7168 connectés
  [TOPIC OFFICIEL] Epox 8RDA3+
 Page :   1  2  3  4
Page Précédente
n°2483968
Sleeve
Posté le 30-05-2003 à 23:35:58  profilanswer
http://img.hexus.net/8RDA3+/Title.jpg
http://membres.lycos.fr/cybear/Forum/topicR+.gif
la mobo vue d'ensemble
http://www.3dnews.ru/documents/5239/8rda3+board_3d.jpg http://www.epox.com.tw/images/pro_pic/EP-8rda3+.jpg
la boite ...
http://www.3dnews.ru/documents/5239/8rda3+box.jpg
le bundle
http://www.3dnews.ru/documents/5239/8rda3+inbox.jpg
http://www.3dnews.ru/documents/5239/8rda3+nb1.jpg
petit detail il y  a un rad passif sur le south bridge
http://www.3dnews.ru/documents/5239/8rda3+slots.jpg
le sorties ... y a 2 brackets en plus (com2,jeux firewire)
http://www.3dnews.ru/documents/5239/8rda3+back_panel.jpg
Specifications in detail
Processors
Supports Socket A (Socket 462) for AMD® Athlon? / Athlon XP / Duron? processor
Supports up to XP3200+ processor and higher (Thoroughbred and Barton compatible)
Support for 200 / 266FSB / 333FSB / 400FSB processors.
Chipset
Northbridge: NVIDIA nForce2 SPP (Ultra 400)
Southbridge: NVIDIA nForce2 MCP
System Memory
3 x 184pin DDR DIMM slots
DDR200 / DDR266 / DDR333 / DDR400 support @ 2.5v
3GB maximum system RAM (non-ECC), 2GB for DDR400
Dual DDR architecture combines 2 independent 64-bit memory controllers
Dual DDR provides up to 6.4GB/s of buffered system bandwidth
Slots
One AGP 8/4x AGP compliant
5x 32-bit PCI 33MHz slots
On-board peripherals
1 Floppy port supports 2 FDD
1 Parallel port
1 iRDA connector
PS/2 Keyboard
PS/2 Mouse
3 Audio Jacks (NVIDIA APU via CMI9739A)
6 x USB 2.0 connectors from MCP SB (4 on-board + 2 by an additional bracket, not supplied)
Headers for 3 FireWire ports and 1 USB2.0 port
On-board IDE
An IDE controller on the NForce2 MCP chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA133/100/66/ operation modes
Can connect up to 4 IDE devices
Sil3112A S-ATA bridge supports 2 S-ATA ports in independent, RAID0 and RAID1 formats
Audio
NVIDIA 6-channel sound via CMI 9739A 6-channel CODEC.
Supports real time software AC3 encoding and S/PDIF-Out
Other features
NVIDIA 10/100 LAN via Realtek RTL8201LB physical interface.
Second 10/100 LAN from Realtek RTL8101L single-chip controller
FireWire support (3x 1394a) via Agere FW323A single-chip controller
BIOS & Voltages
EPoX PowerBIOS
FSB speeds of 100MHz - 250MHz in 1MHz stepless increments
1.1 - 2.2v Vcore adjustable in 0.025v increments
2.5v - 2.9v DDR voltage adjustment in 0.13v increments
1.5 - 1.8v AGP adjustment in 0.1v increments
1.6 - 2.0v Vdd adjustment in 0.2v increments
Bios
dernier en date :
8RD33526
http://www.epox.com.tw/content.exe [...] 3526&page=
BIOS: 8RD33526.BIN (DD00)
Released Date: 05/29/2003
Fixed:
1) Update BPL to V3.02R1.
2) Support auto detect Thorton CPU.
3) Fixed the Sil3112A data loss issue when test RAID and write large files.
