6429 connectés
 Page :   1  2  3  4  5  6  7  8
Linux sur vieux matos: screenshots, dmesg,lspci,uname -a, gcc etc.
n°1186609
Mac Gyver ​974
Posté le 17-12-2009 à 10:36:03  profilanswer
Okay, au moins j'aurais essayé :o
Vivement que tu postes le résultat en tout cas (uname -a etc etc comme dans le titre du topic)
n°1194340
SPlissken
Posté le 22-01-2010 à 13:02:23  profilanswer
NetBSD sur mon PII 400 Mhz 128 Mo Ram
Copyright (c) 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005,
    2006, 2007, 2008, 2009
    The NetBSD Foundation, Inc.  All rights reserved.
Copyright (c) 1982, 1986, 1989, 1991, 1993
    The Regents of the University of California.  All rights reserved.
NetBSD 5.0.1 (GENERIC) #0: Thu Jul 30 01:39:11 UTC 2009
 builds@b8.netbsd.org:/home/builds/ab/netbsd-5-0-1-RELEASE/i386/200907292356Z-obj/home/builds/ab/netbsd-5-0-1-RELEASE/src/sys/arch/i386/compile/GENERIC
total memory = 127 MB
avail memory = 113 MB
timecounter: Timecounters tick every 10.000 msec
timecounter: Timecounter "i8254" frequency 1193182 Hz quality 100
Generic PC
mainbus0 (root)
ACPI Error (tbxfroot-0308): A valid RSDP was not found [20080321]
ACPI: unable to initialize ACPI tables: AE_NOT_FOUND
cpu0 at mainbus0: Intel 686-class, 400MHz, id 0x651
pci0 at mainbus0 bus 0: configuration mode 1
pci0: i/o space, memory space enabled, rd/line, rd/mult, wr/inv ok
pchb0 at pci0 dev 0 function 0
pchb0: vendor 0x8086 product 0x7190 (rev. 0x02)
agp0 at pchb0: aperture at 0xe0000000, size 0x8000000
ppb0 at pci0 dev 1 function 0: vendor 0x8086 product 0x7191 (rev. 0x02)
pci1 at ppb0 bus 1
pci1: i/o space, memory space enabled
vga1 at pci1 dev 0 function 0: vendor 0x121a product 0x0005 (rev. 0x01)
wsdisplay0 at vga1 kbdmux 1: console (80x25, vt100 emulation)
wsmux1: connecting to wsdisplay0
drm at vga1 not configured
pcib0 at pci0 dev 7 function 0
pcib0: vendor 0x8086 product 0x7110 (rev. 0x02)
piixide0 at pci0 dev 7 function 1
piixide0: Intel 82371AB IDE controller (PIIX4) (rev. 0x01)
piixide0: bus-master DMA support present
piixide0: primary channel wired to compatibility mode
piixide0: primary channel interrupting at irq 14
atabus0 at piixide0 channel 0
piixide0: secondary channel wired to compatibility mode
piixide0: secondary channel interrupting at irq 15
atabus1 at piixide0 channel 1
uhci0 at pci0 dev 7 function 2: vendor 0x8086 product 0x7112 (rev. 0x01)
uhci0: interrupting at irq 11
usb0 at uhci0: USB revision 1.0
piixpm0 at pci0 dev 7 function 3
piixpm0: vendor 0x8086 product 0x7113 (rev. 0x02)
timecounter: Timecounter "piixpm0" frequency 3579545 Hz quality 900
piixpm0: 24-bit timer
piixpm0: interrupting at SMIpiixpm0: polling
iic0 at piixpm0: I2C bus
eap0 at pci0 dev 11 function 0: vendor 0x1274 product 0x1371 ES1373-8(rev. 0x08)
eap0: interrupting at irq 5
eap0: ac97: Crystal CS4297A codec; headphone, 20 bit DAC, 18 bit ADC, Crystal Semi 3D
