3543 connectés
  Linux et OS Alternatifs
  Installation
  Probleme de reconnaissance Modem CT 361 de 9online Mandrake 9.2
n°414894
pmousque
L'humanité n'est pas innée
Posté le 22-02-2004 à 02:06:02  profilanswer
Après une semaine de recherche sur les FAQ et Forums je vous livre ce que la doc que j'ai trouve dans le repertoire Linux du disque d'installation 9Online.
je désire comme Gock installer la carte en ethernet dois je suivre tout ou partie de ces indications ???????
pour moi c plutot du chinois
[#5500aa]Beware! To install this USB ADSL Modem Driver, Kernel source is needed.
Open tar ball file(USB_LINUX_ver1.1.3-CT.tar.gz) in where you prefered.
 Ex, ?/root/tar zxvf USB_LINUX_ver1.1.3-CT.tar.gz?
1. Install generic driver
  change directory to ./driver.
  run install $PWD kernel source directory name
   ex, "cd driver; ./install $PWD linux-2.4.7-10"
  ps. kernel source directory name is case sensitive.
2.Install pppoa applet
  change directory to ./pppoa
  run PPP_INSTALL $PWD
   ex, "cd pppoa; ./PPP_INSTALL $PWD"
3.Install third party pppoe client sofware
  download suitable roaring-penguin PPPoE client(RPM package better) from
  "http://www.roaringpenguin.com/pppoe".
  install the PPPoE client software.
  ex, "rpm -Uvh rp-pppoe-3.5-1.i386.rpm"
4.Usage
  a. RFC1483 Bridge Mode
    1. edit /etc/analog/adiusbadsl.conf and change VPI/VCI/
       Encapsulation=(1 or 2) you ISP provided.
       ps. usual Encapsulation of RFC1483 Bridge is 1.
    2. Un-Plug Modem and Re-Plug again.
    3. check ADIModem interface appearing by "ifconfig -a".
       ps. write down the modem's MAC address by the way.
    4. change directory to "/usr/ADI_USB/ADI_LINUX/".
    5. edit "ifcfgeth".
       fill suitable data your ISP provided to this file.
       ps. MACADDR=your modem's MAC address from "ifconfig -a" result.
           "BOOOTPROTO=dhcp" for dynamic address assignment or
           "BOOTPROTO=" for static address assignment.
    6. run "./godhcp ADIModem" for dynamic IP-address assignment.
       run "./gostatic ADIModem aa.bb.cc.dd xxx.xxx.xxx.xxx" for
       static IP-address assignment.
       ps. "aa.bb.cc.dd" is IP-address your ISP assigned for you.
           "xxx.xxx.xxx.xxx is Netmask you ISP recommended.
  b.RFC 1483 Route Mode
       Encapsulation=(3 or 4) you ISP provided.
       ps. usual Encapsulation of RFC1483 Router is 3.
    5. edit "ifcfgeth".
  c.PPPoA Mode
       Encapsulation=(5 or 6) you ISP provided.
       ps. usual Encapsulation of PPPoA is 6.
    3. change directory to "/usr/ADI_USB/ADI_PPPOA/PPP_CONF".
    4. edit "options", "pap-secrets", "chap-secrets".
       fill suitable user-name and password your ISP provided to these
       files and copy these files to "/etc/ppp/".
       ps. user-name in "options" must be identical to user-name field in
           "pap-secrets" and "chap-secrets".
    5. run ADI_PPP_Go.
    6. if "ppp0" appeared in "ifconfig" result, pppoa connected.
  d.PPPoE Mode
       ps. usual Encapsulation of PPPoE is 1.
    3. Be sure that Roaring Penguin PPPoE client have installed in you system.
    4. run adsl_setup to input your user-name ,password, and Ethernet interface        applied PPPoE service.
      ps. in our case you should input "ADIModem" for PPPoE Ethernet interface.
    5. if "ppp0" appeared in "ifconfig" result, pppoe connected.
[#8d0071]Au secours
A nous de commencer le monde que l'on souhaite à nos prochains.
