9461 connectés
  Linux et OS Alternatifs
  probleme d'acceleration materielle avec ati 9600 ss fedora
 Page :   1  2
Page Précédente
n°415489
Bitman
STAY APART
Posté le 22-02-2004 à 20:21:26  profilanswer
matos : nforce 2 avec ses drivers qui marchent
j'ai mis pour l'ati le rpm correcpondant a mon xfree (4.3), g bien viré mesa machin...
mais pas de 3D, donc pas de ET, meme tuxracer tourne a 0.5 fps  :sweat:
je sais pas trop quoi faire aidez moi siouplé  :o
mon xf86config :
# File: XF86Config-4
# File generated by fglrxconfig (C) ATI Research, a substitute for xf86config.
blablabla ...
# DRI Section
Section "dri"
# Access to OpenGL ICD is allowed for all users:
    Mode 0666
# Access to OpenGL ICD is restricted to a specific user group:
#    Group 100    # users
#    Mode 0660
EndSection
# Module section -- this  section  is used to specify
# which dynamically loadable modules to load.
Section "Module"
# This loads the DBE extension module.
    Load        "dbe"   # Double buffer extension
# This loads the miscellaneous extensions module, and disables
# initialisation of the XFree86-DGA extension within that module.
    SubSection  "extmod"
      Option    "omit xfree86-dga"   # don't initialise the DGA extension
    EndSubSection
# This loads the Type1 and FreeType font modules
    Load        "type1"
    Load        "freetype"
# This loads the GLX module
    Load        "glx"   # libglx.a
    Load        "dri"   # libdri.a
EndSection
# Files section.  This allows default font and rgb paths to be set
Section "Files"
# The location of the RGB database.  Note, this is the name of the
# file minus the extension (like ".txt" or ".db" ).  There is normally
# no need to change the default.
    RgbPath "/usr/X11R6/lib/X11/rgb"
# Multiple FontPath entries are allowed (which are concatenated together),
# as well as specifying multiple comma-separated entries in one FontPath
# command (or a combination of both methods)
# If you don't have a floating point coprocessor and emacs, Mosaic or other
# programs take long to start up, try moving the Type1 and Speedo directory
# to the end of this list (or comment them out).
    FontPath   "/usr/X11R6/lib/X11/fonts/local/"
    FontPath   "/usr/X11R6/lib/X11/fonts/misc/"
    FontPath   "/usr/X11R6/lib/X11/fonts/75dpi/:unscaled"
    FontPath   "/usr/X11R6/lib/X11/fonts/100dpi/:unscaled"
    FontPath   "/usr/X11R6/lib/X11/fonts/Type1/"
    FontPath   "/usr/X11R6/lib/X11/fonts/Speedo/"
    FontPath   "/usr/X11R6/lib/X11/fonts/75dpi/"
    FontPath   "/usr/X11R6/lib/X11/fonts/100dpi/"
# The module search path.  The default path is shown here.
#    ModulePath "/usr/X11R6/lib/modules"
EndSection
# Server flags section.
Section "ServerFlags"
# Uncomment this to cause a core dump at the spot where a signal is
# received.  This may leave the console in an unusable state, but may
# provide a better stack trace in the core dump to aid in debugging
#    Option "NoTrapSignals"
# Uncomment this to disable the <Crtl><Alt><BS> server abort sequence
# This allows clients to receive this key event.
#    Option "DontZap"
# Uncomment this to disable the <Crtl><Alt><KP_+>/<KP_-> mode switching
# sequences.  This allows clients to receive these key events.
#    Option "Dont Zoom"
# Uncomment this to disable tuning with the xvidtune client. With
# it the client can still run and fetch card and monitor attributes,
# but it will not be allowed to change them. If it tries it will
# receive a protocol error.
#    Option "DisableVidModeExtension"
# Uncomment this to enable the use of a non-local xvidtune client.
#    Option "AllowNonLocalXvidtune"
# Uncomment this to disable dynamically modifying the input device
# (mouse and keyboard) settings.
#    Option "DisableModInDev"
# Uncomment this to enable the use of a non-local client to
# change the keyboard or mouse settings (currently only xset).
#    Option "AllowNonLocalModInDev"
EndSection
# Input devices
# Core keyboard's InputDevice section
Section "InputDevice"
    Identifier "Keyboard1"
    Driver "Keyboard"
# For most OSs the protocol can be omitted (it defaults to "Standard" ).
# When using XQUEUE (only for SVR3 and SVR4, but not Solaris),
# uncomment the following line.
#    Option "Protocol"   "Xqueue"
    Option "AutoRepeat" "500 30"
# Specify which keyboard LEDs can be user-controlled (eg, with xset(1))
#    Option "Xleds"      "1 2 3"
#    Option "LeftAlt"    "Meta"
#    Option "RightAlt"   "ModeShift"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults).  For example, for a non-U.S.
