4670 connectés
  Linux et OS Alternatifs
  Problème de gravure
Problème de gravure
n°781313
Combi_A_Ve​ndre
Posté le 11-02-2006 à 23:12:52  profilanswer
Bonjour à tous,
J'esssaye de graver un CD depuis un portable avec Mandriva 2006.
Le graveur est usb iomega 48x12x24.
J'utilise K3B. Il me dit rapidement qu'une erreur non grave est apparue, puis rien ne se grave.
Voici la trace debug :
Code :
  1. System
  2. -----------------------
  3. K3b Version: 0.12
  4. KDE Version: 3.5.1
  5. QT Version:  3.3.4
  6. Kernel:      2.6.12-15mdk
  7. Devices
  8. -----------------------
  9. IOMEGA CDRW23042EXT3-C 4.10 (/dev/scsi/host0/bus0/target0/lun0/cd, /dev/sg0) at /mnt/cdrom2 [CD-R; CD-RW; CD-ROM] [CD-ROM; CD-R; CD-RW] [SAO; TAO; RAW; SAO/R96P; SAO/R96R; RAW/R16; RAW/R96P; RAW/R96R]
  10. MATSHITA DVD-ROM SR-8177 NZ15 (/dev/hdc, ) at /mnt/cdrom [CD-ROM; DVD-ROM] [DVD-ROM; CD-ROM] [Aucune]
  11. Used versions
  12. -----------------------
  13. cdrecord: 2.1.1a03
  14. cdrecord
  15. -----------------------
  16. /usr/bin/cdrecord: Cannot allocate memory. WARNING: Cannot do mlockall(2).
  17. /usr/bin/cdrecord: WARNING: This causes a high risk for buffer underruns.
  18. /usr/bin/cdrecord: Operation not permitted. WARNING: Cannot set RR-scheduler
  19. /usr/bin/cdrecord: Permission denied. WARNING: Cannot set priority using setpriority().
  20. /usr/bin/cdrecord: WARNING: This causes a high risk for buffer underruns.
  21. scsidev: '0,0,0'
  22. scsibus: 0 target: 0 lun: 0
  23. Linux sg driver version: 3.5.33
  24. SCSI buffer size: 64512
  25. /usr/bin/cdrecord: Input/output error. read buffer: scsi sendcmd: cmd timeout after 17.193 (200) s
  26. CDB:  3C 00 00 00 00 00 00 FC 00 00
  27. cmd finished after 17.193s timeout 200s
  28. Cdrecord-Clone 2.01.01a03-dvd (i686-pc-linux-gnu) Copyright (C) 1995-2005 Jörg Schilling
  29. Note: This version is an unofficial (modified) version with DVD support
  30. Note: and therefore may have bugs that are not present in the original.
  31. Note: Please send bug reports or support requests to warly at mandriva.com.
  32. Note: The author of cdrecord should not be bothered with problems in this version.
  33. TOC Type: 1 = CD-ROM
  34. Using libscg version 'schily-0.8'.
  35. Driveropts: 'burnfree'
  36. atapi: 1
  37. Device type    : Removable CD-ROM
  38. Version        : 0
  39. Response Format: 1
  40. Vendor_info    : 'IOMEGA  '
  41. Identifikation : 'CDRW23042EXT3-C '
  42. Revision       : '4.10'
  43. Device seems to be: Generic mmc CD-RW.
  44. Current: 0x0009
  45. Profile: 0x000A
  46. Profile: 0x0009 (current)
  47. Profile: 0x0008
  48. Profile: 0x0002 (current)
  49. Using generic SCSI-3/mmc   CD-R/CD-RW driver (mmc_cdr).
  50. Driver flags   : MMC-2 SWABAUDIO BURNFREE
  51. Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R16 RAW/R96P RAW/R96R
  52. Drive buf size : 1971200 = 1925 KB
  53. FIFO size      : 4194304 = 4096 KB
  54. cdrecord command:
  55. -----------------------
  56. /usr/bin/cdrecord -v gracetime=2 dev=0,0,0 speed=4 -dao -dummy driveropts=burnfree -eject -data /home/bibi/Mandriva-Linux-Free-2006-CD1.i586.iso
Je me demande si il n'y a pas un conflit entre le graveur et le lecteur de DVD MATSHITA.
Vous voyez une piste pour que je règle ce problème?
