4018 connectés
 Page :   1  2  3  4  5  ..  175  176  177  ..  461  462  463  464  465  466
[TOPIC UNIQUE] ATI HD 3800 series > HD 3850 & HD 3870
n°6079949
adoy
aka KingOfNuls
Posté le 12-12-2007 à 01:10:10  profilanswer
Ouais bein v'là la config de tueur pour pas être trop cpu limited hors haut de gamme. Faut pas oublier de le préciser, c'est carrément important car on voit que les trois plus hauts scores sont proches.
Intel Core 2 Quad QX9650
Corsair PC2-8500 4GB
Message édité par adoy le 12-12-2007 à 01:10:42
n°6079958
johnny-vul​ture
Wesh wesh ma poule !
Posté le 12-12-2007 à 01:25:14  profilanswer
I have a P965 DQ6 rev. 1.0 16x/4x and 2xHD3870 840/2400 Q6600@3.33ghz and scores 17100 points in 3Dmark 2006. So the "old" DQ6 is not to bad after all. But, still, a P35 with 8x/8x or a x38 with 16x/16x PCI-E 2.0 is the way to go to get the most out of a crossfire system!
Pour comparer en gros.
http://img48.imageshack.us/my.php? [...] 032xm7.jpg
Message édité par johnny-vulture le 12-12-2007 à 01:29:57
n°6079976
jjacques52​9
Posté le 12-12-2007 à 01:59:54  profilanswer
BIOS vmodding didn't work on the 3870. It was one of the first things we tried in the unleashed thread about 3 weeks ago. I've tried modifying the voltage tables up to 1.5v, and it does not budge. The checksum changes as soon as you modify anything on the original bios, and an incorrect checksum will give you a blank device ID / info when you try flash. The -f flag forces it, but you still dont get any change in voltage. guess has a tool to modify powerplay tables / clockspeeds, but he is under NDA and that tool is likely not going to be public.
So, pretty much if you want working vmods you either do hardware mod, or wait for w1z to get working software control in the next version of ATITool. You could probably try figuring out how to get a matching checksum and see if that makes bios modding work. But rather that wasting so much time to do that, imo you could just hardmod it and be done with it...
Vu ici
En gros reste plus qu'à attendre la prochaine version d'ati tool / rivatuner ou ati tray tool (en croisant les doigts pour qu'on puisse modifier le vgpu :ange: )
n°6079979
johnny-vul​ture
Posté le 12-12-2007 à 02:16:45  profilanswer
Encore un autre plus intuitif niveau comparaison 8x/8x vs 16x/4x
http://www.anandtech.com/video/sho [...] i=2990&p=4
Ajoutez 10 % de perf en plus pour CF 3870 en moyenne.
Message édité par johnny-vulture le 12-12-2007 à 02:53:12
n°6079997
tony54
Posté le 12-12-2007 à 04:04:47  profilanswer
je voudrais savoir que pensez-vous de cette carte pour un 22 pouces en 1680*1050 :
http://www.cdiscount.com/informati [...] &numpage=1
niveau bruit et chauffe ca donne quoi ?
Mon Feed-Back
n°6080030
acnoar
Posté le 12-12-2007 à 08:25:20  profilanswer
apparement, lui ne met qu'un pont pour son Xfire  :whistle:
n°6080032
cassoux
Posté le 12-12-2007 à 08:29:54  profilanswer
cassoux a écrit :
http://www.enregistrersous.com/images2/vignettes_images/138286327220071211235801.png
Overclockée la version 256Mo est déjà vraiment sympa en 1680*1050 (même @stock d'ailleurs :p ) donc la version 512 devrai être géniale :jap:
Niveau bruit c'est super silencieux, mais ça chauffe (le ventilo en auto ne dépasse jamais les 40%)
Message édité par cassoux le 12-12-2007 à 10:17:19
\|/A/V\|/FeedBack\|/\|/Ebay\|/\|/
n°6080066
LoDeNo
Tricourge du JeuDuDico
Posté le 12-12-2007 à 09:20:31  profilanswer
Noté ! :D
n°6080156
Esteb@n
Posté le 12-12-2007 à 10:07:38  profilanswer
La version 512 tourne à la meme vitesse que la 256 ? (pke on a eu des surprises avec saphirre et powecolor)
Edit : en fait je voudrais savoir si la 3850 est OK pour jouer à Crysis (actuellement je joue en high/moyen en 1440*900 à 15-20fps avec ma 7950GT). Si la 3850 me permet de jouer à 25-30 fps dans les memes conditions c génial mais on trouve aucun test avec les 7900, y'a que des tests 8800/38xx.
