5720 connectés
  Probleme graveur Traxdata 121032 - Focus or tracking error
n°1394668
k'wet
Posté le 29-04-2002 à 14:34:55  profilanswer
il me marque une erreur Focus or tracking error sous nero 5540 !
cela fait 2 cds de mort !
voici le log complet :
nico
perso
150302-401360-284042-449015
Windows NT 5.0
WinAspi: -
ahead WinASPI: File 'C:\Program Files\ahead\Nero\Wnaspi32.dll': Ver=2.0.1.28, size=172099 bytes, created 06/09/2001 14:29:05
Nero Version: 5.5.4.0
Recorder:             <TRAXDATA CDRW121032plus> Version: LSR1 - HA 0 TA 1 - 5.5.4.0
 Adapter driver:      <atapi>                   HA 0
 Drive buffer  :      2048kB
CD-ROM:               <SAMSUNG  DVD-ROM SD-616> Version: BS02 - HA 1 TA 0 - 5.5.4.0
 Adapter driver:      <atapi>                   HA 1
=== Scsi-Device-Map ===
DiskPeripheral       : Maxtor 52049H3                   atapi Port 0 ID 0  DMA: On
CdRomPeripheral      : TRAXDATA CDRW121032plus          atapi Port 0 ID 1  DMA: Off
CdRomPeripheral      : SAMSUNG DVD-ROM SD-616           atapi Port 1 ID 0  DMA: Off
DiskPeripheral       : Conner Peripherals 1620MB -      atapi Port 1 ID 1  DMA: On
AutoRun : 0
CmdQueuing     : 1
CmdNotification: 2
WriteBufferSize: 40894464 (0) Byte
ShowDrvBufStat : 0
EraseSpeed     : 0
BUFE           : 0
Physical memory     : 319MB (327152kB)
Free physical memory: 102MB (104988kB)
Memory in use       : 67 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry: 1
Wizard: On
Copie CD
29.4.2002
14:29:11 #1 SCSI -1065 File Cdrdrv.cpp, Line 1101
 SCSI Exec, HA 1, TA 0, LUN 0
 Status:     0x04 (0x01, SCSI_ERR)
 HA-Status   0x00 (0x00, OK)
 TA-Status   0x02 (0x01, SCSI_TASTATUS_CHKCOND)
 Sense Key:  0x05 (KEY_ILLEGAL_REQUEST)
 Sense Code: 0x20
 Sense Qual: 0x00
 CDB Data:   0xBB 0x00 0xFF 0xFF 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
 Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
             0x00 0x00 0x00 0x00 0x20 0x00
14:29:11 #2 Phase 72 File dlgbrnst.cpp, Line 1348
 BURN-Proof activated
14:29:12 #3 Text 0 File Reader.cpp, Line 117
 Reader running
14:29:12 #4 Text 0 File Writer.cpp, Line 122
 Writer CDRW121032plus   running
14:29:12 #5 Phase 48 File dlgbrnst.cpp, Line 1348
 Analyzing CD
14:29:12 #6 SCSI -1065 File Cdrdrv.cpp, Line 1101
 Sense Code: 0x20
 Sense Qual: 0x00
14:29:12 #7 SCSI -1065 File Cdrdrv.cpp, Line 1101
 Sense Code: 0x20
 Sense Qual: 0x00
14:29:12 #8 Text 0 File CDCopy.cpp, Line 2318
 session 0 (0 - 0): last session
14:29:12 #9 CDCOPY -1 File CDCopy.cpp, Line 2451
 The CD is copyrighted
14:29:17 #10 SCSI -1065 File Cdrdrv.cpp, Line 1101
 Sense Code: 0x20
 Sense Qual: 0x00
14:29:47 #11 Text 0 File CDCopy.cpp, Line 2687
           _Index0_ _______Index1_______ PostPause   ___LastBlockOfTrack_
 Track  1:        0        0 (  0:02.00)    353693     353693 ( 78:37.68)
14:29:47 #12 Text 0 File CDCopy.cpp, Line 1023
 Copy options: read subcode: OFF   jitter correction: OFF     copy on-the-fly:  ON
               read ISRC/MCN:  ON  ignore inv. TOC type:  ON  ignore audio read error:  ON
 source disc does not look like CD Extra
