5183 connectés
  Linux et OS Alternatifs
  Installation
  Linux sur vieux matos: screenshots, dmesg,lspci,uname -a, gcc etc.
 Page :   1  2  3  4  5  6  7  8
Page Précédente
n°1093747
trouble_fe​te
Posté le 29-11-2008 à 07:30:48  profilanswer
Voila je créé ce topic pour ne plus polluer celui des uname -a :D
Voila comme certains ont l'air d'etre interessé je commence :D
Voici donc une Gentoo qui etait a la base un stage 3 x86 (donc i486) , entièrement recompilé en i586 (les stage 3 i586 n'existant pas ;) )avec upgrade vers gcc-4.3.2 avec -march=pentium-mmx:
http://img233.imageshack.us/img233/9595/20081129170858800x600scaw5.png
dmesg:
pentium-mmx166 mac_gyver # dmesg
Linux version 2.6.26.7 (root@pentium-mmx166) (gcc version 4.3.2 (Gentoo 4.3.2 p1.2) ) #5 PREEMPT Thu Nov 27 11:57:18 Local time zone must be set--see
BIOS-provided physical RAM map:
 BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
 BIOS-e820: 0000000000100000 - 0000000000800000 (usable)
 BIOS-e820: 0000000000800000 - 0000000001000000 (reserved)
 BIOS-e820: 0000000001000000 - 0000000003f00000 (usable)
 BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
63MB LOWMEM available.
Entering add_active_range(0, 0, 16128) 0 entries of 256 used
Zone PFN ranges:
  DMA             0 ->     4096
  Normal       4096 ->    16128
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
    0:        0 ->    16128
On node 0 totalpages: 16128
  DMA zone: 32 pages used for memmap
  DMA zone: 0 pages reserved
  DMA zone: 4064 pages, LIFO batch:0
  Normal zone: 94 pages used for memmap
  Normal zone: 11938 pages, LIFO batch:1
  Movable zone: 0 pages used for memmap
DMI 2.0 present.
ACPI Error (tbxfroot-0218): A valid RSDP was not found [20080321]
Allocating PCI resources starting at 10000000 (gap: 03f00000:fc080000)
PM: Registered nosave memory: 000000000009f000 - 0000000000100000
PM: Registered nosave memory: 0000000000800000 - 0000000001000000
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16002
Kernel command line: BOOT_IMAGE=2.6.26.7 ro root=303 video=vesafb:mtrr,ywrap,1024x768-32@85
Initializing CPU#0
PID hash table entries: 256 (order: 8, 1024 bytes)
Detected 165.796 MHz processor.
Console: colour VGA+ 80x50
console [tty0] enabled
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 50344k/64512k available (2867k kernel code, 5564k reserved, 1168k data, 324k init, 0k highmem)
virtual kernel memory layout:
    fixmap  : 0xffff5000 - 0xfffff000   (  40 kB)
    vmalloc : 0xc4800000 - 0xffff3000   ( 951 MB)
    lowmem  : 0xc0000000 - 0xc3f00000   (  63 MB)
      .init : 0xc05f4000 - 0xc0645000   ( 324 kB)
      .data : 0xc04cccea - 0xc05f0e30   (1168 kB)
      .text : 0xc0200000 - 0xc04cccea   (2867 kB)
Checking if this processor honours the WP bit even in supervisor mode...Ok.
CPA: page pool initialized 1 of 1 pages preallocated
SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay using timer specific routine.. 332.28 BogoMIPS (lpj=166144)
Mount-cache hash table entries: 512
Intel Pentium with F0 0F bug - workaround enabled.
CPU: Intel Pentium MMX stepping 03
Checking 'hlt' instruction... OK.
