2502 connectés
  Disque dur
  Analyse smartcl seagate Barracuda
n°10504394
mr-toc
Posté le 10-01-2019 à 18:06:37  profilanswer
Je viens de recevoir mon hdd et j'ai quelques valeurs qui me semblent suspectes  :sweat:
La seule source d'informations pour essayer de comprendre smart, c'est https://fr.wikipedia.org/wiki/Self- [...] .T._connus
Si quelqu'un peut me confirmer
Code :
  1. smartctl -a /dev/sdc
  2. smartctl 6.6 2016-05-31 r4324 [x86_64-linux-4.9.0-8-amd64] (local build)
  3. Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
  4. === START OF INFORMATION SECTION ===
  5. Device Model:     ST8000DM004-2CX188
  6. Serial Number:    WCT0PM0P
  7. LU WWN Device Id: 5 000c50 0b9fc3f20
  8. Firmware Version: 0001
  9. User Capacity:    8 001 563 222 016 bytes [8,00 TB]
  10. Sector Sizes:     512 bytes logical, 4096 bytes physical
  11. Rotation Rate:    5425 rpm
  12. Form Factor:      3.5 inches
  13. Device is:        Not in smartctl database [for details use: -P showall]
  14. ATA Version is:   ACS-3 T13/2161-D revision 5
  15. SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
  16. Local Time is:    Thu Jan 10 17:56:30 2019 CET
  17. SMART support is: Available - device has SMART capability.
  18. SMART support is: Enabled
  19. === START OF READ SMART DATA SECTION ===
  20. SMART overall-health self-assessment test result: PASSED
  21. General SMART Values:
  22. Offline data collection status:  (0x00) Offline data collection activity
  23.     was never started.
  24.     Auto Offline Data Collection: Disabled.
  25. Self-test execution status:      (   0) The previous self-test routine completed
  26.     without error or no self-test has ever
  27.     been run.
  28. Total time to complete Offline
  29. data collection:   (    0) seconds.
  30. Offline data collection
  31. capabilities:     (0x73) SMART execute Offline immediate.
  32.     Auto Offline data collection on/off support.
  33.     Suspend Offline collection upon new
  34.     command.
  35.     No Offline surface scan supported.
  36.     Self-test supported.
  37.     Conveyance Self-test supported.
  38.     Selective Self-test supported.
  39. SMART capabilities:            (0x0003) Saves SMART data before entering
  40.     power-saving mode.
  41.     Supports SMART auto save timer.
  42. Error logging capability:        (0x01) Error logging supported.
  43.     General Purpose Logging supported.
  44. Short self-test routine
  45. recommended polling time:   (   1) minutes.
  46. Extended self-test routine
  47. recommended polling time:   ( 987) minutes.
  48. Conveyance self-test routine
  49. recommended polling time:   (   2) minutes.
  50. SCT capabilities:         (0x30a5) SCT Status supported.
  51.     SCT Data Table supported.
  52. SMART Attributes Data Structure revision number: 10
  53. Vendor Specific SMART Attributes with Thresholds:
  54. ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  55.   1 Raw_Read_Error_Rate     0x000f   100   100   006    Pre-fail  Always       -       4286
  56.   3 Spin_Up_Time            0x0003   099   099   000    Pre-fail  Always       -       0
  57.   4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       1
  58.   5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  59.   7 Seek_Error_Rate         0x000f   100   253   045    Pre-fail  Always       -       210
  60.   9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       0 (11 170 0)
  61. 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
  62. 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       1
  63. 183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
  64. 184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
  65. 187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
  66. 188 Command_Timeout         0x0032   100   253   000    Old_age   Always       -       0
  67. 189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
  68. 190 Airflow_Temperature_Cel 0x0022   077   077   040    Old_age   Always       -       23 (Min/Max 17/23)
  69. 191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
  70. 192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       1
  71. 193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       1
  72. 194 Temperature_Celsius     0x0022   023   040   000    Old_age   Always       -       23 (0 17 0 0 0)
  73. 195 Hardware_ECC_Recovered  0x001a   100   100   000    Old_age   Always       -       4286
  74. 197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
  75. 198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
  76. 199 UDMA_CRC_Error_Count    0x003e   200   253   000    Old_age   Always       -       0
  77. 240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       0 (47 57 0)
  78. 241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       0
  79. 242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       4286
  80. SMART Error Log Version: 1
  81. No Errors Logged
  82. SMART Self-test log structure revision number 1
  83. No self-tests have been logged.  [To run self-tests, use: smartctl -t]
  84. SMART Selective self-test log data structure revision number 1
  85. SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
  86.     1        0        0  Not_testing
  87.     2        0        0  Not_testing
  88.     3        0        0  Not_testing
  89.     4        0        0  Not_testing
  90.     5        0        0  Not_testing
  91. Selective self-test flags (0x0):
  92.   After scanning selected spans, do NOT read-scan remainder of disk.
  93. If Selective self-test is pending on power-up, resume after 0 minute delay.
Message édité par mr-toc le 10-01-2019 à 18:08:31
Mes ventes - Mon FeedBack
n°10504411
seagate_su​rfer
Posté le 10-01-2019 à 18:32:45  profilanswer
Bonjour @mr-toc,
Afin de vérifier la santé de votre disque, il vaut mieux d'utiliser le logiciel fourni par le fabricant. De ce fait, nous vous conseillons d'analyser votre lecteur avec les tests Générique Court et Générique Long de l'outil SeaTools bootable.