eap0: ac97: ext id 200<AMAP>
audio0 at eap0: full duplex, mmap, independent
midi0 at eap0: AudioPCI MIDI UART
rtk0 at pci0 dev 12 function 0: Realtek 8139 10/100BaseTX (rev. 0x10)
rtk0: interrupting at irq 10
rtk0: Ethernet address 00:08:a1:b6:b0:13
rlphy0 at rtk0 phy 7: Realtek internal PHY
rlphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto
isa0 at pcib0
lpt0 at isa0 port 0x378-0x37b irq 7
com0 at isa0 port 0x3f8-0x3ff irq 4: ns16550a, working fifo
com1 at isa0 port 0x2f8-0x2ff irq 3: ns16550a, working fifo
pckbc0 at isa0 port 0x60-0x64
pckbd0 at pckbc0 (kbd slot)
pckbc0: using irq 1 for kbd slot
wskbd0 at pckbd0: console keyboard, using wsdisplay0
pms0 at pckbc0 (aux slot)
pckbc0: using irq 12 for aux slot
wsmouse0 at pms0 mux 0
attimer0 at isa0 port 0x40-0x43: AT Timer
pcppi0 at isa0 port 0x61
midi1 at pcppi0: PC speaker (CPU-intensive output)
sysbeep0 at pcppi0
isapnp0 at isa0 port 0x279: ISA Plug 'n Play device support
npx0 at isa0 port 0xf0-0xff
npx0: reported by CPUID; using exception 16
fdc0 at isa0 port 0x3f0-0x3f7 irq 6 drq 2
attimer0: attached to pcppi0
isapnp0: no ISA Plug 'n Play devices found
timecounter: Timecounter "clockinterrupt" frequency 100 Hz quality 0
fd0 at fdc0 drive 0: 1.44MB, 80 cyl, 2 head, 18 sec
uhub0 at usb0: vendor 0x8086 UHCI root hub, class 9/0, rev 1.00/1.00, addr 1
uhub0: 2 ports with 2 removable, self powered
wd0 at atabus0 drive 0: <Hitachi HDS721680PLAT80>
wd0: drive supports 16-sector PIO transfers, LBA48 addressing
wd0: 32253 MB, 65531 cyl, 16 head, 63 sec, 512 bytes/sect x 66055248 sectors
wd0: 32-bit data port
wd0: drive supports PIO mode 4, DMA mode 2, Ultra-DMA mode 6 (Ultra/133)
wd0(piixide0:0:0): using PIO mode 4, Ultra-DMA mode 2 (Ultra/33) (using DMA)
atapibus0 at atabus1: 2 targets
cd0 at atapibus0 drive 0: <GoldStar CD-RW CED-8080B, 2000/02/22, 1.05> cdrom removable
cd0: 32-bit data port
cd0: drive supports PIO mode 4, DMA mode 2
cd0(piixide0:1:0): using PIO mode 4, DMA mode 2 (using DMA)
Kernelized RAIDframe activated
pad0: outputs: 44100Hz, 16-bit, stereo
audio1 at pad0: half duplex
boot device: wd0
root on wd0a dumps on wd0b
/: replaying log to memory
root file system type: ffs
/: replaying log to disk
wsdisplay0: screen 1 added (80x25, vt100 emulation)
wsdisplay0: screen 2 added (80x25, vt100 emulation)
wsdisplay0: screen 3 added (80x25, vt100 emulation)
wsdisplay0: screen 4 added (80x25, vt100 emulation)
Tout le monde se bat , personne se barre
n°1195421
Mac Gyver ​974
Posté le 27-01-2010 à 16:57:34  profilanswer
Generic PC
mainbus0 (root)
pci1 at ppb0 bus 1
isa0 at pcib0
sysbeep0 at pcppi0
boot device: wd0
Pas mal pas mal  :)
n°1195472
SPlissken
Posté le 27-01-2010 à 20:34:11  profilanswer
Par contre j'ai un prob avec la carte 3DFX inside , j'ai eu beau recompiler le kernel en ajoutant tdfxdrm dans le fichier de conf, quand je met tdfx dans le xorg.conf , ecran noir et clavier muet.
