2305 connectés
  PowerColor HD 7990 Devil 13
n°8432904
OrcusZ
Pro AMD | .Net lover
Posté le 30-08-2012 à 11:03:08  profilanswer
Bonjour à tous :D,
Voilà, premier avant gout d'une HD 7990... Ou simple fusion de deux HD 7970, peut importe, les performances risque d'êtres monstrueuse ( mais aussi la consommation et la température ) mais pourquoi se plaindre alors que se petit bijoux avec un packaging en adéquation avec la bête nous fera grimper au plafond grâce à ces performances.
http://www.pcworld.fr/carte-graphi [...] 1023,1.htm
Maintenant reste à savoir les vrais performances attendons les test et le verdict de celui-ci ( et bien sur le PRIX !!! )
Made you your own sentence without believing that of the others...
n°8434108
kikamaruu
All Or Nothing !
Posté le 31-08-2012 à 01:32:48  profilanswer
Comment je kifferai l'avoir.
n°8434110
Invite_Sur​prise
Racaille de Shanghaï
Posté le 31-08-2012 à 01:35:14  profilanswer
http://www.techpowerup.com/reviews [...] _Devil_13/
Important: All data in this review was obtained after I repaired a major design error of the card. When I received it, the card ran extremely high temperatures, reaching beyond 100°C, causing instability and black screen hangs. Also the fan would run at 100% almost instantly. This is caused by screws with integrated stop, that resulted in too little mounting pressure between GPU and heatsink, which is clearly an engineering oversight. I added three metal washers on each screw, by removing the screws, adding the washers and putting the screws back. The cooler was removed for this procedure, and thermal paste was replaced with a thin layer. Only this procedure enabled the card to run stable. Out of the box the card was unusable.
PowerColor's HD 7990 Devil 13 is the first dual-GPU HD 7990 card that we review. I have to praise PowerColor for making the bold move and engineering their card without any help from AMD. AMD's HD 7990 is still MIA and might never be released at all. The HD 7990 Devil 13 provides awesome performance in games that properly support CrossFire. But many games don't show ideal scaling, or no scaling at all. AMD's CrossFire technology requires profiles for each game to provide maximum performance, which is often a problem with newly released games as AMD is slower than NVIDIA in updating their profiles. Compared to NVIDIA's dual-GPU GeForce GTX 690, the PowerColor Devil 13 is 11% behind in performance when averaged over all our testing.
Message édité par Invite_Surprise le 31-08-2012 à 01:37:05
n°8434137
serialof83
Posté le 31-08-2012 à 05:54:12  profilanswer
Vive la copie des DCUII...Nan franchement...
n°8434189
bucheron9
I like juice
Posté le 31-08-2012 à 09:18:15  profilanswer
un poil decevant quand meme,je m attendais a de meilleurs resultats...
Listen to the hidden tune
n°8434216
OrcusZ
Posté le 31-08-2012 à 09:54:30  profilanswer
C'est vrai que c'est un peut décevant, mais mieux que Nvidia ( on verra quand on aura le prix de la carte si cela est vraiment intéressant ) et de plus on ne sais pas d'où sort cette carte...
Sois c'est AMD qu'il leurs on laissez l'exclu pour faire un coup marketing, ou powercolor qui à fait un bi-gpu de la 7970 et à demandez l'autorisation à AMD de l'appeler 7990...
Sachant qu'a la base elle devait s'appeler HD 7970x2...
En espérant qu'AMD réagisse sur cette carte
n°8434229
bucheron9
I like juice
Posté le 31-08-2012 à 10:11:56  profilanswer
les rumeurs c est qu AMD a abandonné la 7990,et a laissé aux marques le soin de faire leur propre bi gpu.
le point positif c est quand meme que les gpu ne sont pas castrés niveau frequence,et qu on a meme droit a un bios oc,ce qui est rare sur ce genre de carte
en plus si les hd 8xxx sortent debut 2013,cette generation de bi gpu a pas grand interet,sauf si le prix est interessant comparé a un cf de 7970 classique (900roro grand max)
n°8434241
OrcusZ
Posté le 31-08-2012 à 10:19:38  profilanswer
C'est vrai, mais il y a eu tellement de rumeur avec cette carte qu'on ne sais plus quoi penser :/
n°8434249
aliss
Rhyme the Rhyme Well
Posté le 31-08-2012 à 10:26:00  profilanswer
Il semble tout de même y avoir un soucis avec cette carte puisque malgré des specs identiques à un cross de 7970, elle n'en a de toute évidence pas les perfs (le scaling est particulièrement mauvais, même en 1600p).
n°8434274
OrcusZ
Posté le 31-08-2012 à 10:34:25  profilanswer
En clair il sont fait du boulot de roumain :o, powercolor on surement voulu faire un coup marketing
n°8434278
bucheron9
I like juice
Posté le 31-08-2012 à 10:35:36  profilanswer
n°8434457
kayo
Posté le 31-08-2012 à 13:45:52  profilanswer
Et cette carte: Sapphire Toxic HD 7970 GHz Edition 6 Go  http://www.ldlc.com/fiche/PB00133573.html n'est-elle pas déjà une des plus puissante?
n°8434460
OrcusZ
Posté le 31-08-2012 à 13:46:39  profilanswer
Hum... Faudrait chercher des test
n°8434470
OrcusZ
Posté le 31-08-2012 à 13:51:26  profilanswer
Voilà un petit test trouvé sur internet
http://www.tweaktown.com/reviews/4 [...] ndex1.html
n°8434484
OrcusZ
Posté le 31-08-2012 à 14:00:41  profilanswer
Bon je viens de lire et de regardez les bench...
C'est pas terrible terrible, le mieux c'est la consommation et les températures qui rende la carte très très inintéressante.
