7528 connectés
  Linux et OS Alternatifs
  Installation
  [debian]Pas de son avec alsa
n°765161
174flo
Posté le 23-12-2005 à 17:27:05  profilanswer
Pendant un moment j'avais du son avec alsa, et la, plus rien. :(
Par contre, j'arive a en avoir avec oss... :sweat:
resultat de lsmod:
Module                  Size  Used by
nls_iso8859_1           4032  1
isofs                  38264  1
udf                    94596  0
ipt_tcpmss              2240  1
nvidia               3711236  12
lp                     12036  0
pppoe                  14336  2
pppox                   3464  1 pppoe
ipt_TCPMSS              4352  2
ipt_MASQUERADE          3392  1
ipt_state               1856  1
iptable_nat             8004  1
ip_nat                 19700  2 ipt_MASQUERADE,iptable_nat
ip_conntrack           55280  4 ipt_MASQUERADE,ipt_state,iptable_nat,ip_nat
nfnetlink               6616  2 ip_nat,ip_conntrack
iptable_filter          2880  1
ip_tables              20224  6 ipt_tcpmss,ipt_TCPMSS,ipt_MASQUERADE,ipt_state,iptable_nat,iptable_filter
ipv6                  267136  8
ppp_generic            30100  6 pppoe,pppox
slhc                    7616  1 ppp_generic
ide_generic             1216  0 [permanent]
tda9887                14032  0
tuner                  39912  0
3c59x                  41768  0
joydev                  9920  0
mii                     5696  1 3c59x
saa7134               117460  0
snd_mpu401              6600  1
snd_intel8x0           34912  0
video_buf              22148  1 saa7134
v4l2_common             5824  1 saa7134
v4l1_compat            14916  1 saa7134
ir_common               9092  1 saa7134
snd_ac97_codec         97404  1 snd_intel8x0
snd_ac97_bus            2240  1 snd_ac97_codec
videodev                9344  1 saa7134
snd_pcm_oss            54944  0
snd_mixer_oss          19840  1 snd_pcm_oss
snd_pcm                92360  3 snd_intel8x0,snd_ac97_codec,snd_pcm_oss
snd_mpu401_uart         7424  1 snd_mpu401
snd_rawmidi            25504  1 snd_mpu401_uart
snd_seq_device          8844  1 snd_rawmidi
snd_timer              24836  1 snd_pcm
snd_page_alloc         11016  2 snd_intel8x0,snd_pcm
nvidia_agp              8092  1
snd                    55972  12 snd_mpu401,snd_intel8x0,snd_ac97_codec,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_mpu401_uart,snd_rawmidi,snd_seq_device,snd_timer
forcedeth              22656  0
i2c_nforce2             6976  0
ide_cd                 43780  1
cdrom                  40800  1 ide_cd
nvsound              1542712  0
usblp                  13440  0
floppy                 63620  0
pcspkr                  3488  0
psmouse                39492  0
serio_raw               7300  0
agpgart                35656  2 nvidia,nvidia_agp
parport_pc             36932  1
parport                37192  2 lp,parport_pc
i2c_core               22224  4 tda9887,tuner,saa7134,i2c_nforce2
soundcore               9824  3 saa7134,snd,nvsound
shpchp                 98852  0
pci_hotplug            28532  1 shpchp
rtc                    12664  0
reiserfs              279280  1
ide_disk               18944  3
amd74xx                14556  0 [permanent]
generic                 4484  0 [permanent]
ide_core              129888  5 ide_generic,ide_cd,ide_disk,amd74xx,generic
sata_nv                 9476  0
libata                 51464  1 sata_nv
scsi_mod              141800  1 libata
evdev                   9664  0
mousedev               11680  1
usbhid                 39392  0
yealink                13248  0
ehci_hcd               35464  0
ohci_hcd               21572  0
usbcore               127296  6 usblp,usbhid,yealink,ehci_hcd,ohci_hcd
J'ai essayer plusieurs fois de reinstaller alsa, mais il n'y a rien a faire, pire, j'ai eu plusieurs kernel panics... Quelqu'un a une idée?
n°765184
SuperDindo​n
pseudonyme obsolète
Posté le 23-12-2005 à 18:13:59  profilanswer
Vérifies tes niveaux de volume avec alsamixer ( et qu'ils sont pas muets )
n°765189
174flo
Posté le 23-12-2005 à 18:17:52  profilanswer
florian@hal9000:~$ alsamixer
alsamixer: function snd_ctl_open failed for default: No such device
C'est le truc que je ne comprend pas, la carte marche avec  oss, masi alsa n'a pas l'ai de voir le driver :sweat:
Je crois que je vais regler le probleme a la bourrin (reinstalle  :cry: )
n°765194
goldyfruit
Je me lève et je confirme !
