5047 connectés
  MSI K7N415 PRO C'est pour quand ?
n°1301203
beckman
Posté le 26-03-2002 à 23:32:28  profilanswer
http://perso.wanadoo.fr/trajan/k7n415%2520pro.jpg
Main Memory
3 DDR DIMMs.
Maximum memory size of 1.5GB.
Support 128-bit system memory.
Slots
One CNR Slot(Communication Network Riser).
One AGP Slot. Note: AGP 2.0 2x/4x (1.5V only)
Five PCI (v2.2) 32 bit Master PCI bus slots.
Onboard IDE
An IDE controller on the MCP chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA 100 operation modes.
Can connect to 4 IDE devices.
Video
Shared with External Memory up to 32MB.
256-bit 2D/3D graphics accelerator.
2nd generation T&L engine, NVIDIA Shading Rasterizer (NSR).
Multiplex DVI /TV interface with the AGP slot. (optional)
PC 2001 compliant SMA and operates with 128-bit system memory installed.
Network
Chip integrated 10/100 BaseT Ethernet/Fast Ethernet.
Audio
APU (Audio Processing Unit) integrated in MCP
Support up to 256 hardware-processed voices or 64 hardware voices in 3D.
Support multi-speaker 3D audio.
S/PDIF out through external bracket.
Onboard peripherals
1 Floppy port supports 2 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes.
2 Serial ports (COM A + COM B)
6 USB ports (2 rear connectors and 2 USB front pin header to support four ports)
1 Parallel port supports SPP/EPP/ECP mode.
1 VGA connector.
1 IrDA connector.
1 Audio/Game port.
1 RJ-45 port.
BIOS
The mainboard BIOS provides AMI "Plug & Play" Flash BIOS which detects the peripheral devices and expansion cards of the board automatically.
The mainboard provides a Desktop Management Interface(DMI) function which records your mainboard specifications.
Dimension
ATX Form Factor.
Mounting
6 mounting holes.
Quelqu'un a des infos sur cette carte mère ? Disponibilitée en france, prix...
[jfdsdjhfuetppo]--Message édité par beckman--[/jfdsdjhfuetppo]
n°1301866
beckman
Posté le 27-03-2002 à 11:48:10  profilanswer
:bounce:
n°1304809
trajan
Pas de déclaration !
Posté le 28-03-2002 à 12:37:22  profilanswer
:bounce:
[PB] GF4 Prolink et MSI KT 266 Pro 2MSI K7T Turbo2 et ecran de boot
Comment flasher le Bios d'une MSI K7T pro2Webcam Philips ToUcaM Pro : Un probleme (et le bouton)
Sortie TV (s-video) 3D Prothet II Pro GTS Help !!carte mere MSI 6373 K7N420 nForce (SocketA) DDR = infos SVP??
Pb de souris avec les cartes mères MSI 845 Ultra ARU ?MSI K7T Turbo dont les voyants d indication sont morts => virus WINK ?
MSI G4 TI4600ou4400
Plus de sujets relatifs à : MSI K7N415 PRO C'est pour quand ?