Freeing SMP alternatives: 0k freed
ACPI: Core revision 20080321
ACPI Exception (tbxface-0629): AE_NO_ACPI_TABLES, While loading namespace from ACPI tables [20080321]
ACPI: Unable to load the System Description Tables
net_namespace: 324 bytes
NET: Registered protocol family 16
EISA bus registered
PCI: PCI BIOS revision 2.10 entry at 0xfd941, last bus=0
PCI: Using configuration type 1 for base access
Setting up standard PCI resources
ACPI: Interpreter disabled.
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI: disabled
PnPBIOS: Scanning system for PnP BIOS support...
PnPBIOS: Found PnP BIOS installation structure at 0xc00f9f70
PnPBIOS: PnP BIOS version 1.0, entry 0xf0000:0xa070, dseg 0x400
PnPBIOS: 15 nodes reported by PnP BIOS; 15 recorded by driver
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
PCI: Probing PCI hardware
PCI: Probing PCI hardware (bus 00)
system 00:08: iomem range 0xe8000-0xfffff could not be reserved
system 00:08: iomem range 0x0-0x9ffff could not be reserved
system 00:08: iomem range 0x100000-0x7fffff could not be reserved
system 00:08: iomem range 0x800000-0xffffff could not be reserved
system 00:08: iomem range 0x1000000-0x3efffff could not be reserved
system 00:08: iomem range 0xfffffffffff80000-0xffffffffffffffff has been reserved
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
microcode: CPU0 not a capable Intel processor
IA-32 Microcode Update Driver: v1.14a <tigran@aivazian.fsnet.co.uk>
apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16ac)
Total HugeTLB memory allocated, 0
msgmni has been set to 98
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
pci 0000:00:00.0: Limiting direct PCI/PCI transfers
pci 0000:00:07.0: Activating ISA DMA hang workarounds
pci 0000:00:08.0: Boot video device
vga16fb: initializing
vga16fb: mapped to 0xc00a0000
Console: switching to colour frame buffer device 80x30
fb0: VGA16 VGA frame buffer device
isapnp: Scanning for PnP cards...
pnp 01:01.00: SB audio device quirk - increased port range
 01:01: card 'Creative ViBRA16X PnP'
isapnp: 1 Plug & Play card detected total
Real Time Clock Driver v1.12ac
[drm] Initialized drm 1.1.0 20060810
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing disabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
00:0c: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
00:0d: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
parport_pc 00:0b: reported by Plug and Play BIOS
parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
FDC 0 is a National Semiconductor PC87306
brd: module loaded
loop: module loaded
usbcore: registered new interface driver ub
8139too Fast Ethernet driver 0.9.28
eth0: RealTek RTL8139 at 0xfc00, 00:05:5d:47:fc:3c, IRQ 11
eth0:  Identified 8139 chip type 'RTL-8100B/8139D'
Linux video capture interface: v2.00
Uniform Multi-Platform E-IDE driver
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
PIIX3: IDE controller (0x8086:0x7010 rev 0x00) at  PCI slot 0000:00:07.1
PIIX3: not 100% native mode: will probe irqs later
    ide0: BM-DMA at 0xffa0-0xffa7
    ide1: BM-DMA at 0xffa8-0xffaf
Probing IDE interface ide0...
hda: WDC AC24300L, ATA DISK drive
Clocksource tsc unstable (delta = 97962168 ns)
hda: host max PIO4 wanted PIO255(auto-tune) selected PIO4
hda: MWDMA2 mode selected
Probing IDE interface ide1...
