4706 connectés
  probleme bande noir sortie tv
n°5093216
maniweb
Posté le 06-10-2006 à 00:06:09  profilanswer
Bonjour a tous
Voila j'ai un mini pc aopen avec une carte graphique intel 915 driver 'i810'
Ma config est sur cette page http://www.anoria.biz/offre.php?id=120
J'ai installé la derniere version de ubuntu (dapper).
J'ai branché mon pc sur la sortie svideo de la tele (sharp LCDTV). Ca fonctionne bien mais j'ai des bandes noires autour de l'image sur la télé
voila la configuration de mon xorg.conf. Je sais pas si je l'ai vraiment optimisé mon but c'est juste d'afficher sur la télé
. Pour le reste je controle mon pc par vnc via mon portable.
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#   sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
 FontPath "/usr/share/X11/fonts/misc"
 FontPath "/usr/share/X11/fonts/cyrillic"
 FontPath "/usr/share/X11/fonts/100dpi/:unscaled"
 FontPath "/usr/share/X11/fonts/75dpi/:unscaled"
 FontPath "/usr/share/X11/fonts/Type1"
 FontPath "/usr/share/X11/fonts/100dpi"
 FontPath "/usr/share/X11/fonts/75dpi"
 # path to defoma fonts
 FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
 Load "i2c"
 Load "bitmap"
 Load "ddc"
 Load "dri"
 Load "extmod"
 Load "freetype"
 Load "glx"
 Load "int10"
 Load "type1"
 Load "vbe"
EndSection
Section "InputDevice"
 Identifier "Generic Keyboard"
 Driver  "kbd"
 Option  "CoreKeyboard"
 Option  "XkbRules" "xorg"
 Option  "XkbModel" "pc105"
 Option  "XkbLayout" "fr"
 Option  "XkbVariant" "latin9"
EndSection
 Identifier "Configured Mouse"
 Driver  "mouse"
 Option  "CorePointer"
 Option  "Device"  "/dev/input/mice"
 Option  "Protocol"  "ExplorerPS/2"
 Option  "ZAxisMapping"  "4 5"
 Option  "Emulate3Buttons" "true"
EndSection
  Driver        "wacom"
  Identifier    "stylus"
  Option        "Device"        "/dev/wacom"          # Change to
                                                      # /dev/input/event
                                                      # for USB
  Option        "Type"          "stylus"
  Option        "ForceDevice"   "ISDV4"               # Tablet PC ONLY
EndSection
  Driver        "wacom"
  Identifier    "eraser"
                                                      # /dev/input/event
                                                      # for USB
  Option        "Type"          "eraser"
EndSection
  Driver        "wacom"
  Identifier    "cursor"
                                                      # /dev/input/event
                                                      # for USB
  Option        "Type"          "cursor"
EndSection
Section "Device"
 Identifier "Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller"
 Driver  "i810"
 BusID  "PCI:0:2:0"
        Option          "MonitorLayout" "TV,LFP"
        Option   "TVOutFormat" "SVideo"
        Option   "TVOverScan" "1.0"
        Option          "Clone" "true"
EndSection
Section "Monitor"
 Identifier "Generic Monitor"
 Option  "DPMS"
 HorizSync 31.5-90
 VertRefresh 50-90
EndSection
Section "Screen"
 Identifier "Default Screen"
 Device  "Intel Corporation Mobile 915GM/GMS/910GML Express Graphics Controller"
 Monitor  "Generic Monitor"
 DefaultDepth 24
 SubSection "Display"
  Depth  1
  Modes  "1024x768" "800x600" "640x480"
 EndSubSection
  Depth  4
 EndSubSection
  Depth  8
 EndSubSection
  Depth  15
 EndSubSection
  Depth  16
 EndSubSection
  Depth  24
 EndSubSection
EndSection
Section "ServerLayout"
 Identifier "Default Layout"
 Screen  "Default Screen"
 InputDevice "Generic Keyboard"
 InputDevice "Configured Mouse"
 InputDevice     "stylus" "SendCoreEvents"
 InputDevice     "cursor" "SendCoreEvents"
 InputDevice     "eraser" "SendCoreEvents"
EndSection
Section "DRI"
 Mode 0666
EndSection
Merci pour votre aide
A+ mani
Probleme d'affichage..probleme disque dur externe et autres peripheriques
Problème disque dur en RAIDProbleme d'installation de Windows sur DD SATA
Problème écran PC PortableBloqué avant le bios
problème ASUS, LINUX et SATAMême problème d'USB sur 2 PC
Problème ASUS X850XTDispariton de partitions sur un HDD 150Go
Plus de sujets relatifs à : probleme bande noir sortie tv