# keyboard, you will probably want to use:
#    Option "XkbModel"   "pc102"
# If you have a US Microsoft Natural keyboard, you can use:
#    Option "XkbModel"   "microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
#    Option "XkbLayout"  "de"
# or:
#    Option "XkbVariant" "nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
#    Option "XkbOptions" "ctrl:swapcaps"
# These are the default XKB settings for XFree86
#    Option "XkbRules"   "xfree86"
#    Option "XkbModel"   "pc101"
#    Option "XkbLayout"  "us"
#    Option "XkbVariant" ""
#    Option "XkbOptions" ""
#    Option "XkbDisable"
    Option "XkbLayout" "fr"
EndSection
# Core Pointer's InputDevice section
# Identifier and driver
    Identifier "Mouse1"
    Driver "mouse"
    Option "Protocol"   "ImPS/2"
    Option "ZAxisMapping"   "4 5"
    Option "Device"     "/dev/mouse"
# When using XQUEUE, comment out the above two lines, and uncomment
# the following line.
# Baudrate and SampleRate are only for some Logitech mice. In
# almost every case these lines should be omitted.
#    Option "BaudRate"   "9600"
#    Option "SampleRate" "150"
# Emulate3Buttons is an option for 2-button Microsoft mice
# Emulate3Timeout is the timeout in milliseconds (default is 50ms)
#    Option "Emulate3Buttons"
#    Option "Emulate3Timeout"    "50"
# ChordMiddle is an option for some 3-button Logitech mice
#    Option "ChordMiddle"
EndSection
# Other input device sections
# this is optional and is required only if you
# are using extended input devices.  This is for example only.  Refer
# to the XF86Config man page for a description of the options.
# Section "InputDevice"
#    Identifier  "Mouse2"
#    Driver      "mouse"
#    Option      "Protocol"      "MouseMan"
#    Option      "Device"        "/dev/mouse2"
# EndSection
#    Identifier "spaceball"
#    Driver     "magellan"
#    Option     "Device"         "/dev/cua0"
# EndSection
#    Identifier "spaceball2"
#    Driver     "spaceorb"
# EndSection
#    Identifier "touchscreen0"
#    Driver     "microtouch"
#    Option     "Device"         "/dev/ttyS0"
#    Option     "MinX"           "1412"
#    Option     "MaxX"           "15184"
#    Option     "MinY"           "15372"
#    Option     "MaxY"           "1230"
#    Option     "ScreenNumber"   "0"
#    Option     "ReportingMode"  "Scaled"
#    Option     "ButtonNumber"   "1"
#    Option     "SendCoreEvents"
# EndSection
#    Identifier "touchscreen1"
#    Driver     "elo2300"
#    Option     "MinX"           "231"
#    Option     "MaxX"           "3868"
#    Option     "MinY"           "3858"
#    Option     "MaxY"           "272"
#    Option     "ButtonThreshold"    "17"
# EndSection
# Monitor section
# Any number of monitor sections may be present
Section "Monitor"
    Identifier  "Monitor0"
    HorizSync   31.5 - 91.1
    VertRefresh 60 - 85
    Option "DPMS"
