3048 connectés
  [HELP] probléme de dalle sur mon portable médion
n°4762202
emigerr
Posté le 12-04-2006 à 19:26:05  profilanswer
bonjour à tous
voila un matin à ma grande surprise j allume mon pc et écran noir mais quand on regarde bien on distingue le bureau et les icones
c est un médion md 95197
  CPU-Z version 1.33
CPUID Output
Number of CPUs   1
Name    Intel Celeron M 340
Code name   Banias
Specification   Intel(R) Celeron(R) M processor         1500MHz
Family/Model/Stepping  695
Extended Family/Model  0/0
Brand ID   18
Package    mPGA-479M (7h)
Core Stepping   B1
Technology   0.13um
Instructions Sets  MMX, SSE, SSE2
Features
Clock Speed   1493.9 MHz
Clock multiplier  x15.0
Front Side Bus Frequency 99.6 MHz
Bus Speed   398.4 MHz
Stock frequency   1500 MHz
L1 Data Cache   32 KBytes, 8-way set associative, 64 Bytes line size
L1 Instruction Cache  32 KBytes, 8-way set associative, 64 Bytes line size
L2 Cache   512 KBytes, 8-way set associative, 64 Bytes line size
L2 Latency   5
L2 Speed   1493.9 MHz (Full)
L2 Location   On Chip
L2 ECC Check   enabled
L2 Data Prefetch Logic  yes
L2 Bus Width   256 bits
    eax  ebx  ecx  edx
Function 00000000  00000002 756e6547 6c65746e 49656e69
Function 00000001  00000695 00000812 00000000 a7e9f9bf
Function 00000002  02b3b001 00000000 00000000 2c043086
Function 80000000  80000004 00000000 00000000 00000000
Function 80000001  00000000 00000000 00000000 00000000
Function 80000002  65746e49 2952286c 6c654320 6e6f7265
Function 80000003  20295228 7270204d 7365636f 20726f73
Function 80000004  20202020 20202020 30303531 007a484d
    edx  eax
MSR 0000002A   00000000 43C80000
MSR 00000017   001C0000 F20787A9
MSR 0000011E   00000000 003C052B
MSR 0000008B   00000045 00000000
Chipset
Northbridge  Intel i855GM/GME rev. A2
Southbridge  Intel 82801DB (ICH4-M) rev. 03
Memory Type  DDR
Memory Size  512 MBytes
Memory Frequency 132.8 MHz (3:4)
CAS#   2.0
RAS# to CAS#  2
RAS# Precharge  2
Cycle Time (tRAS) 6
Memory SPD
DIMM #1
General
Memory type  DDR
Manufacturer (ID) Hyundai Electronics (AD00000000000000)
Size   256 MBytes
Max bandwidth  PC3200 (200 MHz)
Part number  HYMD232M646D6-D43
Serial number  FFFF0512
Manufacturing date Week 50/Year 04
Attributes
Number of banks  2
Data width  64 bits
Correction  None
Registered  no
Buffered  no
Timings table
Frequency (MHz)  133 166 200
CAS#   2.0 2.5 3.0
RAS# to CAS# delay 2 3 3
RAS# Precharge  2 3 3
TRAS#   6 7 8
DIMM #2
General
Memory type  DDR
Size   256 MBytes
Serial number  FFFF024D
Attributes
Number of banks  2
Data width  64 bits
Correction  None
Registered  no
Buffered  no
Timings table
CAS#   2.0 2.5 3.0
TRAS#   6 7 8
Dump Module #1
      0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F
00   80 08 07 0D 09 02 40 00 04 50 70 00 82 10 00 01
10   0E 04 1C 01 02 20 C0 60 70 75 75 3C 28 3C 28 20
20   60 60 40 40 00 00 00 00 00 37 46 28 28 50 00 00
30   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4E
40   AD 00 00 00 00 00 00 00 01 48 59 4D 44 32 33 32
50   4D 36 34 36 44 36 2D 44 34 33 20 41 41 04 32 FF
60   FF 05 12 00 00 00 00 00 00 00 00 00 00 00 00 37
70   49 34 38 53 30 30 37 37 32 2D 30 34 20 00 00 00
Dump Module #2
60   FF 02 4D 00 00 00 00 00 00 00 00 00 00 00 00 37
Monitoring
