11962 connectés
  Hardware - Périphériques
  Divers
  problem avec graveur
n°67158
james2003
Posté le 04-06-2004 à 21:39:00  profilanswer
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10/09/1999 17:06:00
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16/12/2003 19:18:06
Nero API version: 6.3.0.2
Using interface version: 6.0.0.0
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Recorder:             <SONY DVD RW DW-U50A>     Version: 1.5f - HA 1 TA 0 - 6.3.0.2
 Adapter driver:      <atapi>                   HA 1
 Drive buffer  :      8192kB
 Bus Type      :      default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
DiskPeripheral       : HITACHI_DK23FA-60                atapi Port 0 ID 0  DMA: On
CdRomPeripheral      : SONY DVD RW DW-U50A              atapi Port 1 ID 0  DMA: On
=== CDRom-Device-Map ===
SONY DVD RW DW-U50A        F:   CDRom0
AutoRun : 1
Excluded drive IDs:
CmdQueuing     : 1
CmdNotification: 2
WriteBufferSize: 66060288 (0) Byte
ShowDrvBufStat : 0
EraseSpeed     : 0
BUFE           : 0
Physical memory     : 446MB (457712kB)
Free physical memory: 132MB (135936kB)
Memory in use       : 70 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry    : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
22.5.2004
NeroAPI
18:18:44 #1 Phase 111 File APIProgress.cpp, Line 253
 DVD-Video files sorted
18:18:45 #2 Text 0 File Reader.cpp, Line 118
 Reader running
18:18:45 #3 Text 0 File Writer.cpp, Line 124
 Writer SONY     DVD RW DW-U50A   running
18:18:45 #4 ISO9660GEN -11 File geniso.cpp, Line 3882
 First writeable address = 0 (0x00000000)
18:18:45 #5 ISO9660GEN -11 File geniso.cpp, Line 3882
18:18:45 #6 Text 0 File Burncd.cpp, Line 3101
 Turn on Disc-At-Once, using DVD media
18:19:37 #7 Text 0 File DlgWaitCD.cpp, Line 240
 Last possible write address on media:  2295103 (510:01.28, 4482MB)
 Last address to be written:            2286125 (508:01.50, 4465MB)
18:19:37 #8 Text 0 File DlgWaitCD.cpp, Line 245
 Write in overburning mode: FALSE
18:19:37 #9 Text 0 File DlgWaitCD.cpp, Line 2085
 Recorder: SONY DVD RW DW-U50A, Media type: DVD+RW
  Disc Manufacturer ID: RICOHJPN, Media Type ID: W11, Product revision number: 1
  Disc Application Code: 0, Extended Information Indicators: 1
18:19:37 #10 Text 0 File DlgWaitCD.cpp, Line 406
 >>> Protocol of DlgWaitCD activities: <<<
 Insert empty disc to write to.
  (Medium in drive: unknown. Medium required by compilation: DVD+R/RW; DVD-R/RW.)
18:19:37 #11 Text 0 File ThreadedTransferInterface.cpp, Line 779
 Setup items (after recorder preparation)
  0: TRM_DATA_MODE1 (CTransferItem)
     2 indices, index0 (150) not provided
     original disc pos #0 + 2286126 (2286126) = #2286126/508:1.51
     relocatable, disc pos for caching/writing not required/required, no patch infos
     -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286126 blocks [SONY     DVD RW DW-U50A  ]
18:19:37 #12 Text 0 File ThreadedTransferInterface.cpp, Line 948
 Prepare recorder [SONY     DVD RW DW-U50A  ] for write in CUE-sheet-DAO
 DAO infos:
  MCN: ""
  TOCType: 0x00; Session Closed, disc fixated
  Tracks 1 to 1:
    1: TRM_DATA_MODE1, 2048/0x00, FilePos             0             0    4681986048, ISRC ""
 DAO layout:
  __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
        0 |  lead-in |   0 |   0x00 |  0x41
        0 |        1 |   0 |   0x00 |  0x41
        0 |        1 |   1 |   0x00 |  0x41
  2286126 | lead-out |   1 |   0x00 |  0x41
18:19:37 #13 Phase 24 File APIProgress.cpp, Line 253
 Caching of files started
18:19:37 #14 Text 0 File Burncd.cpp, Line 4073
 Cache writing successful.