Message édité par Esteb@n le 12-12-2007 à 10:16:33
n°6080174
rick@r
coin coin coin
Posté le 12-12-2007 à 10:19:28  profilanswer
J'ai reçu ma jetway 3870, mais j'ai un problème quand j'installe les catalyst , une fenêtre notify s'affiche et l'erreur suivante apparait : "data.size()!=3"
Qlq a déjà eu ce problème ?
n°6080192
Gigathlon
Quad-neurones natif
Posté le 12-12-2007 à 10:27:32  profilanswer
Probablement un problème lié au .NET framework... :o
n°6080196
rick@r
coin coin coin
Posté le 12-12-2007 à 10:29:14  profilanswer
C'est ce que je me suis dit.
J'avais le 1.1, le 2 et le 3 d'installé, j'ai vu qu'il fallait le 2 pour installer les catalyst. J'ai donc désintaller le 3 en me disant qu'il y avait peut être des conflits, mais rien n'y fait :/
n°6080200
badre2911
Posté le 12-12-2007 à 10:31:28  profilanswer
Ca donne quoi la decompression HD H263 par rapport a la HD2600XT la HD3850 ?
n°6080277
Nco34
Trackmaniaque
Posté le 12-12-2007 à 11:06:54  profilanswer
264  :o
Psn Id : TheKensei - Garage GT5 - Mon feedback
n°6080331
pir@tem
Posté le 12-12-2007 à 11:24:54  profilanswer
bonjour je vien de metre un zalman VF-700 AL-CU sur ma 3870 il se monte sans probleme est la carte chauf beaucoup moin ! 73° max 7 min d'ati tool . :love:
la carte retombe a 45° apres 2min !
Message édité par pir@tem le 12-12-2007 à 11:29:21
n°6080346
F@bek
6 SEASONS AND A MOVIE §§§
Posté le 12-12-2007 à 11:30:52  profilanswer
topik sur le bidouillage de bios en allemand
http://www.area3d.de/forum/showthread.php?t=2545
n°6080386
zarkdav
Posté le 12-12-2007 à 11:46:05  profilanswer
Bon bah ça y est, j'ai commandé ma config. J'ai longuement hésité entre 8800 GT, GTS², Xfire de HD3850 ou de HD3870, et finalement:
1 Antec P182 (noir)
1 Corsair HX 520W
1 G.Skill Kit Extreme2 2 x 1 Go PC6400 HZ
1 Gigabyte GA-P35-DS4 rev 2.0
1 Intel® Pentium® E2160
1 Samsung SH-S202N - OEM, noir
2 Sapphire Radeon™ HD 3870 512 Mo
1 Western Digital Raptor 74 Go - 16 Mo
J'ai réussi à me décider et j'espère que la config sera sous le sapin!
Any sufficiently advanced technology is indistinguishable from magic. -- Arthur C. Clarke, "Profiles of The Future", 1962 (Clarke's third law) | Mes photos (flickr)
n°6080427
Hornetnest
Posté le 12-12-2007 à 12:00:04  profilanswer
Je souhaiterais réaliser un crossfire de radeon sur chipset x38 (p-e sur une gigabyte  X38-DQ6, je laisse tomber asus suite aux trop nombreux retours SAV que j'ai eu avec cette marque ces derniers temps). Je souhaite jouer sur mon 24" LCD (donc résolution de 1920x1200)
J'hésite entre des HD2900Pro 1Go et HD3870 512Mo.
La HD2900Pro s'oc facilement en XT et le Go de ram permet d'activer tous les filtres en 1920x1200 sous certains jeux.
La HD3870 a l'avantage de la consommation mais j'ai peur que son bus 256bits et les 512Mo limitent un peu en très haute résolution avec filtres avec certains jeux. J'ai lu dans un article qu'en 1920x1200 avec filtres activés, 512Mo commencaient à devenir juste.
Est ce que je me trompe?
Les deux types de cartes étant quasiment au même prix, j'hésite. Pouvez vous me donner quelques avis?
J'ai une alim seasonic M12 700W, est ce que ça suffit? Sinon j'ai la possiblité de rajouter une alim thermaltake pure power express 250W pour CG.