Sensor Chip  FFFFFFFF FFFFFFFF
PCI Device List
Host Bridge
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
 Vendor ID  0x8086
 Model ID  0x3580
 Revision ID  0x02
 PI   0x00
 SubClass  0x00
 BaseClass  0x06
 Cache Line  0x00
 Latency   0x00
 Header   0x80
PCI header
 Address 0 (memory) 0x00000000
 Subvendor ID  0x1071
 Subsystem ID  0x8089
 Int. Line  0x00
 Int. Pin  0x00
Capabilities
 Vendor Dependant Capability
  Dump
  00 01 02 03 04
  09 00 05 E1 AE
Dump
 00   86 80 80 35 06 00 90 20 02 00 00 06 00 00 80 00
 10   08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 20   00 00 00 00 00 00 00 00 00 00 00 00 71 10 89 80
 30   00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00
 40   09 00 05 E1 AE 00 00 00 00 00 C1 FE 02 28 00 0E
 50   00 01 54 00 00 00 00 00 00 10 11 11 33 00 33 13
 60   0A 38 00 00 00 00 08 00 00 00 00 00 00 00 00 00
 70   02 09 00 00 10 60 00 00 00 00 00 00 00 00 00 00
 80   02 00 00 66 00 00 00 00 00 00 00 00 00 00 00 00
 90   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 A0   02 00 20 00 17 02 00 1F 00 00 00 00 00 00 00 00
 B0   00 00 F0 E9 00 00 00 00 00 00 00 00 00 00 00 00
 C0   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 D0   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 E0   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 F0   00 00 00 00 00 00 00 00 00 00 02 00 09 01 00 00
System Device
bus 0 (0x00), device 0 (0x00), function 1 (0x01)
Common header
 Vendor ID  0x8086
 Model ID  0x3584
 Revision ID  0x02
 PI   0x00
 SubClass  0x80
 BaseClass  0x08
 Cache Line  0x00
 Latency   0x00
 Header   0x00
PCI header
 Subvendor ID  0x1071
 Subsystem ID  0x8089
 Int. Line  0x00
 Int. Pin  0x00
Dump
 00   86 80 84 35 06 00 80 00 02 00 80 08 00 00 00 00
 10   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 30   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 40   04 08 0C 10 00 00 00 00 00 00 00 00 00 00 00 00
 50   11 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 60   2A 44 00 2A 00 00 00 00 00 04 F1 10 00 00 00 00
 70   71 99 00 20 01 00 00 00 74 E9 1F 00 00 00 00 00
 80   31 00 AF 00 3C 03 00 00 10 00 00 00 00 00 00 00
 90   00 00 00 00 00 00 00 00 D4 19 25 22 C6 A3 45 63
 A0   FF A2 0A 30 00 00 00 00 36 2F 12 00 06 A8 6D 00
 B0   24 C7 0E 00 7A 04 0F 00 DC 9D 41 00 BF E2 F5 03
 C0   03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 F0   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
System Device
bus 0 (0x00), device 0 (0x00), function 3 (0x03)
Common header
 Vendor ID  0x8086
 Model ID  0x3585
 Revision ID  0x02
 PI   0x00
 SubClass  0x80
 BaseClass  0x08
 Cache Line  0x00
 Latency   0x00
 Header   0x80
PCI header
 Subvendor ID  0x1071
 Subsystem ID  0x8089
 Int. Line  0x00
 Int. Pin  0x00
Dump
 00   86 80 85 35 06 00 80 00 02 00 80 08 00 00 80 00
 40   04 04 00 00 00 00 11 11 3C 45 5E 09 46 5E 09 49
 50   62 09 00 00 00 00 00 00 01 08 39 2D 54 4B 06 0F
 60   00 00 00 00 00 00 00 00 04 04 00 00 32 38 00 00
 70   00 00 00 00 04 04 41 27 E7 C7 0F 46 28 12 84 02
 80   FF 1F 00 00 EF 00 00 00 00 00 00 00 00 00 00 00
 A0   00 00 00 00 00 00 00 00 00 80 03 18 00 00 00 00
 B0   00 00 00 00 80 02 00 00 00 00 00 00 00 00 00 00
 D0   01 00 21 02 00 00 00 00 08 C3 00 FF 25 00 00 00
