1934 connectés
  Bsod intempestive solution
n°9910712
love22956
Posté le 11-08-2016 à 18:07:35  profilanswer
Bonjour je rencontre depuis quelque jour des blue screen avec l'erreur 124 a la fin.
sa m'arrive souvent sur youtube est en jeux.
ma carte graphique chauffe pas.
mon processeur chauffe pas.
ma configuration:
carte mère:msi z77a-g43
processeur:intel core i7 2600k @4.6
mémoire:12gb ddr3 1600mhz gskill
watercooling ek l240
boitier: nzxt h440
ssd samsung evo 500gb
r9 290 oc gelid icy
artic cooling 550watt
voila le rapport de whocrased.
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Thu 11/08/2016 15:43:31 GMT your computer crashed
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: Unknown (0x00000000)
Bugcheck code: 0x124 (0x0, 0xFFFFFA800C996028, 0xBE200000, 0x5110A)
Error: WHEA_UNCORRECTABLE_ERROR
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might also be caused because of overheating (thermal issue).
A third party driver was identified as the probable root cause of this system error.
Google query: WHEA_UNCORRECTABLE_ERROR
Conclusion
One crash dump has been found and analyzed.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
je vous en remercie d'avance
j'ai fait un memtest tout la nuit sa a rien trouvé
mon feed back http://forum.hardware.fr/hfr/Achat [...] 1493_1.htm
n°9910750
arthurg95
Posté le 11-08-2016 à 19:01:12  profilanswer
Juste une idée comme ça, tu as essayé de revenir à une fréquence stock sur ton CPU voir si tu avais toujours le soucis ? Parce que 4.6 pour du 3.4 de base il est quand même pas mal poussé !
Message édité par arthurg95 le 11-08-2016 à 19:01:57
Tout est dit mais comme personne n'écoute il faut toujours répéter.
n°9910945
love22956
Posté le 11-08-2016 à 22:54:38  profilanswer
arthurg95 a écrit :
salut je viens de le remettre d'origine j'ai le mème soucis de blue screen
n°9910947
Zurkum
Posté le 11-08-2016 à 22:57:39  profilanswer
Tu n'as rajouté de la RAM récemment ?
n°9910950
love22956
Posté le 11-08-2016 à 22:59:06  profilanswer
salut Zurkum non du tout j'ai testé une par une les barrette ras niveaux mémtest est pareil en jeu est youtube
BSOD HD Radeon 7970 ASUS 4GoBSOD Changement de carte mère
Solution de stockage fiable pour très long termeBSOD dpc watchdog violation quand pilotes NViDIA installés (pavé)
Nouveau matériel, BSOD, puis impossible d'installer WindowsBSOD version Van Gogh
BSOD - Athrxusb.sys - Ou chercher ?BSOD
BSOD impossible de booter, carte mère HS ?BSOD BugcheckCode 156 event id 41
Plus de sujets relatifs à : Bsod intempestive solution
