3536 connectés
 Page :   1  2  3
Page Suivante
[NEWS] Gtx 760 & Gtx 760 Ti
n°8763244
WizardPC
Posté le 19-06-2013 à 16:14:31  profilanswer
Mieux vaut se trouver une 680 d'occasion ou 670 neuve dans ce cas ^^
Modding/Watercooling : PiBoy! ~ WaterBox // Achat / Vente !!
n°8763972
titienzo18
Fight Fire With Fire
Posté le 20-06-2013 à 02:54:36  profilanswer
attention!
-170W de TDP pour la 760 comme pour la 670. Elle disposera de deux connecteurs d'alimentation 6 pins PCIe pour une puissance max de 225W.
-Pas la même conso entre la 760 et les 670/670...  :non:  123W max pour la 670 de ref en charge, 170W pour la 680. La conso de la 760 de ref devrait être d'environ 125W et 145W max sur les modèles custom.
La 760 de ref (98% certain):
http://cdn2.wccftech.com/wp-content/uploads/2013/06/GeForce-GTX-760-635x368.png
Une idée de performance, pincettes de rigueur:
Chiploco reports 3D Mark benchmark scores for the GTX 760, and here they are:
NVIDIA GeForce GTX 760 3DMark 11 Scores:
    3DMark 11 Performance Score: Px830 (Assuming 8830)
    Graphics Score: 8897
    Physics Score: 9676
    Combined Score: 7435
http://wimages.vr-zone.net/2013/06/NVIDIA-GeForce-GTX-760-3DMark-11.jpg
NVIDIA GeForce GTX 760 Performance
While the GTX 770 was designed as a counterpart to Radeon HD 7970 GHz Edition, the GTX 760 will be competing with the HD 7950 Boost. The new card from NVIDIA is slightly faster than Radeon model.
NVIDIA GeForce GTX 760 Official Specifications Confirmed
The GeForce GTX 760 graphics card would feature a GK104-225-A2 Kepler core architecture that would boast 1152 cores, 96 TMUs, 32 ROPs along with a 2 GB GDDR5 memory interface running along a 256-bit wide memory interface. Manufacturer’s are free to release 4 GB models as they wish at an extra price. The GPU runs at a base clock of 980 MHz while boosts up to 1033 MHz which are faster speeds than as seen on the GeForce GTX 670. The memory on some of the overclocked variants is clocked at 7 GHz while reference still operate at the reference 6 GHz effective clock speeds, the GPU pumps out a bandwidth of 192 GB/s at 6 GHz and overclocked models at 224.4 GB/s at 7 GHz effective clock speeds.
► Topic unique GTX 760 ►MOD
n°8763973
titienzo18
Posté le 20-06-2013 à 03:19:10  profilanswer
Ca se précise de plus en plus:
http://www.techpowerup.com/gpudb/b [...] aming.html
http://www.monhardware.fr/msi-gefo [...] on-gaming/
Seul couac qui semble se vérifier, la fréquence mémoire ne serait pas de 7GHz mais encore de 6008MHz même si Nvidia laissera le choix aux fabriquant quant à la fréquence. Visiblement le modèle MSI reste à 6008MHz.
Superbe MSI GTX 760 OC Gaming Edition:
http://www.techpowerup.com/gpudb/images/b2120.jpg
http://www.monhardware.fr/wp-content/uploads/2013/06/GeForce-GTX-760-Gaming-OC_1-635x468-300x221.jpg
La carte graphique GeForce GTX 760 OC Gaming comporterait une architecture de base GK104-225-A2 Kepler (...). Le GPU fonctionne à une fréquence de base de 1085 MHz tandis qu’en boosts celui-ci monte jusqu’à 1150 MHz. La mémoire de certaines des variantes overclocké est cadencé à 7 GHz tandis que d’autres fonctionnent encore sous la vitesses d’horloge efficaces de 6 GHz, les GPU puise leurs ressources sur une bande passante de 192 Go / s à 6 GHz et 224,4 Go / s à 7 GHz vitesses horloge effective.