# === mode lines based on GTF ===
# VGA @ 100Hz
# Modeline "640x480@100" 43.163 640 680 744 848 480 481 484 509 +hsync +vsync
# SVGA @ 100Hz
# Modeline "800x600@100" 68.179 800 848 936 1072 600 601 604 636 +hsync +vsync
# XVGA @ 100Hz
# Modeline "1024x768@100" 113.309 1024 1096 1208 1392 768 769 772 814 +hsync +vsync
# 1152x864 @ 60Hz
# Modeline "1152x864@60" 81.642 1152 1216 1336 1520 864 865 868 895 +hsync +vsync
# 1152x864 @ 85Hz
# Modeline "1152x864@85" 119.651 1152 1224 1352 1552 864 865 868 907 +hsync +vsync
# 1152x864 @ 100Hz
# Modeline "1152x864@100" 143.472 1152 1232 1360 1568 864 865 868 915 +hsync +vsync
# 1280x960 @ 75Hz
# Modeline "1280x960@75" 129.859 1280 1368 1504 1728 960 961 964 1002 +hsync +vsync
# 1280x960 @ 100Hz
# Modeline "1280x960@100" 178.992 1280 1376 1520 1760 960 961 964 1017  +hsync +vsync
# SXGA @ 100Hz
# Modeline "1280x1024@100" 190.960 1280 1376 1520 1760 1024 1025 1028 1085 +hsync +vsync
# SPEA GDM-1950 (60Hz,64kHz,110MHz,-,-): 1280x1024 @ V-freq: 60.00 Hz, H-freq: 63.73 KHz
# Modeline "GDM-1950"  109.62  1280 1336 1472 1720  1024 1024 1026 1062 -hsync -vsync
# 1600x1000 @ 60Hz
# Modeline "1600x1000" 133.142 1600 1704 1872 2144 1000 1001 1004 1035 +hsync +vsync
# 1600x1000 @ 75Hz
# Modeline "1600x1000" 169.128 1600 1704 1880 2160 1000 1001 1004 1044 +hsync +vsync
# 1600x1000 @ 85Hz
# Modeline "1600x1000" 194.202 1600 1712 1888 2176 1000 1001 1004 1050 +hsync +vsync
# 1600x1000 @ 100Hz
# Modeline "1600x1000" 232.133 1600 1720 1896 2192 1000 1001 1004 1059 +hsync +vsync
# 1600x1024 @ 60Hz
# Modeline "1600x1024" 136.385 1600 1704 1872 2144 1024 1027 1030 1060 +hsync +vsync
# 1600x1024 @ 75Hz
# Modeline "1600x1024" 174.416 1600 1712 1888 2176 1024 1025 1028 1069 +hsync +vsync
# 1600x1024 @ 76Hz
# Modeline "1600x1024" 170.450 1600 1632 1792 2096 1024 1027 1030 1070 +hsync +vsync
# 1600x1024 @ 85Hz
# Modeline "1600x1024" 198.832 1600 1712 1888 2176 1024 1027 1030 1075 +hsync +vsync
# 1920x1080 @ 60Hz
# Modeline "1920x1080" 172.798 1920 2040 2248 2576 1080 1081 1084 1118 -hsync -vsync
# 1920x1080 @ 75Hz
# Modeline "1920x1080" 211.436 1920 2056 2264 2608 1080 1081 1084 1126 +hsync +vsync
# 1920x1200 @ 60Hz
# Modeline "1920x1200" 193.156 1920 2048 2256 2592 1200 1201 1203 1242 +hsync +vsync
# 1920x1200 @ 75Hz
# Modeline "1920x1200" 246.590 1920 2064 2272 2624 1200 1201 1203 1253 +hsync +vsync
# 2048x1536 @ 60
# Modeline "2048x1536" 266.952 2048 2200 2424 2800 1536 1537 1540 1589 +hsync +vsync
# 2048x1536 @ 60
# 1400x1050 @ 60Hz M9 Laptop mode
# ModeLine "1400x1050" 122.000 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync
# 1920x2400 @ 25Hz for IBM T221, VS VP2290 and compatible display devices
# Modeline "1920x2400@25" 124.620 1920 1928 1980 2048 2400 2401 2403 2434 +hsync +vsync
# 1920x2400 @ 30Hz for IBM T221, VS VP2290 and compatible display devices
# Modeline "1920x2400@30" 149.250 1920 1928 1982 2044 2400 2402 2404 2434 +hsync +vsync
EndSection
# Graphics device section
# Any number of graphics device sections may be present
# Standard VGA Device:
#Section "Device"