Donc je suis obligé d'utiliser vesa , mais alors pas de plein ecran avec mplayer....
n°1195477
Mac Gyver ​974
Posté le 27-01-2010 à 21:30:31  profilanswer
Ah merde ça c'est ballot, pourtant j'ai jamais eu de soucis avec ma 3DFX Voodoo3, il ne faut pas non plus oublier d'installer aussi xf86-video-tdfx ;) (opengl nickel, je faisais même tourner une ancienne version de Nexuiz  :lol: )
Edith Piaf: ah merde c'est pas un Linux, je connais pas en fait :D
Message édité par Mac Gyver 974 le 27-01-2010 à 21:32:57
n°1196018
Mac Gyver ​974
Posté le 30-01-2010 à 16:28:58  profilanswer
Uptime de 91 jours et 19 heures présentement pour mon serveur en carton, qui etait la machine du premier post du topic...(à cette période la machine n'était pas en carton mais dans un boitier à plat "Zenith Z-Station EL"  :lol:
n°1196021
SPlissken
Posté le 30-01-2010 à 17:47:11  profilanswer
Woaw http://splissken.free.fr/smiley/delarue.gif , c'est beau , 91 jours sans même une micro coupure de courant....
n°1196023
Mac Gyver ​974
Posté le 30-01-2010 à 17:51:29  profilanswer
Il y a eu plusieurs micro coupure, mais j'ai un onduleur  :D (dont je décharge totalement la batterie au plomb une fois par mois comme conseillé par le constructeur, pour garantir une meilleure durée de vie à celle-ci, tout en faisant gaffe à rebrancher la prise dans la seconde des que les bip rapproché me signalent que ça va couper  :lol: )
C'est un simple Infosec de 500VA 700VA/360 Watts avec une batterie de 7A/H, elle tient 41 minutes s'il n'y a que le serveur et le modem-routeur (sans wi-fi activé sur celui-ci)
Edit: le voila le petit onduleur acheté 65 euros... (le modèle 700VA pour ma part), dont la batterie est facile à changer, nettement moins cher que l'onduleur complet, et très facile à trouver sous des tas de marques.
Line-interactive donc avec régulation de tension, chose interessante ici à l'île de La Réunion, mon serveur en carton apprécie (mon PC est également sur cet onduleur, mais le PC ne tourne absolument pas H24, seulement quand je suis là, pret à l'éteindre pr préserver la batterie en vu de garder le serveur on-line)
Message édité par Mac Gyver 974 le 30-01-2010 à 18:01:29
n°1196030
deK
watching for beerz on the wing
Posté le 30-01-2010 à 20:11:48  profilanswer
hippo:~# uprecords
     #               Uptime | System                                     Boot up
     1   106 days, 16:47:28 | Linux 2.6.26-2-xen-amd64  Sun Oct  4 20:30:32 2009
     2    86 days, 02:01:11 | Linux 2.6.26-2-xen-amd64  Fri Jul 10 08:28:03 2009
Sans onduleur  [:cerveau prodigy]
(old) Feed HA/V
n°1196032
Mac Gyver ​974
Posté le 30-01-2010 à 20:16:43  profilanswer
deK a écrit :
hippo:~# uprecords
Quand on est correctement alimenté, c'est plus facile :o
Moi je vais ptet me taper des cyclones en plus, et donc des coupures qui risquent de largement dépasser l'autonomie de mon onduleur :( (ou pas :o ), je voudrais faire péter le gros uptime sur mon Pentium 166 là, mais le reseau electrique risque de me trahir....(je mettrais bien un ptit groupe electrogène, mais faudrait qu'il démarre auto en cas de coupure donc très très compliqué pour un petit groupe a pas cher...)
Mon prochain serveur sera problablement de l'Alix (ou équivalent au moment ou mon uptime aura pété :D )
Edit: comme ça panneau solaire et batterie devraient me permettre de me passer totalement du reseau electrique.