 E0   2C 10 1C 00 98 00 9C 00 00 00 00 00 00 04 00 00
 F0   00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 00
VGA Controller
bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
 Vendor ID  0x8086
 Model ID  0x3582
 Revision ID  0x02
 PI   0x00
 SubClass  0x00
 BaseClass  0x03
 Cache Line  0x00
 Latency   0x00
 Header   0x80
PCI header
 Address 0 (memory) 0xB0000000
 Address 1 (memory) 0xF0000000
 Address 2 (port) 0x0000E000
 Subvendor ID  0x1071
 Subsystem ID  0x8089
 Int. Line  0x0A
 Int. Pin  0x01
Capabilities
 Power Management Capability
  Version  1.0
  Dump
  00 01 02 03 04 05 06 07
Dump
 00   86 80 82 35 07 00 90 00 02 00 00 03 00 00 80 00
 10   08 00 00 B0 00 00 00 F0 01 E0 00 00 00 00 00 00
 30   00 00 00 00 D0 00 00 00 00 00 00 00 0A 01 00 00
 40   09 00 05 E1 AE 40 00 00 00 00 00 00 00 00 00 00
 50   00 01 54 00 00 00 00 00 00 00 02 00 00 00 00 00
 60   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 70   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 80   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 A0   FF A2 0A 30 00 00 00 00 56 2F 12 00 6E 82 6E 00
 B0   A4 C8 0E 00 86 04 0F 00 7E BE 41 00 AF FA FE 03
Display Controller
bus 0 (0x00), device 2 (0x02), function 1 (0x01)
Common header
 Vendor ID  0x8086
 Model ID  0x3582
 Revision ID  0x02
 PI   0x00
 SubClass  0x80
 BaseClass  0x03
 Cache Line  0x00
 Latency   0x00
 Header   0x80
PCI header
 Address 0 (memory) 0xE8000000
 Address 1 (memory) 0xFAB00000
 Subvendor ID  0x1071
 Subsystem ID  0x8089
 Int. Line  0x00
 Int. Pin  0x00
Capabilities
  Version  1.0
  Dump
Dump
 00   86 80 82 35 07 00 90 00 02 00 80 03 00 00 80 00
 10   08 00 00 E8 00 00 B0 FA 00 00 00 00 00 00 00 00
 30   00 00 00 00 D0 00 00 00 00 00 00 00 00 00 00 00
 A0   FF A2 0A 30 00 00 00 00 5E 2F 12 00 3E EC 6E 00
 B0   E0 C8 0E 00 86 04 0F 00 52 D0 41 00 23 64 03 04
USB Controller (UHCI)
bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
 Vendor ID  0x8086
 Model ID  0x24C2
 Revision ID  0x03
 PI   0x00
 SubClass  0x03
 BaseClass  0x0C
 Cache Line  0x00
 Latency   0x00
 Header   0x80
PCI header
 Address 4 (port) 0x00001200
 Subvendor ID  0x1071
 Subsystem ID  0x8089
 Int. Line  0x0A
 Int. Pin  0x01
Dump
 00   86 80 C2 24 05 00 80 02 03 00 03 0C 00 00 80 00
 20   01 12 00 00 00 00 00 00 00 00 00 00 71 10 89 80
 30   00 00 00 00 00 00 00 00 00 00 00 00 0A 01 00 00
 40   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 50   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 60   10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 A0   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 B0   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 C0   00 2F 00 00 03 00 00 00 00 00 00 00 00 00 00 00
 F0   00 00 00 00 00 00 00 00 60 0F 00 00 00 00 00 00
bus 0 (0x00), device 29 (0x1D), function 1 (0x01)
Common header
 Vendor ID  0x8086
 Model ID  0x24C4
 Revision ID  0x03
 PI   0x00
 SubClass  0x03
 BaseClass  0x0C
 Cache Line  0x00
 Latency   0x00
 Header   0x00
PCI header
 Address 4 (port) 0x00001600
 Subvendor ID  0x1071
 Subsystem ID  0x8089
 Int. Line  0x0B
 Int. Pin  0x02
Dump
 00   86 80 C4 24 05 00 80 02 03 00 03 0C 00 00 00 00
 20   01 16 00 00 00 00 00 00 00 00 00 00 71 10 89 80