#    Identifier  "Standard VGA"
#    VendorName  "Unknown"
#    BoardName   "Unknown"
# The chipset line is optional in most cases.  It can be used to override
# the driver's chipset detection, and should not normally be specified.
#    Chipset     "generic"
# The Driver line must be present.  When using run-time loadable driver
# modules, this line instructs the server to load the specified driver
# module.  Even when not using loadable driver modules, this line
# indicates which driver should interpret the information in this section.
#    Driver      "vga"
# The BusID line is used to specify which of possibly multiple devices
# this section is intended for.  When this line isn't present, a device
# section can only match up with the primary video device.  For PCI
# devices a line like the following could be used.  This line should not
# normally be included unless there is more than one video device
# installed.
#    BusID       "PCI:0:10:0"
#    VideoRam    256
#    Clocks      25.2 28.3
# EndSection
# === ATI device section ===
Section "Device"
    Identifier                          "ATI Graphics Adapter"
    Driver                              "fglrx"
# ### generic DRI settings ###
# === disable PnP Monitor  ===
    #Option                              "NoDDC"
# === disable/enable XAA/DRI ===
    Option "no_accel"                   "no"
    Option "no_dri"                     "no"
# === misc DRI settings ===
    Option "mtrr"                       "off" # disable DRI mtrr mapper, driver has its own code for mtrr
# ### FireGL DDX driver module specific settings ###
# === Screen Management ===
    Option "DesktopSetup"               "0x00000000"
    Option "MonitorLayout"              "AUTO, AUTO"
    Option "IgnoreEDID"                 "off"
    Option "HSync2"                     "unspecified"
    Option "VRefresh2"                  "unspecified"
    Option "ScreenOverlap"              "0"
# === TV-out Management ===
    Option "NoTV"                       "yes"
    Option "TVStandard"                 "NTSC-M"
    Option "TVHSizeAdj"                 "0"
    Option "TVVSizeAdj"                 "0"
    Option "TVHPosAdj"                  "0"
    Option "TVVPosAdj"                  "0"
    Option "TVHStartAdj"                "0"
    Option "TVColorAdj"                 "0"
    Option "GammaCorrectionI"           "0x00000000"
    Option "GammaCorrectionII"          "0x00000000"
# === OpenGL specific profiles/settings ===
    Option "Capabilities"               "0x00000000"
# === Video Overlay for the Xv extension ===
    Option "VideoOverlay"               "on"
# === OpenGL Overlay ===
# Note: When OpenGL Overlay is enabled, Video Overlay
#       will be disabled automatically
    Option "OpenGLOverlay"              "on"
# === Center Mode (Laptops only) ===
    Option "CenterMode"                 "off"
# === Pseudo Color Visuals (8-bit visuals) ===
    Option "PseudoColorVisuals"         "off"
# === QBS Management ===
    Option "Stereo"                     "off"
    Option "StereoSyncEnable"           "1"
# === FSAA Management ===
    Option "FSAAEnable"                 "no"
    Option "FSAAScale"                  "1"
    Option "FSAADisableGamma"           "no"
    Option "FSAACustomizeMSPos"         "no"
    Option "FSAAMSPosX0"                "0.000000"
    Option "FSAAMSPosY0"                "0.000000"
    Option "FSAAMSPosX1"                "0.000000"
    Option "FSAAMSPosY1"                "0.000000"
    Option "FSAAMSPosX2"                "0.000000"
    Option "FSAAMSPosY2"                "0.000000"
    Option "FSAAMSPosX3"                "0.000000"
    Option "FSAAMSPosY3"                "0.000000"
    Option "FSAAMSPosX4"                "0.000000"
    Option "FSAAMSPosY4"                "0.000000"
    Option "FSAAMSPosX5"                "0.000000"
    Option "FSAAMSPosY5"                "0.000000"
# === Misc Options ===
    Option "UseFastTLS"                 "0"
    Option "BlockSignalsOnLock"         "on"
    Option "UseInternalAGPGART"         "yes"
    Option "ForceGenericCPU"            "no"
    BusID "PCI:2:0:0"    # vendor=1002, device=4152
    Screen 0
EndSection
# Screen sections
# Any number of screen sections may be present.  Each describes
# the configuration of a single screen.  A single specific screen section
# may be specified from the X server command line with the "-screen"
# option.
Section "Screen"
    Identifier  "Screen0"
    Device      "ATI Graphics Adapter"
    Monitor     "Monitor0"
    DefaultDepth 24
    #Option "backingstore"
    Subsection "Display"
        Depth       24
        Modes       "1280x1024" "1024x768" "800x600" "640x480"