Un article sur les perfs du crossfire HD3870 par rapport au single  :
http://en.expreview.com/?p=53&page=3
Merci pour vos réponses
n°6080449
Cizia
Posté le 12-12-2007 à 12:09:10  profilanswer
1 Antec P182 (noir)
1 Corsair HX 520W
trop faiblard 520w pour ta config....
n°6080469
F@bek
Posté le 12-12-2007 à 12:19:23  profilanswer
zarkdav a écrit :
Bon bah ça y est, j'ai commandé ma config..
il me semble avoir vu une review qui montrait que l'X38 donnait des ailes au crossfire par rapport au P35... oui je sais c'est pas le même prix , mais si tu pars sur une config neuve
Message édité par F@bek le 12-12-2007 à 12:26:12
n°6080470
Posté le 12-12-2007 à 12:19:32  answer
Faux...
Ça va passer comme une lettre a la poste avec cette alim :spamafote: (C'est les corsair avec une base seasonic non ?)
n°6080473
bernardo
qu'est ce tu'dis ?
Posté le 12-12-2007 à 12:20:20  profilanswer
Salut, tu m'intéresses :d
J'ai un VF700 Cu et je me tate pour l'installer sur ma 3870 que je trouve un poil bruyante...
Ton VF700, il tourne en 5,7 ou 12V ?
Merci :hello:
n°6080492
F@bek
Posté le 12-12-2007 à 12:27:54  profilanswer
 :heink: je n'ai jamais dépassé les 65° avec le ventilo d'origine (avec le bios correctif)
Message édité par F@bek le 12-12-2007 à 12:30:40
n°6080500
johnny-vul​ture
Posté le 12-12-2007 à 12:30:50  profilanswer
Regarde les sites que j'ai mis plus haut. Y'a des comparaisons. Juste quelques pourcentages et ça dépend des jeux.
n°6080507
gatapass
Posté le 12-12-2007 à 12:35:16  profilanswer
il faut toujours un cable special vga pour brancher derriere les deux cg pour le crossfire? personne a un plan pour faire un cable a partir de deux cables vga?
n°6080512
secalex
Stalker forever
Posté le 12-12-2007 à 12:37:16  profilanswer
Non.
Cela ce fait dans le chassis avec des cables nappe souple fournis avec la CG. ;)
FEED-BACK /   I phoque PiseptO (Paidai i7 Owner)
n°6080531
Gigathlon
Quad-neurones natif
Posté le 12-12-2007 à 12:49:42  profilanswer
Ta sonde doit être foireuse car ça fait quand même 2x qu'on obtient des résultats bien supérieurs à toi... :o
28°C idle, qui plus est en passif, par une temp ambiante proche des 20°C c'est assez louche déjà, et concernant la temp avec le bios d'origine j'avais approché les 80°C en idle, ventilo à 40%... (certes à 700, mais sans charge)
n°6080534
gatapass
Posté le 12-12-2007 à 12:51:43  profilanswer
donc je peux brancher quatre ecran en utilisant le crossfire?
n°6080538
zarkdav
Posté le 12-12-2007 à 12:52:52  profilanswer
Yep. Existe en 520W et 620W. Mon calcul était rapide mais je pense que ça devrait passer.
n°6080613
Olio
Posté le 12-12-2007 à 13:20:24  profilanswer
Oui j'ai eu le meme soucis !!
J'ai donc installé les drivers séparement ( tu vas dans panneau de config et tu fais l'installe manuel en trouvant le dossier drivers dans les catalyst )
Ensuite tu peux installer le driver catalyst
n°6080626
whilsesqua​d
Posté le 12-12-2007 à 13:23:06  profilanswer
SAlut, j'ai une hd3870 Connect 3D, je voudrais savoir si il est possible de reguler automatique via logiciel le ventilo de la cg? Car je voudrais que le ventilo soit à 60-70% lorsque la cg atteint 60° Merci
Message édité par whilsesquad le 12-12-2007 à 13:24:42
n°6080630
F@bek
Posté le 12-12-2007 à 13:23:55  profilanswer
Gigathlon a écrit :
Ta sonde doit être foireuse car ça fait quand même 2x qu'on obtient des résultats bien supérieurs à toi... :o )
niet, seth-01 avait les mêmes t° avec le ventilo d'origine (bios sapphire)
le bios d'origine est foireux dans la gestion du ventilo, autant ne pas en parler
concernant ma t° avec l'Accelero, on verra avec celui des autres quand ils le recevront
mais vu la superficie de l'accelero, ne le compares pas aux temp de ton VF-1000, ils n'ont franchement rien a voir
Message édité par F@bek le 12-12-2007 à 13:32:18
n°6080651
Gigathlon
Quad-neurones natif
Posté le 12-12-2007 à 13:28:31  profilanswer
L'accelero étant passif et en alu, grande surface ou pas le GPU chauffera forcément, d'ailleurs sa surface est loin d'être grande en réalité... les ailettes sont beaucoup plus espacées que sur le VF-1000 en plus d'être moins larges.