 30   00 00 00 00 00 00 00 00 00 00 00 00 0B 02 00 00
USB 2.0 Controller (EHCI)
bus 0 (0x00), device 29 (0x1D), function 7 (0x07)
Common header
 Vendor ID  0x8086
 Model ID  0x24CD
 Revision ID  0x03
 PI   0x20
 SubClass  0x03
 BaseClass  0x0C
 Cache Line  0x00
 Latency   0x00
 Header   0x00
PCI header
 Address 0 (memory) 0xFEBFF000
 Subvendor ID  0x1071
 Subsystem ID  0x8089
 Int. Line  0x0B
 Int. Pin  0x04
Capabilities
  Version  1.1
  Dump
  01 58 C2 C9 00 00 00 00
 Debug Port Capability
Dump
 00   86 80 CD 24 06 00 90 02 03 20 03 0C 00 00 00 00
 10   00 F0 BF FE 00 00 00 00 00 00 00 00 00 00 00 00
 30   00 00 00 00 50 00 00 00 00 00 00 00 0B 04 00 00
 50   01 58 C2 C9 00 00 00 00 0A 00 80 20 00 00 00 00
 60   20 20 7F 00 00 00 00 00 01 00 00 00 00 00 00 C0
 70   00 00 F7 0F 00 00 00 00 00 00 00 00 00 00 00 00
 80   00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00
 F0   78 BF 1F 00 88 83 00 00 60 0F 00 00 06 00 00 00
PCI to PCI Bridge
bus 0 (0x00), device 30 (0x1E), function 0 (0x00)
Common header
 Vendor ID  0x8086
 Model ID  0x2448
 Revision ID  0x83
 PI   0x00
 SubClass  0x04
 BaseClass  0x06
 Cache Line  0x00
 Latency   0x00
 Header   0x01
PCI header
 Primary bus  0x00
 Secondary bus  0x01
 Int. Line  0x00
 Int. Pin  0x00
Dump
 00   86 80 48 24 07 01 80 80 83 00 04 06 00 00 01 00
 10   00 00 00 00 00 00 00 00 00 01 02 20 C0 D0 80 22
 20   00 E0 F0 EF 00 A0 F0 AF 00 00 00 00 00 00 00 00
 30   00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 08
 40   02 28 20 00 00 01 00 00 00 00 00 00 00 00 00 00
 50   02 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 70   40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 80   00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00
 A0   10 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00
 B0   01 00 02 00 00 00 C0 00 00 00 00 00 00 00 00 00
 F0   00 00 00 00 00 00 00 00 60 0F 00 00 00 00 54 2A
PCI to ISA Bridge
bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
 Vendor ID  0x8086
 Model ID  0x24CC
 Revision ID  0x03
 PI   0x00
 SubClass  0x01
 BaseClass  0x06
 Cache Line  0x00
 Latency   0x00
 Header   0x80
PCI header
 Subvendor ID  0x0000
 Subsystem ID  0x0000
 Int. Line  0x00
 Int. Pin  0x00
Dump
 00   86 80 CC 24 0F 00 80 02 03 00 01 06 00 00 80 00
 20   00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 40   01 10 00 00 10 00 00 00 00 00 00 00 00 00 02 00
 50   00 00 00 00 00 00 00 00 01 13 00 00 10 00 00 00
 60   0A 0A 80 0B D0 00 00 00 0B 80 80 0B 00 00 00 00
 90   FF FC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 A0   A8 02 00 00 00 00 00 00 12 00 00 00 00 00 00 00
 B0   00 00 00 00 00 00 00 00 00 00 01 02 00 00 00 00
 D0   06 20 00 00 02 00 00 00 04 00 00 00 00 00 00 00
 E0   10 00 00 80 00 00 08 1C 33 22 11 00 00 00 67 45
 F0   0F 00 00 04 00 00 00 00 60 0F 03 00 00 00 81 00
IDE Controller
bus 0 (0x00), device 31 (0x1F), function 1 (0x01)
Common header
 Vendor ID  0x8086
 Model ID  0x24CA
 Revision ID  0x03
 PI   0x8A
 SubClass  0x01
 BaseClass  0x01
 Cache Line  0x00
 Latency   0x00
 Header   0x00
PCI header
 Address 4 (port) 0x00001100
 Address 5 (memory) 0xFEBFFC00
 Subvendor ID  0x1071
 Subsystem ID  0x8089
 Int. Line  0x00
 Int. Pin  0x01
Dump
