3661 connectés
  Linux et OS Alternatifs
  prism intersilGT install firmware reussie (suse10) mais conecte pas
n°812335
optimisteo
oh god, do my eyes deceive me?
Posté le 23-05-2006 à 16:28:28  profilanswer
Bonjour
Je suis sous suse 10
il y a un probleme lors de la supposee install automatique par yast du firmware.
vous pouvez lire le detail ici
http://prism54.org/punbb/viewtopic.php?pid=6472#p6472
J'ai reussi a le faire a la main.
Maintenant les led clignottent mais sans reussir a connecter a mon access point.
voici ce que dmsg donne
kjournald starting.  Commit interval 5 seconds
EXT3 FS on hda1, internal journal
EXT3-fs: mounted filesystem with ordered data mode.
SFW2-INext-DROP-DEFLT IN=eth0 OUT= MAC= SRC=192.168.1.101 DST=224.0.0.251 LEN=73  TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=53
SFW2-INext-DROP-DEFLT IN=eth0 OUT= MAC= SRC=192.168.1.101 DST=224.0.0.251 LEN=10 7 TOS=0x00 PREC=0x00 TTL=255 ID=4 DF PROTO=UDP SPT=5353 DPT=5353 LEN=87
eth1: timeout waiting for mgmt response 250, triggering device
eth1: islpci_close ()
prism54_hostapd - len=48
eth1: Caught WPA supplicant wpa init request
eth1: Caught WPA drop unencrypted request
eth1: resetting device...
eth1: uploading firmware...
eth1: firmware version: 1.0.4.3
eth1: firmware upload complete
eth1: interface reset complete
eth1: Enabling WPA
eth1: no IPv6 routers present
e100: eth0: e100_watchdog: link up, 100Mbps, full-duplex
eth0: no IPv6 routers present
eth1: timeout waiting for mgmt response 225, triggering device
SFW2-INext-DROP-DEFLT IN=eth0 OUT= MAC= SRC=192.168.1.101 DST=224.0.0.251 LEN=73  TOS=0x00 PREC=0x00 TTL=255 ID=1 DF PROTO=UDP SPT=5353 DPT=5353 LEN=53
SFW2-INext-DROP-DEFLT IN=eth0 OUT= MAC= SRC=192.168.1.101 DST=224.0.0.251 LEN=73  TOS=0x00 PREC=0x00 TTL=255 ID=2 DF PROTO=UDP SPT=5353 DPT=5353 LEN=53
SFW2-INext-DROP-DEFLT IN=eth0 OUT= MAC= SRC=192.168.1.101 DST=224.0.0.251 LEN=10 7 TOS=0x00 PREC=0x00 TTL=255 ID=3 DF PROTO=UDP SPT=5353 DPT=5353 LEN=87
aussi jai une erreur au demarrage comme quoi eth1 n'a pas pu etre mise 'up'
voila
Comment savoir ce qui pose probleme?
merci de votre aide.
Opti
Message édité par optimisteo le 23-05-2006 à 16:31:02
Cherche du boulot sur Paris comme ingé sécu - cryptographie
n°812491
Riot
Buy me a riot
Posté le 23-05-2006 à 21:15:15  profilanswer
Hello, moi aussi j'utilise le driver prism54 avec ma carte wifi (netgear WG511).
Je trouve plusieures choses bizarres dans ton log :
1- je vois que tu utilises wpa_supplicant,
2- je vois prism54_hostapd
3- tu utilises le WPA
1-> Dans un premier temps, tu devrais te connecter "à la main" avec les wireless-tools : 'iwconfig <ton_interface> essid <le_nom_de_ton_AP>'. Puis tu récupères ton IP (soit en static, soit avec un client dhcp).
2-> hostapd sert à transformer ta carte en AP, or je ne crois pas que ce soit ce que tu veuilles.
3-> voir avec le point 1- : dans un premier temps, ne pas essayer de faire marcher ta carte avec du WEP ou du WPA; procède étape par étape.
De plus, le driver WPA ne supporte pas le WPA.
Bon courage.
Message édité par Riot le 23-05-2006 à 21:16:38
n°813187
optimisteo
Posté le 25-05-2006 à 20:31:17  profilanswer
Salut merci de ta reponse.
C'est vrai j'avoue j'utilise wpa supplicant car mon probleme majeur est d'avoir acces a mon reseau wifi crypte en wpa)
avec autre chose que windows.Biensur je ne veux pas downgrader la securite de mon wifi (wardriving...)
Je voudrais bien y aller a la mano, mais je ne crois pas avoir les wireless-tools ni iwconfig (teste en terminal)
je n'ai pas non plus installe host ap ni configure l'interface reseau dans ce but... donc je ne sais pas ce qu'il fait la.
Je vais effectivement essayer sans wpa ce week end mais je ne peux pas le faire pour l'instant car je ne suis pas seul a utiliser internet donc je ne peux pas rebooter le routeur ni changer les settings quand les autres sont la...
Que veux tu dire par le driver wpa ne supporte pas le wpa?
N'y a t'il aucun moyen d'utiliser wpa avec linux?? :((
Merci encore
et a++
Opti
Bon courage.
n°815452
optimisteo
Posté le 01-06-2006 à 22:02:14  profilanswer
alors, pas de wpa avec linux possible?
n°815594
Riot
Buy me a riot
Posté le 02-06-2006 à 13:15:07  profilanswer
Pardon ... je voulais dire que le driver prism54 ne supporte pas le WPA (pour l'instant).
Si tu veux absolument avoir le WPA avec cette carte, il te fait utiliser le driver non-libre ndiswrapper.
Install FreeBSDEcran noir + Erreur à l'install de la FC5 [resolved]
Script de demarrage wlan0 sous Suse10install+config wifi chip atheros sous debian sarge
Installation logiciel sur redhat 9 à partir des cdroom d'install.Intersil Prism PCI WLAN driver
PIII 733 - Install Linux pour débutant ?!Mandrake 10.1 install mais pas de liloo
install debian sarge par reseauprob install rpm
Plus de sujets relatifs à : prism intersilGT install firmware reussie (suse10) mais conecte pas