8rd33507
http://www.epox.com.tw/file/8RD33507.BIN
Site officiel (taiwan)
http://www.epox.com.tw/product.exe?pn=EP-8RDA3%2b
Message édité par Sleeve le 07-06-2003 à 21:52:09
n°2483977
Sleeve
Posté le 30-05-2003 à 23:39:57  profilanswer
pour mbm les reglages par exemple ?
c bizarre je viens de voir qu'il n'y a pas de com, uniquement 1 fourni su run bracket  :whistle: ...
bon demain formatage de c ... depuis janvier mon hd a vue :
nforce 2(chaintech 7NJS) + ti4400(Msi)
nforce 2 + ati radeon 9700 (manli)
kt333 + ati radeon9700
kt400 + ati radeon9700
nforce 2 ultra 400 + ati radeon9700
et sans aucun formatage ... chapeau à xp pro ... :sarcastic:
n°2484249
Sleeve
Posté le 31-05-2003 à 08:34:38  profilanswer
:bounce:
Message édité par Sleeve le 31-05-2003 à 08:35:13
n°2484365
Nowa
XOXO
Posté le 31-05-2003 à 10:53:47  profilanswer
Je l'ai eu il y a 3 jours  :D
Très très content d'elle  :love:
 :whistle:
Message édité par Nowa le 31-05-2003 à 11:03:41
n°2484644
-fleo-
HUH?
Posté le 31-05-2003 à 13:36:03  profilanswer
qq1 sait si cette cm lit la sonde interne du procco
parce que vu que la 8rda+ ne la lit pas je me demandais :> ..
n°2484725
Sleeve
Posté le 31-05-2003 à 14:25:54  profilanswer
je sais pas trop mais sous mbm j'ai 3 temperatures ...
winbond 1 => chipset 30°c
winbond 2 => die (?) 38°C
winbond 3 => socket (?)  35°c
piece 25°c .
je sais pas mais ça ressemble bien au die pour la winbond 2 ...
n°2485935
EpOx_PoWa
Athlon 64 POWWAAA !!!
Posté le 01-06-2003 à 08:27:42  profilanswer
bon c moi sleeve j'ai perdu mon password pour mon ce pseudo ... et je sais pas comment faire pour le retrouver ...  :sweat:
n°2486453
-fleo-
HUH?
Posté le 01-06-2003 à 13:29:37  profilanswer
donc personne ne sait si ya une lecture de la sonde interne du core   :pt1cable:
n°2486641
Noooky
Posté le 01-06-2003 à 14:47:33  profilanswer
je crois qu'elle lit la sonde interne  ...
-gere t elle les coeff sup à 12.5 ?
n°2486752
neo keon
Posté le 01-06-2003 à 15:22:03  profilanswer
lut a tous dit moi sleeve chez quel revendeur l'as tu trouvée?
n°2486761
EpOx_PoWa
Posté le 01-06-2003 à 15:25:11  profilanswer
open jl , j'habite à 5min du magasin ...
155euros .
et oui elle gere TOUS les coefs , du moins sur mon xp2400+, et bios d'origine ...
et pour la sonde avec mbm c ok elle lit la sonde interne,socket et chipset . c sur .
n°2486778
neo keon
Posté le 01-06-2003 à 15:29:31  profilanswer
open jl  :heink:
il est en vpc ? une adresse ?
n°2486844
EpOx_PoWa
Posté le 01-06-2003 à 15:55:14  profilanswer
tu connais pas ?  :??: ? heu ... enfin bon ... c un des plus gros magasin de tuning/watercooling pc en france , à coté on a aussi doc-micro .
les adresses :
www.openjl.fr
www.docmicro-fr.com
autrement c bien la 8rda3+ ... j'ai testé mon xp2400+@2175(13x166) bon ras sous 3dmar2001se, par contre reboot sous gta vice city, faut que je vois je pense que ma ram est sous alimenté, avant ras sur une 7NJS ram à 2.7 par defaut et avec l'epox la ram est à 2.53 ou 2.66 je sais plus ... je testerai demain ^^ .là aujourd'hui c detente , jeux ,animez ...
n°2490973
Noooky
Posté le 03-06-2003 à 11:21:07  profilanswer
:bounce:
n°2490980
franck1135
Posté le 03-06-2003 à 11:25:13  profilanswer
J'ai cette carte depuis samedi et dans l'ensemble elle est bien.