 00   86 80 CA 24 07 00 80 02 03 8A 01 01 00 00 00 00
 10   01 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00
 20   01 11 00 00 00 FC BF FE 00 00 00 00 71 10 89 80
 30   00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00
 40   47 A3 47 A3 00 00 00 00 05 00 01 02 00 00 00 00
 50   00 00 00 00 55 14 00 00 00 00 00 00 00 00 00 00
 60   08 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00
SMBus Controller
bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
 Vendor ID  0x8086
 Model ID  0x24C3
 Revision ID  0x03
 PI   0x00
 SubClass  0x05
 BaseClass  0x0C
 Cache Line  0x00
 Latency   0x00
 Header   0x00
PCI header
 Address 4 (port) 0x00001400
 Subvendor ID  0x1071
 Subsystem ID  0x8089
 Int. Line  0x05
 Int. Pin  0x02
Dump
 00   86 80 C3 24 01 00 80 02 03 00 05 0C 00 00 00 00
 20   01 14 00 00 00 00 00 00 00 00 00 00 71 10 89 80
 30   00 00 00 00 00 00 00 00 00 00 00 00 05 02 00 00
 40   01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Audio device
bus 0 (0x00), device 31 (0x1F), function 5 (0x05)
Common header
 Vendor ID  0x8086
 Model ID  0x24C5
 Revision ID  0x03
 PI   0x00
 SubClass  0x01
 BaseClass  0x04
 Cache Line  0x00
 Latency   0x00
 Header   0x00
PCI header
 Address 0 (port) 0x0000E100
 Address 1 (port) 0x0000E200
 Address 2 (memory) 0xF0080400
 Address 3 (memory) 0xF0080600
 Subvendor ID  0x1071
 Subsystem ID  0x8089
 Int. Line  0x0A
 Int. Pin  0x02
Capabilities
  Version  1.1
  Dump
  01 00 C2 C9 00 00 00 00
Dump
 00   86 80 C5 24 07 00 90 02 03 00 01 04 00 00 00 00
 10   01 E1 00 00 01 E2 00 00 00 04 08 F0 00 06 08 F0
 30   00 00 00 00 50 00 00 00 00 00 00 00 0A 02 00 00
 40   09 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
 50   01 00 C2 C9 00 00 00 00 00 00 00 00 00 00 00 00
Modem
bus 0 (0x00), device 31 (0x1F), function 6 (0x06)
Common header
 Vendor ID  0x8086
 Model ID  0x24C6
 Revision ID  0x03
 PI   0x00
 SubClass  0x03
 BaseClass  0x07
 Cache Line  0x00
 Latency   0x00
 Header   0x00
PCI header
 Address 0 (port) 0x0000E300
 Address 1 (port) 0x0000E400
 Subvendor ID  0x1071
 Subsystem ID  0x8089
 Int. Line  0x0A
 Int. Pin  0x02
Capabilities
  Version  1.1
  Dump
Dump
 00   86 80 C6 24 05 00 90 02 03 00 03 07 00 00 00 00
 10   01 E3 00 00 01 E4 00 00 00 00 00 00 00 00 00 00
Network Controller
bus 1 (0x01), device 1 (0x01), function 0 (0x00)
Common header
 Vendor ID  0x1260
 Model ID  0x3886
 Revision ID  0x01
 PI   0x00
 SubClass  0x80
 BaseClass  0x02
 Cache Line  0x10
 Latency   0x38
 Header   0x00
PCI header
 Address 0 (memory) 0xE0002000
 Subvendor ID  0x17CF
 Subsystem ID  0x0036
 Int. Line  0x0B
 Int. Pin  0x01
Capabilities
  Version  1.0
  Dump
  01 00 01 FE 00 00 00 00
Dump
 00   60 12 86 38 16 01 98 02 01 00 80 02 10 38 00 00
 10   00 20 00 E0 00 00 00 00 00 00 00 00 00 00 00 00
 20   00 00 00 00 00 00 00 00 01 08 00 00 CF 17 36 00
 30   00 00 00 00 DC 00 00 00 00 00 00 00 0B 01 0A 1C
 D0   00 00 00 00 00 00 00 00 00 00 00 00 01 00 01 FE
Ethernet Controller
bus 1 (0x01), device 2 (0x02), function 0 (0x00)
Common header
 Vendor ID  0x1106
 Model ID  0x3106
 Revision ID  0x8B
 PI   0x00
 SubClass  0x00
 BaseClass  0x02
 Cache Line  0x04
 Latency   0x08
 Header   0x00
PCI header
 Address 0 (port) 0x0000C000
