9564 connectés
  [Topic unique ] DFI LanParty PRO875 , vos avis ....
n°2469418
netpower
Posté le 24-05-2003 à 23:41:56  profilanswer
salut
Voila, je trouve le pack DFI avec ces carte LanParty assez sympa et les carte ont l'air tres complete , mais une question subsite :
que pensez vous qu'elle vaille pour l'overclocking sachant qu'elle integre un Bios Award intégrant leur "Genie Bios" ?
Voici les caracteristique :
http://www.dfi.com.tw/Product/xx_p [...] CT_ID=1134
http://www.dfi.com.tw/Upload/Product_Picture/LANPARTY%20PRO875%20b.jpg
Bouyton de RESET sur la carte mere
http://www.pconline.com.cn/pchardware/tpylab/main/10305/pic/cp0351406.jpg
http://www.pconline.com.cn/pchardware/tpylab/main/10305/pic/cp0351409.jpg
Cable ronf phosphorescent
http://www.pconline.com.cn/pchardware/tpylab/main/10305/pic/cp0351414.jpg
PROCESSOR
Intel® Pentium® 4 Processor with Hyper-Threading Technology - 800MHz and 533MHz FSB
Intel® P4 Northwood and Prescott processor (478-pin)
Supports 800MHz, 533MHz or 400MHz FSB
  CHIPSET
 Intel® 875P chipset
     - Intel® 82875P Memory Controller Hub (MCH)
     - Intel® 82801ER I/O Controller Hub (ICH5R)
  SYSTEM MEMORY
 Supports dual channel (128-bit wide) memory interface
     - Each channel supports 2 DIMM sockets
Supports up to 4GB system memory
Supports Dynamic mode to optimize system performance
Synchronous operation with processor system bus
     - PC2100/PC2700/PC3200 (DDR266/DDR333/DDR400) with 800MHz FSB CPU (supports PAT mode). DDR333 will run
       at 320MHz memory frequency when used with 800MHz FSB CPU.
     - PC2100/PC2700 (DDR266/DDR333) with 533MHz FSB CPU
     - PC2100 (DDR266) with 400MHz FSB CPU
Supports ECC/non-ECC DIMMs
Supports unbuffered DIMMs
  BIOS
 Award BIOS, Windows® 98SE/2000/ME/XP Plug and Play compatible
Genie BIOS provides:
     - CPU/DRAM overclocking in 1MHz stepping
     - AGP/PCI/SATA overclocking
     - CPU/DIMM/AGP overvoltage
Flash EPROM for easy BIOS upgrades
4Mbit flash memory
  ENERGY EFFICIENT DESIGN
 Supports ACPI specification and OS Directed Power Management
Supports ACPI STR (Suspend to RAM) function
Wake-On-Events include:
     - Wake-On-Keyboard/Mouse
     - Wake-On-USB Keyboard
     - Wake-On-Ring (external modem)
     - Wake-On-LAN
     - RTC timer to power-on the system
  DAMAGE FREE INTELLIGENCE
 Monitors CPU/system temperature and overheat alarm
Monitors CPU/1.5V/5VSB/VBAT/3.3V/5V/±12V voltages and failure alarm
Monitors CPU/chassis/second fan speed and failure alarm
Automatic chassis/second fans on/off control
Read back capability that displays temperature, voltage and fan speed
CPU Fan Protection function monitors the CPU fan during system boot-up
CPU Temperature Protection function monitors CPU  temperature during system boot-up
  AUDIO FEATURES
 20-bit stereo full-duplex codec with independent variable sampling rate
High quality differential CD input
True stereo line level outputs
S/PDIF-in/out interface
6-channel audio output
  ONBOARD CSA GIGABIT LAN
 Uses 82547EI Gigabit LAN CSA interface
Integrated power management functions
Full duplex support at both 10, 100 and 1000 Mbps
Supports IEEE 802.3u auto-negotiation
Supports wire for management
  ATA RAID (Redundant Array of Inexpensive Disk)
 Uses HighPoint 372N RAID controller
RAID 0, 1, 0+1 and 1.5
Two independent IDE channels support 4 hard disk drives (ATA/33, ATA/66, ATA/100, ATA/133 or EIDE)
Supports PIO modes 0/1/2/3/4, DMA modes 0/1/2 and UDMA modes 0/1/2/3/4/5/6
  PCI IDE INTERFACE
 Supports ATA/33, ATA/66 and ATA/100 hard drives
PIO Mode 4 Enhanced IDE (data transfer rate up to 14MB/sec.)
Bus mastering reduces CPU utilization during disk transfer
Supports ATAPI CD-ROM, LS-120 and ZIP
  ICH5R SATA IDE/RAID0 INTERFACE
 Supports two SATA (Serial ATA) interfaces which are  compliant with SATA 1.0 specification (1.5Gbps interface)
Supports RAID 0
  PROCESSOR SOCKET
 Socket 478
  ACCELERATED GRAPHICS PORT (A.G.P.)
 Supports 1.5V AGP 8x (2.13GB/sec.) and AGP 4x (1066MB/sec.) for 3D graphics applications (AGP 2x and
     3.3V AGP card are not supported)
Supports AGP 3.0 and AGP 2.0 spec.