n°415045
Mjules
Parle dans le vide
Posté le 22-02-2004 à 11:02:49  profilanswer
tu branches ton modem en ethernet
tu installes rp-pppoe (urpmi rp-pppoe)
puis adsl-setup
puis adsl-start
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
n°415125
pmousque
Posté le 22-02-2004 à 13:00:40  profilanswer
j'ai déja croisé cette proposition de solution en ligne,
voici les réponses en console SU :
# urpmi rp-pppoe
Tout est déja installé
# adsl-setup
j'ai même récupéré les DNS de 9online bien sur non fourni sur le cd d'installation mais ici "http://www.9online.fr/EspaceAbonnes/assistance/2b.asp"
# adsl-start
"la led ADSL TX/RX du modem scintille par trois fois puis :"
............... TIMED OUT
/usr/sbin/adsl-start : line 194: 3200 terminated       $CONNECT "$@" >/dev/null 2>&1
# ifconfig
eth0      Lien encap:Ethernet  HWaddr 00:50:BA:F4:DF:3D
          inet adr:10.0.0.10  Bcast:10.0.0.255  Masque:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:327 errors:0 dropped:0 overruns:0 frame:0
          TX packets:351 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 lg file transmission:100
          RX bytes:19860 (19.3 Kb)  TX bytes:22602 (22.0 Kb)
          Interruption:5 Adresse de base:0x9000
lo        Lien encap:Boucle locale
          inet adr:127.0.0.1  Masque:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:70 errors:0 dropped:0 overruns:0 frame:0
          TX packets:70 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 lg file transmission:0
          RX bytes:4594 (4.4 Kb)  TX bytes:4594 (4.4 Kb)
Voila cela fait 1 semaine que j'en suis la.
Il est hors de question que je reinstalle XP que j'utilise bien assez sur mon portable et les ordinateurs de mon boulot.
J'ai croise pas mal de post de personne qui comme Gock et moi qui galérent avec la config 9telecom mais pas encore de post d'installation je m'engage à le réaliser si je trouve la solution avant de me décider de changer de provider.
Merci d'avance de votre compréhention
n°415132
Mjules
Parle dans le vide
Posté le 22-02-2004 à 13:06:43  profilanswer
combien as tu de carte réseau ?
si tu n'en as qu'une alors ce n'est pas normal que eth0 ai une IP
le timeout n'est pas un pb, quelquefois quand j'ai du mal à me connecter, rp-pppoe se met en timeout mais ça ne l'empêche pas de rééssayer jusqu'à ce qu'il y arrive.
ouvres une console, passes en root et tapes :
tail -f /var/log/messages
ça te permettra de voir en direct ce qu'il se passe
Message édité par Mjules le 22-02-2004 à 13:07:26
n°415240
pmousque
Posté le 22-02-2004 à 14:12:11  profilanswer
Merci Mjules de jeter un oeil sur mon prob :
J'ai une carte reseau D_Link que j'ai rajouté quand j'ai vu que la led du modem ne semblait pas répondre sur le port RJ de mon ASUS A7N8X-X.
Voila pour le tail :
[root@grandmouss papamouss]# tail -f /var/log/messages
Feb 23 13:01:00 grandmouss msec: changed mode of /var/log/wtmp from 664 to 640
Feb 23 13:01:00 grandmouss msec: changed group of /var/log/wtmp from utmp to adm
Feb 23 13:01:00 grandmouss msec: changed mode of /var/log/XFree86.0.log from 644 to 640
Feb 23 13:01:00 grandmouss msec: changed group of /var/log/XFree86.0.log from root to adm
Feb 23 13:01:00 grandmouss msec: changed mode of /var/log/urpmi.log from 644 to 640
Feb 23 13:01:00 grandmouss msec: changed group of /var/log/urpmi.log from root to adm
Feb 23 13:01:00 grandmouss msec: changed mode of /var/log/ksyms.0 from 644 to 640
Feb 23 13:01:00 grandmouss msec: changed group of /var/log/ksyms.0 from root to adm
Feb 23 13:53:12 grandmouss kernel: eth0: Link changed: 100Mbps, full duplex
Feb 23 13:53:15 grandmouss kernel: eth0: Link changed: 10Mbps, half duplex
Feb 23 13:55:12 grandmouss kernel: eth0: Link changed: 10Mbps, half duplex
Feb 23 13:55:13 grandmouss kernel: eth0: Link changed: 100Mbps, full duplex
"et la console c arreté j'ai du sortir par Ctrl-C"
n°415272
Mjules
Parle dans le vide
Posté le 22-02-2004 à 14:32:15  profilanswer
non, faut pas l'arrêter ;) c'est le log en direct ; tu la mets dans un coin, tu lances ta connexion et tu vois ce qu'il te dit
n°416221
pmousque
Posté le 23-02-2004 à 20:28:45  profilanswer
 :bounce: je dois admettre que c noeud de ma part de ne pas l'avoir compris
Bon voila j'ai retrouve une interface graphique apres 5 reinstall complete depuis mon dernier post (vive gnome, KDE veut rien savoir).
Donc le tail donne ca :
[papamouss@localhost papamouss]$ su
Password:
[root@localhost papamouss]# tail -f /var/log/messages
Feb 24 19:24:30 localhost pppd[2256]: pppd 2.4.1 started by root, uid 0
Feb 24 19:24:30 localhost pppd[2256]: Using interface ppp0
Feb 24 19:24:30 localhost pppd[2256]: Connect: ppp0 <--> /dev/pts/1
Feb 24 19:24:30 localhost /etc/hotplug/net.agent: assuming ppp0 is already up
fév 24 19:24:50 localhost su(pam_unix)[2383]: session opened for user root by papamouss(uid=501)
Feb 24 19:25:01 localhost pppd[2256]: LCP: timeout sending Config-Requests
Feb 24 19:25:01 localhost pppd[2256]: Connection terminated.
