4655 connectés
  Info sur carte-mère Matsonic MS7012D
n°1441577
Maxens
Posté le 15-05-2002 à 18:48:12  profilanswer
Pouvez vousm'en dire plus ??? type de chipset ? elle prend koi comme type de P3 ? slot one ???
Sur le site du contructeur, il n'y a plus trop d'info dessus, juste les dernier bios.
n°1441602
Maxens
Posté le 15-05-2002 à 18:58:31  profilanswer
il paraitrait qu elle serait equipée du chipset i810e. C le fameux BX ?? sinon, il accepte koi comme cpu ?
n°1441659
bobo
Posté le 15-05-2002 à 19:16:31  profilanswer
http://www.matsonic.com.tw/eng/pro [...] s7012d.htm
[Home][Product]
        MS7012D
[img]http://www.matsonic.com.tw/mbimage/ms7012d.gif
PROCESSOR
Slot 1 / socket 370 supports any one of the following processors:
PentiumIII processor
450/500/550/600
PentiumII processor
233/266/300/333/350/400/450
Celeron processor
266/300/333/366/400/433/466/500MHz
CHIPSET
Intel 82810E & 82801AA Chipset With  133/100/66MHZ FSB
ITE LPC I/O - IT8870F
CMI8738 PCI 3D Audio/HSP 56K V9.0   Fax/Modem
CACHE RAM
None (CPU Embedded)
MEMORY
Two 168-pin DIMM sockets for 3.3V PC 100 SDRAM
Maximum: 512MB
SYSTEM BIOS
Award BIOS with 4Mb Flash ROM in Firmware Hub (FWH)
Supports Plug and Play 1.0A, APM  1.2, Multi Boot, DMI Full support for  ACPI revision 1.0A specification
 I/O INTERFACE
Supports Plug and Play I/O function
One - EPP/ECP mode parallel port
Two - 16550 high-speed serial I/O ports
VGA Connector
Supports 360K~2.88M Byte, 3 Mode FDDs or  LS120
Dual PCI IDE interfaces - supports four IDE devices  (PIO mode 4, DMA Mode 2, Ultra DMA 33/66 )
PS/2 Keyboard and PS/2 Mouse Connectors
ATX Power Supply Connector
Audio Ports(Line-in, Line-out, Mic-in,  CD-in and Game Port)
Two sets of USB connector
3D PCI AUDIO ONBOARD
SB 16/PRO compatible with DirectSound 3D support HRTF 3D Positional Audio Technology with full duplex stereo Supports 44.1K digital audio-in (SPDIF)
56K FAX/MODEM ONBOARD
Supports V.90 Fax/ModemStandard for your internet Communication
OTHER
IrDA/CIR cable Header
Green, HDD, Power indicator LED Connectors
CPU Fan, Power Fan and Chassis Fan Headers
LAN Card Wake Up/Internal Modem Ring Wake-Up Headers
BUS ARCHITECTURE
5 PCI Slots
1 AMR Slot
FORM FACTOR AND LAYERS
ATX Size (305mmx243mm), 4 layers
1+1=10
Qui a une carte Msi 745 Ultra pour Athlon ?Test de 10 carte avec le via KT333
a peu pres 1500 francs pour une carte graphique qui gere le mpeg2 ??- Conseil sur RAM et CARTE GRAPHIQUE.
Carte video 3D PCIrecherche driver d'une carte reseau sans marque, comment faire ??
pb carte son sur carte merehelp ma carte mère msi ne veut plus démarre j'ai tout essayé !!
Plus de sujets relatifs à : Info sur carte-mère Matsonic MS7012D
