3311 connectés
 Page :   1  2  3  4  5  ..  98  99  100  ..  414  415  416  417  418  419
[Officiel - R+] A7N8X all versions --> Lire Page 1
n°2752118
dolan
Made in madinina
Posté le 01-10-2003 à 23:34:07  profilanswer
Z_COOL a écrit :
Slot A ok
mais
Slot 1 ??
parce que c'etait le premier slot de ce type (perpendiculaire à la mobo)  :jap:
..... il est bien évident ici que je spécule  :D
Topic A7N8X - Topic UX32VD
n°2752310
dolan
Made in madinina
Posté le 02-10-2003 à 08:03:18  profilanswer
n°2752311
dolan
Made in madinina
Posté le 02-10-2003 à 08:04:09  profilanswer
Extrait du forum nforcershq.com
"I tried it with my 128MB USB stick and got it to work after some trial&error.
I am using a rev 2 deluxe board with the 1006 bios, so I do not know if this works as well for 1.04/06 boards and/or other bios versions.
Here is what I did:
1.) prepared the stick so that is formated like a HD, created a FAT16 primary partition and set this to active (I used linux fdisk but any dos/windows fdisk type of software should be fine) - btw. many USB sticks that I have seen are already set up like that.
2.) I prepared a win98 bootable floppy disk (just search with e.g. google and you will find plenty of places where to download this) that included the sys.com dos-util (again I found it with google within the first 5 links)
3.) Enable the "USB Keyboard & Legacy Support" within the Advanced/Integrated Pheripherals menu of the bios (without this the bios does not see the USB stick)
4.) Boot from the prepared win98 bootdisk while the USB stick is inserted
5.) now drive b: should be your USB stick (check it!)
6.) back on a: type "sys b:" which transfers the DOS system to the USB stick
7.) reboot and enter the bios. Now change within "Advanced BIOS features" for the boot device of your choice (first/secound/third) the option to "USB-ZIP" (that took some time to figure out, but this is the only option that lets the bios boot from my USB stick)
8.) exist&save (with a prayer to the almighty bios save bug - as always  ) - voilá, now it should work.
Btw. always try to insert the USB stick directly into the mainboard USB plugs if you have problems, I could not use the USB hub within my monitor to boot from the stick.
Cheers,
Bigben
P.S.: another way how this could work is to format the USB stick as a superfloppy (e.g. using the linux mkdosfs command), this might help those who have problems with the method I described above, but since this worked for me, I did not try the superfloppy method yet."
http://www.nforcershq.com/forum/vi [...] +usb+a7n8x
n°2753116
DiB91
Bwaaaaaaah
Posté le 02-10-2003 à 17:11:16  profilanswer
NeoKill@h a écrit :
Ben désolé je savais pas qu'il y avait un rapport  :heink:
Merci quand même :)
Socket 462 aussi  :)
n°2754343
NSV
Living on my own.
Posté le 03-10-2003 à 12:42:09  profilanswer
Je tourne actuellement avec les nforce 2.03 sur une 2.0 Deluxe, ça vaut le coup que je passe aux 2.45 à votre avis? Et comment procéder? Désinstaller les vieux par le panneau de config ou y aller à la barbare direct en lançant l'exec. ?
n°2754525
Gigathlon
Quad-neurones natif
Posté le 03-10-2003 à 14:45:03  profilanswer
Et tu spécule bien :D
Le principe est de donner des noms aux sockets, noms qui permettent de déposer un brevet (sisi :lol: ), en l'occurrence, Intel a breveté le Slot 1, avec un format "standard" SC-242 et ses connexions, là où AMD a breveté son Slot A de la même manière...
Au final ça permet théoriquement de toucher des royalties si on utilise le même format, ce qui n'est plus trop le cas, puisque à part Intel et AMD, plus personne de développe de CPU quasiment... (on exclue IBM)
Rappel:
Intel:
- Socket 3 (486)
- Socket 5 (P166 et < )
- Socket 7 (27W max, dual voltage, donc P200 puis Pentium MMX)
- Socket 8 (Pentium Pro)
- Slot 1 (P2, P3, Celeron, Celeron A)
- Slot 2 (P2 & P3 Xeon)
- Socket 428 (?) (P4 0.18µ)
- Socket 478 (P4)
- Socket 603 (P4 Xeon)
AMD:
- Super Socket 7 (idem socket 7 mais puissance plus élevée, pour les K6-2 et K6-3, un brevet sur un autre en somme :pt1cable: )
- Slot A (Athlon)
- Socket A/462 (Athlon, Duron)
Etc etc...