hdc: CRD-8520B, ATAPI CD/DVD-ROM drive
hdc: host max PIO4 wanted PIO255(auto-tune) selected PIO4
hdc: MWDMA2 mode selected
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
ide1 at 0x170-0x177,0x376 on irq 15
hda: max request size: 128KiB
hda: 8421840 sectors (4311 MB) w/256KiB Cache, CHS=8912/15/63
hda: cache flushes not supported
 hda: hda1 hda2 hda3
hdc: ATAPI 52X CD-ROM drive, 128kB Cache
Uniform CD-ROM driver Revision: 3.20
Driver 'sd' needs updating - please use bus_type methods
Driver 'sr' needs updating - please use bus_type methods
usbmon: debugfs is not available
ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
USB Universal Host Controller Interface driver v3.0
uhci_hcd 0000:00:07.2: UHCI Host Controller
uhci_hcd 0000:00:07.2: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:07.2: irq 11, io base 0x0000ff40
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usb 1-2: new low speed USB device using uhci_hcd and address 2
usb 1-2: configuration #1 chosen from 1 choice
usbcore: registered new interface driver usblp
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
i8042 aux: probe of 00:07 failed with error -16
PNP: PS/2 Controller [PNP0303] at 0x60,0x64 irq 1
PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
input: AT Translated Set 2 keyboard as /class/input/input0
EISA: Probing bus 0 at eisa.0
EISA: Detected 0 cards.
cpuidle: using governor ladder
cpuidle: using governor menu
input: PIXART USB OPTICAL MOUSE as /class/input/input1
input: USB HID v1.11 Mouse [PIXART USB OPTICAL MOUSE] on usb-0000:00:07.2-2
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.16.
ALSA device list:
  No soundcards found.
TCP cubic registered
NET: Registered protocol family 10
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
Using IPI Shortcut mode
EXT3-fs: INFO: recovery required on readonly filesystem.
EXT3-fs: write access will be enabled during recovery.
kjournald starting.  Commit interval 5 seconds
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
VFS: Mounted root (ext3 filesystem) readonly.
Freeing unused kernel memory: 324k freed
sb16 01:01.00: activated
EXT3 FS on hda3, internal journal
Adding 500368k swap on /dev/hda2.  Priority:-1 extents:1 across:500368k
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
eth0: no IPv6 routers present
usb 1-2: USB disconnect, address 2
J'utilise dessus une carte son ISA SoundBlaster parfaitement detecté et configuré avec alsaconf  :p (il n'y a pas de son intégré)
La carte réseau (car il n'y a pas de reseau intégré sur ce vieux bousin) est une Realtek RTL 8139, du classique quoi.
l'USB intégré (oui oui y en a  :ouch: ) fonctionne parfaitement (il y a 2 prises USB  :ouch: )
Le pc en lui même est absolument non standard, la carte mère a un format que j'ai jamais vu, les port ISA et PCI sont sur une carte branché sur un port bizarre bref tout est a l'avenant mais ça a pas l'air perturber ma ptite Gentoo  :whistle:
Le hdd unique fait 4,3Go, la vidéo intégré ( :whistle: ) est une s3 (pas virge ni savage !) voila ce que ça donne dans xorgconfig:
23  ** S3 (not ViRGE or Savage) (generic) [s3]        -
 24  ** S3 Savage (generic)                [savage]    -
 25  ** S3 ViRGE (generic)                 [s3virge]   -
le pilote graphique est donc:
*  x11-drivers/xf86-video-s3
      Latest version available: 0.5.0
      Latest version installed: [ Not Installed ]
      Size of files: 234 kB
      Homepage:      http://xorg.freedesktop.org/
      Description:   X.Org driver for s3 cards
      License:       xf86-video-s3
dans le make.conf:
VIDEO_CARDS="s3"
Voici autre chose d'important que j'ai mis des le départ, donc avant d'upgrader vers gcc-4.3.2:
CFLAGS="-march=pentium-mmx -O2 -pipe -fomit-frame-pointer"
CXXFLAGS="${CFLAGS}"
CHOST="i586-pc-linux-gnu"
MAKEOPTS="-j2"
Au départ j'ai eu peur du résultat, sachant que j'ai mis i586 dans le chost alors que j'étais sur un stage 3 ou c'était i486 a l'origine...mais finalement que du bonheur  :love:
voila donc je peux maintenant lire ma radio en ligne préféré, la carte son ISA etant relié a ma chaine Hi-Fi  ;)
Voici un lspci, mais tout n'est pas listé car l'ISA n'apparait jamais la dedans ce qui semble logique  :D :
pentium-mmx166 mac_gyver # lspci
00:00.0 Host bridge: Intel Corporation 430VX - 82437VX TVX [Triton VX] (rev 02)
00:07.0 ISA bridge: Intel Corporation 82371SB PIIX3 ISA [Natoma/Triton II] (rev 01)
00:07.1 IDE interface: Intel Corporation 82371SB PIIX3 IDE [Natoma/Triton II]
00:07.2 USB Controller: Intel Corporation 82371SB PIIX3 USB [Natoma/Triton II] (rev 01)
00:08.0 VGA compatible controller: S3 Inc. 86c764/765 [Trio32/64/64V+] (rev 44)
00:13.0 Ethernet controller: D-Link System Inc RTL8139 Ethernet (rev 10)
Ma radio en ligne en pleine lecture :D
http://img399.imageshack.us/img399/9181/mplayerdm7.png
Et alsamixer:
http://img175.imageshack.us/img175/1539/alsamixerwo8.png
Il dispose de 64Mo d'EDO.
