3801 connectés
  Processeur
  BSOD & Temperature CPU trop élevé
n°10671991
RoYaLSleT
Il est urgent de ne rien faire
Posté le 17-12-2019 à 15:27:10  profilanswer
Je viens vous voir parce que j'ai des écrans bleus assez régulier avec ma nouvelle config...
J'ai effectué des tests et je vois que, par ailleurs, mon CPU monte très haut en température sur certains tests.
En terme de matos :
MSI z390 gaming edge ac
9900KF
NOCTUA NH-U12P SE2
Patriot Memory Viper Steel DDR4 4400 16Go (2x8Go) C19 - Tourne à 4266
EVGA 1080 FTW2 Gaming
Carte son Phoebus Solo
2 x M2 NVME en SSD
Alim Corsair HX850
Voici les températures :
https://zupimages.net/up/19/51/5zpp.png
Et mes derniers rendu avec le logiciel WhoCrashed :
On Tue 17/12/2019 11:33:26 your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\121719-5687-01.dmp
This was probably caused by the following module: wof.sys (0xFFFFF8003BA43FB3)
Bugcheck code: 0x50 (0xFFFFE000EE8CD4B6, 0x2, 0xFFFFF8003BA43FB3, 0x2)
Error: PAGE_FAULT_IN_NONPAGED_AREA
file path: C:\Windows\system32\drivers\wof.sys
product: Système d’exploitation Microsoft® Windows®
company: Microsoft Corporation
description: Filtre de superposition Windows
Bug check description: This indicates that invalid system memory has been referenced.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in a Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system that cannot be identified at this time.
crash dump file: C:\Windows\MEMORY.DMP
This was probably caused by the following module: wdfsconnect2017.sys (wdfsconnect2017+0x2DDB)
file path: C:\Windows\system32\drivers\wdfsconnect2017.sys
product: WDFS Connect
company: Western Digital Technologies, Inc.
description: Western Digital VFS Driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: wdfsconnect2017.sys (Western Digital VFS Driver, Western Digital Technologies, Inc.).
Google query: wdfsconnect2017.sys Western Digital Technologies, Inc. PAGE_FAULT_IN_NONPAGED_AREA
J'avoue que je sais plus trop comment tester... J'ai du mal à provoquer les erreurs manuellement et donc, du mal à pouvoir les analyser...
Quelqu'un à une idée pour passer au peigne fin en terme de logiciel ou de méthode?
Merci d'avance  :hello:
Topic de ventes
n°10672011
kabyll
Posté le 17-12-2019 à 16:03:51  profilanswer
salut,
pour les températures
- tu peux lancer hwinfo ou cpuz et regarder le vcore de ton cpu
pour les crash, des pistes :
- faire un memtest (clé usb) pour vérifier que la ram n'a pas un souci
- pour le second crash, tu as un disque externe Western Digital? les crash arrivent que quand il est connecté?
- tu peux lancer une invite de commande et faire un sfc /scannow
n°10672321
RoYaLSleT
Posté le 18-12-2019 à 08:55:39  profilanswer
kabyll a écrit :
salut,
Pour la température, merci, je vais regarder en parallèle voir si c'est les bonnes. Si c'est le cas, c'est tendu non? :/
Quelles sont les pistes? Changement du refroidissement? Délid? La circulation d'air me parait bonne, mais je vais revérifier...
Pour les Crash :
J'ai désinstaller l'utilitaire WD vu que je change de NAS de toute façon.
Je n'ai pas fais de corrélation entre les 2 mais j'avais déjà des crash quand je n'avais pas encore le NAS WD, donc je pense que même si celui ci vient du driver, ça se reproduira pour d'autres raisons.
Pour le SFC :
Début de l’analyse du système. Cette opération peut nécessiter un certain temps.
Démarrage de la phase de vérification de l’analyse du système.
La vérification est à 100% terminée.
Le programme de protection des ressources Windows n’a trouvé aucune violation d’intégrité.
Topic de ventes
n°10672342
zonka
x58 forever!
Posté le 18-12-2019 à 09:30:04  profilanswer
Il nous faudrait la valeur de vcore max en charge pendant le test OCCT, et la fréquence max (4.7 je suppose).