Message édité par Gigathlon le 03-10-2003 à 14:51:18
n°2754528
xanack
Posté le 03-10-2003 à 14:45:36  profilanswer
oublis vite les 2.45 ! si tu n'as pas de pb reste comme tu es.... sinon moi je preconise plutot les asus 1.16
n°2754591
NSV
Living on my own.
Posté le 03-10-2003 à 15:20:37  profilanswer
Ok, après différentes lectures c'est ce que j'en ai déduit :) . D'autant plus que le driver nvidia IDE marche nickel chez moi :D .
n°2754709
neokill@h
Tss tss tss!!
Posté le 03-10-2003 à 16:42:30  profilanswer
J'ai enfin acheté la cm :D, et je suis en train de la monter en ce moment. Mais maintenant, j'ai un problème. Sur le premier post, c'est indiqué que pour avoir le dual ddr, il est préférable de mettre les barettes sur les slots 1 & 3, donc c'est ce que j'ai fait :whistle:
Mais un ami m'a dit que pour avoir le dual ddr, il fallait que je mette les barettes sur les deux emplacements de même couleur (bleu)  [:axlrose]
Qui croire?  [:columbo2]
Voici comment je les ai mise:
http://neokillah.free.fr/img/P1010041.jpg
n°2754812
xanack
Posté le 03-10-2003 à 17:38:36  profilanswer
de toute façon tu le vois au boot sur le premier ecran => single ou dual channel......
n°2754835
TKILLA
Posté le 03-10-2003 à 17:58:26  profilanswer
Dual DDR sur Asus A7n8x = Slot 1 & 3
Testé et approuvé !
Avril L'ivrogne
n°2754839
Dakans
pouet pouet
Posté le 03-10-2003 à 17:59:07  profilanswer
NeoKill@h a écrit :
DDR 1 + DDR3,ou DDR2 + DDR3 ou encore 2x256Meg sur les DDR1&2 + 512Meg sur DDR3
tu le met comme tu veut,faut juste k'il y ai une barete dans le DDR3,stou :o
n°2754847
neokill@h
Tss tss tss!!
Posté le 03-10-2003 à 18:05:58  profilanswer
ok merci :jap:
je termine les derniers branchements et je vous tiens au courant :)
n°2754883
dolan
Made in madinina
Posté le 03-10-2003 à 18:27:45  profilanswer
De toute façon si tu mets sur les deux bleux de TA carte mère ce sera aussi en dual car tu seras en 2+3... et comme dit en première page en général on met 1+3...
n°2754898
neokill@h
Tss tss tss!!
Posté le 03-10-2003 à 18:36:59  profilanswer
ok :jap:
Attention, j'allume !!!!! :D
n°2754923
neokill@h
Tss tss tss!!
Posté le 03-10-2003 à 18:53:35  profilanswer
Il reconnait mon athlon xp 2800 + au demarrage, c'est déjà ca :)
par contre je voudrais changer le fsb du proc et de la ram, mais je sais pas ou trouver ca dans le bios vous pouvez m'aider?
n°2754970
neokill@h
Tss tss tss!!
Posté le 03-10-2003 à 19:15:38  profilanswer
"Memory Frequency is at 166 MHz, Dual Channel mode" [:netbios]  :sol:
Par contre, j'ai toujours ce message:
"Warning!! CPU have been changes"  :??:
Message édité par neokill@h le 03-10-2003 à 19:16:45
n°2755141
neokill@h
Tss tss tss!!