Message édité par trouble_fete le 11-10-2009 à 10:38:17
Tyan Tiger 200T, SDR PC 133, 1*256Mo, Bi-Tualatin 1,4Ghz, disque Maxtor 6Y080L0 IDE 80Go, FX 5200 en format PCI, modem/routeur DSL-524T, le tout sous Gentoo
n°1093761
trouble_fe​te
Posté le 29-11-2008 à 10:17:37  profilanswer
Si quelqu'un a un PC encore plus pourri que le mien, et qu'il a installer Gentoo Linux dessus, faites tourner :D
Edit: ou si vous avez un vieux PC y compris pas très normalisé (c'est même mieux encore :D) vous pouvez vous en débarrasser en me le donnant  :love:
Message édité par trouble_fete le 29-11-2008 à 10:20:05
n°1093853
malikg
Posté le 29-11-2008 à 16:36:18  profilanswer
une machine un peu plus puissante: ultra-portable SONY Vaio C1XD
http://i00.twenga.com/p/39/98/223998.png
poids < 1 kg
Pentium II 400 MHz, RAM 128 MO, HD 12 GO, CG NeoMagic (résolution 1024*480)
carte réseau PCMCIA HS :( >>> net avec clé WiFi USB D-Link :)
batterie HS :(
webcam (elle fonctionnait à l'install, puis plus rien  :??: je ne l'utilise pas ceci dit)
Il me sert à surfer vite fait (sans flash), contrôler mon "juke-box", regarder des petites vidéos ...
Il tourne avec pekwm + rox + fbpanel + mplayer + sonata + emesene + firefox + xchat + filezilla ...
Le suspend-to-RAM/Disk fonctionne bien (très pratique sinon le boot doit bien prendre 2-3 min)
Compilations avec distcc + athlon XP2000+
dmesg: http://pastebin.com/f87c77d2
/usr/sbin/lspci
00:00.0 Host bridge: Intel Corporation 440BX/ZX/DX - 82443BX/ZX/DX Host bridge (rev 03)
00:01.0 PCI bridge: Intel Corporation 440BX/ZX/DX - 82443BX/ZX/DX AGP bridge (rev 03)
00:07.0 ISA bridge: Intel Corporation 82371AB/EB/MB PIIX4 ISA (rev 02)
00:07.1 IDE interface: Intel Corporation 82371AB/EB/MB PIIX4 IDE (rev 01)
00:07.2 USB Controller: Intel Corporation 82371AB/EB/MB PIIX4 USB (rev 01)
00:07.3 Bridge: Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev 03)
00:08.0 FireWire (IEEE 1394): Sony Corporation CXD3222 i.LINK Controller (rev 02)
00:09.0 Multimedia audio controller: Yamaha Corporation YMF-744B [DS-1S Audio Controller] (rev 02)
00:0a.0 Multimedia controller: Kawasaki Steel Corporation KL5A72002 Motion JPEG (rev 01)
00:0c.0 CardBus bridge: Ricoh Co Ltd RL5c475 (rev 80)
01:00.0 VGA compatible controller: Neomagic Corporation NM2200 [MagicGraph 256AV] (rev 20)
$ uname -a
Linux vaio 2.6.25-gentoo-r8 #1 PREEMPT Fri Oct 10 18:20:48 CEST 2008 i686 Mobile Pentium II GenuineIntel GNU/Linux
un screenshot:
http://img353.imageshack.us/img353/2101/screenshot2008110111454xx7.png
Message édité par malikg le 30-11-2008 à 01:10:28
n°1093859
enfoiro
a nickname is just a nickname
Posté le 29-11-2008 à 17:48:22  profilanswer
oh, ca doit pouvoir se trouver :D
n°1093863
zecrazytux
Posté le 29-11-2008 à 18:10:01  profilanswer
après "qui a la plus grosse", c'est "qui a la plus petite" :D
Blog photo/récits activités en montagne http://planetcaravan.net
n°1093864
SPlissken
Posté le 29-11-2008 à 18:11:15  profilanswer
J'aime bien ce topic ,faudrait peut etre le changer et mettre topic ordinosaure/exotique
Tout le monde se bat , personne se barre
n°1093865
SPlissken
Posté le 29-11-2008 à 18:13:29  profilanswer
La regle pourrait etre , pas de machine au dessus de 500 Mhz
n°1093866
zecrazytux
Posté le 29-11-2008 à 18:13:35  profilanswer
ça va plaire à l'autre coderz en bash qui utilise un slockozore :]
n°1093868
SPlissken
Posté le 29-11-2008 à 18:20:42  profilanswer
Revoici une serie de screen que j'avais posté dans le concours du plus bureau mais c'etait pas vraiment sa place
Screenshot de BeOS sur un Pentium II 400 Mz 128 Mo avec double boot Linux
C'est du naturel bien sur , pas du qemu ou autre virtualisation
http://splissken.free.fr/Images/Divers/_thumb/BeOSScreen1.jpg
http://splissken.free.fr/Images/Divers/_thumb/BeOSScreen2.jpg
http://splissken.free.fr/Images/Divers/_thumb/BeOSScreen3.jpg
http://splissken.free.fr/Images/Divers/_thumb/BeOSScreen4.jpg
Dernier screen avec Retour vers le Futur II :)
http://splissken.free.fr/Images/Divers/_thumb/BeOSScreen5.jpg
n°1093871
SPlissken
Posté le 29-11-2008 à 18:33:14  profilanswer
Et la, a coté du PC un Amstrad CPC 464 fonctionnel :)
http://splissken.free.fr/Images/Divers/_thumb/CPC_004.jpg
n°1093873
SPlissken
Posté le 29-11-2008 à 18:36:55  profilanswer
Et là le même PII que tout a l'heure avec BeOS mais ce coup ci en live CD avec distro tinyMe avant que je l'installe
http://splissken.free.fr/Images/Linux/_thumb/TinyMePII.png
Message édité par SPlissken le 29-11-2008 à 22:53:00
n°1093921
Mjules
Modérateur
Parle dans le vide
Posté le 29-11-2008 à 21:41:44  profilanswer
tiens, ya eu des trio64 sur PCI, je pensais pas, j'en avais vu que sur VLB.
Message édité par Mjules le 29-11-2008 à 21:42:04
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
n°1093926
trouble_fe​te
Posté le 29-11-2008 à 22:09:51  profilanswer
Ah oui, lspci ne listerais pas les périphériques sur bus VLB ?