Un  classique sur 9900k, j'imagine un vcore de fou >1.4v appliqué par la carte-mère.
n°10672368
RoYaLSleT
Posté le 18-12-2019 à 10:00:48  profilanswer
Hello, le vcore oscille entre 1.2 & 1.25 environ
https://zupimages.net/up/19/51/2sey.png
Topic de ventes
n°10672382
disabled 9​3
Posté le 18-12-2019 à 10:19:10  profilanswer
Si tu as 1.25v tu es dans les clous.
Après un 9900K avec un NH-U12P SE2 sous OCCT c'est pas raisonnable  :D
Arrete de faire de tel benchs ou augmente ton refroidissement par les plus gros ventirad ou Watercooling.
Le NH-U12P SE2 devrait suffire je pense sans les tortures qui tu lui impose  :D
Corsair 500D/Corsair RM850/ROG STRIX Z590-A GAMING WIFI/Core i7-11700K/CORSAIR iCUE H115i ELITE CAPELLIX/G.Skill TridentZ NEO 2x16Go 3600Mhz Cas16/Nvidia RTX 3090 FE/SSD P5+ 1To/SSD 970EVO 500Go/SSD BX100 500Go/SSD MX500 1To
n°10672388
kabyll
Posté le 18-12-2019 à 10:22:22  profilanswer
+1 le vcore semble normal. Y'aurait peut-etre moyen de le tripoter mais comme dit disabled, en conditions normales il aura probablement jamais aussi chaud
donc a voir à l'usage, mais si ca ne monte pas jusque là en jeu ou autre, te casse pas la tête.
sinon, changement de ventirad, probablement trop léger pour un tel cpu
n°10672405
RoYaLSleT
Posté le 18-12-2019 à 10:40:34  profilanswer
Je vois :D
Alors pour info, il monte quand je fais des tests sous OCCT, mais je ne cherche pas à bench, j'ai des BSOD et je cherche d'ou vient la cause, du coup j'avoue faire des tests, mais rien de fou... :s
Tu penses vraiment que ce ventirad n'est pas "suffisant"? J'avoue qu'il m'a suffit pour tout mes procs, jusqu'à mon ancien (8700k)
Je suis pas contre changer, surtout que je vais revendre mon ancienne config et du coup il fallait que j'achète un RAD pour l'ancienne, donc autant mettre mon noctua dans l'ancienne à revendre et m'en reprendre un... Mais lequel.. sachant que j'aime pas les AIO ( trop d'entretien à mon gout )
Et pour revenir au sujet principal, je cherche toujours le moyen de tester proprement d'ou viennent mes BSOD :(
Topic de ventes
n°10672421
kabyll
Posté le 18-12-2019 à 10:54:16  profilanswer
Y a eu un autre sujet sur les températures d'un 9900k, lui avait un NH-U12A,
Comme le tiens monte plus haut en fréquence, il chauffe plus, donc c'est pas vraiment étonnant.
Delid je ferais pas, en dehors du fait de perdre la garantie, en principe c'est de l'indium dans ce cpu.
Ca me semble mieux de changer de refroidissement.
Si tu voulais de tte facon en mettre un sur l'ancienne config avant de la revendre, alors oui, mets le NH U12 dessus et pour ton 9900kf tu peux viser les gros classiques du marché Dark Rock 4 (ou Pro), NH D15, ou autre
Pour tes BSOD, ca peut être tellement de choses, il faut ratisser large au début
- nfs scannow , ok pas de fichiers corrompus
- WD externe, tu penses que c'est pas lié, ok, débranche le pour être sûr
- memtest tu as essayé? pour fermer cette piste
n°10672433
RoYaLSleT
Posté le 18-12-2019 à 11:15:53  profilanswer
Je vois, j'ai fais l'erreur de penser que ça serait similaire entre mon NOCTUA NH-U12P SE2 et un récent.. mais tu as surement raison :-)
Je vais faire comme ça et comme je n'ai jamais été déçu de cette marque, je pense continuer et partir sur la version dont tu parles :)
Par contre je suis étonné, le NH-U12A est aussi cher sur tout les sites que le NH D15, c'est donc qu'il est à peu près aussi performant non? :o
Si le mec a un problème de chauffe avec ça........
Je vais faire le memtest cette nuit, mais si je dis pas de bêtises, j'avais déjà essayé de le faire tourner sans être présent et quand je suis revenu, le système avait reboot et rien n'avait été enregistré...
