3084 connectés
  Linux et OS Alternatifs
  Installation
  [debian] Apt-get qui merde sur des packages comme console-common...
n°317199
Tetedeienc​h
Head Of God
Posté le 31-08-2003 à 18:01:11  profilanswer
Et ca me fait suer :(
j'ai faoit juste un apt-get update suivi d'un apt-get upgrade, et monsieur bloque tjs sur les packages :
- console-common
- console-data
- base-config
- ocaml
Voila les erreurs :
Setting up console-common (0.7.25) ...
Looking for keymap to install:
us
dpkg: error processing console-common (--configure):
 subprocess post-installation script returned error exit status 2
Setting up console-data (2002.12.04dbs-15) ...
us
dpkg: error processing console-data (--configure):
dpkg: dependency problems prevent configuration of base-config:
 base-config depends on console-data (>= 1999.08.29-13); however:
  Package console-data is not configured yet.
dpkg: error processing base-config (--configure):
 dependency problems - leaving unconfigured
Setting up ocaml (3.06-21) ...
install/ocaml: Handling install for emacsen flavor emacs20
Wrote /usr/share/emacs20/site-lisp/ocaml/caml-compat.elc
Wrote /usr/share/emacs20/site-lisp/ocaml/caml-font.elc
Wrote /usr/share/emacs20/site-lisp/ocaml/caml-help.elc
Wrote /usr/share/emacs20/site-lisp/ocaml/caml-hilit.elc
Wrote /usr/share/emacs20/site-lisp/ocaml/caml.elc
Wrote /usr/share/emacs20/site-lisp/ocaml/camldebug.elc
Wrote /usr/share/emacs20/site-lisp/ocaml/inf-caml.elc
Done
install/ocaml: Handling install for emacsen flavor xemacs21
Compiling /usr/share/xemacs21/site-lisp/ocaml/caml-compat.el...
Wrote /usr/share/xemacs21/site-lisp/ocaml/caml-compat.elc
Compiling /usr/share/xemacs21/site-lisp/ocaml/caml-font.el...
Wrote /usr/share/xemacs21/site-lisp/ocaml/caml-font.elc
Compiling /usr/share/xemacs21/site-lisp/ocaml/caml-help.el...
Wrote /usr/share/xemacs21/site-lisp/ocaml/caml-help.elc
Compiling /usr/share/xemacs21/site-lisp/ocaml/caml-hilit.el...
Wrote /usr/share/xemacs21/site-lisp/ocaml/caml-hilit.elc
Compiling /usr/share/xemacs21/site-lisp/ocaml/caml.el...
While compiling toplevel forms in file /usr/share/xemacs21/site-lisp/ocaml/caml.el:
  !! File error (("Cannot open load file" "compile" ))
>>Error occurred processing caml.el: Cannot open load file: compile
Compiling /usr/share/xemacs21/site-lisp/ocaml/camldebug.el...
While compiling toplevel forms in file /usr/share/xemacs21/site-lisp/ocaml/camldebug.el:
  !! File error (("Cannot open load file" "comint" ))
>>Error occurred processing camldebug.el: Cannot open load file: comint
Compiling /usr/share/xemacs21/site-lisp/ocaml/inf-caml.el...
While compiling toplevel forms in file /usr/share/xemacs21/site-lisp/ocaml/inf-caml.el:
>>Error occurred processing inf-caml.el: Cannot open load file: comint
Done
emacs-package-install: /usr/lib/emacsen-common/packages/install/ocaml xemacs21 emacs20 xemacs21 failed at /usr/lib/emacsen-common/emacs-package-install line 30, <TSORT> line 1.
dpkg: error processing ocaml (--configure):
 subprocess post-installation script returned error exit status 29
Errors were encountered while processing:
 console-common
 console-data
 base-config
 ocaml
E: Sub-process /usr/bin/dpkg returned an error code (1)
Vous avez une idée sur ce que je peux faire ?