        ViewPort    0 0  # initial origin if mode is smaller than desktop
#        Virtual     1280 1024
    EndSubsection
EndSection
# ServerLayout sections.
# Any number of ServerLayout sections may be present.  Each describes
# the way multiple screens are organised.  A specific ServerLayout
# section may be specified from the X server command line with the
# "-layout" option.  In the absence of this, the first section is used.
# When now ServerLayout section is present, the first Screen section
# is used alone.
Section "ServerLayout"
# The Identifier line must be present
    Identifier  "Server Layout"
# Each Screen line specifies a Screen section name, and optionally
# the relative position of other screens.  The four names after
# primary screen name are the screens to the top, bottom, left and right
# of the primary screen.
    Screen "Screen0"
# Each InputDevice line specifies an InputDevice section name and
# optionally some options to specify the way the device is to be
# used.  Those options include "CorePointer", "CoreKeyboard" and
# "SendCoreEvents".
    InputDevice "Mouse1" "CorePointer"
    InputDevice "Keyboard1" "CoreKeyboard"
EndSection
### EOF ###
[:sharpknife]
n°415491
vanilla
datoune's revival
Posté le 22-02-2004 à 20:23:10  profilanswer
Tu peux acheter une nvidia, ça marche bien sous linusque.
Membre du Front de Libération de Datoune | Soutenez le FLD | A Tribute To Datoune
n°415495
Bitman
STAY APART
Posté le 22-02-2004 à 20:23:44  profilanswer
je sais j'avais une 4200 avant :p
n°415498
vanilla
datoune's revival
Posté le 22-02-2004 à 20:27:24  profilanswer
Je sais pas :/
T'as pas des messages d'erreurs (enfin un truc qui pourrait faire avancer) ? cat /var/log/messages ?
n°415726
steph73
Posté le 23-02-2004 à 10:49:05  profilanswer
En lisant la doc de Lea: http://lea-linux.org/hardware/atidriver.php3
Il disent de faire que quelque modif ds le Xfreeconf, as tu essaye de supprimer toutes les options, met jsute le necessaire ?
Je vais bientot avoir a configure une Radeon 9200 pour une personnes, je t'en dirais plus alors.
Steph
n°415732
steph73
Posté le 23-02-2004 à 10:58:24  profilanswer
fglrxinfo
     Typical output information (3D acceleration is working properly)
     may read like this:
         OpenGL vendor string: ATI
         OpenGL renderer string: FireGL 8700/8800
         OpenGL version string: 1.2.1234 (1.2.3)
Ca donne quoi cette commande chez toi ?
n°415839
atom747
the flavour is here....
Posté le 23-02-2004 à 12:25:25  profilanswer
le module "fglrx" est il chargé?
n°416410
Bitman
STAY APART
Posté le 24-02-2004 à 00:15:08  profilanswer
j'ai tout posté ici : http://forum.hardware.fr/hardwaref [...] tm#t412922
la je suis pas chez moi je reviens demain ;-)
n°416524
steph73
Posté le 24-02-2004 à 09:03:21  profilanswer
Y a pas FGLRXINFO (fglrxinfo), c'est une commande d'ATI a priori pour avoir des infos sur le X
n°422387
Bitman
STAY APART
Posté le 02-03-2004 à 21:21:50  profilanswer
[bitman@localhost bitman]$ fglrxinfo
display: :0.0  screen: 0
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL renderer string: Mesa GLX Indirect
OpenGL version string: 1.3 Mesa 4.0.4
voalaaaa  :D
n°422423
BMOTheKill​er
Posté le 02-03-2004 à 21:54:06  profilanswer
ben faut croire que non :/
n°422424
Bitman
STAY APART
Posté le 02-03-2004 à 21:56:16  profilanswer
je sais bien, mais que faire ? [:matleflou]
si je vire mesa la, vu que ma video tourne dessus je risque pas de fucker mon X ?
n°422435
steph73
Posté le 02-03-2004 à 22:03:13  profilanswer
Si tu vire Mesa c'est que l'opengl qui ne marche plus
Message édité par steph73 le 02-03-2004 à 22:03:32
n°422436
BMOTheKill​er
Posté le 02-03-2004 à 22:04:20  profilanswer
il faut pas remplacer le module XFree glx par un autre ?
atom747 t'as demandé si le module fglrx est bien chargé ?