Topic de ventes
n°10672438
kabyll
Posté le 18-12-2019 à 11:24:54  profilanswer
Au cas où, le mieux c'est memtest sur une clé usb bootable,
Si tu lances qqch sous windows, et que c'est windows qui est instable, ca fausse le résultat évidemment.
Si tu l'avais fait comme ca, sur clé usb bootable, et que le pc a rebooté, alors ya un souci oui.
n°10672440
zouaf
Posté le 18-12-2019 à 11:26:14  profilanswer
Non, sur le site de noctua, ton ventirad est qualifié de moyen pour refroidir un 9900k. Ce n'est pas le cas d'un NH D 15 où de sa variante D15s.
https://noctua.at/fr/nh-u12p-se2/cpucomp
Pourquoi est-il au même tarif? loi de l'offre et de la demande  :pt1cable:
Edit: j'avais pas vu mais il est censé avoir les même perfs de refroidissement qu'avec un 8700k.
Donc tu devrais avoir plus où moins la même chose avec ton 9900kf.
Sur ton premier screen, le cpu fait un pic à 100° au bout de 34s d'OCCT :pt1cable:
Il y a un soucis, c'est censé monter progressivement.
Sur le mien, ça monte d'un coup vers 60° et puis progressivement vers 69°-72°(au bout de 15-20 min).
Ce qui m'amène au montage du ventirad.. tu devrais vérifier  :heink:
Message édité par zouaf le 18-12-2019 à 11:48:27
n°10672442
disabled 9​3
Posté le 18-12-2019 à 11:34:10  profilanswer
Si tu BSOD sans trop chauffer je regarderais en premier du coté de la RAM.
Je connais pas cette RAM mais 4266Mhz c'est beaucoup.
Descend ta fréquence vers 3600Mhz deja voir ce que ca donne.
Ton XMP fait peut etre de la merde aussi.
Active le quand meme pour qu'il applique les réglages mais descend en fréquence.
Regarde si ton XMP monte bien les tensions VRAM/VCCIO/VCCSA,applique les bons timmings.
Avec des kits aussi haut en fréquence c'est souvent que tu arrive pas a tenir,il faut bidouiller selon le CPU et le chipset de ta mobale.
Puis tu t'en balance de monter si haut en faite,ca apporte plus emmerdes de toute facon que de performances supplémentaire  :D
Et sur la MSI Z390 gaming edge ac que j'ai actuellement,elle a du mal a monter en fréquence  VRAM,j'ai des kits qui monte plus haut d'ailleurs sur d'autre mobales que j'ai test comme la Taichi par exemple.
Message édité par disabled 93 le 18-12-2019 à 11:38:58
n°10672499
RoYaLSleT
Posté le 18-12-2019 à 13:13:51  profilanswer
Alors en gros, oui, je l'avais fais sur une clée bootable.
Si je comprends bien, normalement, si je le laisse la nuit, il est censé m'afficher les résultats le matin? Et si on part du principe que ça plante, c'est que ya un soucis et que ça pourrait venir de la mémoire, right?
Je vais regarder si j'ai bien les ventilateurs dans le bon sens, mais grosso modo, de souvenir, j'ai mis qu'un des 2 ventilos du noctua.
Pour shématiser ça donne :
| Boitier | Rad | Ventilo qui souffle vers le boitier
Et je suppose que si je rajoute le seconde ventilo du noctua je fais
| Boitier | Ventilo qui souffle vers le boitier | Rad | Ventilo qui souffle vers le boitier
Tu en penses quoi?
Pour la RAM, je suis en XMP 2, profil à 4266 donc et j'ai un affichage qui me semble étrange : le NB fréquency dans l'onglet mémory est à 4300, pas à 4266.
le DRAM Frequency oscille entre 2132 & &2134, mais le NB est entre 4297 & 4302 environ...
Je vais tester dans la soirée de passer manuellement à moins pour voir si c'est une question de stabilité RAM.
Merci pour les réponses en tout cas, c'est top ;-)
Topic de ventes
n°10672518
disabled 9​3
Posté le 18-12-2019 à 14:04:35  profilanswer
Le NB Frequency il bouge,ca monte et ca descend entre 800 et 4300Mhz,un truc du genre,si tu touche a rien dans le bios biensur.
