3474 connectés
  Linux et OS Alternatifs
  Problème d'OpenGL avec ma Ubuntu 6.10...
n°889140
xx_shade_x​x
Posté le 22-02-2007 à 22:28:25  profilanswer
Bonsoir a tous les utilisateurs d'ordinateur  :hello: .
Voila mon problème: mon ordi freeze lorsque je lance une application utilisant l'OGL.
Voila mes confs:
uname -a
Code :
  1. Linux ******** 2.6.17-11-386 #2 Thu Feb 1 19:50:13 UTC 2007 i686 GNU/Linux
X -version
Code :
  1. X Protocol Version 11, Revision 0, Release 7.1.1
  2. Build Operating System: Linux 2.6.15.7 i686
  3. Current Operating System: Linux Darkness 2.6.17-11-386 #2 Thu Feb 1 19:50:13 UTC 2007 i686
  4. Build Date: 07 July 2006
  5.         Before reporting problems, check http://wiki.x.org
  6.         to make sure that you have the latest version.
  7. Module Loader present
modeinfo nvidia
Code :
  1. filename:       /lib/modules/2.6.17-11-386/kernel/drivers/video/nvidia.ko
  2. license:        NVIDIA
  3. alias:          char-major-195-*
  4. vermagic:       2.6.17-10-386 mod_unload 486 REGPARM gcc-4.1
  5. depends:        agpgart,i2c-core
  6. alias:          pci:v000010DEd*sv*sd*bc03sc00i00*
  7. alias:          pci:v000010DEd*sv*sd*bc03sc02i00*
  8. parm:           NVreg_RMEdgeIntrCheck:int
  9. parm:           NVreg_PanelBrightnessLimits:int
  10. parm:           NVreg_PanelPWMFrequency:int
  11. parm:           NVreg_EnableBrightnessControl:int
  12. parm:           NVreg_SaveVBios:int
  13. parm:           NVreg_VbiosFromROM:int
  14. parm:           NVreg_RegistryDwords:charp
  15. parm:           NVreg_DetectPrimaryVga:int
  16. parm:           NVreg_UseCPA:int
  17. parm:           NVreg_RemapLimit:int
  18. parm:           NVreg_RmLogonRC:int
  19. parm:           NVreg_DevicesConnected:int
  20. parm:           NVreg_FlatPanelMode:int
  21. parm:           NVreg_ResmanDebugLevel:int
  22. parm:           NVreg_DeviceFileMode:int
  23. parm:           NVreg_DeviceFileGID:int
  24. parm:           NVreg_DeviceFileUID:int
  25. parm:           NVreg_ModifyDeviceFiles:int
  26. parm:           NVreg_Mobile:int
  27. parm:           NVreg_SoftEDIDs:int
  28. parm:           NVreg_EnableAGPFW:int
  29. parm:           NVreg_EnableAGPSBA:int
  30. parm:           NVreg_NvAGP:int
  31. parm:           NVreg_ReqAGPRate:int
  32. parm:           NVreg_EnableALiAGP:int
  33. parm:           NVreg_EnableVia4x:int
  34. parm:           NVreg_VideoMemoryTypeOverride:int
  35. parm:           nv_disable_pat:int
cat /proc/driver/nvidia/cards/0
Code :
  1. Model:           GeForce 6200SE TurboCache(TM)
  2. IRQ:             233
  3. Video BIOS:      05.44.02.37.06
  4. Card Type:       PCI-E
  5. DMA Size:        39 bits
  6. DMA Mask:        0x7fffffffff
cat /proc/driver/nvidia/agp/card
Code :
  1. cat: /proc/driver/nvidia/agp/card: Aucun fichier ou répertoire de ce type
Est-ce normal?  :pfff:
cat /proc/driver/nvidia/agp/host-bridge
Code :
  1. cat: /proc/driver/nvidia/agp/host-bridge: Aucun fichier ou répertoire de ce type
cat /proc/driver/nvidia/agp/status
Code :
  1. cat: /proc/driver/nvidia/agp/status: Aucun fichier ou répertoire de ce type
Forcement  :D
dmesg | grep agp
Code :
  1. [17179592.192000] Linux agpgart interface v0.101 (c) Dave Jones
Tiens?  :heink:
lspci
Code :
  1. 00:00.0 Host bridge: ATI Technologies Inc RS480 Host Bridge (rev 10)
  2. 00:02.0 PCI bridge: ATI Technologies Inc RS480 PCI-X Root Port
  3. 00:12.0 IDE interface: ATI Technologies Inc ATI 4379 Serial ATA Controller
  4. 00:13.0 USB Controller: ATI Technologies Inc IXP SB400 USB Host Controller
  5. 00:13.1 USB Controller: ATI Technologies Inc IXP SB400 USB Host Controller
  6. 00:13.2 USB Controller: ATI Technologies Inc IXP SB400 USB2 Host Controller
  7. 00:14.0 SMBus: ATI Technologies Inc IXP SB400 SMBus Controller (rev 11)
  8. 00:14.1 IDE interface: ATI Technologies Inc Standard Dual Channel PCI IDE Controller ATI
  9. 00:14.3 ISA bridge: ATI Technologies Inc IXP SB400 PCI-ISA Bridge