Edit: la s3 trio c'est de l'intégré ;)
Message édité par trouble_fete le 29-11-2008 à 22:10:43
n°1093927
Mjules
Modérateur
Parle dans le vide
Posté le 29-11-2008 à 22:13:19  profilanswer
non, ya pas de VLB sur pentium, le FSB avait une fréquence de 66MHz et ça posait problème avec le VLB qui n'était pas isolé niveau fréquence et ne pouvait pas monter aussi haut. Au contraire du PCI qui a une horloge dédiée (ou tout au moins a un multiplicateur par rapport au FSB)
s3 trio, ya eu du stand alone, j'avais une trio32 sur mon 486 ;) (86c805/801 de mémoire)
Message édité par Mjules le 29-11-2008 à 22:14:34
n°1093928
trouble_fe​te
Posté le 29-11-2008 à 22:16:50  profilanswer
D'accord ! je vois que tu as des connaissances poussées sur les ordinosaures  :love:
n°1093929
Mjules
Modérateur
Parle dans le vide
Posté le 29-11-2008 à 22:18:24  profilanswer
ben pour moi, ils ne sont pas si vieux... :D
n°1093930
trouble_fe​te
Posté le 29-11-2008 à 22:19:23  profilanswer
poids < 1 kg
batterie HS :(
Linux vaio 2.6.25-gentoo-r8 #1 PREEMPT Fri Oct 10 18:20:48 CEST 2008 i686 Mobile Pentium II GenuineIntel GNU/Linux[/fixed]
un screenshot:
Pas mal, mais dommage pour la batterie... :/
n°1093931
trouble_fe​te
Posté le 29-11-2008 à 22:19:56  profilanswer
je vois  :whistle:
n°1093946
deK
watching for beerz on the wing
Posté le 30-11-2008 à 00:49:14  profilanswer
J'ai eu une S3 Trio 64 V2 en PCI  :jap:
(et une Trio 64 V+ en intégré, idem mais avec 1Mo de mémoire au lieu de 2 sur la V2)
Sinon drap, je suis fan d'ordinosaures, dans quelques temps j'aurais la place de tous les remettre en service, ça va saigner. :love:
Au menu : du Pentium Pro 200 (vieux Dell Poweredge), du P200MMX, du Celeron 433, et la perle, mon bi-Celeron 500 sur Abit BP6  [:huit]
Message édité par deK le 30-11-2008 à 00:51:55
(old) Feed HA/V
n°1093953
trouble_fe​te
Posté le 30-11-2008 à 08:23:10  profilanswer
Nom de... j'ai hate que tu passes a l'acte et nous montre les images  :love:
J'ai une Gentoo sur bi-P3 1,4Ghz sur Tyan 200T également  :love: (deprecated mais bon, quand même puissant, c'était du lourd quand c'est sorti...)
Et une autre sur un portable Pentium mmx 266Mhz, 32Mo de ram  :love: les captures vont suivre...(j'arrive a utiliser mplayer sur le portable mais pas avec toute les vidéos, si qualité trop grande ça lag, sinon nickel mais sans le son, celui-ci fonctionne bien séparément mais faire lire image+son a mplayer ça lag  :whistle: )
Sur ce portable le son intégré est sur bus ISA et fonctionne magnifiquement bien, je peux même régler le niveau avec des bouton plus/moins sur le coté...sauf que si alsamixer est en marche a ce moment, Linux plante complètement avec effet sapin de noël via les led du portable car kernel panic  :whistle: soit alsamixer, soit les boutons latéraux, pas les 2  :D
Message édité par trouble_fete le 30-11-2008 à 09:06:50
n°1094090
the_k586
♥ Punk à Chats ♥
Posté le 01-12-2008 à 00:29:32  profilanswer
Possédant un tas de vieilleries (encore fonctionnelles) je jette rien depuis le début [:cupra]