VF-1000: 53 ailettes de ~160x15 soit ~2544cm², en cuivre et avec ventilo
Accelero S1: 33 ailettes de ~215x20 soit ~2838cm², en alu et sans ventilo
Message édité par Gigathlon le 12-12-2007 à 13:40:35
n°6080656
marllt2
Posté le 12-12-2007 à 13:29:57  profilanswer
C'est peut-être l'interface chaise-clavier qui est foireuse. [:cosmoschtroumpf]
n°6080684
ocz57
Posté le 12-12-2007 à 13:39:21  profilanswer
HD3870 reçue,
j'ai installé les drivers et catalyst 7.11, tout s'installe parfaitement, mais une fois installé et lorsque je click pour lancer Catalyst control Center, rien de se lance???
(driver cleaner pro passé au préalable, les drivers et tout s'installent nickel)
la carte fonctionne parfaitement.
ps: dans le gestionnaire de programmes, Catayst Controle Center ne fait que 0.02mo (lol) pourtant l'installe s''est bel et bien déroulée)
pas d'icone sur le bureau ou dans la barre de tâches mais present dans "demarrer...."
deja désinstallé et réinstallé ...toujours pareil... :whistle:
Message édité par ocz57 le 12-12-2007 à 13:41:06
n°6080729
Olio
Posté le 12-12-2007 à 13:55:48  profilanswer
Je recois l'accelero S1 demain , j'espere qu'il ira sur la 3850
n°6080755
e2d2
g33k m4t0s
Posté le 12-12-2007 à 14:02:26  profilanswer
en principe oui, je souhaiterai savoir si l'étage d'alimentation sera aussi 'refroidit'
[ACH/VDS/ECH] - Feed Back
n°6080783
F@bek
Posté le 12-12-2007 à 14:10:44  profilanswer
Gigathlon a écrit :
L'accelero étant passif et en alu, grande surface ou pas le GPU chauffera forcément...
patience on sera le fin mot de l'histoire dans les jours a venir avec le témoignanges d'autres utilisateurs
une chose est certaine pour moi, avant avec le ventilo d'origine, le dessus de ma carte aprés un long passage sous 3dmark était trés chaud, maintenant c'est moyennement chaud
en IDLE le rad entier est froid
PS: je ne crois ni en la vierge, ni en raël
Message édité par F@bek le 12-12-2007 à 14:18:23
n°6080788
Nco34
Trackmaniaque
Posté le 12-12-2007 à 14:12:54  profilanswer
+1 faut arreter de dire des conneries.
n°6080802
barbybulle
GIGABYTE OC Team
Posté le 12-12-2007 à 14:18:55  profilanswer
Pour une fois , je dit -1
Les Alim Corsair sont excellente , garantie 5 ans + fabriqué chez Seasonic  :)
Gigabyte France
n°6080812
Proov
Art & Science
Posté le 12-12-2007 à 14:23:03  profilanswer
J'ai une Tagan 480W, ça passera si je remplace ma X850 XT par une 3870 ? :??:
ATI HD2600 Pro à 256 Mo DDR3 dédiésl'alim de mon boitier ANTEC PERFORMANCE TAC Series TX635 siffle
[Topic Unique] Cartes Mères MSI chispet P35 Neo etc ...HDD et CD ROM sur le meme et unique IDE
[Topic Unique] Processeurs Intel Nehalem / Westmere LGA 1366 (i7)HD 3850 et 3870
[Topic Unique] Samsung SpinPoint F1[ Topic Unique] Shuttle SX38P2 Pro
Pilote Ati
Plus de sujets relatifs à : [TOPIC UNIQUE] ATI HD 3800 series > HD 3850 & HD 3870