Par contre le prix ne vaut pas le gain de performances
n°8434506
OrcusZ
Posté le 31-08-2012 à 14:11:46  profilanswer
Test complet de la Devil 13 :
http://www.techpowerup.com/reviews [...] 13/32.html
Je trouve qu'elle à des perfs bizarre ( un coup elle est bien l’autre moins bien sur le même jeux ) mais elle à l'air tout de même d'être plus puissante que la gtx690 ( en espérant quelle ne soit pas à 1000 euros aussi )
Ensuite elle consomme comme pas possible, le seul point positif c'est les température qui sont je trouve très bonne pour une carte de se type
n°8434507
bucheron9
I like juice
Posté le 31-08-2012 à 14:12:12  profilanswer
kayo a écrit :
rien a voir,la sapphire est mono gpu,la powercolor en a 2
n°8434517
OrcusZ
Posté le 31-08-2012 à 14:16:37  profilanswer
Ouais mais quand on auras le prix de la devil on pourra comparer selon le prix. Car si le prix/perf de la mono est 50% plus intéressant que la bi-gpu... On la prendra pas la devil :o
n°8434545
uNReaLx77
üNReaL
Posté le 31-08-2012 à 14:31:33  profilanswer
sur le test de teshpowerup elle est donné au meme prix qu'une 690 (1000$)
en general les prix ici n'en sont pas loin, dans les 950euro
n°8434581
kayo
Posté le 31-08-2012 à 14:49:06  profilanswer
En Suisse, le prix de la SAPPHIRE HD7970 Toxic HD 7970 GHz 6.0GB GDDR5
Prix à partir de 588.92 EUR
Pour l'autre, je l'avais vu sur le site hier mais ils ont retiré :ouch: Elle était environ vers 1080 francs suisse (900€) mais en supprimant la tva (7.9%) suisse et en mettant la tva française, probablement qu'elle sera aux environs des 1000€.
http://fr.toppreise.ch/index.php?k2=7
n°8434586
OrcusZ
Posté le 31-08-2012 à 14:56:26  profilanswer
1000$ on peut espérer l'avoir pour 800 euros vu que 1000$ c'est environ 750 euros :o
C'est toujours 200 euros de moins que la gtx690
n°8434594
Invite_Sur​prise
Posté le 31-08-2012 à 15:19:40  profilanswer
C'est pas vraiment ce dit le test de TPU.
PowerColor is asking $999 for their card, which is the same as NVIDIA's GTX 690. I find it hard to recommend the PowerColor card at that price-point. NVIDIA's card provides the better overall experience, less power, noise, heat, better max OC performance, in a dual slot form factor, and better drivers.
n°8434610
OrcusZ
Posté le 31-08-2012 à 15:31:34  profilanswer
Moi j'ai look les bench, elle est souvent devant la gtx690 ( de peux et souvent sur les grosse résolution )
Et sa c'est mon coté fanatique ATI qui a pris le dessus ^^
n°8434623
Posté le 31-08-2012 à 16:03:12  answer
Ouai enfin, déjà "Better max OC Performance" veut rien dire du tout suivant la carte, "Better drivers" c'est subjectif, "noise" ça dépend du boost de la GTX690 etc .....
n°8436050
wnorton
Je suis néerlandophone
Posté le 02-09-2012 à 15:44:38  profilanswer
Tu trouve toi un récap sur les performances en haute résolution:
http://tpucdn.com/reviews/Powercolor/HD_7990_Devil_13/images/perfrel_2560.gif
Maintenant c'est pas une carte de réf AMD la PowerColor Devil 13 donc à comparer avec celle-ci la Asus mars III 2 GTX680 avec leur fréquence d’origine & 8Go Ram ;)
http://assets.hardwarezone.com/img/2012/05/asus_mars_iii_main.jpg
http://www.pcworld.fr/carte-graphi [...] 8639,1.htm
Je comprend mieux pourquoi AMD a pas (encore) sortie la carte officiel HD7990 ou HD7970x2 depuis un bon moment, un gouffre en consommation pour des performances ridicule
pour un bi-gpu, il aurai du la re sortir quelque mois plut tard en GHz Edition :whistle:
Message édité par wnorton le 02-09-2012 à 15:51:27
Je suis néerlandophone une fois
n°8436111
Posté le 02-09-2012 à 17:02:41  answer
http://www.youtube.com/watch?v=B9PjBgWOkng
n°8436826
OrcusZ
Posté le 03-09-2012 à 13:29:37  profilanswer
Thanks pour la récap :D
Suffit de voir le prix définitif... 1000$ ou pas 1000$ tel est la question :o
n°8437227
wnorton
Posté le 03-09-2012 à 17:19:12  profilanswer
sur que le prix sera entre 900€ & +/-1100€ du Sapphire une marque quand même, en espèrent que cette fois il on mis une meilleur gestion d'alimentation pour évidé le grésillement. :o
n°8437873
OrcusZ
Posté le 04-09-2012 à 07:59:55  profilanswer
Ouep, bon à voir.
En espérant qu'AMD nous sorte un jolie bébé ( pour la hd 79990 ) ou une série hd8000 qui pète le feu.
R6970 HD ligthning twin frozr 3...aie aie aieAvis pour config PC : PAO, MAO, Montage Video HD
Remplacement HD 5870[HFR] Actu : PowerColor lance la Devil 13 HD7990
Conseil pour un Cfire 6870 HDRadeon HD 7870 sous gpu-z
Fréquence Sapphire HD 7770 OCHD 7850 dédié jeux + Gt 610/20/30 dédié physiX/Cuda.
Problème LIVE GAMER HD
Plus de sujets relatifs à : PowerColor HD 7990 Devil 13
