> /etc/resolv.conf
  27. #################################
  28. # Use your SATA/RAID0 partition #
  29. #################################
  30. # run this script (or do it manually) (floppy-disk is better)
  31. wget http://people.redhat.com/arjanv/pdcraid/MAKEDEV
  32. # load RAID
  33. modprobe ataraid
  34. modprobe silraid
  35. # now it's ok
  36. # do whatever you want on /dev/ataraid/d0
  37. # look my partitions (created with Partition Magic)
  38. fdisk /dev/ataraid/d0
  39. Command : m
  40. /dev/ataraid/d0p1   NTFS        # primary partition
  41. /dev/ataraid/d0p2   Win98 Ext'd # logical partition
  42. /dev/ataraid/d0p5   Linux       # /boot
  43. /dev/ataraid/d0p6   Linux       # /
  44. /dev/ataraid/d0p7   Linux       # /home
  45. /dev/ataraid/d0p8   Win95 Fat32 # exchange
  46. /dev/ataraid/d0p9   Linux Swap  # swap
  47. # Prepare the system
  48. mkswap /dev/ataraid/d0p9
  49. swapon /dev/ataraid/d0p9
  50. mount /dev/ataraid/d0p6 /mnt/disk
  51. mkdir -p disk/boot disk/home
  52. mount /dev/ataraid/d0p5 /mnt/disk/boot
  53. mount /dev/ataraid/d0p7 /mnt/disk/home
  54. #######################
  55. # Install Your Distro #
  56. #######################
  57. # for example :
  58. #-Gentoo ;)
  59.   # get the lastest stage and follow the "Howto install Gentoo" page.
  60. # any other distros comments ??
  61. # don't forget to load ataraid and silraid modules in /etc/modules[.autoload]
  62. # if your system like Gentoo use devfs pay attention :
  63. # /dev/ataraid/dXpY becomes /dev/ataraid/discX/partY !!
  64. # change it in your fstab and in lilo.conf
  65. # otherwise create the nodes to your ataraid system
  66. # (script http://people.redhat.com/arjanv/pdcraid/MAKEDEV)
  67. ##########################
  68. # Create your own Kernel #
  69. ##########################
  70. # get the lastest kernel from kernel.org
  71. cd /usr/src/
  72. wget ftp://ftp.belnet.be/mirror/ftp.ke [...] .20.tar.gz
  73. tar xvzf linux-2.4.20.tar.gz
  74. ln -s linux-2.4.20 linux
  75. # choose one of these solution
  76. # -- only for SATA support (not RAID) (developpment is stable):
  77. wget ftp://ftp.belnet.be/mirror/ftp.ke [...] 20-ac2.bz2
  78. # -- for SATA with RAID support (under developpment - for testing):
  79. # get one of these
  80. wget ftp://ftp.belnet.be/mirror/ftp.ke [...] 4/testing/
  81. - patch-2.4.21-pre5.bz2
  82. - patch-2.4.21-pre7.bz2
  83. - patch-2.4.21-rc1.bz2
  84. wget ftp://ftp.belnet.be/mirror/ftp.ke [...] .4/2.4.21/
  85. - patch-2.4.21-pre5-ac3.bz2
  86. - patch-2.4.21-pre7-ac1.bz2
  87. - patch-2.4.21-rc1-ac1.bz2
  88. cd linux
  89. # for each patch
  90. bzcat ../patch-2.4.xx.bz2 | patch -p1
  91. # Configure your kernel
  92. make menuconfig
  93. # Select the following options (Sil3112 support and Raid0):
  94. - Code Maturity option
  95. -- (*)Prompt for Developpment and/or incomplete code/drivers
  96. ...
  97. - ATA/IDE/MFM/RLL support
  98. -- IDE, ATA and ATAPI Block Devices
  99. --- (*) Silicon image chipset support #SATA Support
  100. --- (*) Support for IDE RAID controllers (EXPERIMENTAL)
  101. ---- (*) Silicon Image Medley software RAID (EXPERIMENTAL) # RAID support
  102. # if you select modules, don't forget to load them
  103. ##################
  104. # Configure lilo #
  105. ##################
  106. # edit lilo.conf
  107. vi /et/lilo.conf
  108.   boot=/dev/ataraid/d0
  109.   ...
