6362 connectés
  Linux et OS Alternatifs
  Débats
  Probleme avec gmplayer ss mdk 9 (résolu)
n°186428
Bitman
STAY APART
Posté le 10-11-2002 à 08:48:47  profilanswer
j'ai recup les sources, j'ai compilé, installé, mplayer marche correctement (mais j'ai pas de commandes au clavier) mais impossible de lancer gmplayer pourtant j'ai mis l'option enable--GUI a la compilation...
au lancement j'ai ceci :
Code :
  1. Using GNU internationalization
  2. Original domain: messages
  3. Original dirname: /usr/share/locale
  4. Current domain: mplayer
  5. Current dirname: /usr/local/share/locale
  6. MPlayer 0.90pre9-3.2 (C) 2000-2002 Arpad Gereoffy (see DOCS)
  7. CPU: Advanced Micro Devices Athlon 4 PM Palomino/Athlon MP Multiprocessor/Athlon
  8. XP eXtreme Performance (Family: 6, Stepping: 2)
  9. CPUflags:  MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 0
  10. Compiled for x86 CPU with extensions: MMX MMX2 3DNow 3DNowEx SSE
  11. [cfg] read config file: /home/bitman/.mplayer/gui.conf
  12. Xlib:  extension "XFree86-VidModeExtension" missing on display ":0.0".
  13. vo: X11 running at 1024x768 with depth 24 and 32 bpp (":0.0" => local display)
  14. Reading /home/bitman/.mplayer/codecs.conf: can't open '/home/bitman/.mplayer/cod              ecs.conf': No such file or directory
  15. Reading /usr/local/etc/mplayer/codecs.conf: 38 audio & 110 video codecs
  16. font: can't open file: /home/bitman/.mplayer/font/font.desc
  17. font: can't open file: /usr/local/share/mplayer/font/font.desc
  18. Linux RTC init error in ioctl (rtc_irqp_set 1024): Permission denied
  19. Try adding "echo 1024 > /proc/sys/dev/rtc/max-user-freq" to your system startup               scripts.
  20. Using usleep() timing
  21. Can't open input config file /home/bitman/.mplayer/input.conf : No such file or               directory
  22. Can't open input config file /usr/local/etc/mplayer/input.conf : No such file or               directory
  23. Falling back on default (hardcoded) input config
  24. Gdk-ERROR **: BadWindow (invalid Window parameter)
  25.   serial 166 error_code 3 request_code 20 minor_code 0
que faire ?
Message édité par Bitman le 14-11-2002 à 08:35:24
n°186436
Mr YouP
-- le crayon et le clavier --
Posté le 10-11-2002 à 10:20:27  profilanswer
il te manque peut-être une librairie gtk-devel ou un truc du même gout...
n°186454
Bitman
STAY APART
Posté le 10-11-2002 à 11:04:07  profilanswer
[:bresse] je pense pas ca c installé correctement...
par contre qqun peut m'expliquer ca :
et ca :
n°186465
the_fireba​ll
I have fucking failed
Posté le 10-11-2002 à 11:17:13  profilanswer
Deja tu devrais corriger toutes les petites merdes que tu as, à savoir :
* il ne trouve pas les fonts pour la gui, fauidrait les installer soit dans /home/bitman/.mplayer/font/ soit dans /usr/local/share/mplayer/font/
* Pour le RTC, laisse tomber ou change les droit sur /dev/rtc en jouant avec les users/groupes
* il ne trouve pas le fichier inout.conf. Ce n'est pas grave mais normalement, il devrait etre la
Voila corrige toutes ses petites erreurs, et on verra si ton erreur grave n'est pas une conséquence de celles la
Two thousand years of misery, of torture in my name, hypocrisy made paramount, paranoia the law, my name is called religion, sadistic, sacred whore.
n°186466
the_fireba​ll
Posté le 10-11-2002 à 11:19:21  profilanswer
et ca :
Ben il te manque l'extension XVIDEO, donc la lecture des films va  etre un peu molle :D  Tu as quelle carte video pour avoir ce message ???
