4543 connectés
 Page :   1  2
Page Suivante
Impossible d'installer une imprimante correctement
n°283093
clockover
That's the life
Posté le 25-06-2003 à 23:21:09  profilanswer
Voila l'état des choses.
J'ai installé une debian woody 3.0r1.
Puis un coup de:
apt-get install cupsys cupsys-client cupsys-driver-gimpprint
Je configure le tout avec lynx http://localhost:631
Tout fonctionne (pas de test, commande lp)
Ensuite:
apt-get install samba
Je lui configure son smb.conf (vite fe histoire d imprimer et de tester)
http://clockover.free.fr/hfr/smb.jpg
Mais rien dans le dossier imprimantes  :sweat:
n°283373
clockover
That's the life
Posté le 26-06-2003 à 13:36:35  profilanswer
n°283566
clockover
That's the life
Posté le 26-06-2003 à 16:34:33  profilanswer
:cry:
n°283799
clockover
That's the life
Posté le 26-06-2003 à 22:43:28  profilanswer
:sweat:
n°283853
the_fireba​ll
We Are What We Shit
Posté le 27-06-2003 à 00:04:58  profilanswer
Dans mon smb.conf qui fonctionne j'ai
# If you want to automatically load your printer list rather
# than setting them up individually then you'll need this
   load printers = yes
# you may wish to override the location of the printcap file
   printcap name = cups
# on SystemV system setting printcap name to lpstat should allow
# you to automatically obtain a printer list from the SystemV spool
# system
;   printcap name = lpstat
# It should not be necessary to specify the print system type unless
# it is non-standard. Currently supported print systems include:
# bsd, sysv, plp, lprng, aix, hpux, qnx
   printing = cups
[printers]
   comment = All printers
   path = /var/spool/samba
   browseable = no
# Set public = yes to allow user 'guest account' to print
   guest ok = no
   writable = no
   printable = yes
   use client driver = Yes
et avec ça mon poste sour 2k peut imprimer avec mon user
Two thousand years of misery, of torture in my name, hypocrisy made paramount, paranoia the law, my name is called religion, sadistic, sacred whore.
n°283855
clockover
That's the life
Posté le 27-06-2003 à 00:16:23  profilanswer
thrs aps d imprimante visible sur mon partage :/
n°283949
clockover
That's the life
Posté le 27-06-2003 à 12:21:31  profilanswer
personen n a une idée ?
n°284089
clockover
That's the life
Posté le 27-06-2003 à 18:38:48  profilanswer
je pense que si kan meme ;)
n°284492
clockover
That's the life
Posté le 29-06-2003 à 05:02:36  profilanswer
c bizare kom pb en tt cas
n°284517
the_fireba​ll
We Are What We Shit
Posté le 29-06-2003 à 11:23:47  profilanswer
Faudrait tout récapituler car la je t'ai filé ma conf qui marche et du coup je ne vois pas ce qui cloche.
Rien dans les logs de samba ou de cups ?
n°284535
clockover
That's the life
Posté le 29-06-2003 à 12:23:45  profilanswer
bon alors j'ai fe comme toi (meme paquetage et meme smb.conf)
En local ca marche impek. Mais sur le dossier de partage je ne vois pas d imprimantes (donc cela depuis le client windows)
n°284992
clockover
That's the life
Posté le 29-06-2003 à 21:00:48  profilanswer
Bon je vois mon imprimante maintenant. Et je peux imprimer par IPP sous Win XP. Mais avec samba:
"La page de test n'a pas pu être imprimée. Voulez-vous afficher les conseils pour la résolutions des problèmes d'impression ? Impossible de créer une tâche d'impression."
Une idée ? :??:
n°285884
clockover
That's the life
Posté le 30-06-2003 à 20:51:29  profilanswer
mise ajour de samba et ca passe  :)
 Page :   1  2
Page Suivante
impossible de me connecter à mon serveur X[IDEAJ 3.0.4] impossible d'installer IDEAJ 3.0.4 ...
Peut on installer des logociels linux en fonctionnant sous Knoppix??[Tomcat] Comment installer une webapp?
Imprimante reseaux et partageimpossible de démarrer sur le nouveau noyau nouvellement compilé
Imprimante réseauMontage d'une imprimante avec Samba (urgent)
Imprimante compatible ?
Plus de sujets relatifs à : Impossible d'installer une imprimante correctement