C'est le NordBrigde du CPU en faite,on appel ca aussi la fréquence RING.
La fréquence DRAM c'est autre chose,c'est la fréquence de la RAM quoi  :D
Si tu as réglé a 4200Mhz dans le bios,ca correspond a 2100Mhz dans CPUZ,il divise par 2 en faite pour faire simple,et ca bouge pas normalement.
En gros tu as 3 fréquences principales:
-La fréquence des Cores du CPU qui varie selon la charge.
-La fréquence NB/RING du CPU/Chipset qui varie selon la charge aussi.
-La fréquence DRAM de ta mémoire qui reste fixe.
Message édité par disabled 93 le 18-12-2019 à 14:05:41
n°10672545
RoYaLSleT
Posté le 18-12-2019 à 14:47:23  profilanswer
Ah oui okay, donc pas vraiment pertinent quoi !
D'accord ;-)
C'est dingue quand même, parce que j'suis quand même plutôt "connaisseur", mais quand je vois tout ce que je peux apprendre d'autres, j'me dis que ya encore énoooooooormement de choses autres à voir :D
C'est trop cool !
Je repasserais demain pour les resultats du coup, en esperant que ça plante pas pendant la nuit :-)
Vu la longueur des tests de ram, j'avoue que j'suis moyen chaud pour le faire la journée, sachant que j'suis chez moi en + en ce moment.......
Topic de ventes
n°10672562
kabyll
Posté le 18-12-2019 à 15:10:33  profilanswer
c'est pas censé planter/rebooter pendant la nuit non,
jete déjà un oeil au bout d'une heure, ca n'a pas forcément besoin de tourner toute une nuit,
idealement barrette par barrette, mais si c'est un kit de tte facon faudra renvoyer le kit complet
comme dit disable, tu peux essayer sans profil xmp aussi, comme c'est de l'oc, parfois faut bidouiller un peu les tensions
n°10672564
disabled 9​3
Posté le 18-12-2019 à 15:11:26  profilanswer
Utilise HWINFO64 quand tu veux lire tes valeurs.
Il est très complet et tu as toutes les infos en un coup d'oeil.
Tu vois le comportement de toutes tes tensions,fréquences,températures,vitesse de ventilation,consommations et encore plein d'infos.
La total.
Outil indispensable pour connaitre tes valeurs sur un moment T ou tes valeurs mini/maxi par exemple.
Avec cette outil tu apprend plein de chose sur le comportement de ta machine selon les charges que tu lui impose.
Au début on se perd un peu mais c'est tellement utile et très fiable en plus.
https://nsa40.casimages.com/img/2019/12/18/191218031407178031.png
n°10672628
kiloutyg
Posté le 18-12-2019 à 16:51:45  profilanswer
ouais faut au moins un ventirad efficace comme du NH-D15 ou de l'aio 240 ou plus.
De base faudrait regler le probleme de chaleur du cpu sans l'xmp ou n'importe quelle OC d'autre chose que le cpu.
Une fois que ça c'est bon faire l'oc des ram.
Ceci dit en attendant tu peux juste activer l'xmp et baisser la frequence a 4000 normalement c'est un reglage qui va passer tranquillement.
Au dessus de 4133 c'est plus rare que ça passe.
Mais bon faut vraiment d'abord gere le cpu seul dans son coin, le stress test seul etc.
Les prix du Matos Info Neuf: https://www.gputracker.eu/fr | https://ledenicheur.fr/ | https://www.hagglezon.com/ | https://www.idealo.fr/ | https://fr.pcpartpicker.com/list/ | https://www.dealabs.com/
n°10672704
zouaf
Posté le 18-12-2019 à 19:30:00  profilanswer
Tu en penses quoi?
Je pensais surtout à la pâte thermique et à la fixation du ventirad  :D
Tes températures ne sont pas normales même avec un nh u12p.
Rajouter le deuxième ventilateur ne peut pas faire de mal  :jap:
n°10672732
RoYaLSleT
Posté le 18-12-2019 à 20:15:55  profilanswer
Bon alors, premier retour :
J'ai fais un memtest via clé USB avec la config telle qu'elle -> des dizaines de lignes d'erreurs
https://zupimages.net/up/19/51/hmvu.jpg
Ensuite, j'ai baissé dans le bios, la vitesse des RAM à 4000, plus d'erreurs sur 4 phases de test.
