4527 connectés
  Linux et OS Alternatifs
  Probleme de gravure kernel 2.6
n°420450
The Dml
pouet.. pouet ...
Posté le 29-02-2004 à 15:43:53  profilanswer
Salut !
j'ai un probleme a graver/effacer mes rw avec mon noyau.
par contre avec mes cd-r cela marche bien.
je précise que je n utilise pas l'émemulation scsi
pour un cd sony voici le message derreur que j' ai
dmlpc2:/etc/modprobe.d# cdrecord -v dev=/dev/hdc -blank=fast
Cdrecord-Clone 2.01a25 (i686-pc-linux-gnu) Copyright (C) 1995-2004 Jörg Schilling
NOTE: this version of cdrecord is an inofficial (modified) release of cdrecord
      and thus may have bugs that are not present in the original version.
      Please send bug reports and support requests to <cdrtools@packages.debian.org>.
      The original author should not be bothered with problems of this version.
TOC Type: 1 = CD-ROM
scsidev: '/dev/hdc'
devname: '/dev/hdc'
scsibus: -2 target: -2 lun: -2
Warning: Open by 'devname' is unintentional and not supported.
Linux sg driver version: 3.5.27
Using libscg version 'schily-0.8'.
SCSI buffer size: 64512
atapi: 1
Device type    : Removable CD-ROM
Version        : 0
Response Format: 1
Vendor_info    : 'IDE-CD  '
Identifikation : 'R/RW 4x4x32     '
Revision       : '1.3B'
Device seems to be: Generic mmc CD-RW.
Using generic SCSI-3/mmc   CD-R/CD-RW driver (mmc_cdr).
Driver flags   : MMC SWABAUDIO
Supported modes: TAO PACKET RAW/R16
Drive buf size : 1572864 = 1536 KB
Current Secsize: 2048
ATIP info from disk:
  Indicated writing power: 3
  Reference speed: 6
  Is not unrestricted
  Is erasable
  Disk sub type: High speed Rewritable (CAV) media (1)
  ATIP start of lead in:  -11625 (97:27/00)
  ATIP start of lead out: 333750 (74:12/00)
  1T speed low:  4 1T speed high: 10
  2T speed low:  4 2T speed high:  0 (reserved val  6)
  power mult factor: 1 5
  recommended erase/write power: 5
  A1 values: 24 1A D8
  A2 values: 26 B2 4A
Disk type:    Phase change
Manuf. index: 0
Manufacturer: Illegal Manufacturer code
cdrecord.mmap: Trying to use high speed medium on low speed writer.
pour un tdk j ai ca ca
Manufacturer: unknown (not in table)
Manufacturer is unknown because of the orange forum embargo.
As the orange forum likes to get money for recent information,
it may be that this media does not use illegal manufacturer coding.
une idée du probleme ?
Message édité par The Dml le 29-02-2004 à 15:44:26
n°420468
The Dml
pouet.. pouet ...
Posté le 29-02-2004 à 16:00:21  profilanswer
bisard, avec un emetec cela marche  :??:,
vous avez ce probleme vous avec certains cd ?
n°420490
Taz
bisounours-codeur
Posté le 29-02-2004 à 16:16:50  profilanswer
oui
noob@debian : connerie avec le kernel donc kernel panic[FreeBSD 5.1] Kernel upgrade raté : Réglé par maj compl. -> 5.2
Problème avec Xkb et la layout fr[debian] probleme de "locale"
carte pci HPT372A et kernel 2.6 :/probléme sous Mandrake 10 et bittorrent ou comment parametré Socks 5
Problème avec ATI9800SE et drivers fglrxProblème de configuration Samba
probleme clavier sous window maker....pitit probleme svp
Plus de sujets relatifs à : Probleme de gravure kernel 2.6