Pour le 1024, il te dit juste que dans un souci d'optimisation, tu pourrais mettre cette valeur dans le fichier /proc/sys/dev/rtc/max-user-freq, mais je ne sais pas pq :)
n°186469
Bitman
STAY APART
Posté le 10-11-2002 à 11:32:48  profilanswer
j'ai une GF4 4200  :D (avec les drivers installés)
pour les ptites merde ok je veux bien les résoudres mais les fontes sont déja dans usr/ machin ...  :(
Message édité par Bitman le 10-11-2002 à 11:33:02
n°186489
e_esprit
Posté le 10-11-2002 à 12:36:48  profilanswer
T'aurais pas ca dans ton fichier XF86Config par hasard :
Option "DisableVidModeExtension" "true"
parce que sinan...
n°186506
Tux Le Pen​guin
Posté le 10-11-2002 à 13:57:50  profilanswer
nan mais laisse tomber ça, c'est pas méchant
par contre, regarde effectivement si tu n'as pas une options qui désactive le vidmode
et dis moi, tu lance bien gmplayer depuis l'utilisateur propriétaire de te session X ?
n°186640
Bitman
STAY APART
Posté le 10-11-2002 à 17:50:04  profilanswer
le msg plus haut c qd je lance a partir d'un shell
sinon je le lance en auto avec konqueror, comme xine etc quoi, en association de fichiers
n°188280
lucaramel
Posté le 13-11-2002 à 00:47:13  profilanswer
Pourquoi ne pas installer la paquet du PLF ?
n°188282
Bitman
STAY APART
Posté le 13-11-2002 à 00:52:33  profilanswer
paske je n'ai aucune idée de ce que ca peut etre  :lol:
n°188407
e_esprit
Posté le 13-11-2002 à 09:44:22  profilanswer
T'as pas repondu a ma question pour ta config XFree...
n°188410
houplaboom​42
Posté le 13-11-2002 à 09:45:30  profilanswer
-> http://plf.zarb.org
n°188444
Bitman
STAY APART
Posté le 13-11-2002 à 11:28:47  profilanswer
sorry esprit, apres verif mon xfree etait comme il faut :D
hum apres un petit format pour cause d'acces au net impossible et irrésolvable (pour moi), j'ai repris l'install au départ en créant le fichier win32 des codecs AVANT de compiler le jambon, ca marche nickel  :D en root
par contre en user j'ai ca :
Failed to open /dev/rtc: Permission denied (mplayer should be setuid root or /dev/rtc should be readable by the user.)
ca a pas l'air bien méchant, si ce n'est que je ne sais pas quelle est la meilleure solution (ni comment le faire a vrai dire hihihi)
vous avez fait quoi vous autres ? :o
Message édité par Bitman le 13-11-2002 à 11:29:53
n°188448
e_esprit
Posté le 13-11-2002 à 11:39:41  profilanswer
tu fais "ls -l /dev/rtc" pour savoir a quel groupe il appartient, et tu ajoutes ton user dans le groupe en question.
Ca devrait faire l'affaire.
n°188456
Bitman
STAY APART
Posté le 13-11-2002 à 12:01:36  profilanswer
il appartiens a root, donc je me suis mis root en groupe supplémentaire pour "bitman" mais c pareil :/
edit : pas tout a fais le msg a change :
probleme résolu ! --> [root@bitmachine rtc]# echo 1024 > max-user-freq  :bounce:
oups pas résolu en fait gt resté en roor [:rougit]
je crois que gmplayer n'arrive pas a acceder aux rep de conf par défaut, il me cherche tout dans /home/bitman/.mplayer
Message édité par Bitman le 13-11-2002 à 12:25:31
n°188479
littlebobo​y
Posté le 13-11-2002 à 12:30:23  profilanswer
dans ce cas tu ruses en copiant les fichiers qui vont bien ou il faut :D
n°188482
zeb2
aka libredr
Posté le 13-11-2002 à 12:35:24  profilanswer
Oui, installe le PLF media, tu en auras besoin si un jour tu veux compresser des DVD en mpeg4.
urpmi.addmedia plf... etc c'est sur leur site.
n°188506
Bitman
STAY APART
Posté le 13-11-2002 à 13:11:35  profilanswer
j'ai urpmi le plf, mais a vrai dire j'ai pas top compris a quoi ca servais [:le kneu]
n°188520
gm_superst​ar
Appelez-moi Super
Posté le 13-11-2002 à 13:58:47  profilanswer
A ajouter une source de paquets pour urpmi.
