4449 connectés
  Technologies Mobiles
  Android
  Cherche Appli Android pour déplacer appli de mémoire interne -> SDcart
n°1183801
phguitton
Posté le 23-09-2012 à 19:12:20  profilanswer
Bonjour
je cherche une appli dans Play store pour déplacer les applications de la mémoire interne vers ma SDcart.
La fonction native de mon mobile ne me déplace pas certaines applis et cela m'empêche de charger d'autres appli.
Quelqu'un connait -il une telle  appli miracle ?
merci d'avance
Philippe
n°1190654
genesis63
Posté le 29-09-2012 à 00:47:21  profilanswer
Bonjour Philippe,
J'ai vu ça quelque part (qui a l'air de répondre à ton besoin). Mais je ne sais si l'appli est gratuite et je ne l'ai pas essayée...
System Tuner Pro v2.5.2 (Android) | 1.8MB
The most complete Android tuner and manager for all your phones and tablets!
The most complete Android system suite: monitor and record all activities, backup and restore *any* applications, extended task killer, CPU SD and memory controls, logcat reader, terminal emulator, widgets and notifications, all in one highly optimized app!
Requirements: Android 1.5 and up
WARNING: Requires WIFI, BT, PHONE and GPS permissions to record phone states. App checked with Privacy Inspector!
By far the lowest consumption monitoring app! Check web-site for app consumption!
You can add shortcuts to your home screen for any of the below features/screens!
Task Manager: (can be set as main UI, see options)
- Filter user/system/kernel processes and exclusion list
- Shows cpu load/frequency, memory/internal/sd usage
- Sort processes by cpu times, start time, memory or by name
- Kill non manually excluded apps automatically
- Shows detailed information about running apps and processes
- Open app system settings
- Read app logcat
- Manually kill running apps
CPU Manager (rooted phones):
- Tweak CPU governor + frequencies during screen-off, on-call
- Tweak CPU voltage (when available on custom Kernel)
- Set CPU settings on boot
- Uses OC/deamon when available and can disable it
Extended Task Killer
- Kill non-excluded apps automatically or manually
- Kill apps during screen-on, screen-off or when widget refreshes
- Manually exclude or include apps
- All system apps are excluded by default
- Manually kill kernel processes (root)
- Display memory and SD details (RAM & internal)
Application Manager without root:
- Backup/restore/uninstall user apps, only APKs are backed-up
- Launch and read app logcat
Application Manager with root:
- Freeze/unfreeze apps
- Remove app from boot, enabled/disabled any app events
- Backup/restore/uninstall any apps and settings, including system apps
- Launch and read app logcat (disabled on JellyBean)
- Display application data and cache usage
- Sort application by name, data usage or cache usage
- Move any apps to/from system/user/SD space
- Clear caches or dalvik cache (must reboot after)
Activity Recorder:
- Record (optionally at boot) activities in the background
- Record all apps or all processes
- Record phone states (screen, wifi, bluetooth, gps, mobile data, signal)
- Import Battery Monitor Widget Pro data for detailed analysis!
- Allows analyzing past recordings without limits
Logcat Reader:
- Display log(cat) for all/one process
- Filter logcat by message levels
- Filter logcat based on user-defined text
- Save logcat to file
- Clear existing logcat (root)
Terminal Emulator:
- Keeps history of previously used Linux commands
- Save output to file
- Run pre-existing scripts
- Run commands as Super User (root)
System Tweaker (root):
- build.prop and sysctl editors
- Tweak SD cache size to boost performance
- Tweak IO scheduler to boost performance
- App booster on boot (APK alignement + DB cleanup)
- Tweak Android auto-kill memory settings
- Uses Linux init.d script when available
Notifications:
- Show cpu load, frequency, governor, free/used memory (flash/internal/sd)
- Show most information (cpu, memory, internal, SD)
- Optionally shows a configurable graphic time-line
- Provided as external packages, many available for white/black notification backgrounds
Widget:
- Many different widget backgrounds: HTC Sense 2 or 3, Google, Glassy half, ICS or fully transparent.
- Show cpu load, frequency, governor, free/used memory (flash/internal/sd), process count using text or 2 side levels.
- Starts 2 different actions by clicking on the icon or label, including:
. Start/stop recording process activity
. Kill all non-excluded processes
. Refresh
. Start any app activities
. Open settings
"Deux intellectuels assis vont moins loin qu'une brute qui marche".
  Android
[Android] comment installer une App seulement dispo sur le store US ?[cherche] tablette windows 7 performante
Mémoire interne limitée sur HTC Wildfire Sandroid peut-il se connecter à internet via le cable usb ?
question d'appli sur l'Alcatel One Touch 995Transformer son Android en écran externe
[Topic Unique] GameKlip, adaptateur Dual Shock pour Android
Plus de sujets relatifs à : Cherche Appli Android pour déplacer appli de mémoire interne -> SDcart