  REAR PANEL I/O PORTS
 4 USB 2.0/1.1 ports
1 RJ45 LAN port
2 DB-9 serial ports
1 DB-25 parallel port
1 mini-DIN-6 PS/2 mouse port
1 mini-DIN-6 PS/2 keyboard port
3 audio jacks: line-out, line-in and mic-in
  I/O CONNECTORS
 2 connectors for 4 additional external USB 2.0/1.1 ports
1 front audio connector for external line-out and mic-in jacks
1 connector for an external game/MIDI port
2 internal audio connectors (CD-in and AUX-in)
1 4-channel audio output connector
1 S/PDIF-in/out connector
1 connector for IrDA interface
2 RAID IDE connectors
2 Serial ATA connectors
2 IDE connectors
1 floppy connector
2 ATX power supply connectors
1 Wake-On-LAN connector
3 fan connectors for CPU fan, chassis fan and second fan
  EXPANSION SLOTS
 1 AGP slot
5 PCI slots
  COMPATIBILITY
 PCI 2.2 and AC ?97 compliant
Intel AGP version 3.0
  PCB
 4 layers, ATX form factor
30.5cm (12.05" ) x 24.4cm (9.6" )
de plus il ont une sorte de softmenu IIi a la Abit mais qui s'appelle "Genie Bios" chez DFI :
CPU Clock : The available option allow you to adjust the processor bus clock by Imhz increment
CPU ratio clock :This field use to select the CPU freqhency ratio
CPU Clock Now Is : This field will show the CPU clock based on the setting in the CPU CLOCK and CPU CLOCK RATIO fields
AGP/PCI/SATA clock: this fields is use to select AGP/PCI/SATA bus clock
Auto select PCI Clk ; when enabled , the system automatically send clock signal to existing PCI devices
Current CPU voltage : This fields show the CPU voltage
CPU Voltage control : this fields allow ypu to manually adjust to a highter core voltage that is supplied to the CPU. If you want tu use CPU defaul core voltage , leave this fields in its default setting, Wich "default" , the CPU Vcore will be generated according to the CPU VID configuration
Dimm voltage control : this fields alow you to manually select highter voltage supplied to the AGP
CSA Lan (gigabyte) : this fields is used to enabled the onboard CSA Ggabyte LAN
Sinon il y a tous ce qu'il faut pour le reglage de la memoire DDR , vopus pouvez telechargez les 2 manuel au format PDF (multilanguage) sur cette page :
http://www.dfi.com.tw/Support/Down [...] _TYPE=null
Et le dernier bios est telechargeable ici :
http://www.dfi.com.tw/Support/Down [...] TUS_FLAG=A
Pensez vous que cette carte soit taillé pour l'Overclocking ??
Message édité par netpower le 24-05-2003 à 23:47:01
n°2469513
netpower
Posté le 25-05-2003 à 01:05:37  profilanswer
Bon ,; j'aimerais au moins l'avis d'une personne concernant les possibilité d'overclocking de cette carte ??
pensez vous qu'elle vaillent le coup !!
meri d' m'aider car j'envisage peut etre de l'acheter !!
n°2469539
sigma_me
Succube en herbe
Posté le 25-05-2003 à 01:23:50  profilanswer
DFI n'etant pas très vendu en France .. et la carte étant récente ... je pense qu'il va etre plus difficile d'obtenir des commentaires dessus que sur une asus p4c800 ;)
enfin up d'encouragement :D
Depuis 2001, il est toujours déconseillé de m'appeler "mec, gars, monsieur" sur HFR sinon je mords !
n°2469543
[DMA] JF
Posté le 25-05-2003 à 01:25:57  profilanswer
Si elle est dans la lignée des autres DFI fuit  :D  :lol:
BigZeon et BigThon au rapport :)
n°2469544
Ken
H.P. Lovecraft forever !!!
Posté le 25-05-2003 à 01:27:24  profilanswer
 [:darkmavis]
Croire en Dieu est néfaste à l'émancipation individuelle.   "N'est pas mort ce qui à jamais dort, et au long des siècles peut mourir même la mort" HPL
n°2469554
sigma_me
Succube en herbe
Posté le 25-05-2003 à 01:39:10  profilanswer
Nan justemment elle est censée etre différentes ...
ils ont meme refait leur site avec une partie en flash pour les cartes LANPARTY ...
mauvaise langue  :kaola:
(enfin peut etre pas non plus :lol: ;) )
Message édité par sigma_me le 25-05-2003 à 01:39:30
n°2470285
[DMA] JF
Posté le 25-05-2003 à 14:08:54  profilanswer
 :o  :D
n°2608657
Kryten
Casio brille-brille, t'entends
Posté le 20-07-2003 à 22:57:46  profilanswer
Up :D
Des feedbacks à poster ?
Technique maquereau | ECNSP | Fructifier son argent avec les branques
n°2937343
Posté le 11-01-2004 à 20:58:43  answer
drapa
n°2938359
Posté le 12-01-2004 à 12:37:08  answer
euh j'ai chercher un peu mais j'ai rien trovuer sur ce sujet la :/
la carte pro875 ou la pro875b on t'elle le firewire???
Posté le 12-01-2004 à 12:37:08  profilanswer
n°3055127
easyupper
Je t'aime my fairy | In LoVe
Posté le 05-03-2004 à 01:54:18  profilanswer
la pro875 n'a pas  le firewire sinon c'est une tres bonne carte je trouve :)
Puchi Puchi ... - Wa Waaa mon coeur - chi chiii! - Nyuuuuuuu ** Pouf **
Avis sur un magasin d'achat en ligne[topic officiel] Asus A7V8X-X
Avis entre un athlon 2400 + et 2800 +Votre avis sur ma CM
[Topic Unique] ASUS P4C800 & P4P800 (BIOS 1011 officiel) !!![AVIS] Kel imprimante laser couleur CHOISIR ?
Avis pour choix configVos avis sur une telle config...
Avis sur configuration
Plus de sujets relatifs à : [Topic unique ] DFI LanParty PRO875 , vos avis ....
