Je pars d'une Debian Lenny propre.
Je suis passé en Squeeze et depuis j'ai cette erreur quand je fais un aptitude upgrade:
Code :
- The following partially installed packages will be configured:
- grub grub-pc
- No packages will be installed, upgraded, or removed.
- 0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
- Need to get 0 B of archives. After unpacking 0 B will be used.
- Setting up grub-pc (1.98+20100804-14+squeeze1) ...
- Generating core.img
- grub-probe: error: cannot find a device for /boot/grub (is /dev mounted?).
- install_device not specified.
- dpkg: error processing grub-pc (--configure):
- subprocess installed post-installation script returned error exit status 1
- configured to not write apport reports
- dpkg: dependency problems prevent configuration of grub:
- grub depends on grub-pc; however:
- Package grub-pc is not configured yet.
- dpkg: error processing grub (--configure):
- dependency problems - leaving unconfigured
- Errors were encountered while processing:
- grub-pc
- grub
- E: Sub-process /usr/bin/dpkg returned an error code (1)
- A package failed to install. Trying to recover:
- grub-pc
- grub
comment puis-je régler le problème ?
note: si je fais un fdisk -l
ca ne me retourne ... rien Oo
Message édité par ghawar le 20-12-2011 à 20:44:05