Message édité par Mac Gyver 974 le 30-01-2010 à 20:18:04
n°1196114
SPlissken
Posté le 31-01-2010 à 14:47:58  profilanswer
Tiens , uprecords , je  connaissais pas
n°1196173
deK
Posté le 31-01-2010 à 20:28:24  profilanswer
http://podgorny.cz/moin/Uptimed  ;)
(old) Feed HA/V
n°1196180
SPlissken
Posté le 31-01-2010 à 22:49:45  profilanswer
Pas l'air d'etre dispo pour NetBSD mais a l'air d etre dispo pour FreeBSD
n°1196191
Mac Gyver ​974
Posté le 01-02-2010 à 07:58:50  profilanswer
Je viens d'installer la dernière version (0.3.16) et la commande uprecords n'existe pas :??:
Edit: problème de path surement car en lançant l'executable avec le chemin complet ça se lance, MAIS un autre problème (similaire ?) surgit:
/usr/local/bin/uprecords
/usr/local/bin/uprecords: error while loading shared libraries: libuptimed.so.0: cannot open shared object file: No such file or directory
Edith Piaf: J'ai mis directement un script php sur la page relative au serveur dans mon site web, qui affiche directement en Français l'uptime en temps réel  :love:
Message édité par Mac Gyver 974 le 01-02-2010 à 12:45:57
n°1218328
SPlissken
Posté le 17-05-2010 à 20:49:20  profilanswer
Des videos maintenant , d'OS différents sur mon vieux Pentium II 400 Mhz 128 Mo de ram
SalixOS : une distrib linux basée sur Slackware
http://www.youtube.com/watch?v=N7dcFsXz2JI
NetBSD 5.0
http://www.youtube.com/watch?v=J6TiL3StjuI
BeOS
Booting  : http://www.youtube.com/watch?v=uKfIQALL3HE
Running : http://www.youtube.com/watch?v=03ZhMADgaDE
Message édité par SPlissken le 18-05-2010 à 07:40:05
n°1218342
Mac Gyver ​974
Posté le 17-05-2010 à 23:07:20  profilanswer
SalixOS : une distrib linux basé sur Slakware
NetBSD 5.0
BeOS
Merci, voila une jolie contribution  :love:
Dommage que je ne puisse faire pareil avec mon serveur, enfin je devrais attendre de pouvoir "profiter" d'une coupure de courant particulièrement longue (41 minutes d'autonomie sur onduleur au dernier test y a 2 mois...) pour filmer le boot de la Gentoo du LAMP sur ce Pentium mmx 166Mhz, 64Mo d'EDO. (et il tourne toujours ! accessible via le lien dans ma signature, il tient vachement le coup malgré que les 2 HDD soit "morts", consécutivement au voyage en avion en soute...)
Edit: par contre il n'y a aucune trace de mémoire cache sur le Pentium mmx dans /proc/cpuinfo, est-ce normal ?  :??:
cat /proc/cpuinfo
processor       : 0
vendor_id       : GenuineIntel
cpu family      : 5
model           : 4
model name      : Pentium MMX
stepping        : 3
cpu MHz         : 165.771
cache size      : 0 KB
fdiv_bug        : no
hlt_bug         : no
f00f_bug        : yes
coma_bug        : no
fpu             : yes
fpu_exception   : yes
cpuid level     : 1
wp              : yes
flags           : fpu vme de pse tsc msr mce cx8 mmx
bogomips        : 331.54
clflush size    : 32
power management:
Re edit:
http://img25.imageshack.us/img25/8945/alsav.png
Comme on peut le voir sur cette capture d'un alsamixer dans ssh, il y a des réglages grave et aigu.... mais ils n'ont aucun effet  :??:
Message édité par Mac Gyver 974 le 17-05-2010 à 23:21:43
n°1218343
BloodyCarn​age
Posté le 17-05-2010 à 23:24:17  profilanswer
cat /proc/cpuinfo
processor       : 0
cpu family      : 5
model           : 4
stepping        : 3
cpu MHz         : 165.771
cache size      : 0 KB
fdiv_bug        : no
hlt_bug         : no
f00f_bug        : yes
coma_bug        : no
fpu             : yes
fpu_exception   : yes
cpuid level     : 1
wp              : yes
bogomips        : 331.54
clflush size    : 32
power management:
Normal. Cache size ne liste que le L2. Le pentium mmx n'ayant que du L1, il affiche 0.
Idem pour les CPU équipés de L3, il n'est pas compté non plus.
n°1218345
Mac Gyver ​974
Posté le 17-05-2010 à 23:27:34  profilanswer
Ah d'accord, j'ai eu peur que sa mémoire cache ne soit pas géré  :whistle:  :jap:
n°1226429
Mac Gyver ​974
Posté le 04-07-2010 à 12:16:25  profilanswer
Bonne nouvelle, mon Pentium 166 va reprendre du service comme serveur, je vais y mettre un hdd de ... 80Go ! (directement sur le controleur IDE intégré) j'ai vu que ça ne pose aucun problème, alors j'en profite...