Posté le 03-10-2003 à 21:06:28  profilanswer
Voilà j'ai reussi a mettre le fsb a 166 car dans le bios il etait toujours à 100 mhz :) je passe a l'nstallation de windows puis je fais des tests
n°2755178
Dakans
pouet pouet
Posté le 03-10-2003 à 21:18:22  profilanswer
par default et par securiter,le FSB est toujour a 100Mhz lors du 1er allumage
et il me semble ke la ram est elle aussi toujour a 100% du FSB par default
et c la ke je m'interoge
si ton FSB etai a 100Mhz,pkoi ta ram etai a 166 ?!?! [:meganne]
n°2755218
neokill@h
Tss tss tss!!
Posté le 03-10-2003 à 21:34:18  profilanswer
je sais pas du tout :D
j'avais mis le fsb a 166 au debut, mais quand je suis revenu dans le bios il était revenu a 100
en fait, quand je sauvegarde, je fais "save to cmos" et "save without quit" mais ca marchait pas pour changer le fsb, donc j'ai fait "save and quit" et la ca a sauvegarder le fsb
n°2755437
Dakans
pouet pouet
Posté le 04-10-2003 à 00:12:48  profilanswer
moi je fait F10 puis touche "entrée"
aucun mobo ne ma encore fait le coup du "g pas vue ke tu voulai sauvegarder les reglage" :o
n°2755582
ispider
C'est méchant un renne...
Posté le 04-10-2003 à 01:55:38  profilanswer
A quoi sert le bios uber 1004 ? Que m'apporte t'il de plus par rapport aux bios officiels ?
n°2755692
Zeplusoif
Posté le 04-10-2003 à 09:39:40  profilanswer
Pour répondre à ta kestion : g installé les 2.45 par dessus les 2.03 (sans désinstaller) ==> formatage direct ensuite, plus aucun périphérique ki ne fonctionnait  :pfff:
n°2755708
tonio
Posté le 04-10-2003 à 09:56:35  profilanswer
+ 1 pour la sauveagerde des parametres dans le Bios avec la technique de sauvegarde sans quitter puis quitté sans sauvegarder ca sauvegarde les paramatre sans les prendre en compte... c'est à dire que j'ai un fsb de 180, je le passe à 190 et je fais save to cmos puis exit without saving et au redémarrage je suis à 180, je rentre dans le bios et la je suis à 190 !!! :heink:
Je lève le coude pour ne pas baisser les bras  [:tonio]
n°2755943
Gigathlon
Quad-neurones natif
Posté le 04-10-2003 à 12:29:59  profilanswer
AlbatorX a écrit :
et l'eax advanced HD, t'en fais quoi??? [:ddr555]
C'est bien ce que je disais: le moteur d'effets...
Seulement à l'heure actuelle même les jeux "optimisés EAX" n'utilisent que très peu ces effets voire pas du tout, du fait de leur complexité de mise en oeuvre (réflexions/réfractions/résonances et autres âneries, en gros il faudrait faire un calcul d'enceinte complexe à chaque déplacement...)
n°2757168
pedzouille
Posté le 05-10-2003 à 12:06:05  profilanswer
salut.
j'ai un probleme avec cette carte, mais j'ai pas trouver mon bonheur dans le topic.
Je m'explique. A l'installation de windows ( XP ou 2000 )lors de l'installation des peripheriques, au 2/3, l'ecran se coupe mais ne redemarre pas, il reste noir.
J'ai donc changer de carte graphique, je suis passer d'une radeon 7500 à une radeon 8500, et là tout se passe bien.
Une fois installé, si je remet la 7500, windows me laisse choisir l'utilisateur, et une fois le chargement lancer, l'ecran reste noir.
Est un probleme de voltage, de drivers, la cg ????
Pour info, j'ai mis le dernier bios, ayant eu des problemes de detection du duron 1600, avant cela j'avais des problemes ACPI.
Aucun peripheriques pci installé, et les integrés non utilisés coupés.