PLF te donne accès à ces paquets :
Here you will find some package that cannot be included into the Mandrake distro for legal reasons (copyright/license/patent).
dont mplayer.
Donc commence par désinstaller ton mplayer foireux puis tu fais un :
urpmi mplayer-gui mplayer-fonts
Message édité par gm_superstar le 13-11-2002 à 13:59:59
Incongru : une FAQ abandonnée sur les Standards du Web - FAQ périmée de blabla@Prog
n°188832
Bitman
STAY APART
Posté le 13-11-2002 à 21:50:08  profilanswer
heuu l'est pas foireux mon mplayer  :cry:
cai juste qu'il marche ken root ! ca peut avoir un rapport avec le fait que j'ai tous fais en root pour l'install ?
n°188838
Tux Le Pen​guin
Posté le 13-11-2002 à 21:52:55  profilanswer
:pfff:
n°188840
Tux Le Pen​guin
Posté le 13-11-2002 à 21:54:23  profilanswer
lol !  :lol:
mais les releases se suivent à un rythme efreiné ces temps ci  :D
aller hop, une petite install de mplayer
n°188843
Bitman
STAY APART
Posté le 13-11-2002 à 21:57:54  profilanswer
huummmm la question a 10.000 ?
je sais installer compiler ca va c pas dur, mais...désinstaller je fais comment ?  [:totoz]
ou alors je urpmise par dessus mais c la mdk 9 j'ai peur que ca merde (ya plein de rpm qui chibrent avec ste distro non ?)
n°188856
gm_superst​ar
Appelez-moi Super
Posté le 13-11-2002 à 22:17:46  profilanswer
make uninstall ?
Sinon tout ce qui est installé est normalement dans /usr/local/ donc il te suffira de regarder ce qu'il y a dans les sous-répertoires, et supprimer à la main ce que mplayer a mis...
n°188859
Bitman
STAY APART
Posté le 13-11-2002 à 22:24:31  profilanswer
c'est tout ? :o
n°188910
Bitman
STAY APART
Posté le 13-11-2002 à 23:05:41  profilanswer
L'installation a échoué:
        libdv2 est nécessaire à mplayer-0.90-0.pre9.3plf
        libggi2 est nécessaire à mplayer-0.90-0.pre9.3plf
        libgii0 est nécessaire à mplayer-0.90-0.pre9.3plf
        libdv.so.2 est nécessaire à mplayer-0.90-0.pre9.3plf
        libggi.so.2 est nécessaire à mplayer-0.90-0.pre9.3plf
        libgg.so.0 est nécessaire à mplayer-0.90-0.pre9.3plf
        libgii.so.0 est nécessaire à mplayer-0.90-0.pre9.3plf
        liblzo.so.1 est nécessaire à mplayer-0.90-0.pre9.3plf
[root@bitmachine mplayer]#
génial non ?  :lol:
je suppose kil existe une fonction pour savoir quel paquet installer pour avoir des libs non ?
urpmi m'a DL ceci :
libdha0.1-0.90-0.pre9.3plf.i586.rpm  mplayer-fonts-1.0-3plf.noarch.rpm
libfaad2_0-1.1-2plf.i586.rpm         mplayer-gui-0.90-0.pre9.3plf.i586.rpm
liblirc0-0.6.5-2mdk.i586.rpm         mplayer-skins-1.3-1plf.noarch.rpm
libmad0-0.14.2b-4mdk.i586.rpm        win32-codecs-1.0-1plf.i586.rpm
libnas2-1.6-1mdk.i586.rpm            xvid-20021107-1plf.i586.rpm
mplayer-0.90-0.pre9.3plf.i586.rpm
j'ai installé toutes les libs, le xvid, nickel, mais le mplayer y veut pas  :(
Message édité par Bitman le 13-11-2002 à 23:12:01
n°188924
gm_superst​ar
Appelez-moi Super
Posté le 13-11-2002 à 23:16:23  profilanswer
Tu dois installer une source pour les contribs aussi :
urpmi.addmedia contrib ftp://ftp.lip6.fr/pub/linux/distr [...] ntrib/RPMS with ../../i586/Mandrake/base/hdlist2.cz
et tu refais urpmi mplayer-gui il te téléchargera les paquets qui manquent.