Posté le 23-12-2005 à 18:44:20  profilanswer
Essaye avec :
Code :
  1. # alsaconf
Message édité par goldyfruit le 23-12-2005 à 18:44:36
https://openvoiceos.org | https://github.com/orgs/smartgic/
n°765195
dht
Posté le 23-12-2005 à 18:45:17  profilanswer
ben non.
essaie un dpkg-reconfigure tonimage
ça doit être udev.
Message édité par dht le 23-12-2005 à 18:45:59
n°765216
174flo
Posté le 23-12-2005 à 19:54:47  profilanswer
Trop tard :/
C'est aller vite, puisque j'avais deja des fichiers de configuration fonctionellent (pas de docs a relire, etc...)
Bon, si j'ai de nouveau le probleme, je reeseillerai, merci pour votre aide :)  :hello:
n°765217
goldyfruit
Posté le 23-12-2005 à 19:55:12  profilanswer
n°765221
174flo
Posté le 23-12-2005 à 20:01:14  profilanswer
Desoler  :sweat:  :ange: Mauvaise habitude de mon passer de windowsien  :whistle:
n°765286
Posté le 23-12-2005 à 21:14:32  answer
J'ai aussi un problème à chaque démarrage :o donc c'est alsaconf + alsactl store à chaque boot... Sympathique...
n°765321
willou94
Posté le 23-12-2005 à 22:50:12  profilanswer
J'ai le meme probleme sous slackware lorsque je met alsa à jour sans mettre à jour le kernel. Il faut mettre à jour les deux en meme temps.
Et une fois que c'est fait lancer alsaconf si on a toujours pas de son, ca detecte la carte et regle le son.
n°765373
174flo
Posté le 24-12-2005 à 02:03:33  profilanswer
A ok, il faut attendre que la mise a jour sois dispo, c'est ca? Je pensait qu'il n'y avait se genre de probleme qu'avec sid :o
n°765375
willou94
Posté le 24-12-2005 à 02:10:41  profilanswer
Je ne sais pas comment ca se passe avec la sid puisque je suis sous slackware, mais je me suis dit que ca pouvait etre le meme probleme. Le truc c'est que le gestionnaire de paquet ne met pas à jour le kernel par defaut. C'est la meme chose à avec apt-get non ?
n°765383
goldyfruit
Posté le 24-12-2005 à 02:50:44  profilanswer
Chui en Sid et j' ai pas ce problème ...
n°765397
174flo
Posté le 24-12-2005 à 09:29:56  profilanswer
Bah, je suis en etch, et... [:kaleos]  :heink:
Je pense que je vais passer en sid alors  :whistle: (ou alors c'est moi le probleme)
n°765476
Posté le 24-12-2005 à 15:48:27  answer
J'ai ce problème en Sarge... Mais seulement depuis l'installation d'une carte Tuner TV...
n°765477
174flo
Posté le 24-12-2005 à 16:05:35  profilanswer
Par hasard, c'est une carte à base de saa7130, comme la asus TV FM card?
n°765479
Posté le 24-12-2005 à 16:30:09  answer
Hardware Class: tv card
  Model: "LeadTek Leadtek WinFast TV 2000"
  Vendor: pci 0x109e "Brooktree Corporation"
  Device: pci 0x036e "Bt878"
  SubVendor: pci 0x107d "LeadTek Research Inc."
  SubDevice: pci 0x6606 "Leadtek WinFast TV 2000"
  Revision: 0x11
  Memory Range: 0xdfdfe000-0xdfdfefff (rw,prefetchable)
  IRQ: 169 (no events)
  Driver Info #0:
    Driver Status: bttv is not active
    Driver Activation Cmd: "modprobe bttv"
  Config Status: cfg=new, avail=yes, need=no, active=unknown
 [:spamafote]  désolé
n°765608
174flo
Posté le 25-12-2005 à 14:56:42  profilanswer
Regler apres mise à jour :o Ca devait venir de debconf
  Installation
ALSA : problème de modules sous DebianLe son 5.1 Alsa sous Debian
[Debian] Installation ALSA[Debian] Problèùme pour enregistrer le micro (ALSA)
[DEBIAN] Probleme Son Alsa-NvidiaALSA, hotplug sur Debian
Debian Install ALSA (OSS marche)[debian] alsa + kernel 2.9.X
Debian + alsa & aumixdebian 2.4.27 alsa : problemes à l'installation
Plus de sujets relatifs à : [debian]Pas de son avec alsa