  110.   image=/boot/bzImage
  111.   root=/dev/ataraid/d0p6
  112.   ...
  113.   other=/dev/ataraid/d0p1
  114.   ...
  115. # activate your settings
  116. # don't forget to mount your /boot partition if it exists
  117. /sbin/lilo
  118. # look at this place to avoid disk problems (freeze when hardworking)
  119. http://forums.gentoo.org/viewtopic.php?t=63442
Message édité par ethernal le 29-06-2003 à 15:17:38
n°248665
hornetmen
GaZZzz... Et Flash....22
Posté le 13-04-2003 à 17:01:12  profilanswer
ca m'interesse aussi.....
n°248667
ethernal
Posté le 13-04-2003 à 17:06:33  profilanswer
un copain qui a acheté la même config que moi a posté sur le forum de Gentoo : http://forums.gentoo.org/viewtopic [...] =sata+raid
j'attends la suite de son témoignage... (je suis un peu perdu là :( )
n°248671
hornetmen
Posté le 13-04-2003 à 17:15:46  profilanswer
bah ouais, impossible de trouver quoi que ce soit....
Je souhaitais passer en full linux, mais c'est pas gagné...
J'arrive pas à booter, 2 60go en stripping... :cry:
n°248686
ethernal
Posté le 13-04-2003 à 17:42:00  profilanswer
(actuellement j'attends mes disques sata 80gb)
j'ai donc un bête Seagate 60 Gb sur IDE...
- Gentoo 1.4rc4 stage 1 : après le boot d'install, écran noir.
- Mandrake 9.1 : idem.
 :sweat:
heu j'ai peur là :(
Message édité par ethernal le 13-04-2003 à 18:14:12
n°248697
hornetmen
Posté le 13-04-2003 à 18:04:23  profilanswer
- Gentoo 1.4rc4 stage 1, après l'affichage d'accueil, écran noir. (j'ai jamais installé cette distro, mais à mon avis c'est pas normal  :sweat:)
- Mandrake 9.1 écran noir.
heu j'ai peur là :(
bah moa rh8, pas de disk reconnu au boot, il me demande un disk driver pour mon controleur...Mais introuvable sur le net.
n°248699
kyo54
Posté le 13-04-2003 à 18:11:32  profilanswer
et sans utiliser le raid, est-ce que y'a des pilotes pour ce chip?
n°248701
ethernal
Posté le 13-04-2003 à 18:11:49  profilanswer
ça s'est normal  :sweat:
mais là j'ai pas de disque sur le controlleur spécial et il veut rien faire !!
normalement le pre patch pour le kernel 2.4.21 est ici :
http://www.kernel.org/pub/linux/kernel/people/hedrick/
...oups kernel error...
n°248721
hornetmen
Posté le 13-04-2003 à 19:06:08  profilanswer
ca sert à quoi exectement ?
n°248730
ethernal
Posté le 13-04-2003 à 19:27:49  profilanswer
je sais pas trop soit c'est pour charger le module sil.o et supporter le controleur de disque qui n'est pas fournit en standard, soit c'est pour charger le RAID hardware.
correction pour la mandrake 9.1, il passe en install mode text (c'est sans doute mon ecran tft ou ma gforce ti4200 qui ne passe pas).
messages à l'install :
- le controleur 3112 est reconnu "SERIAL ATA controller IDE Controller".
- Aucune mention des possibilités RAID.
- Pendant l'install, la carte réseau Broadcom est détectée, mais si je la configure ça plante :(
c'est déjà un bon point
Message édité par ethernal le 15-04-2003 à 00:59:50
n°248737
hornetmen
Posté le 13-04-2003 à 19:54:28  profilanswer
- le controleur 3112 est reconnu comme SERIAL ATA controleur.
a quelle moment tu lui passes le patch ?