 Address 1 (memory) 0xE0000000
 Subvendor ID  0x8089
 Subsystem ID  0x1071
 Int. Line  0x0B
 Int. Pin  0x01
Capabilities
  Version  1.1
  Dump
  01 00 02 FE 00 00 00 00
Dump
 00   06 11 06 31 87 00 10 02 8B 00 00 02 04 08 00 00
 10   01 C0 00 00 00 00 00 E0 00 00 00 00 00 00 00 00
 20   00 00 00 00 00 00 00 00 00 00 00 00 89 80 71 10
 30   00 00 00 00 44 00 00 00 00 00 00 00 0B 01 03 08
 40   00 00 00 00 01 00 02 FE 00 00 00 00 00 00 00 00
PCI to CardBus Bridge
bus 1 (0x01), device 3 (0x03), function 0 (0x00)
Common header
 Vendor ID  0x104C
 Model ID  0xAC50
 Revision ID  0x02
 PI   0x00
 SubClass  0x07
 BaseClass  0x06
 Cache Line  0x08
 Latency   0x80
 Header   0x02
PCI header
Capabilities
  Version  1.0
  Dump
  01 00 11 FE 00 00 C0 00
Dump
 00   4C 10 50 AC 07 00 10 02 02 00 07 06 08 80 02 00
 10   00 E0 BF FE A0 00 00 02 01 02 02 40 00 D0 BF FE
 20   00 D0 BF FE 00 D0 BF FA 00 C0 BF FE 00 FF 00 00
 30   FC FF 00 00 00 FE 00 00 FC FE 00 00 0A 01 C0 00
 40   71 10 89 80 01 00 00 00 00 00 00 00 00 00 00 00
 80   60 90 44 00 00 00 00 00 00 00 00 00 02 1C 11 01
 90   C0 22 64 61 00 00 00 00 00 00 00 00 00 00 00 00
 A0   01 00 11 FE 00 00 C0 00 17 00 00 00 07 00 00 00
DMI
DMI BIOS
 vendor  Insyde Software Corporation
 version  M1.02
 date  09/13/2004
DMI System Information
 manufacturer Notebook
 product  MIM2050
 version  FAB-2
 serial  12345678
 UUID  55555555-55555555-55555555-55555555
DMI Baseboard
 vendor  Notebook
 model  Montara-GML
 revision FAB-2
 serial  12345678
DMI System Enclosure
 chassis type Portable
 chassis serial 12345678
DMI Processor
 manufacturer GenuineIntel
 model  Pentium 4
 clock speed 1500.0MHz
 FSB speed 133.0MHz
 multiplier 11.5x
DMI Port Connector
 designation Kbd Connector (internal)
 designation J8 (external)
 port type Keyboard Port
 connector PS/2
DMI Port Connector
 designation Mouse Conn. (internal)
 designation J9 (external)
 port type Mouse Port
 connector PS/2
DMI Port Connector
 designation USB Conn. (internal)
 designation J12 (external)
 port type USB
DMI Port Connector
 designation Dock Conn. (internal)
 designation J6 (external)
DMI Port Connector
 designation VGA Conn. (internal)
 designation J7 (external)
DMI Port Connector
 designation DC Input (internal)
 designation J35 (external)
DMI Port Connector
 designation CardBus Conn. (internal)
 designation J26 (external)
 port type Cardbus
DMI Extension Slot
 designation ISA Slot
 type  ISA
 width  16 bits
 populated no
DMI Extension Slot
 designation PCI Slot
 type  PCI
 width  32 bits
 populated no
DMI Physical Memory Array
 location Motherboard
 usage  System Memory
 correction None
 max capacity 256MBytes
 max# of devices 1
 usage  Flash Memory
 correction None
 max capacity 0MBytes
 max# of devices 1
 usage  Cache Memory
 correction None
 max# of devices 1
DMI Memory Device
 designation DRAM Slot 0
 format  DIMM
 type  DRAM
 total width 64bits
 data width 64bits
 size  256MBytes
DMI Memory Device
 designation DRAM Slot 1
 format  DIMM
 type  DRAM
 total width 64bits
 data width 64bits
 size  256MBytes
merci d avance pour votre aide
n°4762206
dami1stm
Eco-coco φ
Posté le 12-04-2006 à 19:29:34  profilanswer
Ste paté...  [:gaxx]
Je pensse à l'ecran, ou la CG...
