3734 connectés
  i815 ep pro supporte combien de sdram maX ?
n°2309005
theangel24
Posté le 21-03-2003 à 09:53:36  profilanswer
GA-6OXC (je suis pas sur de la fin, sur c'est que cun i815ep pro, y a aps de son, mais udma 100 et support p3 et c2)
Intel 815(E/P/EP) chipset
Processor
Socket 370 for Intel® FC-PGA Pentium® III or other compatible processors
Supports Auto/66/100/133 MHz FSB (Front Side Bus)
Chipset
Intel® 815P AGPset
Intel® FW82801AA (ICH)
iTE IT8712F Super I/O & health chip
Memory
3 DIMMs 168-pin sockets
Supports 32/64/128/256/512 MB SDRAM modules
Expansion Slots
1 x AGP slot supports 2X/4X mode & AGP 2.0 compliant
6 x PCI slots support 33MHz & PCI 2.2 compliant
1 x AMR slot (reversed)
I/O
2 x UDMA ATA 66/33 IDE ports on board
1 x FDD, 2 x COM, 1 x LPT, PS/2 Keyboard, PS/2 Mouse on board
2 x USB ports on board
1 x SCR (Smart Card Reader) connector
IrDA TX / RX header
Power
ATX power connector
Power-on by LAN, RTC, Modem & Switch
Power-off by Windows® 95/98/Me/2000/NT shut down & Switch
Form Factor
ATX form factor , 4 layer PCB (30.5*21.5 cm)
H/W Monitoring
Auto speed down and alarm when CPU overheat or fan failure (OS independent & driverless)
3 fan power & speed detection connectors
System health status detect & report by BIOS
H/W detect & report power-in voltage, CPU voltage and CMOS battery status
BIOS
2M bit flash ROM BIOS, enhanced ACPI feature for PC98/Win98/Win2000/ WinME compliance, Green, PnP, DMI, INT13 (>8.4GB) & Anti-Virus functions
IDE#1~#4, SCSI, LS120, ZIP & CD-ROM bootable
Auto-detect & report system health status
Supports @BIOS? Live Update
Other Features
Supports Wake-On-LAN (WOL)
Supports Internal / External Modem Ring On
Includes 3 fan power connectors
Poly fuse for keyboard over-current protection
Supports EasyTune III?
Driver
Gigabyte Windows Manager Utility
Gigabyte EasyTune III? and @BIOS? utility
Intel® LDCM® and 815 patch utility for Windows
Hardware monitor utility
je voulais savoir combien suppoorte en sdram le i815 ep pro ???
car je vais la vendre a qq'un qui veut mettre 2x512mo . comme je peux tester la carte que demain je voudrais deja avoir des avis merci^^
mais à mon avis le i815 doit supporter ça quand meme  :sweat:  :D
n°2309007
ixemul
Nan mais sans blague ! ⚡
Posté le 21-03-2003 à 09:55:02  profilanswer
512Mo de ram MAX pour n'importe quelle version du i815... dommage d'ailleur  :sweat:
n°2309013
ixemul
Posté le 21-03-2003 à 10:00:51  profilanswer
jovial a écrit :
aucun pb pour 2x512
 :non:
PS: houuuu le vilain edit/delete :D
n°2309017
Jovial
It's clobberin' time
Posté le 21-03-2003 à 10:05:47  profilanswer
j'm'est trompe, avais cru lire i845  :)
n°2309126
BloodyCarn​age
Posté le 21-03-2003 à 11:10:11  profilanswer
Je confirme, avec + de 512Mo, la carte compte la RAM correctement mais ne boot pas.
n°2309142
ixemul
Posté le 21-03-2003 à 11:16:33  profilanswer
Normal, c'est bien précisé dans les limitation du chipset i815
n°2309149
BloodyCarn​age
Posté le 21-03-2003 à 11:18:48  profilanswer
vi vi je c, mais g pas pu m'enpecher d'essayer :D
n°2309292
theangel24
Posté le 21-03-2003 à 12:15:43  profilanswer
donc c limité à 512mo dans n'importe qu'elle cas ... c nul intel vraiment nul ... :kaola:
n°2309397
theangel24
Posté le 21-03-2003 à 12:55:17  profilanswer
d'autre avis ? :bounce:
n°2309409
ixemul
Posté le 21-03-2003 à 13:00:25  profilanswer
 :pfff:
n°2309437
theangel24
Posté le 21-03-2003 à 13:15:42  profilanswer
ben quoi ... meme via ils ont pas fait ça ... :o
n°2309466
trustinato​r
Posté le 21-03-2003 à 13:24:31  profilanswer
Avant de critiquer Intel faudrais peut être se rappeller le contexte de l'époque, le I815 etait au départ un chipset bas de gamme d'où une limitation à 512 de ram, faire attention aussi au barette simple et double face car avec 3 barette double face ca merde.
n°2309488
theangel24
Posté le 21-03-2003 à 13:31:53  profilanswer
:sweat:  :jap: c t du cheap ... :(
n°2986147
Okysp
Rien.