18:19:37 #15 Phase 25 File APIProgress.cpp, Line 253
 Caching of files completed
18:19:37 #16 Phase 36 File APIProgress.cpp, Line 253
 Burn process started at 2x (2 770 KB/s)
18:19:39 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2264
 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
18:19:39 #18 Text 0 File Cdrdrv.cpp, Line 7941
 ---- DVD Structure: Physical Format Information (00h) ----
 Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
  Book Type: DVD+RW  (9), Part Version: 2
  Disc Size: 120 mm,      Maximum Rate: <not specified> (F h)
  Number of Layers: 1,    Track Path: Parallel Track Path (PTP),  Layer Type: re-writable
  Linear Density:         0,267 um/bit,  Track Density:  0,74 um/track
  Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
  End Physical Sector Number of Data Area:      26053F h
  End Sector Number in Layer 0:                 0 h
  Data in Burst Cutting Area (BCA) does not exist
  Media Specific:
       00 01 52 49 43 4F 48 4A - 50 4E 57 31 31 01 39 23    ..RICOHJPNW11.9#
       00 8A 86 68 02 26 00 8A - 86 70 02 28 00 8A 86 6A    ...h.&...p.(...j
       02 28 22 12 10 E0 00 F0 - 00 00 00 00 00 00 00 01    .(".............
18:19:39 #19 Phase 98 File APIProgress.cpp, Line 253
 Start formatting disc before burning
18:20:07 #20 Phase 100 File APIProgress.cpp, Line 253
 Formatting disc was successful
18:20:07 #21 Phase 65 File APIProgress.cpp, Line 253
18:20:09 #22 Text 0 File DVDPlusRW.cpp, Line 564
 Start write address at LBA 0
 DVD high compatibility mode: Yes
18:20:12 #23 SCSI -1046 File Cdrdrv.cpp, Line 1431
 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x013C0000
 Status:     0x04 (0x01, SCSI_ERR)
 HA-Status   0x00 (0x00, OK)
 TA-Status   0x02 (0x01, SCSI_TASTATUS_CHKCOND)
 Sense Key:  0x05 (KEY_ILLEGAL_REQUEST)
 Sense Code: 0x30
 Sense Qual: 0x10
 CDB Data:   0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
 Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x12
             0x00 0x00 0x00 0x00 0x30 0x10
18:20:12 #24 CDR -1046 File Writer.cpp, Line 301
 Illegal disc
18:20:12 #25 Text 0 File ThreadedTransfer.cpp, Line 229
 all writers idle, stopping conversion
18:20:12 #26 Text 0 File ThreadedTransfer.cpp, Line 223
 conversion idle, stopping reader
18:20:12 #27 Phase 38 File APIProgress.cpp, Line 253
 Burn process failed at 2x (2 770 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10/09/1999 17:06:00
File 'Drivers\PXHELP20.SYS': Ver=2.02.53a, size=17136 bytes, created 03/06/2003 02:02:00 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
voici le message d'erreur que j'obtiens lorsque je veux graver un DVD Phillips DVD+RW
sur mon ordi portable un graveur sony PCG-FR315S
  Divers
Installation graveur via port parallèllegraveur lg , aidez moi
Compatibilité graveur interne ?GRAVEUR QUE!FIRE / MAC OS 9.2
probleme graveur plextor[Pb graveur] Cd qui passe pas !!
problem avec clavier logitech deluxe accessGraveur DVD Externe Cibox de Carrefour
graveur dvddisparition du graveur
Plus de sujets relatifs à : problem avec graveur