"La liberté d'expression n'a d'ennemis que ceux qui veulent se réserver le droit de tout faire" - "Seems all have gone insane for gold"
n°4764026
gaston lag​affe22
m'enfin !?!
Posté le 13-04-2006 à 15:16:29  profilanswer
Rétro-éclairage HS je dirais... :/
n°4764034
tompouss
Petit chat
Posté le 13-04-2006 à 15:20:28  profilanswer
vérifie si ton contraste et ta luminosité sont pas au minimum...
n°4764426
emigerr
Posté le 13-04-2006 à 17:45:01  profilanswer
Ben quand je le passe en vga tout va bien
Quelqu un sait le prix d une répa comme ça (rétro-éclairage)??
n°4764455
tompouss
Petit chat
Posté le 13-04-2006 à 17:57:37  profilanswer
à mon avis trop cher (genre tu t'en rachete un nouveau ca te revient moins cher)
n°4764660
gaston lag​affe22
m'enfin !?!
Posté le 13-04-2006 à 19:37:43  profilanswer
C'est à dire? Tu veux dre quand tu branche un écran externe derrière ton portable? [:figti]
n°4764670
emigerr
Posté le 13-04-2006 à 19:40:58  profilanswer
oui c est ça
n°4764894
gaston lag​affe22
m'enfin !?!
Posté le 13-04-2006 à 20:59:42  profilanswer
emigerr a écrit :
oui c est ça
ok! :jap:
n°4765142
emigerr
Posté le 13-04-2006 à 22:24:34  profilanswer
je suis bien avancé avec tout ça
n°4765200
gaston lag​affe22
m'enfin !?!
Posté le 13-04-2006 à 22:55:41  profilanswer
Il a combien d'années ton portable? Il est toujours sous garantie? [:figti]
n°4765473
emigerr
Posté le 14-04-2006 à 08:45:22  profilanswer
plus garantie elle est dépassé de 2 mois
il a 14 mois arf
n°4765482
mrdoug
Posté le 14-04-2006 à 09:01:42  profilanswer
Un portable vit environ 3 ans.
14 mois c'est rien :/
n°4766002
gaston lag​affe22
m'enfin !?!
Posté le 14-04-2006 à 13:41:48  profilanswer
il a 14 mois arf
T'es sûr qu'il a pas une garantie de 3 ans??? [:figti]
Même plus que 3 ans! Le mien à 5 ans et il est nickel! (bon ok c'est un IBM, mais quand même!) :jap:
probleme avec disque dur externe teac. au secours!Probleme DD SATA. Windows Bloque au login
gros pb help me!aidez moi svp gros probleme disque dur!!
problème avec carte intégrer ETHERNET NVIDIAProblème graveur DVD sous Windows XP
Probleme ASUS P4P800E Dlx / Disques WD740 Raid 0Pc qui ne démarre plus ! Help !
Probléme de drivers :(
Plus de sujets relatifs à : [HELP] probléme de dalle sur mon portable médion