Mais il y a toujours le problème de mise en veille j'ai était obliger de mettre des rads sur les moffsets avec un ventilo qui souffle dessus.Sinon en cassant la patte du régulateur cela resoud le problème mais bon apres plus de garantie.
n°2491001
EpOx_PoWa
Posté le 03-06-2003 à 11:33:27  profilanswer
c k cepbm de mise en veille ?
autrement quia mis son bios àjour ?
n°2491028
Noooky
Posté le 03-06-2003 à 11:45:34  profilanswer
à partir de quel fsb ? tes timmings, ta ram stp ?
merci ;)             edit: ok pour la ram corsair LL PC 3200
Message édité par Noooky le 03-06-2003 à 11:46:52
n°2491067
franck1135
Posté le 03-06-2003 à 12:00:43  profilanswer
A partir a 1.95 de vcore mise en veille a m'importe quel FSB.Maintenant avec les rads et le ventilo j'ai essayé 2.15 v et pas de mise en veille.
Message édité par franck1135 le 03-06-2003 à 12:01:36
n°2491100
EpOx_PoWa
Posté le 03-06-2003 à 12:18:47  profilanswer
tu peux nous mettre une petite photo ? :D
n°2491103
Noooky
Posté le 03-06-2003 à 12:20:13  profilanswer
refroidissement du northbridge actif, passif ?
n°2491134
EpOx_PoWa
Posté le 03-06-2003 à 12:38:23  profilanswer
moi le rad il est chaud je trouve, j'ai un zalman, je me demande si ça serait pas mieux ... au pire je monterais un waterblock dessus ... :whistle:
n°2491141
franck1135
Posté le 03-06-2003 à 12:41:17  profilanswer
Je vais mettre une photos  :D je mange et je la poste.
Et sur mon rad du chipset il y a un ventilo de taisol 690.
Message édité par franck1135 le 03-06-2003 à 12:42:00
n°2491884
kingelmer
Posté le 03-06-2003 à 16:14:22  profilanswer
juste une tite kestion pour la 8rda3+ le chipset son est celui de nvidia ou un chipset ac 97 banal ???
n°2491916
ionik
Posté le 03-06-2003 à 16:23:23  profilanswer
y'aurait'il un truc pour cooller des petit radiateur dur les moffset avec de la pate thermique artic silver 3? sans avoir de pate thermique collante? car j'ai une 8rda3+ et j'ai des mise en veille a partir de 2350 ceux qui est un peu chiant vu que mon cpu tiens a 1.70 volt reel a cette frequence xp 1700+ dlt3c il me semble que c'est un 1103
n°2492971
EpOx_PoWa
Posté le 03-06-2003 à 21:55:32  profilanswer
c l'apu nvidia, mais collé à un C-Media, tres bonne qualité, utilisé aussi par chaintech . le seul truc, c qu'il manque le dolby digital, mais pour l'utilisation courante on s'en balance ... moi j'ai un lecteur dvd et un home cinema dans le salon ...  :hello:
n°2493062
franck1135
Posté le 03-06-2003 à 22:36:12  profilanswer
une vu globale
http://perso.wanadoo.fr/franck1135/pc.jpg
Et une vue sur les moffsets
http://perso.wanadoo.fr/franck1135/pc3.jpg
n°2494973
dd83
Posté le 04-06-2003 à 18:59:54  profilanswer
Non ce n'est pas possible, il n'y a pas l'APU Nvidia (c'est le MCP et non le MCP-T) sur cette mobo :sweat:
C'est un chip Cmedia qui s'occupe du son à la place, tu dois donc installer les drivers Cmedia pour le son.