Feb 24 19:25:01 localhost /etc/hotplug/net.agent: NET unregister event not supported
Feb 24 19:25:05 localhost pppoe[2257]: Timeout waiting for PADO packets
Feb 24 19:25:05 localhost pppd[2256]: Exit.
"la je debranche l'usb du modem qui le relit a mon portable XP qui me permet de communiquer et je relance"
Feb 24 19:25:58 localhost pppd[2559]: pppd 2.4.1 started by root, uid 0
Feb 24 19:25:58 localhost pppd[2559]: Using interface ppp0
Feb 24 19:25:58 localhost pppd[2559]: Connect: ppp0 <--> /dev/pts/1
Feb 24 19:25:58 localhost /etc/hotplug/net.agent: assuming ppp0 is already up
Feb 24 19:26:29 localhost pppd[2559]: LCP: timeout sending Config-Requests
Feb 24 19:26:29 localhost pppd[2559]: Connection terminated.
Feb 24 19:26:29 localhost /etc/hotplug/net.agent: NET unregister event not supported
Feb 24 19:26:33 localhost pppoe[2560]: Timeout waiting for PADO packets
Feb 24 19:26:33 localhost pppd[2559]: Exit.
"j'eteind et rallume le modem en le laissant relie a mon pc par RJ"
Feb 24 19:26:45 localhost pppd[2792]: pppd 2.4.1 started by root, uid 0
Feb 24 19:26:45 localhost pppd[2792]: Using interface ppp0
Feb 24 19:26:45 localhost pppd[2792]: Connect: ppp0 <--> /dev/pts/1
Feb 24 19:26:45 localhost /etc/hotplug/net.agent: assuming ppp0 is already up
Feb 24 19:27:16 localhost pppd[2792]: LCP: timeout sending Config-Requests
Feb 24 19:27:16 localhost pppd[2792]: Connection terminated.
Feb 24 19:27:16 localhost /etc/hotplug/net.agent: NET unregister event not supported
Feb 24 19:27:20 localhost pppoe[2793]: Timeout waiting for PADO packets
Feb 24 19:27:20 localhost pppd[2792]: Exit.
Feb 24 19:27:23 localhost kernel: eth0: Link changed: 100Mbps, full duplex
Feb 24 19:27:26 localhost kernel: eth0: Link changed: 10Mbps, half duplex
Feb 24 19:27:30 localhost pppd[3025]: pppd 2.4.1 started by root, uid 0
Feb 24 19:27:30 localhost pppd[3025]: Using interface ppp0
Feb 24 19:27:30 localhost pppd[3025]: Connect: ppp0 <--> /dev/pts/1
Feb 24 19:27:30 localhost /etc/hotplug/net.agent: assuming ppp0 is already up
Feb 24 19:28:01 localhost pppd[3025]: LCP: timeout sending Config-Requests
Feb 24 19:28:01 localhost pppd[3025]: Connection terminated.
Feb 24 19:28:01 localhost /etc/hotplug/net.agent: NET unregister event not supported
Feb 24 19:28:05 localhost pppoe[3026]: Timeout waiting for PADO packets
Feb 24 19:28:05 localhost pppd[3025]: Exit.
 :??:  j'ai pas l'impression que ca avance le schimblick
n°416231
Mjules
Parle dans le vide
Posté le 23-02-2004 à 20:44:12  profilanswer
j'avais ce genre de message quand je n'arrivais pas à accéder à mon modem à cause d'un câble du muvais type (croisé alors qu'il fallait un droit dans mon cas)
n°416284
pmousque
Posté le 23-02-2004 à 21:35:29  profilanswer
Pourtant c le cable livré avec le modem qui etait branché
Ca va j'en ai 2 autres,
Avec le premier ca donne :
Feb 24 21:09:05 localhost pppd[3886]: Connect: ppp0 <--> /dev/pts/1
Feb 24 21:09:05 localhost /etc/hotplug/net.agent: assuming ppp0 is already up
Feb 24 21:09:05 localhost pppoe[3887]: PPP session is 6767
Feb 24 21:09:06 localhost pppd[3886]: CHAP authentication failed
Feb 24 21:09:06 localhost pppd[3886]: Connection terminated.
Feb 24 21:09:06 localhost pppoe[3887]: read (asyncReadFromPPP): Session 6767: Input/output error
Feb 24 21:09:06 localhost pppoe[3887]: Sent PADT
Feb 24 21:09:06 localhost pppd[3886]: Exit.
f?v 24 21:09:06 localhost adsl-connect: ADSL connection lost; attempting re-connection.