  10. 00:14.4 PCI bridge: ATI Technologies Inc IXP SB400 PCI-PCI Bridge
  11. 00:14.5 Multimedia audio controller: ATI Technologies Inc IXP SB400 AC'97 Audio Controller (rev 02)
  12. 00:18.0 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
  13. 00:18.1 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Address Map
  14. 00:18.2 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] DRAM Controller
  15. 00:18.3 Host bridge: Advanced Micro Devices [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
  16. 01:00.0 VGA compatible controller: nVidia Corporation Unknown device 0162 (rev a1)
  17. 02:01.0 Multimedia controller: Philips Semiconductors SAA7134 Video Broadcast Decoder (rev 01)
  18. 02:03.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
  19. 02:04.0 FireWire (IEEE 1394): VIA Technologies, Inc. IEEE 1394 Host Controller (rev 80)
lsmod | grep nvidia
Code :
  1. nvidia               4714580  22
  2. i2c_core               22288  4 i2c_ec,nvidia,saa7134,ir_kbd_i2c
  3. agpgart                33456  2 nvidia,ati_agp
glxinfo | grep direct
Code :
  1. direct rendering: Yes
cat /etc/X11/Xorg.conf
Code :
  1. # nvidia-xconfig: X configuration file generated by nvidia-xconfig
  2. # nvidia-xconfig:  version 1.0  (buildmeister@builder3)  Wed Sep 20 16:56:19 PDT 2006
  3. # /etc/X11/xorg.conf (xorg X Window System server configuration file)
  4. #
  5. # This file was generated by dexconf, the Debian X Configuration tool, using
  6. # values from the debconf database.
  7. #
  8. # Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
  9. # (Type "man /etc/X11/xorg.conf" at the shell prompt.)
  10. #
  11. # This file is automatically updated on xserver-xorg package upgrades *only*
  12. # if it has not been modified since the last upgrade of the xserver-xorg
  13. # package.
  14. #
  15. # If you have edited this file but would like it to be automatically updated
  16. # again, run the following command:
  17. #   sudo dpkg-reconfigure -phigh xserver-xorg
  18. Section "ServerLayout"
  19.     Identifier     "Default Layout"
  20.     Screen         "Default Screen" 0 0
  21.     InputDevice    "Generic Keyboard"
  22.     InputDevice    "Configured Mouse"
  23.     InputDevice    "stylus" "SendCoreEvents"
  24.     InputDevice    "cursor" "SendCoreEvents"
  25.     InputDevice    "eraser" "SendCoreEvents"
  26. EndSection
  27. Section "Files"
  28.         # path to defoma fonts
  29.     FontPath        "/usr/share/X11/fonts/misc"
  30.     FontPath        "/usr/share/X11/fonts/cyrillic"
  31.     FontPath        "/usr/share/X11/fonts/100dpi/:unscaled"
  32.     FontPath        "/usr/share/X11/fonts/75dpi/:unscaled"
  33.     FontPath        "/usr/share/X11/fonts/Type1"
  34.     FontPath        "/usr/share/X11/fonts/100dpi"
  35.     FontPath        "/usr/share/X11/fonts/75dpi"
  36.     FontPath        "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
  37. EndSection
  38. Section "Module"
  39.     Load           "i2c"
  40.     Load           "bitmap"
  41.     Load           "ddc"
  42.     Load           "extmod"
  43.     Load           "freetype"
  44.     Load           "glx"
  45.     Load           "int10"
  46.     Load           "type1"
  47.     Load           "vbe"
  48. EndSection
  49. Section "InputDevice"
  50.     Identifier     "Generic Keyboard"
  51.     Driver         "kbd"
  52.     Option         "CoreKeyboard"
  53.     Option         "XkbRules" "xorg"
  54.     Option         "XkbModel" "pc105"
  55.     Option         "XkbLayout" "fr"
  56.     Option         "XkbVariant" "latin9"
  57. EndSection
  58. Section "InputDevice"
  59.     Identifier     "Configured Mouse"
  60.     Driver         "mouse"
  61.     Option         "CorePointer"
  62.     Option         "Device" "/dev/input/mice"
  63.     Option         "Protocol" "ExplorerPS/2"
  64.     Option         "ZAxisMapping" "4 5"
  65.     Option         "Emulate3Buttons" "true"
  66. EndSection
  67. Section "InputDevice"