n°188934
Bitman
STAY APART
Posté le 13-11-2002 à 23:40:24  profilanswer
en effet il m'a téléchargé des trucs en plus, mplayer etc c'est installé comme il faut, il marche nickel en root, et ca foire encore en user ...  :cry:
CPU: Advanced Micro Devices Athlon 4 PM Palomino/Athlon MP Multiprocessor/Athlon XP eXtreme Performance (Family: 6, Stepping: 2)
Reading /home/bitman/.mplayer/codecs.conf: can't open '/home/bitman/.mplayer/codecs.conf': No such file or directory
Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
Using Linux hardware RTC timing (1024Hz)
SKIN dir 1: '/home/bitman/.mplayer/Skin'
SKIN dir 2: '/usr/local/share/mplayer/Skin'
[skin] error in skin config file on line 10: file not found ( /usr/local/share/mplayer/Skin/default/main )
Skin configfile read error ( default ).
[bitman@bitmachine bitman]$
fo que je lui donne des permission je crois, paskil arrive pas a lire/ecrire dans mon ./mplayer non ?
Message édité par Bitman le 13-11-2002 à 23:44:56
n°188938
Bitman
STAY APART
Posté le 13-11-2002 à 23:54:59  profilanswer
derniere information : en lisant mes fichiers avec mplayer, ca lance le gui aussi, donc j'oublie le mystere des gmplayer pour l'instant  :o
merci a ceux qui m'ont proposé leur aide ! :bounce:
n°188941
gm_superst​ar
Appelez-moi Super
Posté le 13-11-2002 à 23:59:29  profilanswer
n°188943
Bitman
STAY APART
Posté le 14-11-2002 à 00:03:39  profilanswer
gm_superstar a écrit a écrit :
urpmi mplayer-skins ?
ils y sont (sont moches d'ailleurs hihihi)
n°188952
gm_superst​ar
Appelez-moi Super
Posté le 14-11-2002 à 00:22:03  profilanswer
Bon en fait tu dois modifier ton fichier de config et remplacer toutes les occurences de /usr/local/share par /usr/share/
n°188961
lucaramel
Posté le 14-11-2002 à 00:50:50  profilanswer
Essaie Proton alors.
n°188963
Bitman
STAY APART
Posté le 14-11-2002 à 01:01:05  profilanswer
cai celle que j'ai choisie  :)
zoli player mplayer, mieux que xine je trouve, meme si j'en ai chié un peu pour l'installer :/
n°189001
calvaire31​8
Posté le 14-11-2002 à 08:17:21  profilanswer
j'ai eu le meme probleme ,
Il a suffit que je fasse
chmod -R 755 /usr/local/share/mplayer/
n°189002
Bitman
STAY APART
Posté le 14-11-2002 à 08:21:59  profilanswer
argh la solution au moment ou j'en avait plus besoin !!!!  :D
  Débats
Léger Problème smbmountUtilisation de GProFTPD (GUI - proftpd) - Problème de Users
big probleme avec la commande "mount_cd9660" helpppprobleme avec rpmbuild
[Help] probleme complique [squid]Probleme, de dynamic DNS !
Probleme pour eteindre le pc avec HALTPas de télé sur Pinnacle PCTV/Rave (RESOLU ! )
Probleme de login en rootProblème réseau avec RH8. Des experts?
Plus de sujets relatifs à : Probleme avec gmplayer ss mdk 9 (résolu)