Feb 24 21:09:06 localhost /etc/hotplug/net.agent: NET unregister event not supported
Feb 24 21:09:36 localhost pppd[3951]: pppd 2.4.1 started by root, uid 0
Feb 24 21:09:36 localhost pppd[3951]: Using interface ppp0
Feb 24 21:09:36 localhost pppd[3951]: Connect: ppp0 <--> /dev/pts/1
Feb 24 21:09:36 localhost /etc/hotplug/net.agent: assuming ppp0 is already up
Feb 24 21:09:36 localhost pppoe[3952]: PPP session is 6770
Feb 24 21:09:36 localhost pppd[3951]: CHAP authentication failed
Feb 24 21:09:36 localhost pppd[3951]: Connection terminated.
Feb 24 21:09:36 localhost pppoe[3952]: read (asyncReadFromPPP): Session 6770: Input/output error
Feb 24 21:09:36 localhost pppoe[3952]: Sent PADT
Feb 24 21:09:36 localhost pppd[3951]: Exit.
et le second :
Feb 24 21:10:05 localhost pppoe[4187]: PPP session is 6776
Feb 24 21:10:05 localhost pppd[4186]: CHAP authentication failed
Feb 24 21:10:05 localhost pppd[4186]: Connection terminated.
Feb 24 21:10:05 localhost pppoe[4187]: read (asyncReadFromPPP): Session 6776: Input/output error
Feb 24 21:10:05 localhost pppoe[4187]: Sent PADT
Feb 24 21:10:05 localhost pppd[4186]: Exit.
f?v 24 21:10:05 localhost adsl-connect: ADSL connection lost; attempting re-connection.
Feb 24 21:10:05 localhost /etc/hotplug/net.agent: NET unregister event not supported
Feb 24 21:17:37 localhost kernel: sr0: mmc-3 profile: Ah
Feb 24 21:18:37 localhost kernel: eth0: Link changed: 10Mbps, half duplex
Feb 24 21:21:11 localhost pppd[4254]: pppd 2.4.1 started by root, uid 0
Feb 24 21:21:11 localhost pppd[4254]: Using interface ppp0
Feb 24 21:21:11 localhost pppd[4254]: Connect: ppp0 <--> /dev/pts/1
Feb 24 21:21:11 localhost /etc/hotplug/net.agent: assuming ppp0 is already up
Feb 24 21:21:42 localhost pppd[4254]: LCP: timeout sending Config-Requests
Feb 24 21:21:42 localhost pppd[4254]: Connection terminated.
Feb 24 21:21:42 localhost /etc/hotplug/net.agent: NET unregister event not supported
Feb 24 21:21:46 localhost pppoe[4255]: Timeout waiting for PADO packets
Feb 24 21:21:46 localhost pppd[4254]: Exit.
En fait je devrai peut etre essaye de parametre un reseau entre mon portable et le pc pour verifie la carte non ?
(et puis ce serai plus simple pour transferer les fichiers TXT que via cdrw)
n°416290
Mjules
Parle dans le vide
Posté le 23-02-2004 à 21:38:43  profilanswer
là avec les 2 autres câbles, c'est au niveau de l'authentification que ça foire donc ça veut dire que tu arrives jusqu'au serveur du FAI.
il faut que tu vérifies/corriges le fichier /etc/ppp/chap-secrets (et probablement aussi pap-secrets)
syntaxe :
'login' * 'mot de passe' *
n°416305
pmousque
Posté le 23-02-2004 à 22:08:08  profilanswer
En fait j'ai regardé la config windows dont on ne voit rien à l'install et l'authentification ne conrespondait pas a celle que j'employai (celle de mon ancienne connection par modem analogique).
Et apres 4 min d'attente (à 30 cts/m)sur la hotline de 9TELECOM j'ai eu confirmation que c'etait pas la meme mais une générique que je vous livre "pn25-4ak8@9onlineadsl512.ipadsl" dont il ne parle meme pas sur le lien que j'ai precedemment livre ici.
Donc je reconfigure mon adsl-setup et je vous tiens au courant
  Installation
Probleme d'install d'un Wifi Linksys Wusb11 2.6Ati 9800se all in wonder @ 9800 pro et mandrake 9.1 pour un newbee
problème sambaProblem de routeur /Modem adsl NetgearDM602 config usb
Mandrake MNF refus connection dès install ( ca c de l'os ! :( )Mandrake 9.1: mon modem Sagem 800 se synchro mais se connecte pas...
cups : probleme étrange : no pages found! | resolu : maj de gs-epsProbleme de configuration d'une geforce 2 mx avec debian...
Kel paramètres mettre pr config le modem en net install?
Plus de sujets relatifs à : Probleme de reconnaissance Modem CT 361 de 9online Mandrake 9.2