Veuillez nous indiquer les résultats de ces tests afin de vérifier la santé de votre disque.
Bien cordialement,
Seagate Technology │Équipe Officielle des Forums
n°10504675
mr-toc
Posté le 11-01-2019 à 08:07:27  profilanswer
seagate_surfer a écrit :
Bonjour @mr-toc,
Bien cordialement,
Je vais lancer le test long
http://thumbs2.imagebam.com/44/21/2a/1092801088960394.jpg
http://thumbs2.imagebam.com/1d/c8/38/9113ba1088960434.jpg
http://thumbs2.imagebam.com/4c/9a/24/2a64b41088960454.jpg
http://thumbs2.imagebam.com/15/78/56/12f9401088960474.jpg
n°10504927
seagate_su​rfer
Posté le 11-01-2019 à 13:05:53  profilanswer
Bonjour mr-toc,
Le disque a réussi à tous les tests que vous avez démarrés et cela indique que ce DD est dans des bonnes conditions.  :)
Si ce HDD réussi aussi au test Générique Long, cela va confirmer la santé du lecteur.
Bien à vous,
n°10505409
mr-toc
Posté le 12-01-2019 à 00:16:11  profilanswer
Bonjour mr-toc,
Bien à vous,
Après plus de 15h de test pour le test générique long je suis content de voir du vert mais c'est outil n'est pas très verbeux.
Ceci dit, je reste attaché à des tests bien plus factuels.
J'ai effectué un autre test avec smartmontools mais pas plus rassurant concernant Raw_Read_Error_Rate et Seek_Error_Rate :
Code :
  16. Local Time is:    Fri Jan 11 23:37:09 2019 CET
  27.     been run.
  34.     command.
  55.   1 Raw_Read_Error_Rate     0x000f   083   083   006    Pre-fail  Always       -       181651181
  56.   3 Spin_Up_Time            0x0003   096   096   000    Pre-fail  Always       -       0
  57.   4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       4
  59.   7 Seek_Error_Rate         0x000f   067   061   045    Pre-fail  Always       -       4681961
  60.   9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       23 (188 189 0)
  62. 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       4
  66. 188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
  68. 190 Airflow_Temperature_Cel 0x0022   064   062   040    Old_age   Always       -       36 (Min/Max 36/36)
  71. 193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       8
  72. 194 Temperature_Celsius     0x0022   036   040   000    Old_age   Always       -       36 (0 17 0 0 0)
  73. 195 Hardware_ECC_Recovered  0x001a   083   083   000    Old_age   Always       -       181651181
  76. 199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
  77. 240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       22 (29 92 0)
  79. 242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       15940649264
  83. Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
  84. # 1  Short offline       Completed without error       00%         5         -
  85. SMART Selective self-test log data structure revision number 1
  86. SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
  87.     1        0        0  Not_testing
  88.     2        0        0  Not_testing
  89.     3        0        0  Not_testing
  90.     4        0        0  Not_testing
  91.     5        0        0  Not_testing
  92. Selective self-test flags (0x0):
  93.   After scanning selected spans, do NOT read-scan remainder of disk.
  94. If Selective self-test is pending on power-up, resume after 0 minute delay.
n°10507167
seagate_su​rfer
Posté le 14-01-2019 à 15:43:17  profilanswer
Bonjour mr-toc,
Veuillez noter que le test Générique Long a fait une analyse de votre disque secteur par secteur, de ce fait, si votre lecteur a réussi à ce test, cela veut dire qu'il est en bon état, vu qu'il s'agit d'une vérification de la totalité des secteurs du HDD.
Malheureusement, nous ne prenons pas en considération les résultats des tiers logiciels, car les outils tiers ne lisent pas avec les mêmes algorithmes que le fabricant du disque et peuvent donner des résultats altérés.
Bien à vous,
  Disque dur
Le Seagate Barracuda 8 To est t'il bien pour un NAS Synology ?novice besoin de pro pour analyse config tour pc
Avis SSD SeagateDisque dur Seagate Firecuda mort ?
Problème disque dur externe SeagateAnalyse OCCT - Suite de bug en série - Redémarrages intempestifs
Disque dur Seagate 1To Barracuda cassé...Diagnostique CPUID - Analyse
Plus de sujets relatifs à : Analyse smartcl seagate Barracuda
