4131 connectés
Sujet : MSI K7N415 PRO C'est pour quand ?
trajan :bounce:
trajan :bounce:
beckman :bounce:
beckman http://perso.wanadoo.fr/trajan/k7n415%2520pro.jpg
Main Memory
3 DDR DIMMs.
Maximum memory size of 1.5GB.
Support 128-bit system memory.
Slots
One CNR Slot(Communication Network Riser).
One AGP Slot. Note: AGP 2.0 2x/4x (1.5V only)
Five PCI (v2.2) 32 bit Master PCI bus slots.
Onboard IDE
An IDE controller on the MCP chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA 100 operation modes.
Can connect to 4 IDE devices.
Video
Shared with External Memory up to 32MB.
256-bit 2D/3D graphics accelerator.
2nd generation T&L engine, NVIDIA Shading Rasterizer (NSR).
Multiplex DVI /TV interface with the AGP slot. (optional)
PC 2001 compliant SMA and operates with 128-bit system memory installed.
Network
Chip integrated 10/100 BaseT Ethernet/Fast Ethernet.
Audio
APU (Audio Processing Unit) integrated in MCP
Support up to 256 hardware-processed voices or 64 hardware voices in 3D.
Support multi-speaker 3D audio.
S/PDIF out through external bracket.
Onboard peripherals
1 Floppy port supports 2 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes.
2 Serial ports (COM A + COM B)
6 USB ports (2 rear connectors and 2 USB front pin header to support four ports)
1 Parallel port supports SPP/EPP/ECP mode.
1 VGA connector.
1 IrDA connector.
1 Audio/Game port.
1 RJ-45 port.
BIOS
The mainboard BIOS provides AMI "Plug & Play" Flash BIOS which detects the peripheral devices and expansion cards of the board automatically.
The mainboard provides a Desktop Management Interface(DMI) function which records your mainboard specifications.
Dimension
ATX Form Factor.
Mounting
6 mounting holes.
Quelqu'un a des infos sur cette carte mère ? Disponibilitée en france, prix...
[jfdsdjhfuetppo]--Message édité par beckman--[/jfdsdjhfuetppo]
