4254 connectés
  Linux et OS Alternatifs
  Installation
  Compilation de GCC 3.3.1
n°471148
burgergold
5$? va chez l'diable!
Posté le 05-05-2004 à 11:54:53  profilanswer
dans le cadre d'une LFS 5.0, j'ai compilé GCC 3.3.1
je trouve pourtant qu'il y a eu pas mal de fail dans le make -k check
LAST_UPDATED:
Native configuration is i686-pc-linux-gnu
                === g++ tests ===
Running target unix
FAIL: g++.dg/tls/init-2.C (test for excess errors)
XPASS: g++.other/init5.C  Execution test
                === g++ Summary ===
# of expected passes            8109
# of unexpected failures        1
# of unexpected successes       1
# of expected failures          94
# of untested testcases         9
# of unsupported tests          14
/mnt/lfs/sources/gcc-build/gcc/testsuite/../g++ version 3.3.1
                === gcc tests ===
Running target unix
FAIL: gcc.dg/duff-2.c (test for excess errors)
FAIL: gcc.dg/uninit-C.c (test for excess errors)
                === gcc Summary ===
# of expected passes            21579
# of unexpected failures        2
# of expected failures          69
# of unsupported tests          85
/mnt/lfs/sources/gcc-build/gcc/xgcc version 3.3.1
                === libstdc++-v3 check-abi Summary ===
# of added symbols:              0
# of missing symbols:            0
# of incompatible symbols:       0
                === libstdc++-v3 tests ===
Running target unix
XPASS: 22_locale/collate_byname.cc execution test
XPASS: 22_locale/collate_members_char.cc execution test
XPASS: 22_locale/collate_members_wchar_t.cc execution test
XPASS: 22_locale/ctype_is_char.cc execution test
XPASS: 22_locale/ctype_is_wchar_t.cc execution test
XPASS: 22_locale/members.cc execution test
XPASS: 22_locale/messages_byname.cc execution test
XPASS: 22_locale/messages_members_char.cc execution test
XPASS: 22_locale/money_get_members_char.cc execution test
XPASS: 22_locale/money_get_members_wchar_t.cc execution test
XPASS: 22_locale/money_put_members_char.cc execution test
XPASS: 22_locale/money_put_members_wchar_t.cc execution test
XPASS: 22_locale/moneypunct_byname.cc execution test
XPASS: 22_locale/moneypunct_members_char.cc execution test
XPASS: 22_locale/moneypunct_members_wchar_t.cc execution test
XPASS: 22_locale/num_get_members_char.cc execution test
XPASS: 22_locale/num_get_members_wchar_t.cc execution test
XPASS: 22_locale/num_put_members_char.cc execution test
XPASS: 22_locale/num_put_members_wchar_t.cc execution test
XPASS: 22_locale/numpunct_byname.cc execution test
XPASS: 22_locale/numpunct_members_char.cc execution test
XPASS: 22_locale/numpunct_members_wchar_t.cc execution test
XPASS: 22_locale/time_get_members_char.cc execution test
XPASS: 22_locale/time_get_members_wchar_t.cc execution test
XPASS: 22_locale/time_put_members_char.cc execution test
XPASS: 22_locale/time_put_members_wchar_t.cc execution test
                === libstdc++-v3 Summary ===
# of expected passes            453
# of unexpected successes       26
# of expected failures          2
Compiler version: 3.3.1
Platform: i686-pc-linux-gnu
configure flags: --host=i686-pc-linux-gnu --prefix=/tools --with-local-prefix=/tools --enable-clocale=gn
u --enable-shared --enable-threads=posix --enable-__cxa_atexit --enable-languages=c,c++
EOF
Mail -s "Results for 3.3.1 testsuite on i686-pc-linux-gnu" gcc-testresults@gcc.gnu.org &&
mv /mnt/lfs/sources/gcc-build/./gcc/testsuite/g++.sum /mnt/lfs/sources/gcc-build/./gcc/testsuite/g++.sum
.sent &&
mv /mnt/lfs/sources/gcc-build/./gcc/testsuite/gcc.sum /mnt/lfs/sources/gcc-build/./gcc/testsuite/gcc.sum
.sent &&
mv /mnt/lfs/sources/gcc-build/./i686-pc-linux-gnu/libstdc++-v3/testsuite/libstdc++-v3-abi.sum /mnt/lfs/s
ources/gcc-build/./i686-pc-linux-gnu/libstdc++-v3/testsuite/libstdc++-v3-abi.sum.sent &&
mv /mnt/lfs/sources/gcc-build/./i686-pc-linux-gnu/libstdc++-v3/testsuite/libstdc++-v3.sum /mnt/lfs/sourc
es/gcc-build/./i686-pc-linux-gnu/libstdc++-v3/testsuite/libstdc++-v3.sum.sent &&
mv /mnt/lfs/sources/gcc-build/./gcc/testsuite/g++.log /mnt/lfs/sources/gcc-build/./gcc/testsuite/g++.log
.sent &&
mv /mnt/lfs/sources/gcc-build/./gcc/testsuite/gcc.log /mnt/lfs/sources/gcc-build/./gcc/testsuite/gcc.log
.sent &&
mv /mnt/lfs/sources/gcc-build/./i686-pc-linux-gnu/libstdc++-v3/testsuite/libstdc++-v3.log /mnt/lfs/sourc
es/gcc-build/./i686-pc-linux-gnu/libstdc++-v3/testsuite/libstdc++-v3.log.sent &&
true
http://www.boincstats.com/signature/user_664861.gif
n°472004
burgergold
Posté le 05-05-2004 à 23:34:36  profilanswer
  Installation
probleme apres la compilation de php 4.3.6 , pas de libphp4.soCompilation Kernel 2.6.5 --> depmod
Prob compilation noyau 2.6.5emacs, latex et compilation background
compilation : probleme de librairieInstallation NAGIOS: erreur de compilation
prob compilation k3b 0.11.9Prob de compilation de driver
Compilation Noyau sur Portableproblème de compilation GCC
Plus de sujets relatifs à : Compilation de GCC 3.3.1