(386/(2) 486/P100-133-166-200MMX/K6-2 233/P2 266/P3 450-500-666 et autres durons 733 et athlons 800-1200-1600 (ce dernier qui tourne d'ailleurs très bien sous ubu8.10 :D)
Et adorant les test, bidouilles,  recompilations JFF :D
Je pose mon drapal ici :o
♦ bl0g ♦ // ♠ Twitter ♠ // << Just for the lulz ! The Only reason anyone does anything >> // Free Open DNS
n°1094124
trouble_fe​te
Posté le 01-12-2008 à 09:05:11  profilanswer
the_k586, ne te débarrasserais tu point d'un 386 (j'en ai pas !) ou de ton 486 ? (j'en ai  pas non plus !) :)
Je suis assez content d'avoir un 586 mmx, y en a pas tant que ça qui en ont :D
n°1094129
black_lord
Modérateur
Truth speaks from peacefulness
Posté le 01-12-2008 à 09:27:00  profilanswer
j'ai un debian 2.2 sur un portable de 1994 :spamafote: et c'est un 486 [:dawa]
uptime is for lousy system administrators what Viagra is for impotent people - mes unixeries - github me
n°1094136
trouble_fe​te
Posté le 01-12-2008 à 09:45:43  profilanswer
Fait péter une capture d'écran, un dmesg et un lspci  :love:
ainsi que alsamixer tient  :)
Edit: et un uname -a ainsi que gcc-config -l si ceci existe sous Debian :??:
Ceci doit rester assez rare car il s'agit simplement d'une Debian  :o bon un HS comme ça s'il est rare sera toléré quand même...
Message édité par trouble_fete le 01-12-2008 à 09:47:45
n°1094137
black_lord
Modérateur
Posté le 01-12-2008 à 09:54:14  profilanswer
il est rangé, et n'a pas de X il me semble.
n°1094139
trouble_fe​te
Posté le 01-12-2008 à 09:57:34  profilanswer
Tu comptes le garder ranger  :whistle: ? moi je saurais m'en occuper, lui titiller les transistors nanométriques  :love:
Vu l'espace disque que tu dois avoir dessus, doit pas etre évident de mettre ne serait-ce que fluxbox  :lol:
Mais qq infos seraient bienvenus  ;) tant pis pour la capture mais peux-tu donner le reste ;) ou me donner le portable  :bounce:
n°1094140
black_lord
Modérateur
Posté le 01-12-2008 à 09:58:38  profilanswer
disque pas d'orgine => 2G et 48Mo de RAM :o
et t'es en plein rêve pour le don :o
Message édité par black_lord le 01-12-2008 à 09:59:07
n°1094141
trouble_fe​te
Posté le 01-12-2008 à 10:01:02  profilanswer
Ah ok bien pour le hdd, sur le P166 mmx c'était un 1,6Go j'ai mis un 4,3, sinon même fluxbox en plus du stage 3 ça aurait pas passé  :D
Sinon pour ton portable ben... l'espoir fait vivre, j'ai plus de soussous (accident de voiture) sinon j'aurais essayé de voir combien tu en voulais ... :(
Edit: le Pentium mmx 166 dispose de 64Mo d'EDO  :D
Message édité par trouble_fete le 01-12-2008 à 10:04:47
n°1094355
Posté le 02-12-2008 à 04:15:08  answer
Avec un IBM 330P100, je suis sélectionné ?
Pentium 100 overclocké 120 ( [:boidleau] ) 32 Mo de RAM EDO, refroidissement full passif (sauf alim).
Lecteur CD-ROM 4x (la grande classe).
Disque dur d'origine (increvable) Western Digital WD2850. De mémoire, il fait dans les 800 Mo formatté.
Carte graph S3 trio 3D.
 [:_-'-_flying_-'-_]
Sinon j'ai aussi un Macintosh PowerBook 145B  (cherchez sur le net, vous allez voir, c'est du ultra high level).