Bientot des news, la "maj matérielle" est en cours  :jap:
n°1226587
SPlissken
Posté le 05-07-2010 à 19:37:49  profilanswer
Ouaiiiiiiiiiiis  http://splissken.free.fr/smiley/youpisein.gif
n°1226991
Mac Gyver ​974
Posté le 07-07-2010 à 14:39:14  profilanswer
ça y est, je commence, la partie logicielle est terminé, techniquement le serveur est de nouveau opérationnel, cette fois avec un hdd de 80Go ! (je doutais, à tort, que cette capacité pose soucis sur un P166 mmx !)
Maintenant la partie matérielle: mise en carton (gros gros HB en cours ...)
n°1227041
BloodyCarn​age
Posté le 07-07-2010 à 19:12:15  profilanswer
Tu tiens quand même une solide couche de masochisme. J'ai ressorti mon p3-550 de la cave, et après une soirée, je me suis dis qu'il allait y retourner tant que j'en conserve encore un bon souvenir.
n°1227051
Mac Gyver ​974
Posté le 07-07-2010 à 20:30:42  profilanswer
Ouais jsuis un sacré maso, tu vas voir vous allez tous halluciner, là je prepare la boite en bois ;)
n°1227288
Mac Gyver ​974
Posté le 09-07-2010 à 11:12:50  profilanswer
Travaux en cours  :jap:
http://img576.imageshack.us/img576/4403/imgp1668.png
n°1227290
deK
Posté le 09-07-2010 à 11:22:51  profilanswer
L'alim à nu  [:delarue5]
Tu t'exposes à des problèmes.
http://fr.wikipedia.org/wiki/Cage_de_Faraday
(old) Feed HA/V
n°1227291
Mac Gyver ​974
Posté le 09-07-2010 à 11:28:36  profilanswer
Oui, je sais bien. Je prends le risque pour des raisons pratiques, si des problèmes surgissent je modifierais, mais comme ça rendrais tout plus complexe je prefere voir ce que ça donne en pratique et ne pas me fier aux théories :D on verra bien ;)
n°1227293
deK
Posté le 09-07-2010 à 11:34:43  profilanswer
Mouais enfin là, les problèmes vont surgir au moment où tu t'y attends le moins, c'est pas que de la théorie bidon pour emmerder le monde, là on parle d'électricité et de bonnes grosses tensions, on n'est pas en 12V/5V.
Enfin j'espère que cette fois tu as prévu tes backups :o
(et un extincteur à proximité)
(old) Feed HA/V
n°1227295
Mac Gyver ​974
Posté le 09-07-2010 à 11:58:17  profilanswer
Backup prévus oui, de ce coté là je suis paré :D
pas d'extincteurs par contre non :o
On verra bien ce que donne cette alim 145 Watts alimentant pour 60 Watts environ :D
n°1227462
High Plain​s Drifter
Posté le 10-07-2010 à 18:43:26  profilanswer
Pour du 60W tu dois pouvoir trouver des circuits d'alims qui prennent du 12V continu en entrée comme pour les portables, j'en ai vu sur un site, mais j'ai pas retrouvé le lien et je le regrette :(
Sinon ce topic me fait penser qu'il faudra que je redémarre mon vieux 166MMX un de ces quatre, voir même que je remette son pentium 100 d'origine dedans  :)
Message édité par High Plains Drifter le 10-07-2010 à 18:44:40
| < Ceci n'est pas une pipe.
n°1227473
Mac Gyver ​974
Posté le 10-07-2010 à 21:45:09  profilanswer
Bon j'ai fini et ça fonctionne correctement hormis que le reseau se coupe tout seul pour une raison inexpliqué :??:
http://img694.imageshack.us/img694/66/photo1s.png
n°1227475
manisque
Posté le 10-07-2010 à 22:11:15  profilanswer
legarsjeff a écrit :
Un pote vient de refourguer ça :
http://www.toshiba-europe.com/bv/c [...] roduct.htm
Il est trop gros pour figurer ici ??
Je compte ne faire une petite plateforme de jeu pour ma nièce (10 ans) avec un émulateur dessus.
Gentoo x86 ça ira je pense (faut juste que je me lance dans la lecture de la doc pour savoir comment on installe ça).
Par contre niveau émulateur ya quoi de bien ?
J'ai exactement le même (satellite pro 4270 ou 4290), avec 128Mo de ram. Il faut juste faire attention aux navigateurs web, ne pas installer ni flash, ni java, un environnement de bureau léger, et ça roule.