La solution de refroidissement Twin Frozr IV utilisé sur la carte est de la même itération que celle que l’on voit sur les GeForce GTX 780 et GTX 770 modèles Lightning. Il fait usage d’un grand réseau d’ailettes en aluminium et un ensemble dissipateur sur le dessus du bloc GPU qui est refroidi par deux grands ventilateurs à pales de type hélice. les sorties d’affichage comprennent des double-DVI, HDMI et un port d’affichage display port. Le PCB non-référence permettrait une plus puissante alimentation PWM sur les cartes de référence permettant un meilleur overclocking. On prévoit que la carte soit disponible au détail dans environ une semaine ou deux pour 299 $. Les modèles de référence seraient censés coûter moins que prévu précédemment.
La GTX 760 sera donc 30% plus puissante que la GTX 660 mais 8% moins véloce que la GTX 670.
n°8763980
Posté le 20-06-2013 à 03:58:35  answer
dommage , si je salue le bus 256 bit
il a un défaut , c'est de repasser à 2go de mémoire
comme pour les 670/680
si en mono ça osef , prendre un SLI de 760 2go ne me parait pas intéressant pour du long terme , ce qui est dommage au vu de la puissance disponible
le hic c'est que NV les fait payer très cher les 2 giga supplémentaires :/
ça risque de donner le syndrome SLI 460/560 : puissance de calcul correct encore aujourd'hui , mais bien trop souvent limité par les 1go de mémoire
et rare sont ceux qui ont pensé à prendre des 2go :/
après , 299 $  , si on a du bol , on devrait peut être trouver des ref à la sortie pour 250 €
je trouve ça encore un poil chéro , la 7950 garde des arguments en face encore je trouve [:urd]
Message édité par Profil supprimé le 20-06-2013 à 11:51:00
n°8763985
titienzo18
Posté le 20-06-2013 à 04:48:23  profilanswer
je créé en accord avec wizardPC un topic unique 760/760 Ti ;)
n°8764036
havok06
Posté le 20-06-2013 à 09:19:43  profilanswer
299$ pas 299€ [:fadiez:1]
Message édité par havok06 le 20-06-2013 à 09:19:56
n°8764159
Posté le 20-06-2013 à 11:50:19  answer
en effet
édité
n°8764232
lyonnais_6​9
Posté le 20-06-2013 à 13:06:34  profilanswer
Je me suis pris un SLI de 670 2go perso, car pour l'instant pas vraiment l'intêret des 4go sauf pour de très rares cas ... (meme quand je fais du downsampling 2160p).
Je changerai d'ici 6/8mois, ou pour du AMD si ils sortent les drivers magiques pour le crossfire ou par une 780 si le prix passe sous les 500€.
Sinon les nouvelles générations arrivent dans 8 mois il me semble non ?
Donc prendre un SLI de 670/680 ou 760 2go maintenant pour 2ans c'est clairement tendu, en prendre un de 4go pour 2 ans c'est certes mieux mais dans 2 ans ça sera tendu niveau perf, 2 nouvelles générations seront passées ... sans compter le surcoût.
Donc mon raisonnement de prendre du 2go à pas cher et changer ds 6/8 mois me semble meilleur, après à vos arguments !