Message édité par Profil supprimé le 02-12-2008 à 04:21:48
n°1094363
SPlissken
Posté le 02-12-2008 à 07:42:05  profilanswer
Pour moi tu es qualifié , mais il faut des screenshots , des dmesg
n°1094376
trouble_fe​te
Posté le 02-12-2008 à 09:10:10  profilanswer
Qualifié il est ! sans soucis, mais comme tu dis il faut screenshot et dmesg, ainsi que uname -a et lspci, et s'il le peut, des photos de sa bête  :)
Et la version de gcc serait sympa pour voir :)
Je vais essayer d'installer scrot sur le portable P266 MMX, mais c'est pas super simple vu qu'il a pas de reseaux :D (l'installation de Gentoo a été un peu folklo de ce fait...a coup de transfert pas clé USB dans les distfiles  :whistle: )
Message édité par trouble_fete le 02-12-2008 à 09:17:16
n°1094378
black_lord
Modérateur
Posté le 02-12-2008 à 09:16:28  profilanswer
faudrait changer le titre du topic :o
n°1094379
trouble_fe​te
Posté le 02-12-2008 à 09:18:17  profilanswer
Par rapport aux lspci, uname -a dmesg et version gcc/archi pour laquelle il compile ?
n°1094381
black_lord
Modérateur
Posté le 02-12-2008 à 09:19:12  profilanswer
pas la peine de chercher si loin "Linux sur du vieux matos" ou un truc approchant ce sera très bien :D
n°1094382
trouble_fe​te
Posté le 02-12-2008 à 09:21:12  profilanswer
Voila j'ai changé :D
n°1094384
black_lord
Modérateur
Posté le 02-12-2008 à 09:30:33  profilanswer
y'a pas que gentoo dans la vie :D
n°1094387
trouble_fe​te
Posté le 02-12-2008 à 09:36:23  profilanswer
Sisi  :love: surtout sur du vieux matos c'est particulièrement rigolo si tu dois compiler sur la bête  :pt1cable:
Mais bon, les autres linux pourront etre tolérés ça reste interessant, mais c'est quand même pas le même challenge, je me suis bien amusé a installer Gentoo par exemple sur mon pc portable sans reseaux :D
n°1094391
black_lord
Modérateur
Posté le 02-12-2008 à 09:38:48  profilanswer
sur mon lappy y'a ni réseau, ni CD et le lecteur de disquette ne fonctionne pas sous linux, j'ai tout fait par liaison PPP sur port série [:franck75]
edit : ça me donne une idée [:cupra]
Message édité par black_lord le 02-12-2008 à 09:39:18
n°1094395
trouble_fe​te
Posté le 02-12-2008 à 09:40:30  profilanswer
 :love: j'ai jamais fait ça, et j'ai un port série tient justement sur mon pc portable, j'aimerais bien essayer le PPP sur port série moi aussi. Mais je sais pas du tout comment on s'y prend  :??:
n°1094396
Posté le 02-12-2008 à 09:40:31  answer
Merrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrdeuuuh  :fou:
Mon pentium 100 veut plus se mettre en route !!!
Je teste une autre alim.
PS: en attendant, je me rappelle qu'il fonctionne avec une vieille RedHat. Ca fait des années que je l'ai pas allumé.
Le noyal est un 2.2.19 recompilé "à l'économique", ça j'en suis sûr. Et ça tournait pas si mal au vu du hardware.
Message édité par Profil supprimé le 02-12-2008 à 09:45:11
Page Précédente
  Installation
Ubuntu-Party ce WE (29-30 nov) à Paris : venez découvrir Linux :)Accélérer le ping sous Linux
Linux/vista/packard bell, soucis de restaurationUtilité d'une carte nvidia quadro sous linux
Imprimante sous serveur linux et os xpClient graphique Linux pour base DB2
[O/C@linux] Enfin sur OSA clockez en 100% linux !!Linux, NTFS et autorisations
Lire le contenu de la bibliothèque de WMP sous linuxRose online > wine > linux ubuntu 8.10: erreur :s
Plus de sujets relatifs à : Linux sur vieux matos: screenshots, dmesg,lspci,uname -a, gcc etc.