vérifies bien toute la manip, puis comme on te l'a déjà dit aussi : fais du ménage dans le fichier, c'est pas très friendly au niveau lecture :/
n°422515
Bitman
STAY APART
Posté le 02-03-2004 à 23:01:51  profilanswer
[bitman@localhost bitman]$ lsmod
Module                  Size  Used by    Tainted: P
fglrx                 189128   0
udf                    92992   0 (autoclean)
i810_audio             26888   1 (autoclean)
ac97_codec             16648   0 (autoclean) [i810_audio]
soundcore               6500   2 (autoclean) [i810_audio]
agpgart                55108   0 (unused)
lp                      8356   0 (autoclean)
parport                36800   0 (autoclean) [lp]
autofs                 12052   0 (autoclean) (unused)
ppp_synctty             6592   0 (unused)
ppp_async               8096   1
ppp_generic            23804   3 [ppp_synctty ppp_async]
slhc                    6660   0 [ppp_generic]
nvnet                  30144   1
sr_mod                 17016   2 (autoclean)
ide-scsi               11856   1
ide-cd                 34176   0
cdrom                  34048   0 [sr_mod ide-cd]
ohci1394               28520   0 (unused)
ieee1394              203940   0 [ohci1394]
ntfs                   58336   2 (autoclean)
nls_iso8859-1           3548   4 (autoclean)
nls_cp437               5180   1 (autoclean)
vfat                   12268   1 (autoclean)
fat                    37592   0 (autoclean) [vfat]
printer                 9280   0
scanner                11544   0 (unused)
floppy                 56348   0 (autoclean)
sg                     34796   0 (autoclean)
sd_mod                 13452   0 (autoclean)
usb-storage            69824   0
scsi_mod              109384   5 [sr_mod ide-scsi sg sd_mod usb-storage]
keybdev                 2624   0 (unused)
mousedev                5204   1
hid                    23652   0 (unused)
input                   5824   0 [keybdev mousedev hid]
ehci-hcd               19784   0 (unused)
usb-ohci               21192   0 (unused)
usbcore                77984   1 [printer scanner usb-storage hid ehci-hcd usb-ohci]
ext3                   70980   1
jbd                    51084   1 [ext3]
franchement j'ai aucune ID de ce qu'il faut faire, avec mon ancienne nvidia ct fastoche la je mouline dans la choucroute :(
n°422532
Bitman
STAY APART
Posté le 02-03-2004 à 23:09:43  profilanswer
de plus :
Section "Device"
   Driver                              "fglrx"
    #Option                              "NoDDC"
    Option "NoTV"                       "yes"
n°422536
BMOTheKill​er
Posté le 02-03-2004 à 23:16:18  profilanswer
tu es sûr de modifier le bon fichier ? peut-être que l'installation des drivers ATI a créé un lien symbolique vers un autre fichier, ou un truc encore plus sioux
vérifies bien le contenu de /etc/X11, parce que sous RH (et fedora c'est même tarif), le fichier c'est /etc/X11/XF86Config et non /etc/X11/XF86Config-4, alors tu peux toujours le modifier ton fichier :o
n°422537
Bitman
STAY APART
Posté le 02-03-2004 à 23:17:34  profilanswer
je sais, le fichier crée était le XF..-4 je l'ai renommé en XF86config normal :)
[bitman@localhost X11]$ ls
applnk         prefdm.rpmorig  xawtvrc                    xkb
desktop-menus  proxymngr       xdm                        Xmodmap
dm             serverconfig    XF86Config                 Xresources
fs             starthere       XF86Config.bof             xserver
gdm            sysconfig       XF86Config.good            xsm
lbxproxy       twm             XftConfig.README-OBSOLETE
prefdm         X               xinit
je vois rien de louche la :/
Message édité par Bitman le 02-03-2004 à 23:18:20
n°422541
BMOTheKill​er
Posté le 02-03-2004 à 23:23:13  profilanswer
le log d'XFree dit quoi ? il doit bien expliquer cette non-utilisation du pilote spécifié, X démarre bien sinon ? il tourne en quoi, vesa ?