Pendant le boot ?
n°248738
ethernal
Posté le 13-04-2003 à 19:57:46  profilanswer
justement je sais pas :(
n°248741
hornetmen
Posté le 13-04-2003 à 20:03:25  profilanswer
J'ai installé la rh 8 sur un ptit hdd en attendant, sur un port ide classique....
Je vois voir ca en cherchant comment monter mon filesystem sur le controleur raid.
n°248743
ethernal
Posté le 13-04-2003 à 20:10:59  profilanswer
je teste aussi sur ide classique :)
fais moi un rapport complet des problèmes d'install, comme ça on pourra faire un howto de base.
n°248749
hornetmen
Posté le 13-04-2003 à 20:17:41  profilanswer
ca roule, d'apres ce que j'ai vu, à partir du kernel 2.4.2..C'est inclu directos.....
Donc je download et test  ;)
n°249417
ethernal
Posté le 15-04-2003 à 02:54:11  profilanswer
wget http://www.kernel.org/pub/linux/ke [...] .20.tar.gz
wget http://www.kernel.org/pub/linux/ke [...] 0ide-1.bz2
Code :
  1. cd /usr/src/linux
  2. bzcat ../2.4.21-pre4-2420ide-1.bz2 | patch -p1
  3. make menuconfig
  4. - ATA/IDE/MFM/RLL support
  5. -- IDE, ATA and ATAPI Block Devices
  6. --- (M) Silicon image chipset support
  7. --- (M) Support for IDE RAID controllers (EXPERIMENTAL)
  8. ---- (M) Silicon Image Medley software RAID (EXPERIMENTAL)
Malheureusement, j'ai un error 2 dans driver/ide (setup-pci.c)
Message édité par ethernal le 16-04-2003 à 13:59:45
n°249833
kyo54
Posté le 15-04-2003 à 19:58:20  profilanswer
ok alors je suis allé voir le site consctructeur.
On y trouve leurs différents chips dont le tien http://www.siimage.com/products/sii3112.asp
si on rentre plus dans les détails http://www.siimage.com/products/overview_sii3112.asp on lit que ça marche sous Linux, reste à savoir comment  :pt1cable:
n°249887
kyo54
Posté le 15-04-2003 à 21:22:06  profilanswer
mes recherches n'ont rien donné  :(
je n'ait pas trouvé de pilotes, ni d'options dans le kernel. Donc si quelqu'un à trouvé quelque chose qu'il fasse signe!
n°250165
ethernal
Posté le 16-04-2003 à 12:10:03  profilanswer
j'ai eu confirmation :
la mandrake 9.1 supporte le sata raid sur le controlleur 3112.
Si vous souhaitez utiliser une autre distro, il faut booter sur un kernel 2.4.21 (2.4.20 patché).
Le plus facile étant de booter sur la mdk 9.1 en rescue et démarrer votre install à partir de là.
Il faut impérativement installer le dernier kernel 2.4.21 pour pouvoir redémarrer après l'installation...
n°250167
kyo54
Posté le 16-04-2003 à 12:11:47  profilanswer
ouais mais il est où le patch? :pt1cable: Faut prendre celui sur kernel.org?
Message édité par kyo54 le 16-04-2003 à 12:16:34
n°250289
ethernal
Posté le 16-04-2003 à 14:51:54  profilanswer
je suis pas encore là :(
essaye le 2.4.21-pre7 ac1
j'ai installé mes HD sata, et installé w*nd*ws.
Comment installer Linux dessus ??