J'en conclu qu'effectivement, le 4266 est pas supporté.
J'ai voulu jouer le malin à prendre de grosses RAM en pensant qu'il suffisait qu'elles soient supportées par la CM pour que ça soit nickel, mauvaise pioche.
Du coup, comme je suis pas overclockeur, je me demande si je vais pas les renvoyer pour prendre du 4000 un peu plus standard, ou basculer sur + de RAM en fréquence plus basse, genre 3200/ CL15
Concernant le proc, j'avoue que j'ai du mal à saisir d'ou ça pourrait venir, je vais essayé de pousser mes verifs sur la pâte termique...
J'ai de la Thermal Grizzly Kryonaut, qui est assez bonne si je dis pas de bêtises et je l'avais correctement étalé, ya environ 2 mois maximum, donc pas d'usure j'imagine...
reste à verifier si la CM fait pas un OC automatique de mon PROC qui le ferait trop chauffer..?
J'avoue que j'suis un peu paumé parce que à part la pâte, le rad est nettoyé... le ventilateur tourne dans le bon sens... etc..
Topic de ventes
n°10672785
kiloutyg
Posté le 18-12-2019 à 21:50:07  profilanswer
Moi je pense qu'il est bien de reverifier la pate et de bien resserrer ou desserrer le montage.
C'est possible que la carte mere fasse partie du delire.
Pour la ram tu fais comme tu veux mais ce genre de matos ça s'oc facilement.
n°10672881
disabled 9​3
Posté le 19-12-2019 à 09:09:48  profilanswer
Ca sert a rien d'avoir d'avoir des RAM a 4000 ou 4400Mhz
Pour des scores de benchs seulement a la limite.
Prend du 3600Mhz avec de bon timmings,c'est largement suffisant.
Puis pas besoin d'OC franchement avec ca et un 9900K.
Tu laisse par défaut et tu active l'XMP.
Tu baisse juste le Vcore si la CM fait un peu de la merde en charge et c'est bon.
Tu deja une machine qui tourne très fort,cherche pas les emmerdes qui apporte que dalle  :D
Après le refroidissement la tu vois selon ton travail ou le game,les benchs tu t'en branle.
Moi je te conseille d'éviter les AIO et de prendre un des meilleurs ventirads ou de passer sur un vrai Watercooling.
n°10672891
zonka
x58 forever!
Posté le 19-12-2019 à 09:27:46  profilanswer
D'accord sur tout avec disabled.....
n°10672893
disabled 9​3
Posté le 19-12-2019 à 09:34:58  profilanswer
[:kellian':4]
n°10672948
RoYaLSleT
Posté le 19-12-2019 à 11:41:17  profilanswer
Helllllllo !
Alors, je vais t'expliquer ce qui m'a amené à faire ça. C'est tout simplement que j'me suis toujours dis que la RAM, je prennais du milieu de gamme et hop, je cherche pas à comprendre..
Et la j'me suis dis, bon, je test de prendre une RAM à la limite de ma CM pour voir si ça change qqchose... :D
Je trouve que ça change énormement entre les 2, ya bcp plus d'emmerdes  :pt1cable:  :pt1cable:
Si tu en as une à me conseiller, je suis preneur... Je suis toujours en mode, oui, mais pour de la 3600, faudrait de la CL17, voir 16 pour que ça soit mieux, blabla...
Je sais pas franchement...
Et pour le proc, je vais simplement prendre un gros ventilo. Le noctua énoncé plus haut est bien?
Merci encore pour tout ça :)
Topic de ventes
n°10672953
zonka
x58 forever!