Gentoo fonctionnait sans problèmes dessus (avec distcc et un bi-p3 + un athlon, ca change un peu), le seul problème, c'était l'occupation mémoire, même en compilant tout en -Os et en faisant bien le ménage dans la variable USE, les 64Mo étaient très vite bouffés (et même après être passé à 128Mo, ça n'a pas changé grand chose).
Maintenant, je suis revenu à la première distrib que j'utilisais quand j'ai eu ce laptop : Debian Sarge (c'était à l'upgrade en etch que j'avais commencé à avoir des problèmes d'occupation mémoire :D )
Le jour où le HDD lache, je pense que j'en profiterais pour installer une NetBSD (mais la rapidité de l'install de debian avec debootstrap et un petit script, ça pèse aussi de l'autre côté :D )
EDIT: Pour faire une cage de faraday, les restes du boitier de l'alim peuvent suffire à blinder au moins le coin qui donne en direction du pc. (Pour faire du vrai HB, j'avais déjà vu des alims demontées entourées de carton recouvert de papier d'alu, mais ça devait être plus psychologique qu'autre chose :o)
Message édité par manisque le 10-07-2010 à 22:45:03
n°1227501
Mac Gyver ​974
Posté le 11-07-2010 à 12:37:34  profilanswer
Comme on peut le voir sur mes photos (comme sur le post précédent), j'ai opté pour 1 couche de scotch, 1 couche d'aluminium, puis une couche de scotch...  :lol:
ça à l'air de bien fonctionner si j'excepte le problème de réseau qui ne serait pas lié à mon montage HB...  :lol:
Je suis sur le coup, peut-etre que passer en IP fixe résoudra le soucis...
Message édité par Mac Gyver 974 le 11-07-2010 à 12:38:41
n°1227620
Mac Gyver ​974
Posté le 12-07-2010 à 14:17:44  profilanswer
C'est bon ce serveur fonctionne de nouveau parfaitement, dans sa nouvelle caisse à vin en bois ...
Cette fois équipé donc d'un hdd de 80 Go .
n°1228257
rengzehn
Posté le 16-07-2010 à 12:17:59  profilanswer
debian sur une silicon graphics O2
http://www.andesi.org/installation [...] ion-sgi-o2
Pas de screenshots, j'ai jamais pu faire tourner X :D
n°1228674
blazkowicz
Posté le 20-07-2010 à 09:39:34  profilanswer
deK a écrit :
Les photos du bouzin :
http://ledek.free.fr/photos/hardware/DSC_3392.JPG
http://ledek.free.fr/photos/hardware/DSC_3398.JPG
http://ledek.free.fr/photos/hardware/DSC_3399.JPG
Donc le disque dur (Maxtor 6.4Go 5400rpm) et le lecteur CD (LiteOn 48X) sont anachroniques évidemment, à la base c'était un Quantum 1.6Go et un lecteur CD 4X.
La carte réseau aussi est anachronique d'ailleurs.
À la différence du tiens, mac gyver 974, c'est de la sdram sur le mien : maximum 64Mo en 2x32Mo, ici 32Mo+16Mo.
(16Mo d'origine)
Je n'ai pas de barette de 32Mo en stock, et une 64 Mo empêche le PC de booter.
À noter que l'alim n'est pas ventilée directement, le seul flux d'air est celui créé par le 40mm d'extraction.
D'ailleurs ces minuscules ventilos font un maximum de bruit, à mon avis en moddant le capot pour y mettre un 80mm en 5V et en virant les 40mm, on pourrait avoir quelque chose d'inaudible et de très bien ventilé [:huit]
Ce PC, s'il avait eu au moins 2 ports PCI (au lieu d'un PCI/ISA et d'un ISA) aurait sûrement fini comme routeur.