Message édité par dd83 le 04-06-2003 à 19:01:03
Carpe Diem. Enjoy the present as if everyday was a gift...
n°2495805
Noooky
Posté le 05-06-2003 à 00:38:20  profilanswer
 :sweat:
merci dd83
n°2496000
John_AmD
Hippi-Kai-He
Posté le 05-06-2003 à 08:59:47  profilanswer
Lut tous, alors pour ceux qui ont cette mobo, j'aimerais savoir a combien vous montez en FSB.
J'aimerai la prendre, monter un ventilateur sur le chipset et allaient jusqu'a un FSB de 250.
Perso, je savais pas que cette mobo utilisaient un chip son media et non l'apu, c vraiment nul :heink:
n°2496052
EpOx_PoWa
Posté le 05-06-2003 à 09:37:04  profilanswer
pas grave il est de qualité ... au dessus d'une sound blaaster live ...
n°2496355
dd83
Posté le 05-06-2003 à 11:47:56  profilanswer
Ben je suis décu aussi :sweat:
La même avec l'APU/Soundstorm je l'aurais achetée direct :)
n°2496420
EpOx_PoWa
Posté le 05-06-2003 à 12:30:51  profilanswer
ouai mais question overlocking, c du epox ... enfin bon, vu la qualité des mobo tout nforce 2 ... moi c'etait vite vu, asus c  :pfff: ... abit oui^^, mais le reste ... :hello:
n°2496473
kingelmer
Posté le 05-06-2003 à 12:59:03  profilanswer
kler que kestion O/C c une bete en puissance je viens de l acheter et je suis en 11*205 peinard :love:  et je vais encore faire des test pour monter plus ht :)
Avant de faire des tests je voulais savoir ce que je pouvais mettre pour refroidir le chipset ?? Merci de vos reponses
Epox 8rda3+ Barton 2500 @2255Mhz Ge Force 4 ti 4400 / Slk 900 + enermax 92 / Xaser III / 2*512 twinx Corsair 3200 LL :)
n°2497377
dd83
Posté le 05-06-2003 à 18:25:59  profilanswer
Ben j'ai une 8RDA+ avec chipset Nforce2 Ultra et je l'adore :)
220 de FSB tranquille :love:
n°2497569
kingelmer
Posté le 05-06-2003 à 19:29:31  profilanswer
j ai juste un tit blem qui m arrive meme quand j O/c pas mon pc !! ca boot aleatoirement !! si kkun a une idee je vois pas !! Merci
n°2497770
franck1135
Posté le 05-06-2003 à 20:27:55  profilanswer
L'acpic est activé ou pas?
n°2501973
Noooky
Posté le 07-06-2003 à 15:40:07  profilanswer
j ai desactive l acpi  ca aide pour les haut fsb parait il :d
n°2502141
EpOx_PoWa
Posté le 07-06-2003 à 17:30:17  profilanswer
:bounce:
n°2502706
Sleeve
Posté le 07-06-2003 à 21:52:30  profilanswer
 :sol:
n°2503572
EpOx_PoWa
Posté le 08-06-2003 à 12:50:43  profilanswer
je sais j'ai retrouvé mon mot de passe ... grace à joce ou marc ... mais je conserve un multinick (celui la et Sleeve) cela depends d'où je me connect ^^.
(epox powa c pour mon frere) et sleevec pour moi . :hello:
 Page :   1  2  3  4
Page Précédente
epox 8k9aOù trouver les drivers de l'Epox P55-TH
Pb de son avec Epox 8-RDa nforce 2[topic officiel] Asus A7V8X-X
[Topic Unique] ASUS P4C800 & P4P800 (BIOS 1011 officiel) !!!Epox: afficher la t° du cpu sur l'afficheur LCD de la cm
Epox 8kha+ et son intégréTopic officiel ViewSonic VP171b. Nouvel écran LCD 17" 16 ms
TOPIC surement officiel SOLTECK 75 FRN2-Labit KX7-333 ou Epox 8K7A+
Plus de sujets relatifs à : [TOPIC OFFICIEL] Epox 8RDA3+
