7837 connectés
  Linux et OS Alternatifs
  Installation
  Flash et Nspluginwrapper sur Debian
n°914492
esox_ch
Posté le 21-05-2007 à 09:36:26  profilanswer
J'ai installé NSPluginwrapper sur ma sid pour pouvoir utiliser flash dans FF bien que je sois en AMD64.
Le problème est le suivant :
Code :
  1. $ nspluginwrapper -v -a -u
  2. Auto-update plugins from /usr/lib/mozilla/plugins
  3. Looking for plugins in /usr/lib/mozilla/plugins
  4. Auto-update plugins from /usr/lib64/mozilla/plugins
  5. Looking for plugins in /usr/lib64/mozilla/plugins
  6. Auto-update plugins from /usr/lib/firefox/plugins
  7. Looking for plugins in /usr/lib/firefox/plugins
  8. Auto-update plugins from /usr/lib64/firefox/plugins
  9. Looking for plugins in /usr/lib64/firefox/plugins
  10. Auto-update plugins from /home/esox/.mozilla/plugins
  11. Looking for plugins in /home/esox/.mozilla/plugins
  12. esox@CColomb:~/install_flash_player_9_linux$ sudo nspluginwrapper -i ./libflashplayer.so
  13. esox@CColomb:~/install_flash_player_9_linux$ nspluginwrapper -v -a -u
  14. Auto-update plugins from /usr/lib/mozilla/plugins
  15. Looking for plugins in /usr/lib/mozilla/plugins
  16. Update plugin /usr/lib/mozilla/plugins/npwrapper.libflashplayer.so
  17.   NS4 plugin ./libflashplayer.so is already installed system-wide, removing wrapper
  18. Remove plugin /usr/lib/mozilla/plugins/npwrapper.libflashplayer.so
  19. Auto-update plugins from /usr/lib64/mozilla/plugins
  20. Looking for plugins in /usr/lib64/mozilla/plugins
  21. Update plugin /usr/lib64/mozilla/plugins/npwrapper.libflashplayer.so
  22.   NS4 plugin ./libflashplayer.so is already installed system-wide, removing wrapper
  23. Remove plugin /usr/lib64/mozilla/plugins/npwrapper.libflashplayer.so
  24. Auto-update plugins from /usr/lib/firefox/plugins
  25. Looking for plugins in /usr/lib/firefox/plugins
  26. Update plugin /usr/lib/firefox/plugins/npwrapper.libflashplayer.so
  27.   NS4 plugin ./libflashplayer.so is already installed system-wide, removing wrapper
  28. Remove plugin /usr/lib/firefox/plugins/npwrapper.libflashplayer.so
  29. Auto-update plugins from /usr/lib64/firefox/plugins
  30. Looking for plugins in /usr/lib64/firefox/plugins
  31. Update plugin /usr/lib64/firefox/plugins/npwrapper.libflashplayer.so
  32.   NS4 plugin ./libflashplayer.so is already installed system-wide, removing wrapper
  33. Remove plugin /usr/lib64/firefox/plugins/npwrapper.libflashplayer.so
  34. Auto-update plugins from /home/esox/.mozilla/plugins
  35. Looking for plugins in /home/esox/.mozilla/plugins
Et bien entendu le plugin ne s'active pas dans FF.
Vous avez une idée?
P.S: Je précise que un locate libflashplayer ne m'a donné aucun résultat autre que les wrappers de nsplugin
Si la vérité est découverte par quelqu'un d'autre,elle perd toujours un peu d'attrait
n°914499
Posté le 21-05-2007 à 09:58:47  answer
T'as tenté de faire un lien symbolique qui atterrit dans ton home ? (genre /home/<user>/.mozilla/firefox/plugins/)
Message édité par Profil supprimé le 21-05-2007 à 10:00:57
n°914515
esox_ch
Posté le 21-05-2007 à 11:18:01  profilanswer
$ ln -sfn /usr/lib64/firefox/plugins/npwrapper.libflashplayer.so ~/.mozilla/iceweasel/plugins/
Aucun changement (à remarquer le fait que j'ai du créer le répertoire plugins)
  Installation
[debian/dedibox] Qmail / Problème de réception d'email externeNO-ip ! DNS dynamique avec une debian "server"
SCSI et Debian etch, je vois pas mon disque...Debian : perte espace partition fat32
debian maj du kernel grub fait n'importe quoi !Pb avec installation de IPP2P sur Linux Debian
[Debian] Compiler en binaire statique + changer l'archi[ Stakanov ] Système linux sur mémoire Flash
pblm install Debian Etch sur proliant ML150Nouveau Slug ( NSLU2 ) sous Debian, thread a conseils :)
Plus de sujets relatifs à : Flash et Nspluginwrapper sur Debian