n°422544
Bitman
STAY APART
Posté le 02-03-2004 à 23:26:01  profilanswer
heu je sais pas trop comment on voit ca désolé, ya certains trucs ou je suis totalement noob :cry:
n°422547
Bitman
STAY APART
Posté le 02-03-2004 à 23:28:28  profilanswer
haaaaaaaaaaa !  :fou:
(II) FireGL8700/8800: Driver for chipset: ATI RV250 Id (R9000),
 ATI RV250 Ie (R9000), ATI RV250 If (R9000), ATI RV250 Ig (R9000),
 ATI RV250 Ld (M9), ATI RV250 Le (M9), ATI RV250 Lf (M9),
 ATI RV250 Lg (M9), ATI RV280 5960 (R9200 PRO),
 ATI RV280 Ya (R9200LE), ATI RV250SE Yd (R9200SE),
 ATI RV250 5C61 (M9+), ATI RV250 5C63 (M9+), ATI R200 QH (R8500),
 ATI R200 QL (R8500), ATI R200 QM (R9100), ATI R200 QT (R8500),
 ATI R200 QU (R9100), ATI R200 BB (R8500), ATI RV350 AP (R9600),
 ATI RV350SE AQ (R9600SE), ATI RV350 AR (R9600 PRO),
 ATI RV350 NP (M10), ATI R300 AD (R9500), ATI R300 AE (R9500),
 ATI R300 AF (R9500), ATI R300 AG (Fire GL Z1/X1),
 ATI R300 ND (R9700 PRO), ATI R300 NE (R9700/R9500 PRO),
 ATI R300 NF (R9600 TX), ATI R300 NG (Fire GL X1),
 ATI R350SE AH (R9800SE), ATI R350 AK (Fire GL unknown),
 ATI RV350 AT (Fire GL T2), ATI RV350 AU (Fire GL T2),
 ATI RV350 AV (Fire GL T2), ATI RV350 AW (Fire GL T2),
 ATI R350 NH (R9800), ATI R350LE NI (R9800LE), ATI R350 NJ (R9800),
 ATI R350 NK (Fire GL X2), ATI RV350 NT (WS/M10)
(II) Primary Device is: PCI 02:00:0
(WW) fglrx: No matching Device section for instance (BusID PCI:2:0:1) found
(--) Chipset ATI RV350 AR (R9600 PRO) found
C QUOI STE MERDE DE DRIVERS QUE J AI ?  :pt1cable:
n°422548
BlindMan
I am not Avery
Posté le 02-03-2004 à 23:29:31  profilanswer
Les 3.7.1 sortent juste ... mais marchent pô chez moi :pt1cable:
n°422549
Bitman
STAY APART
Posté le 02-03-2004 à 23:31:17  profilanswer
j'ai les fglrx-glc22-4.3.0-3.7.0.i386.rpm
n°422551
BMOTheKill​er
Posté le 02-03-2004 à 23:32:49  profilanswer
/var/log/XFree86.0.log (fichier log du dernier lancement)
/var/log/XFree86.0.log.old (fichier log du lancement précédent)
xdpyinfo | less : pour voir les infos sur X, ça permet de voir les extensions chargées entre autres
n°422553
BMOTheKill​er
Posté le 02-03-2004 à 23:35:27  profilanswer
essaye en commentant la ligne : BusID "PCI:2:0:0"    # vendor=1002, device=4152
n°422554
Bitman
STAY APART
Posté le 02-03-2004 à 23:35:52  profilanswer
un extrait :
number of extensions:    31
    ATIFGLEXTENSION
    ATIFGLRXDRI
    ATITVOUT
    BIG-REQUESTS
    DOUBLE-BUFFER
    DPMS
    Extended-Visual-Information
    FontCache
    GLX
    LBX
    MIT-SCREEN-SAVER
    MIT-SHM
    MIT-SUNDRY-NONSTANDARD
    RANDR
    RENDER
    SECURITY
    SGI-GLX
    SHAPE
    SYNC
    TOG-CUP
    X-Resource
    XC-APPGROUP
    XC-MISC
    XFree86-Bigfont
    XFree86-DRI
    XFree86-Misc
    XFree86-VidModeExtension
    XInputExtension
    XKEYBOARD
    XTEST
    XVideo
default screen number:    0
number of screens:    1
n°422555
Bitman
STAY APART
Posté le 02-03-2004 à 23:36:12  profilanswer
de xfree ? ok je vais essayer ;)
n°422559
Bitman
STAY APART
Posté le 02-03-2004 à 23:40:32  profilanswer
bon ben c pareil, meme log, toujours avec mesa :fou:
Message édité par Bitman le 02-03-2004 à 23:40:44
n°422560
BMOTheKill​er
Posté le 02-03-2004 à 23:40:35  profilanswer
sinon vire aussi les extensions mesa si ce n'est pas correctement fait :
rpm -e XFree86-Mesa-libGL XFree86-Mesa-libGLU
tu as une extension glx en trop là
n°422561
Bitman
STAY APART
Posté le 02-03-2004 à 23:41:50  profilanswer
bitman@localhost bitman]$ rpm -e XFree86-Mesa-libGL
erreur: le paquetage XFree86-Mesa-libGL n'est pas installé
[bitman@localhost bitman]$ rpm -e XFree86-Mesa-libGLU
erreur: Dépendances requises:
        libGLU.so.1 est nécessaire pour (déjà installé) qt-3.1.2-14
        libGLU.so.1 est nécessaire pour (déjà installé) chromium-0.9.12-24
        libGLU.so.1 est nécessaire pour (déjà installé) tuxracer-0.61-23
        libGLU.so.1 est nécessaire pour (déjà installé) XFree86-tools-4.3.0-42
        libGLU.so.1 est nécessaire pour (déjà installé) xscreensaver-4.14-2
        libGLU.so.1 est nécessaire pour (déjà installé) kdeartwork-3.1.4-1
[:bitman]
n°422570
BMOTheKill​er
Posté le 02-03-2004 à 23:53:27  profilanswer
mouai, bon j'ai cherché un howto histoire de recentrer, ça a l'air tout bon ça : http://codenix.net/radeon-howto.html
n°422572
Bitman
STAY APART
Posté le 02-03-2004 à 23:57:01  profilanswer
merci jvais voir ca :)
n°422574
Bitman
STAY APART
Posté le 03-03-2004 à 00:01:13  profilanswer
:/ j'ai déja tout fait en fait ...