  68.                                                       # /dev/input/event
  69.                                                       # for USB
  70.     Identifier     "stylus"
  71.     Driver         "wacom"
  72.     Option         "Device" "/dev/wacom"          # Change to
  73.     Option         "Type" "stylus"
  74.     Option         "ForceDevice" "ISDV4"               # Tablet PC ONLY
  75. EndSection
  76. Section "InputDevice"
  77.                                                       # /dev/input/event
  78.                                                       # for USB
  79.     Identifier     "eraser"
  80.     Driver         "wacom"
  81.     Option         "Device" "/dev/wacom"          # Change to
  82.     Option         "Type" "eraser"
  83.     Option         "ForceDevice" "ISDV4"               # Tablet PC ONLY
  84. EndSection
  85. Section "InputDevice"
  86.                                                       # /dev/input/event
  87.                                                       # for USB
  88.     Identifier     "cursor"
  89.     Driver         "wacom"
  90.     Option         "Device" "/dev/wacom"          # Change to
  91.     Option         "Type" "cursor"
  92.     Option         "ForceDevice" "ISDV4"               # Tablet PC ONLY
  93. EndSection
  94. Section "Monitor"
  95.     Identifier     "COMPAQ S710"
  96.     Option         "DPMS"
  97. EndSection
  98. Section "Device"
  99.     Identifier     "NVIDIA Corporation NV40 [GeForce 6200?]"
  100.     Driver         "nvidia"
  101. EndSection
  102. Section "Screen"
  103.     Identifier     "Default Screen"
  104.     Device         "NVIDIA Corporation NV40 [GeForce 6200?]"
  105.     Monitor        "COMPAQ S710"
  106.     DefaultDepth    24
  107.     Option         "AddARGBGLXVisuals" "True"
  108.     Option         "TripleBuffer" "true"
  109.     Option         "NoLogo" "true"
  110.     Option         "CursorShadow" "true"
  111.     SubSection     "Display"
  112.         Depth       1
  113.         Modes      "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
  114.     EndSubSection
  115.     SubSection     "Display"
  116.         Depth       4
  117.         Modes      "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
  118.     EndSubSection
  119.     SubSection     "Display"
  120.         Depth       8
  121.         Modes      "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
  122.     EndSubSection
  123.     SubSection     "Display"
  124.         Depth       15
  125.         Modes      "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
  126.     EndSubSection
  127.     SubSection     "Display"
  128.         Depth       16
  129.         Modes      "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
  130.     EndSubSection
  131.     SubSection     "Display"
  132.         Depth       24
  133.         Modes      "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
  134.     EndSubSection
  135. EndSection
Voila, s'il y a le moindre probleme dans les confs... merci d'avance :jap: !
N.B: j'utilise les pilotes proprios nVidia. Sachant que la derniere version contient un gros bug, j'utilise une version legerement anterieur (la 9626 au lieu de la 9629). De plus, la carte que je possede est une Geforce 6200SE Turbocache (TM), avec pour type de bus: PCI Express 16X (essayer AGP, oui ou non?) et 256Mo de mémoire.
n°889141
arkrom
note, ca passait c'etait beau
Posté le 22-02-2007 à 22:38:20  profilanswer
va voir en section "OS alternatif" il y a un topic unique sur unbuntu V6 ( edgy eft )
Problème de langue avec squirrelmailprobleme de font
Ubuntu 6.10/ Palm TX / JPilotProblème crash avec mandriva discovery 2007!
probleme entre php4 et php5Problème lors d'un apt-get dist-upgrade
problème a l'installation de freebsd 6.2Problème de son avec Skype
probleme avec addmachinescript sous sambaProblème de routage ?
Plus de sujets relatifs à : Problème d'OpenGL avec ma Ubuntu 6.10...