Je crains le jour où la technologie surpassera nos échanges humains. Le monde aura une génération d’idiots. #FB #Twitter #Instagram #TikTok etc...
n°2757178
vinc35
Posté le 05-10-2003 à 12:16:20  profilanswer
Si ca peux te rassurer j'avais une 7500 avais qui passait parfaitement sous XP pro
n°2757216
pedzouille
Posté le 05-10-2003 à 12:37:33  profilanswer
C'est deja ca. t'avais quel bios ??
merci  :hello:
n°2757290
vinc35
Posté le 05-10-2003 à 13:14:39  profilanswer
J'ai le 1004 avec une carte rev 1.04
n°2757331
kenshirooo
Posté le 05-10-2003 à 13:50:37  profilanswer
question : est ce que les bartons fonctionnent sur l'a7n8x rev 1.04 ?
n°2757334
DiB91
Bwaaaaaaah
Posté le 05-10-2003 à 13:52:20  profilanswer
Une Radeon 7500 c en AGP4X ??
n°2757337
dolan
Made in madinina
Posté le 05-10-2003 à 13:54:20  profilanswer
Bien sur!
La moitié de ceux qui ont une A7N8X ont un barton 2500+ (meilleur rapport qualité prix oblige)!
Message édité par dolan le 05-10-2003 à 13:54:32
n°2757340
DiB91
Bwaaaaaaah
Posté le 05-10-2003 à 13:58:00  profilanswer
dolan a écrit :
Bien sur!
n°2757343
kenshirooo
Posté le 05-10-2003 à 14:00:18  profilanswer
j avais entendu qu il y avait des pb ac les 1eres revisions et comme moi j ai une rev 1.04 ...
Mais bon si vous etes surs ça me va :)
Message édité par kenshirooo le 05-10-2003 à 14:00:34
n°2757386
capitaine ​pat
Posté le 05-10-2003 à 14:34:03  profilanswer
C quand méme bizard...je cherche une nouvelle cm et tout le monde me crie au et fort: A7N8X deluxe!!! super je m'dis sa fais l'hunanimiter...
Puis je lis se topic et d'autre a propos de cette cm,et la  :sweat:
tout de suite je vois que des problemes ,que des couille ,des SAV des soucie de rad de o/c et j'en passe... :(
Alors rassurer moi :vous aver vraiment que des merde avec?
vous arriver quand méme a fait 4 heure de CS sans planter
a overcloker resonnablement ,a l'installer sans tropd de soucie? et en plus mon slk y s'monte pas dessus...c nul asus :cry:
Parce que moi elle me plait cette carte... je peut l'acheter sans craindre des heure a chercher les probléme???:cry:
 [:ze potam]
Message édité par capitaine pat le 05-10-2003 à 14:42:42
n°2757391
vinc35
Posté le 05-10-2003 à 14:36:08  profilanswer
Bah non plein n'ont pas de probleme mais ce topic est fait pour aider ceux qui en ont donc normal qui y ai plein de problemes ici
n°2757411
capitaine ​pat
Posté le 05-10-2003 à 14:44:03  profilanswer
:D vi c vrai...desolé... :whistle:
n°2757429
neokill@h
Tss tss tss!!
Posté le 05-10-2003 à 14:49:05  profilanswer
Est ce que vous sauriez s'il y a des incompatibilités entre la cm et les graveurs Plextor? car je n'arrive pas à graver au-dela de 4x avec le mien depuis que je l'ai installé sur ma nouvelle cm
n°2757461
jiel175
Posté le 05-10-2003 à 14:59:03  profilanswer
pas de pb chez moi avec un graveur plextor
n°2757465
neokill@h
Tss tss tss!!
Posté le 05-10-2003 à 15:01:43  profilanswer
:cry:
c kel modele le tien?
n°2757526
usa_satria​ni
S.P.Q.R.
Posté le 05-10-2003 à 15:21:00  profilanswer
de tt facon : les graveurs caitai mieu avant :o
l'a7n8x n'aime pas la radeon 9500 pro?a7n8x deluxe et lan
Pb de stabilité avec A7N8XDetonator FX 44.03 Officiel WHQL
a7n8x veut plus booter apres clear cmosasus a7n8x dl et jumper fsb
Asus A7N8X Deluxe ==> Problème de son !Bios A7N8X
Disponibilité des A7N8X rev 2.0 deluxeProblèmes avec mes port PCI sur mon A7N8X
Plus de sujets relatifs à : [Officiel - R+] A7N8X all versions --> Lire Page 1
