4903 connectés
  CTX 19'' PR960F P0,24 TRINITRON USB BNC (232/30-110/1920*1440)
n°1378080
xice007
Koudy vy îidete?
Posté le 23-04-2002 à 11:16:46  profilanswer
Vous en pensez quoi?
PR960F
http://www.ctxintl.com/images/pr960f_s.jpg
19" FD Trinitron® CRT (18" diagonal Viewable Image Size)
0.24mm Pitch Aperture Grille (Center)
ARAG® Screen Treatment
USB Hub
Frequency Range
Horizontal: 30-110kHz
Vertical: 50-160Hz
Screen Resolutions
1800 x 1440 @ 72Hz
1600 x 1200 @ 87Hz
1280 x 1024 @ 102Hz
1024 x 768 @ 136Hz
800 x 600 @ 160Hz
Video Input
Bandwidth: 232MHz
Input Signal
Video: RGB analog (0.7V p-p, 75 ohms)
Sync: Separate TTL H/V +/-, Composite, Sync-on-green
Input Connector
15-pin mini D-sub (Detachable cable)
BNC Connector
Compatibility
IBM® PC and PC compatibles
Mac® (up to 1152 x 864)
Power Requirement
100-120/220-240V AC (auto switch), 50/60Hz
Power Consumption
Operation Mode: 125W (maximum)
User Controls
Front Panel Controls:
Power On/Off, Key1, Key2, Up, Down
On-Screen Menu Controls:
Brightness/Contrast, H/V Position, H/V Size, Rotation,
Pin-Balance, Side-Pin, Trapezoid, Parallelogram,
Moire canellation, Reset, Multi-language, Degauss, Status,
Convergence, Recall, BNC/D-sub Select, Self-diagnosis
Color Adjustment (3 setting modes, 1 user mode)
Input Freq. Display, Fre. Out of Range Alarm
Regulation Compliant
Safety: UL, CE, cUL, Nemko, FCC-B, CB, BCIQ, TCO'99
X-Ray: DHHS
Ergonomics: ISO9241-3 & ISO9241-8
Plug & Play: DDC-1, DDC-2B
Power Management
Energy Star®, VESA® DPMSTM, TCO'99
Operating Condition
Temperature: 32° F to 104° F (0° to 40° C)
Humidity: 20%-80% (non-condensing)
Dimensions (W x H x D)
Carton:
24.3" x 22.2" x 20.3"
Monitor:
18.1" x 18.5" x 19.1"
Weight
Gross: 61.7 lbs
Net: 57.2 lbs
Warranty
Three year limited warranty on parts, labor and CRT
http://www.ctxintl.com/products/pr960f.htm
n°1378097
Arcord
Posté le 23-04-2002 à 11:21:14  profilanswer
j'en ai un et j'en suis très content.
En plus, le SAV CTX est très bon (on sais jamais).
La sagesse et la Connaissance commencent quand on sait que l'on ne sait rien.
n°1378102
xice007
Koudy vy îidete?
Posté le 23-04-2002 à 11:23:13  profilanswer
merci!
tu la payé combien?
640?
n°1378116
Arcord
Posté le 23-04-2002 à 11:28:50  profilanswer
Nan, je l'ai payé beaucoup, beaucoup moins cher (BCoze i'm Revendeur)
n°1378126
xice007
Koudy vy îidete?
Posté le 23-04-2002 à 11:35:29  profilanswer
MOI je le paye 549....t'en penses quoi nivo prix??
sinon, tu es content à tous nivo?
n°1378130
Arcord
Posté le 23-04-2002 à 11:37:04  profilanswer
549 ?, ça me parait bien.
Je suis content à tous les niveaux, mais la qualité d'affichage d'un moniteur est une notion très subjective je trouve (hors spécification techniques bien sûr).
n°1378135
xice007
Koudy vy îidete?
Posté le 23-04-2002 à 11:39:28  profilanswer
oui c vrai.. mais je voulais juste avoir un avis rassurant pour que je puisse l'acheter les yeux fermés... merci!
Un lcd c bien aussi ;)
n°1386353
xice007
Koudy vy îidete?
Posté le 26-04-2002 à 11:13:38  profilanswer
c bon, je l'ai acheté!
c lourd!
mais quelle qualité d'image!!!!!!!
 :crazy:
n°1386368
Arcord
Posté le 26-04-2002 à 11:17:15  profilanswer
Et oui.
Tu vas pleurer si tu va faire des lan souvent (30 kg je crois).
n°1386383
xice007
Koudy vy îidete?
Posté le 26-04-2002 à 11:21:08  profilanswer
Et oui.
en effet... je vais me muscler!
Mais après la mort de mon 17 pouces (je vais d'ailleurs faire un topic) j'ai décider d'acheter un moniteur, ou un LCD pour 369 euros ou le CTX pour 549 Euros un promo, je suis content de ce dernier choix!
dommage que le hub ne soit pas en USB 2.0 mais c déjà bien! :hello:
n°1386409
reunionf
https://www.sonato.org
Posté le 26-04-2002 à 11:32:40  profilanswer
HT où 7 écran ?
c'est pas une dalle plate ?
n°1386414
xice007
Koudy vy îidete?
Posté le 26-04-2002 à 11:33:38  profilanswer
reunionf a écrit a écrit :
HT où 7 écran ?
SI DALLE PLATE TRINITRON
n°1386415
Arcord
Posté le 26-04-2002 à 11:33:48  profilanswer
Si c'est une dalle plate, le tube est du Trinitron.
pitch de 0,24 si ma mémoire est bonne.
edit: grillé
[jfdsdjhfuetppo]--Message édité par Arcord le 26-04-2002 à 11:34:06--[/jfdsdjhfuetppo]
n°1386424
reunionf
Posté le 26-04-2002 à 11:37:23  profilanswer
Vous l'achetez où ?
dalle plate à grille ?
n°1386522
bobo
Posté le 26-04-2002 à 12:08:37  profilanswer
j'suis content pour vous
j'avais ht un LaCie 19" aux mêmes carctétisques (avec 2 a 3 trucs en + : usb mouse + keyboard + output rgb)
=> ben le vendeur à garde mon fric et l'écran ....
=> c la panacé pour me faire rembourser...
=> depuis g une merde de 19" : iiyama LS902UT g les yeux bouffis en 5min....
1+1=10
n°1386534
reunionf
Posté le 26-04-2002 à 12:13:55  profilanswer
Vous l'achetez où ?
personne !
n°1386549
Arcord
Posté le 26-04-2002 à 12:21:05  profilanswer
Vous l'achetez où ?
Regarde mon deuxième post, tu verras que je ne peux pas te répondre, je ne serais pas objectif. :)
Ports USB[ Scanner Epson Perfection USB + Windows XP ]
probleme USB bizarre...Equerre USB optionnelle, que prendre ?
Lian Li PC 70 --> USB ?Probleme installation sidewinder gamepad USB sur win 98 se :-(
Port USB ou IEEE 1394 pour disque dur externe ?Photoshop 5.0 et APN Coolpix 995 USB Nikon ???
Walking Disk USB ou Pen Drive ?Quel chipset pour modem ECI USB ?
Plus de sujets relatifs à : CTX 19'' PR960F P0,24 TRINITRON USB BNC (232/30-110/1920*1440)