C'est un Dell Dimension L433c (Celeron 433, 128Mo) qui remplit cet office, je vous le présenterai un de ces 4  :o
j'avais un routeur avec deux cartes réseau ISA (des 3com etherlink II) sous.. windows 98 :lol:
P133 et 40Mo de ram. n'empêche, il était stable 24/7, surfait sous IE5, lisait des mp3 (son faible sur un mauvais casque, avec quelques sautes), et permettait de jouer à doom2 et duke3D en réseau (IPX) avec des PC sous 98 et MS-DOS, tout en gardant sa fonction de routeur. ! (le prog c'était wingate je crois)
j'avais un 486SX25 aussi, disque de 130Mo, comme au début du topic, mais avec 20Mo de ram. ben avec celui-là je faisais du lynx sous DOS (avec les 20Mo de ram bien inutiles du coup). chargement des pages instantané!
sous windows 3.1, 5 minutes pour obtenir une page avec netscape, après tu vas pas plus loin. navigateur graphique qui marche, avec onglets (ou plutôt multi-fenêtres accessibles comme des onglets) : opera 2.x! fallait attendre un peu le rendu mais ça marche.
pas de linux à l'époque malheureusement. j'aurais pas pu jouer à grand chose en réseau avec les autres ordis.
mon expérience de l'époque, avant le réseau à la maison, et avant d'avoir le net, c'était un CD ou deux de red hat d'un magazine, vers 98.
l'install était facile et avait permis de couper la partition fat16 de 2Go (clusters de 32Ko..) en deux. seulement voilà au reboot, impossible de booter le linux, et le windows boote mais se freeze avec un curseur de souris bloqué sur fond noir. :o
n°1269728
muzah
Bal Musette @ HFR depuis 1997
Posté le 11-03-2011 à 20:25:20  profilanswer
On viens de me donner un Celeron 433 avec 64Mo de ram et luxe : DVD.
Hop barette -> 192Mo = Rolls
Serveur d'abord, on testera autre chose après :D
n°1271732
agentsteel
Posté le 27-03-2011 à 19:28:25  profilanswer
Hello les bidouilleurs fous :)
J'ai dans l'idée de transformer un très vieux portable IBM thinkpad de 1996 en lecteur MP3
Je ne vois pas bcp d'autre utilisation possible vu qu'il n'a pas d'interface réseau, pas de lecteur CD et le lecteur de D7 est HS!!)
D'autre part ce portable n'a que 16Mo de RAM!
le système et quelques MP3 seraient installés sur le disque dur (1Go) en le branchant sur une autre machine.
ma problématique : je n'ai pas réussi à faire booter un noyau 2.6 récent avec 16Mo de RAM seulement!
y'en a t'il qui ont réussi? Avec quelle version de noyau?
à priori un noyau 2.4 boote sans problème avec 16Mo
mais si je peux le faire avec un noyau 2.6, ça me permettrait de générer directement mon système avec Buildroot au lieu de tout faire à la main :)
Message édité par agentsteel le 27-03-2011 à 19:29:24
http://agentoss.wordpress.com/
n°1271737
Mjules
Parle dans le vide
Posté le 27-03-2011 à 21:34:54  profilanswer
1996, c'est quel CPU ça ? parce que de mémoire, mon 486 DX2/66 avait du mal à lire les mp3.
Message édité par Mjules le 27-03-2011 à 21:35:03
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
n°1271738
Posté le 27-03-2011 à 21:37:05  answer
Je dirais que c'est un bon Pentium des familles…  [:cosmoschtroumpf]
n°1271740
agentsteel
Posté le 27-03-2011 à 21:41:56  profilanswer
oui c'est un thinkpad 365, avec un P133 il me semble
je suis en train de compiler un noyau 2.4, mais j'ai peur que la carte son ne soit pas reconnue...
n°1271745
the_k586
♥ Punk à Chats ♥
Posté le 27-03-2011 à 21:54:25  profilanswer
Perso mon DX4/100 Y arrivait parfaitement :d
De mémoire yavait une "Pentium Optimisation" à désactiver sinon le son "sautait" mais après ça marchait au poil :)
♦ bl0g ♦ // ♠ Twitter ♠ // << Just for the lulz ! The Only reason anyone does anything >> // Free Open DNS
Ubuntu-Party ce WE (29-30 nov) à Paris : venez découvrir Linux :)Accélérer le ping sous Linux
Linux/vista/packard bell, soucis de restaurationUtilité d'une carte nvidia quadro sous linux
Imprimante sous serveur linux et os xpClient graphique Linux pour base DB2
[O/C@linux] Enfin sur OSA clockez en 100% linux !!Linux, NTFS et autorisations
Lire le contenu de la bibliothèque de WMP sous linuxRose online > wine > linux ubuntu 8.10: erreur :s
Plus de sujets relatifs à : Linux sur vieux matos: screenshots, dmesg,lspci,uname -a, gcc etc.