Code :
  1. ########
  2. # Boot #
  3. ########
  4. # insert MDK 9.1 CD and hit F1, choose boot mode
  5. rescue
  6. # load your keyboard spec
  7. loadkeys /usr/share/kbd/keymaps/i386/azerty/be-latin1.maps.gz
  8. # load your nic (mine is on the mb)
  9. modprobe bcm5700
  10. # configure your network (192.168.1.11 is my gateway)
  11. route -add default gw 192.168.1.11 netmask 0.0.0.0 dev eth0
  12. # configure your dns
  13. echo -e "nameserver 212.100.160.51" >> /etc/resolv.conf
  14. echo -e "nameserver 212.100.160.52" >> /etc/resolv.conf
  15. #################################
  16. # Use your SATA/RAID0 partition #
  17. #################################
  18. # 1st run this script (or do it manually):
  19. wget http://people.redhat.com/arjanv/pdcraid/MAKEDEV
  20. # load hardware raid
  21. modprobe ataraid
  22. modprobe silraid
  23. # now it's ok
  24. # do whatever you want on /dev/ataraid/d0
comment monter le disque sur le système ??
cat /proc/ide*/hd*/model
  PLEXTOR -> hda (ide0)
  SAMSUNG DVD -> hdc (ide1)
  AS380023AS -> hde (sata1)
  AS380023AS -> hdg (sata2)
fdisk /dev/hdg
  warning : invalid flag 0x0000 of partition table 5 will be corrected by write
  Command : p
  Disk : /dev/hdg 80Gb ...
  Device             Blocks            system
  /dev/hdg1        6000Mb         NTFS
  /dev/hdg2        150.000Mb    Win95 Extended
Message édité par ethernal le 16-04-2003 à 16:01:03
n°250318
hornetmen
Posté le 16-04-2003 à 15:30:27  profilanswer
je viens d'installer une rh9 au boulot, le noyau fourni à l'air de supporter le sata sil3112...2.4.20-8
Je testerais ptetre ce soir à la maison.
n°250368
ethernal
Posté le 16-04-2003 à 18:17:20  profilanswer
ok dès qu'il est booté, tu dois utiliser ça :
sinon, tu écriras sur tes disques sans le raid.
à moins qu'il n'y ait une option au démarrage
modprobe ataraid
modprobe silraid
# now it's ok
ex : fdisk /dev/ataraid/d0
n°250476
hornetmen
Posté le 16-04-2003 à 22:25:27  profilanswer
modprobe ataraid
modprobe silraid
# now it's ok
c'est installé sur mon veiux hdd.
Par contre, qd je fais modprobe silraid, j'obtiens ca :
[root@localhost root]# modprobe silraid
/lib/modules/2.4.20-8/kernel/drivers/ide/raid/silraid.o: init_module: No such device
Hint: insmod errors can be caused by incorrect module parameters, including invalid IO or IRQ parameters.
      You may find more information in syslog or the output from dmesg
/lib/modules/2.4.20-8/kernel/drivers/ide/raid/silraid.o: insmod /lib/modules/2.4.20-8/kernel/drivers/ide/raid/silraid.o failed
/lib/modules/2.4.20-8/kernel/drivers/ide/raid/silraid.o: insmod silraid failed [i]
n°250542
ethernal
Posté le 17-04-2003 à 00:27:29  profilanswer
il reconnait tes disques ou pas ?
n°250549
hornetmen
Posté le 17-04-2003 à 00:39:47  profilanswer
ouais, ca ca marche....
Mais comme 2 disques distincts je penses....
J'ai 2*60 en raid0 - :
1 part 10 go fat32
1 part 100 go fat32
1 part 10 go unused
Je compile, mais ca marche pas fort....
n°250562
ethernal
Posté le 17-04-2003 à 01:46:25  profilanswer
sans doute que dans cette version il reconnait les controlleurs sata, mais n'utilise pas le raid.
tu dois pouvoir choisir ça dans le kernel pour que ça fct je pense
---- (M) Silicon Image Medley software RAID(EXPERIMENTAL)
n°250563
hornetmen
Posté le 17-04-2003 à 01:48:13  profilanswer
eh eh.....
le pb c'est que dans les sources du kernel fournies, bah je peux pas choisir :
Tout les EXPERIMENTAL, impossible de les selectionner  :o
n°250567
ethernal
Posté le 17-04-2003 à 03:16:48  profilanswer
fo l'activer
Sinon, dans le patch 2.4.20-ac2 d'Alan Cox, il y a le support du chipset Silicon Image 3112, mais pas le support du Raid.