 01.      0 - 353694 = 353694, data (2)
14:29:47 #13 Text 0 File ThreadedTransferInterface.cpp, Line 668
 Setup items (original item values)
  0: TRM_DATA_MODE2_FORM1_NOSUB (1 Données (mode 2))
     2 indices, index0 (150) not provided
     original CD pos #0 + 353694 (353694) = #353694/78:35.69
     relocatable, CD pos for caching/writing not required/not required, no patch infos
14:29:50 #14 Text 0 File DlgWaitCD.cpp, Line 1164
 Recorder:  TRAXDATA CDRW121032plus;
    CDR code: 00 97 34 21; OSJ entry from: Mitsubishi Chemical
    ATIP Data:
      Special    Info [hex] 1: C0 00 98, 2: 61 22 15 (LI 97:34.21), 3: 4F 3B 4A (LO 79:59.74)
      Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
14:29:50 #15 Text 0 File ThreadedTransferInterface.cpp, Line 803
 Prepare recorder CDRW121032plus   for write in cue-sheet-DAO
 DAO infos:
 MCN:
 TOCTYPE: 0x20   Close CD
 Tracks 1 to 1:
    TRM_DATA_RAW_MODE2, 2352/0x0, ISRC "", FilePos 0 352800 832241088
14:29:50 #16 Text 0 File ThreadedTransferInterface.cpp, Line 668
 Setup items (after recorder preparation)
     -> TRM_DATA_RAW_MODE2, 2352, config 0, wanted index0 0 blocks, length 353694 blocks [CDRW121032plus  ]
14:29:50 #17 Phase 24 File dlgbrnst.cpp, Line 1348
 Caching of files started
14:29:50 #18 Phase 25 File dlgbrnst.cpp, Line 1348
 Caching of files completed
14:29:51 #19 Phase 36 File dlgbrnst.cpp, Line 1348
 Burn process started at 8x (1200 KB/s)
14:29:51 #20 Text 0 File ThreadedTransferInterface.cpp, Line 1841
 Verifying CD position of item 0 (relocatable, no CD pos, no patch infos, orig at #0): write at #0
14:29:51 #21 Text 0 File Mmc.cpp, Line 13988
 Set BUFE: BURN-Proof -> ON
14:31:42 #22 SCSI -1039 File Cdrdrv.cpp, Line 1308
 SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x0775F0DC
 Sense Key:  0x04 (KEY_HARDWARE_ERROR)
 Sense Code: 0x09
 Sense Qual: 0x01
 CDB Data:   0x2A 0x00 0x00 0x00 0x1C 0x44 0x00 0x00 0x1B 0x00 0x00 0x00
 Sense Data: 0x70 0x00 0x04 0x00 0x00 0x00 0x00 0x0A
             0x00 0x00 0x00 0x00 0x09 0x01
14:31:42 #23 mmc -1039 File Writer.cpp, Line 308
14:31:42 #24 Text 0 File ThreadedTransfer.cpp, Line 218
 all writers idle, stopping conversion
14:31:43 #25 Text 0 File ThreadedTransfer.cpp, Line 212
 conversion idle, stopping reader
14:31:43 #26 Phase 38 File dlgbrnst.cpp, Line 1348
 Burn process failed at 8x (1200 KB/s)
14:31:43 #27 Text 0 File Scsicmd.cpp, Line 371
 SCSI not using temporary buffers
 20 out of 20 temporary buffers allocated
Existing drivers:
Merci de votre aide ! j'ai essayé de graver a 8x et 12x meme erreur sur 2 cds verbatim 700 mo certif 16x
_    _              _
problème de chauffe XP1800 + GF4Quel graveur ?
probleme de soncarte Ati wonder ve et win xp, putain c'est quoi le probleme ???
Probleme : "Ressource systeme insuffisante " lors de copie de fichiergraveur de cd (helppp)
graveur : vous prendriez quoi ?[win98SE] Problème de partition ntfs résolu !!!
Problème avec graveur BTC
Plus de sujets relatifs à : Probleme graveur Traxdata 121032 - Focus or tracking error