Posté le 19-12-2019 à 11:53:39  profilanswer
1) Ta RAM en 4000+ peut tourner en 3000/3200/3600 etc = trouve au fur et à mesure la fréquence max à laquelle elle fonctionne spécifiquement avec TA carte-mère et TON processeur (et son contrôleur mémoire donc)
2) Pour un 9900K, il FAUT un gros rad (je déconseille aussi les AIO par habitude), comme le Noctua D15 machin chose, ou un Dark Rock Pro 4 (c'est ce que j'ai perso, c'est sans souci avec un 9900K@4.7 1.22v, mais il est delid ceci dit)
n°10672961
kabyll
Posté le 19-12-2019 à 12:06:02  profilanswer
T'es pas obligé de renvoyer ta ram si tu l'as eue a bon prix,
Tu peux la passer en 3600 via les profils xmp ou tweak a la main,
sinon, 3200 C16 c'est +- 80€ ou 3600 C18 +- 100€
3600 C16 ca commence a partir de 130€, et je pense que ton kit t'as couté moins cher que ça donc c'est pas forcément malin, autant baisser la freq de la tienne.
edit : bien bien en retard, grillé comme d'hab quoi :)
Message édité par kabyll le 19-12-2019 à 12:07:04
n°10672963
zonka
x58 forever!
Posté le 19-12-2019 à 12:09:30  profilanswer
Au passage quand le CPU ne sera plus en surchauffe massive il est possible que le contrôleur mémoire fonctionne mieux, accessoirement.
n°10672966
zouaf
Posté le 19-12-2019 à 12:14:49  profilanswer
+1 avec zonka pour le rad.
Je rajouterais que concernant noctua (si tu restes chez eux), la version d15s est la version slim du NH d15.
Pratique quand tu as des barrettes mémoire qui sont haute (bien souvent les modèles haute performance comme celle que tu possèdes).
J'ai le NH D15s avec un 9900k et ça passe nickel :)
Message édité par zouaf le 19-12-2019 à 12:21:49
n°10672967
RoYaLSleT
Posté le 19-12-2019 à 12:14:57  profilanswer
D'accord, bon c'est super alors :-)
Je vais garder mon kit, pour l'instant, je suis à 4000 CL19 sans plantage et sans erreur sur memtest 86, ça parait okay de rester comme ça j'imagine :-)
Je vais commander un noctua plus adapté et je ferais des tests une fois reçu pour verifier la chauffe !
Merci à tous pour vos précisions, vous avez été géniaux !
Topic de ventes
n°10673822
RoYaLSleT
Posté le 21-12-2019 à 11:53:30  profilanswer
Alors déjà, j'ai reçu le Noctua.
Première info, il est monstrueux, j'ai du décaler un ventilateur pour le setup :D
Ensuite, sur le test OCCT, je monte maintenant à 89° maxi, ce qui fait 11 degrés de moins qu'avant, plutôt cool ! Même si je pensais à moins.
Mais bon, je crois que les 9900 KF chauffent un peu plus si j'ai bien compris...
Pour le reste, pour l'instant, avec la baisse de fréquence de la ram ainsi que la température, plus d'erreurs pour l'instant.
Merci encore :-)
Topic de ventes
n°10673834
kabyll
Posté le 21-12-2019 à 12:26:48  profilanswer
C'est déjà une belle différence,
OCCT c'est un cas extrème, en conditions réelles ton cpu ne montera probablement pas aussi haut en temperature
n°10673838
zonka
x58 forever!
Posté le 21-12-2019 à 12:31:27  profilanswer
Tout dépend.
Perso, le test OCCT CPU "normal" monte en gros à ce que j'arrive à faire en charge maximale réelle (compression HEVC). Le test LINPACK lui, effectivement, est "d'un autre monde" )
n°10673879
mallorco
Posté le 21-12-2019 à 14:21:56  profilanswer
Je rejoins disabled 93 j'ai aussi 4*8 go en 4133mhz de chez patriot ( mais sur x299) et le profil xmp me provoque  des erreurs sur occt, j'ai rentré les specs manuellement et gagné 1 cas passage de 19 à 18.
Comme dit plus haut passe les en 3600 et vois si tu as toujours des erreurs en large data set sur occt.
  Processeur
CPU 1 cœur à 100% et les autres à 50% en jeuTempérature max Southbridge
Problème utilisation CPUVentilo GPU qui tourne à fond démarrage(changement de CM)
i7 3770k + RX 5700 XT je suis CPU limited ?Quel CPU choisir ?
Faut-il changer la CM+CPU?Upgrade CPU/RAM/MB
Vieux CPU de 2004 + GPU 2018 OK pour transcoder?CPU/ventirad déreglé après mise à jour bios.
Plus de sujets relatifs à : BSOD & Temperature CPU trop élevé