Merci,
vw
n°781599
Combi_A_Ve​ndre
Posté le 12-02-2006 à 20:02:10  profilanswer
:cry:
Si personne ne connait se problème, vous n'avez pas un autre logiciel de gravure à me conseiller?
Sinon je vais me lancer dans les lignes de commande mais ça m'enchante pas des masses...
Merci,
vw
n°781614
Edes
Posté le 12-02-2006 à 20:31:22  profilanswer
 Et bien, c'est quoi une erreur grave pour ce logiciel. L'explosion du graveur ?
n°781616
Edes
Posté le 12-02-2006 à 20:31:48  profilanswer
essaie nero linux !
n°781643
Combi_A_Ve​ndre
Posté le 12-02-2006 à 21:23:26  profilanswer
Nero Linux est payant non?
J'ai utilisé la ligne de de commande suivante :
cdrecord -v -dao speed=8 dev=0,0,0 /home/vw/Mandriva-Linux-Free-2006-CD1.i586.iso
Et voici le log :
Code :
  1. Cdrecord-Clone 2.01.01a03-dvd (i686-pc-linux-gnu) Copyright (C) 1995-2005 Jörg Schilling
  2. Note: This version is an unofficial (modified) version with DVD support
  3. Note: and therefore may have bugs that are not present in the original.
  4. Note: Please send bug reports or support requests to warly at mandriva.com.
  5. Note: The author of cdrecord should not be bothered with problems in this version.
  6. TOC Type: 1 = CD-ROM
  7. scsidev: '0,0,0'
  8. scsibus: 0 target: 0 lun: 0
  9. Linux sg driver version: 3.5.33
  10. SCSI buffer size: 64512
  11. Using libscg version 'schily-0.8'.
  12. atapi: 1
  13. Device type    : Removable CD-ROM
  14. Version        : 0
  15. Response Format: 1
  16. Vendor_info    : 'IOMEGA  '
  17. Identifikation : 'CDRW23042EXT3-C '
  18. Revision       : '4.10'
  19. Device seems to be: Generic mmc CD-RW.
  20. Current: 0x0009
  21. Profile: 0x000A
  22. Profile: 0x0009 (current)
  23. Profile: 0x0008
  24. Profile: 0x0002 (current)
  25. Using generic SCSI-3/mmc   CD-R/CD-RW driver (mmc_cdr).
  26. Driver flags   : MMC-2 SWABAUDIO BURNFREE
  27. Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R16 RAW/R96P RAW/R96R
  28. Drive buf size : 1971200 = 1925 KB
  29. cdrecord: Input/output error. read buffer: scsi sendcmd: cmd timeout after 17.055 (200) s
  30. CDB:  3C 00 00 00 00 00 00 FC 00 00
  31. cmd finished after 17.055s timeout 200s
  32. FIFO size      : 4194304 = 4096 KB
  33. Track 01: data   696 MB
  34. Total size:      799 MB (79:11.82) = 356387 sectors
  35. Lout start:      799 MB (79:13/62) = 356387 sectors
Cest grosso modo le même que plus haut.
vw
Message édité par Combi_A_Vendre le 12-02-2006 à 21:24:29
n°781650
Combi_A_Ve​ndre
Posté le 12-02-2006 à 21:30:30  profilanswer
Est-ce que je dois rajouter un "append hdx=scsi" dans le lilo.conf alors que c'est un graveur usb?
vw
n°782018
Combi_A_Ve​ndre
Posté le 13-02-2006 à 19:24:11  profilanswer
Help !  :cry:
n°793888
overider
Posté le 19-03-2006 à 16:12:09  profilanswer
j'ai égélement des problèmes de gravure sous linux si tu trouve des chose pourra tu le faire partager merci.
n°793889
overider
Posté le 19-03-2006 à 16:13:05  profilanswer
sinon quel taille fait ton image iso ne serait t'elle pas a graver sus un dvd si c'est le cas voir growisofs
  Problème de gravure
Problème lecture sous titre quand gravure sous Linux[RESOLU]_Problème de gravure avec LE2005.
Problème de gravure DVDLG 4160b - Problème de gravure
Problème Gravure K3b[ Logiciels ] Problème de gravure avec K3B (cdrecord)
Probleme de gravure kernel 2.6Probleme de gravure
Problème gravure isos woodyprobleme de gravure mandrake 8.1
Plus de sujets relatifs à : Problème de gravure