n°422580
BMOTheKill​er
Posté le 03-03-2004 à 00:08:19  profilanswer
bon ailleurs j'ai trouvé d'autres éléments...
plutôt pour une 9200, mais là ils installent mesa-gl en fait, je sais plus lequel est bon maintenant [:joce]
http://users.actrix.co.nz/michael/radeon9200.html
sinon ce serait pas mal que tu postes (enfin plutôt un lien vers) tout ton XFree86.0.log histoire de comparer
n°422586
Bitman
STAY APART
Posté le 03-03-2004 à 00:18:42  profilanswer
oué c avec les drivers génériques ca, spa bon  :(
sinon mon log : http://cit.timone.univ-mrs.fr/buseries/XFree86.0.log
 [:bitman]
n°422589
Zzozo
Un peu, passionément, à la fol
Posté le 03-03-2004 à 00:25:10  profilanswer
Tiens, un revenant ... :o
n°422591
Bitman
STAY APART
Posté le 03-03-2004 à 00:27:45  profilanswer
ouep toujours plein d'emmerdes en fait  :cry:
bon rien de touit cela marche ta pas une ID toi ?  :(
n°422592
Zzozo
Posté le 03-03-2004 à 00:30:25  profilanswer
Prendre des vacances ... ca te va comme ID ? :D
Je sors ce qui me passe par la tête ... :o
P.S. : Merde, une réplique que j'ai sentie ... :/
Message édité par Zzozo le 03-03-2004 à 00:30:44
n°422596
Bitman
STAY APART
Posté le 03-03-2004 à 00:35:43  profilanswer
http://victorjr.users.superford.org/pictures/various/owned/hugepelican.jpg
n°422597
BMOTheKill​er
Posté le 03-03-2004 à 00:36:05  profilanswer
bon, l'erreur est là :
(EE) fglrx(0): [agp] unable to acquire AGP, error "xf86_ENOMEM"
(EE) fglrx(0): cannot init AGP
(II) fglrx(0): [drm] removed 1 reserved context for kernel
(II) fglrx(0): [drm] unmapping 8192 bytes of SAREA 0xf8ab9000 at 0xbf502000
(WW) fglrx(0): ***********************************************
(WW) fglrx(0): * DRI initialization failed!                  *
(WW) fglrx(0): * (maybe driver kernel module missing or bad) *
(WW) fglrx(0): * 2D acceleraton available (MMIO)             *
(WW) fglrx(0): * no 3D acceleration available                *
(WW) fglrx(0): ********************************************* *
(à partir de la ligne 764 du log)
 Page :   1  2
Page Précédente
Problème Flash & FireFoxproblème drivers alsa
warning au boot, probleme pci hotplugprobleme d'install mdk 9.2 et knoppix ne boot pas
Probleme avec lilo!Probleme de reconnaissance Modem CT 361 de 9online Mandrake 9.2
Probleme d'install d'un Wifi Linksys Wusb11 2.6problème samba
cups : probleme étrange : no pages found! | resolu : maj de gs-epsProbleme de configuration d'une geforce 2 mx avec debian...
Plus de sujets relatifs à : probleme d'acceleration materielle avec ati 9600 ss fedora