Posté le 02-02-2004 à 19:25:21  profilanswer
J'up le topic pour demander quel processeur au max le i815 prend.
Ca passe les Celeron style 1,7 Ghz qu'on trouve en ce moment? :??:
n°2986157
Black Hole​ Sun
Esprit chaotique
Posté le 02-02-2004 à 19:30:56  profilanswer
OkYsP a écrit :
les celeron 1.7 sont des socket 478 : tu va avoir du mal à les rentrer dans le socket 370 de ta mobo :ange:
Les Road Runners sur BOINC - Mon site sur le modélisme radio-commandé
n°2986161
Okysp
Rien.
Posté le 02-02-2004 à 19:32:53  profilanswer
Vi mais je demande car j'y connais rien chez Intel, y'a pas ce genre de pb chez AMD...:o (à prendre au 2nd degré)
Sinon, on trouve plus de proc compatible socket 370?
Et merci de ta réponse. :)
n°2986174
Okysp
Rien.
Posté le 02-02-2004 à 19:36:56  profilanswer
Ca c'est du bon je pense: http://www.monsieurprix.com/listin [...] 17406.html
Il sera à la bonne fréquence sur la mobo?
Et heu...Ca vaut le coup de passer d'un 533Mhz à un 1,3Ghz?
La réponse me semble (presque) évidente, mais je demande quand même...
n°2986175
BloodyCarn​age
Posté le 02-02-2004 à 19:36:59  profilanswer
OkYsP> heuuuu non. Tout ce qu'on trouve maintenant est incompatible avec les socket 370. Suivant que ton chipset est un i815 rev. A ou rev. B, dans le 1er cas il accepte tous les P3 et celeron copermine (Intel en a sorti jusqu'à 1.13Ghz). Dans le 2eme cas, il supporte tous les copermine + tous les tualatin (le + gros étant le 1400Mhz si je me rappelle bien). Dans tous les cas ca fait belle lurette qu'Intel n'en produit plus.
n°2986179
starconsol​e
Vous n'en reviendrez pas.
Posté le 02-02-2004 à 19:38:07  profilanswer
Si, les PIII 1 GHz NEUF est dispo ! 139 ? (c cher)
Sinon sur ebay y'en a tout un tas...
n°2986184
BloodyCarn​age
Posté le 02-02-2004 à 19:38:46  profilanswer
OkYsP> erf, pas faire +ieurs choses en même temps, je me fais griller :D
n°2986189
Okysp
Rien.
Posté le 02-02-2004 à 19:48:29  profilanswer
Donc c'est bon, j'ai raison, ça passe bien? :D
Ca peut faire un bon updrage quand même. :)
n°2986224
Okysp
Rien.
Posté le 02-02-2004 à 20:11:24  profilanswer
Je crois que c'est ça, mais c'est un Celeron 533Mhz qu'il y a dedans:
http://www.ordikaz.com/ordikaz/detail/126445.htm
n°2986254
BloodyCarn​age
Posté le 02-02-2004 à 20:27:05  profilanswer
non ca ne passera pas. Contrairement à ce qui est indiqué sur monsieurprix, le celeron 1.3 en question n'est pas FC-PGA mais FC-PGA2 (puisque c un core tualatin). Ce qui le rend incompatible avec ta carte mère équipée d'un i815EP rev A qui ne supporte que les copermine en FC-PGA.
n°2986262
Okysp
Rien.
Posté le 02-02-2004 à 20:31:10  profilanswer
Oki, donc c'est DMC. :/
Merci beaucoup. :)
n°2986922
BloodyCarn​age
Posté le 03-02-2004 à 01:55:19  profilanswer
bah ils vendent encore un P3 copermine 1Ghz, mais vu le prix(~140euro), cherche +tot en occaz. Ou alors lache qq euro de + pour une solution AMD bas de gamme (tu dois pouvoir t'en tirer avec CM+CPU+512Mo pour à peine 200euro)
n°2986924
BloodyCarn​age
Posté le 03-02-2004 à 01:57:38  profilanswer
oups, l'idée n'est pas terrible, c'est pas dans un boiter compaq que tu feras rentrer ça ;)
n°2996836
Okysp
Rien.
Posté le 07-02-2004 à 13:52:14  profilanswer
C'est clair, et avec la ventilation qu'il doit y avoir là dedans. :whistle:
Merci pour tout. :)
KT7 + 1*512 Mo SDRAM "Micron", ben ca plante !K7S5A + XP1800 +256 SDRAM?
fo compter combien de temps environ pour formater un DD de 180 GoHELP ME !!!!!!!! MSI 845PE Max-L
Problème avec ma nouvelle SDRamVoltage ram et carte mère sdram...
cherche CM allant avec une XP1800+ avec SDRAMComment connaitre la frequence d'une barrette de SDRAM???
Un ventilo de proc, ça marche avec du combien ?
Plus de sujets relatifs à : i815 ep pro supporte combien de sdram maX ?