Les patch sur base d'un 2.4.20 de kernel.org :
# en développment:
patch officiel ftp://ftp.belnet.be/mirror/ftp.ke [...] 1-pre5.bz2
éventuellement ajouter le patch d'alan cox :
ftp://ftp.belnet.be/mirror/ftp.ke [...] e5-ac3.bz2
voila :)
ça compile :)
Message édité par ethernal le 17-04-2003 à 05:05:26
n°250600
hornetmen
Posté le 17-04-2003 à 10:02:44  profilanswer
je suis en train de tester la Mdk 9.1 en ce moment meme...
Tout est integré il me semble à premiere vue  :D
Mais si ca marche, je planche sur la RH9  :)
n°250773
BeAsh
because penguins rulez !
Posté le 17-04-2003 à 14:55:39  profilanswer
Hey you owe credits for this how-to !!!
n°250781
kyo54
Posté le 17-04-2003 à 15:05:59  profilanswer
ouais enfin si c'est en beta ça marchera quand même bien? Quand doit sortir le noyau 2.4.21?
n°250784
ethernal
Posté le 17-04-2003 à 15:08:39  profilanswer
heu... c'est à toi que je dois les 3/4 ;)
je l'ai mis en dessous (t'as pas lu ?)
Message édité par ethernal le 17-04-2003 à 15:13:21
n°250786
ethernal
Posté le 17-04-2003 à 15:11:42  profilanswer
je sais pas...
j'ai déjà eu des prob de "input/output Error" lors de l'install (plus moyen d'écrire sur les hds).
Partition magic a déjà détecté des erreurs et j'ai perdu quelques fichiers dans l'histoire.
A mon avis c'est pas encore tout à fait au point.
n°250797
kyo54
Posté le 17-04-2003 à 15:36:56  profilanswer
ethernal a écrit :
je sais pas...
mouais mais tes durs sont en raid non? En solo ça devrait poser moins de probs
n°250800
ethernal
Posté le 17-04-2003 à 15:42:28  profilanswer
oui c'est clair.
Le support pour le sata est considéré comme stable.
il suffit de patcher le 2.4.20 avec le 2.4.20-ac1 ou ac2 (patch d'Alan Cox).
Par contre le support du Raid est encore expérimental...
n°250824
BeAsh
Posté le 17-04-2003 à 16:10:21  profilanswer
hehehe sorry... j'ai lu en diagonal ;)
sinon fo vous tenir au courant amigos !!!
le pre7-ac1 est là (et ca compile nickel):
http://www.kernel.org/pub/linux/ke [...] e7-ac1.bz2
n°250845
kyo54
Posté le 17-04-2003 à 16:41:57  profilanswer
oui j'ai vu, mais je préférerais le vrai 2.4.21 qu'une pre-release...
n°250884
hornetmen
Posté le 17-04-2003 à 18:41:28  profilanswer
mdk9.1  ;)
2.4.21-???
n°250892
kyo54
Posté le 17-04-2003 à 19:09:32  profilanswer
hornetmen a écrit :
mdk9.1  ;)
2.4.21-???
tsss c'est pas le vrai 2.4.21 :pfff:
 Page :   1  2
Page Précédente
  Installation
installation de wine : je ne m'en sors pas !Installation mandrake
Installation de Linux et CentrinoProbleme avec l'installation d'un fichier bin
Installation de bind 9.2.2 a partir des sources sous RedHat 7.1[Pb] Installation new HDD sous slackware 8.0
Installation Linux sur petit portable : le défi de la mort :-)Régler l'affichage à l'installation de Mandrake 9.0 sur un portable
[wineX-MDK9.1] Installation de warcraft III ?Installation d'un fichier tar.gz ?
Plus de sujets relatifs à : [SATA-RAID] Installation sur P4G8X Deluxe (controlleur Sil3112A)