Et aussi, si je pouvais remettre mon clavier en francais car je suis revenu récemment a un azerty, ca m'arrangerai :D
L'ingénieur chipset nortiaux : Une iFricandelle svp ! "Spa du pâté, hin!" ©®Janfynette | "La plus grosse collec vivante de bans abusifs sur pattes" | OCCT v16 OUT !
n°317209
Niala
Posté le 31-08-2003 à 18:05:25  profilanswer
hmm essai dpkg-reconfigure locales.
n°317224
Tetedeienc​h
Head Of God
Posté le 31-08-2003 à 18:10:11  profilanswer
OK merci, mais ca a pas réglé mon probleme si dessus :(
n°317420
kagou
Posté le 31-08-2003 à 19:11:49  profilanswer
Tu as essayé un "apt-get -f install" ?
Forum d'entre-aide pour la Debian : http://www.andesi.org/forum
n°317430
Tetedeienc​h
Head Of God
Posté le 31-08-2003 à 19:21:20  profilanswer
nan, mais ca a rien changé :(
n°317433
blackm
Posté le 31-08-2003 à 19:23:05  profilanswer
J'ai 2 sid et j'ai eu la même chose sur une des deux (:??:), bref j'ai fait des mises à jour les paquets qui suivent la ligne "Les paquets suivants ont été conservés" et c'est passé tout seul après.
n°317434
Tetedeienc​h
Head Of God
Posté le 31-08-2003 à 19:24:09  profilanswer
on fait comment ca ?
n°317435
Tetedeienc​h
Head Of God
Posté le 31-08-2003 à 19:25:39  profilanswer
OK, un bete apt-get upgrade + copier/coller ca passe :D
n°317436
blackm
Posté le 31-08-2003 à 19:27:59  profilanswer
ah :??:
moi je fais apt-get install en tout cas :D
et je les fais petit à petit histoire de bien voir ce qu'il se passe ;)
n°317438
Tetedeienc​h
Head Of God
Posté le 31-08-2003 à 19:32:07  profilanswer
oui, ca, je vais faire :D
Enfin connex adsl qui merde = dl a 12Ko/s :(
n°317464
Tetedeienc​h
Head Of God
Posté le 31-08-2003 à 20:19:17  profilanswer
Tjs pareil, tjs bloqué au meme point :cry:
n°317468
Tetedeienc​h
Head Of God
Posté le 31-08-2003 à 20:26:36  profilanswer
bon je tente en testing ( barbare powsa)
n°317470
void_ppc
Posté le 31-08-2003 à 20:28:48  profilanswer
Essaye de voir la différence entre une sauvegarde de la listes des pakages installés (/var/backups/dpkg.status.* et la liste de maintenant (/var/lib/dpkg/status)
Prends une vielle sauvegarde, histoire de capter les différences entre les 2 fichiers
fait une copie des fichiers cités ci-dessus dans /tmp par ex, ensuite tape :
diff dpkg.status.* status
n°317479
Tetedeienc​h
Head Of God
Posté le 31-08-2003 à 20:36:07  profilanswer
Euh j'ai essayé et tout est différent :D :??:
n°317480
Tetedeienc​h
Head Of God
Posté le 31-08-2003 à 20:37:50  profilanswer
Et surtout, j'ai jamais rien qui concerne console-common...
comprends pas :??:
n°317489
void_ppc
Posté le 31-08-2003 à 21:03:03  profilanswer
dpkg-configure console-data ?
n°317500
Tetedeienc​h
Head Of God
Posté le 31-08-2003 à 21:26:49  profilanswer
debian:/home/tetedeiench# dpkg --configure console-data
Paramétrage de console-data (2002.12.04dbs-16) ...
us
dpkg : erreur de traitement de console-data (--configure) :
 le sous-processus post-installation script a retourné une erreur de sortie d'état 2
Des erreurs ont été rencontrées pendant l'exécution :
 console-data
n°317501
Tetedeienc​h
Head Of God
Posté le 31-08-2003 à 21:27:20  profilanswer
d'ailleurs tiens il cause en francais lui maintenant...