Message édité par lyonnais_69 le 20-06-2013 à 13:09:36
Fractal Design Define R2 // Cooler Master Silent Pro M700 // Intel Core i7 4770k @ 4.5Ghz // Noctua NH12 SE2 // 16 Go Crucial CL8 // ASUS Z87-A // R9 290 Sapphire Tri X OC // Crucial M500 480 Go // LG 236V PN 1080p IPS
n°8764386
Posté le 20-06-2013 à 15:19:16  answer
c'était vrai dans le temps , beaucoup moins maintenant
le gap d'une gen à l'autre est devenu infime comparé à il y a quelques années
du coup , ça se dévalue bien plus vite que les perfs elles n'augmentent
de ce fait , beaucoup de gens font comme moi et vise le long terme lorsqu'il choisissent leur matos au lieu de changer tous les 6 mois comme auparavant
reprenant ton exemple dans 8 mois ça vaudra combien en occas une 670   , pas lourd
il te faudra rajouter un bon billet pour prendre une 780 , tout ça pour des perfs brutes inférieur
et comme tu le soulignais toi même dans 8 mois , ce modèle sera sur le point d'être remplacé
si tu rajoutes à ça le prix d'achat des deux 670   ça commence à faire beaucoup , et j'ai même du mal à percevoir la cohérence du raisonnement  :heink:
PS: faut arrêter avec les drivers magiques D'amd , y a les fanboys nv qui les attendent ,
depuis longtemps déjà , y a ça
http://www.tomshardware.fr/article [...] 16-11.html
et en plus de résoudre les soucis de stutter , ils apportent pas mal de features qui manque dans les drivers amd , comme différents types d'AA , de l'OA ect.......
ce qui permet de rattraper le retard sur ce point par rapport a NV  :sweat:
Message édité par Profil supprimé le 20-06-2013 à 15:27:32
n°8764711
lyonnais_6​9
Posté le 20-06-2013 à 19:11:33  profilanswer
Perso j'ai pas envie de me prendre la tête à créer un profil par jeu ... prend trop de temps ! Et je suis loin d'être un fanboy NV, au contraire je n'ai jamais eu de Nvidia avant cette année (2 x 660 puis 2 x 670 maintenant) ! Et d'ailleurs j'ai une 7950 sur mon deuxième PC ... mais j'ai du prendre du nvidia car le SLI marche mieux que le crossfire (sans bricoler) (et pour d'autre raisons, downsampling plus simple par exemple).
Pour en revenir au LT certes une 670 vaudra pas lourd dans 8 mois (150€) mais c'est le cas de toutes les cartes pas que de la 670 ... et à l'heure actuelle en prix/perf à part le SLI de 660 (et les 7950 /7970 mais en dessous niveau perf) je ne vois pas mieux !
Message édité par lyonnais_69 le 20-06-2013 à 19:12:30
n°8765078
Posté le 21-06-2013 à 01:22:54  answer
c'est nécessaire seulement pour ceux qui pose problème , et heureusement c'est pas le cas de tous ;)
et puis ça ne me dérange pas spécialement , ça prends pas trois plombe non plus une fois que t'as capté le soft
mais  donc si je suis ton raisonnement  en gros , le surcout NV , c'est le prix de la flème  :lol:
un peu comme quand  tu commandes une pizza parce que t'as pas le courage de te faire à bouffer après une dure semaine  :D
ça se tient mais perso , je trouve que ça revient cher la flémingite  :lol:
sinon pour moi , le meilleur rapport perf/prix/futurproof sur cette gen c'est le cross de 7950 et Radeonpro   :)
n°8765107
titienzo18
Posté le 21-06-2013 à 02:06:56  profilanswer
Je met le lien vers le topic "officiel" 760/760Ti...
http://forum.hardware.fr/hfr/Hardw [...] 4790_1.htm
Et au passage Nvidia n'est pas décidé à sortir la 760 Ti pour le moment, pas avant la rentrée en tout cas. :jap:
n°8903237
lottte
STFW
Posté le 20-10-2013 à 05:11:29  profilanswer
C'est fait http://www.hardware.fr/news/13410/ [...] +-+News%29  :jap:
 Page :   1  2  3
Page Suivante
[Résolu] Compatibilité GTX 770 OC Gigabyte et Corsair HX 750w ?[HFR] Actu : Computex: GTX 760 et contrôle strict de Nvidia ?
Choix Gtx 770artefacts graphique GTX 670
[Résolu]GTX 670 boot écran veille après installation[HFR] Actu : Computex: Les GTX 780 et 770 Classified d'EVGA
GTX 560 ti ventirad[HFR] Actu : Computex: Une GTX Titan custom chez Gigabyte ?
Que faire de ma GTX 460?
Plus de sujets relatifs à : [NEWS] Gtx 760 & Gtx 760 Ti