Comment cela se fasse ?
n°317503
blackm
Posté le 31-08-2003 à 21:32:20  profilanswer
ca fait un moment qu'il parle français :o
bon sinon, un pti coup de remove --purge et d'install derrière ? :D
n°317504
void_ppc
Posté le 31-08-2003 à 21:34:51  profilanswer
dpkg --configure -a ?
n°317509
Tetedeienc​h
Head Of God
Posté le 31-08-2003 à 21:43:58  profilanswer
Je préfère en anglais : on change ca ou ? :(
pour dpkg --configure -a : memes erreurs.
je tente le purge la
n°317510
Tetedeienc​h
Head Of God
Posté le 31-08-2003 à 21:45:42  profilanswer
apt-get remove --piurge a strictement rien fait :(
Message édité par Tetedeiench le 31-08-2003 à 21:45:52
n°317532
Zzozo
Un peu, passionément, à la fol
Posté le 31-08-2003 à 22:46:33  profilanswer
T'es bon pour la Gentoo moi je dis, là ... :D
n°317546
Tetedeienc​h
Head Of God
Posté le 31-08-2003 à 23:08:56  profilanswer
Déconne po :D
n°317571
Siam
Posté le 31-08-2003 à 23:50:57  profilanswer
Y a quand meme des problemes avec les paquets instables ces temps-ci...........;
J'ai essayé 3 fois de réinstaller la debian en 10 jours...
Et je confirme qu'il y a des problèmes avec console-data...Le seul truc qui m'a permis de m'en tirer et de ne pas configurer (sais plus quelle option c exactement).
Autre problème : installation de X-Window....T'as essayé un petit apt-get install x-window-system-core (peut-etre qu'en "update" ca passe, mais sur une nouvelle install ca plante lamentablement), tetedeiench ?
Ca m'a trop fait suer ces conneries....Du coup téléchargement mandrake, recompilation noyau, virer les services inutiles à la con, réinstallation des périphs (webcam logitech), samba, apache, et ca roule....
Mais bon ... J'aimerais retrouver mon petit Debian Unstable un jour.
Message édité par Siam le 31-08-2003 à 23:53:21
n°317578
blackm
Posté le 01-09-2003 à 00:00:55  profilanswer
boarf, spa mieux :o
ca fait une semaine que je trifouille les ebuild pour avoir les bonnes sources, ca m'a surpris d'ailleurs, quand j'avais testé la RC chéplukoi ca allait bcp mieux
enfin bon bref, pas d'bol le iench pourtant j'ai eu les mêmes pbs  :??:
n°318552
Tetedeienc​h
Head Of God
Posté le 02-09-2003 à 18:40:45  profilanswer
Bon ben tjs pas reussi a régler l'sooci :(
Je vais faire une install clean du coup.
n°318691
Mismatch
Posté le 02-09-2003 à 22:45:57  profilanswer
profite en pour te faire un sources.list bien complet (avec les sources sid/sarge/woody) et un apt.conf et un /etc/apt/preferences.
Ça t'évitera peut-être des ennuis si tu continues à jouer avec la sid.
Genre ici :
"apt-get -t testing install console-common" aurais peut-être pu te sauver la mise (note que tu peux essayer si t'as pas déjà tout réinstallé).
Message édité par Mismatch le 02-09-2003 à 22:47:38
n°321663
Tetedeienc​h
Head Of God
Posté le 08-09-2003 à 22:56:21  profilanswer
Genre ici :
j'ai pas encore tout réinstallé mais je vais devoir ( changement de DD + ca va m'éviter de retransférer mon merdier dans mon /home :D )
Enfin, merci :jap:
  Installation
[debian] comment on fait pour se plaindre des mainteneurs[Debian] Demander à ce qu'un paquet rentre ?
ya vraiment des pb de dépendances avec une debian SID ??Debian, apple meme combat?
Debian Sid : XFree86 4.2.1-10 refuse de s'installer ...Pb avec dpkg sous debian woody [résolu]
Debian ?Debian Pb Install X-Window-System
Debian : CD -> DVD[Debian] besoin de testeur pour une applet kde
Plus de sujets relatifs à : [debian] Apt-get qui merde sur des packages comme console-common...
