4124 connectés
  comment dezonner ce dvd pionneer SCSI DVD-303S
n°110260
qqpanpan
Mourir pour des idées.....
Posté le 19-08-2001 à 21:44:43  profilanswer
si kelkin pouver m aider jai une carte scsi  390 et SCSI DVD-303S
, DVD-U03S FIRMWARE UPGRADE Version:  2.0 RPC-1
This upgrade should NOT be applied to any other model DVD-ROM drive.
PROCEDURE
1. Set the SCSI ID on the drive to ID=0
    Turn ON the PC.
    Edit your Config.sys file to include an ASPI manager for the SCSI card so this loades when the system is in DOS mode.
    Re-Boot the PC
2. If Windows 95/98 is used, quit Windows mode and re-boot into MS-DOS mode by selecting the Start menu on Windows 95/98.
3. Make sure there is no disc in the drive unit  before the  firmware upgrade is executed.
4. Execute the UP303.BAT file.
5. The current version number of the firmware will be shown and the new firmware will be uploaded.
6. When the DOS prompt returns reboot the computer by powering OFF then ON.
Do not turn OFF the PC while upgrade is executed or the firmware upgrade will fail. Retry upgrade procedure from 4 through 6 if the firmware upgrade is fails.
Apply power cycle (OFF/ON) if the firmware upgrade fails.
IMPORTANT:
The upgrade will not function and permanent failure of the drive could occur unless the drive is connected as per point 1.
n°110348
qqpanpan
Posté le 19-08-2001 à 23:52:13  profilanswer
up
n°110803
qqpanpan
Posté le 20-08-2001 à 22:01:56  profilanswer
up
n°110820
groux
Intolérant au sans Gluten!
Posté le 20-08-2001 à 22:20:14  profilanswer
Bon, tu touches à rien les pioneer 6x (303 et 303S) sont RPC-1 donc multi-zones d'origine. La seule chose à faire est de ne pas enlever le jumper qui se trouve à l'arrière du lecteur.
n°110879
qqpanpan
Posté le 20-08-2001 à 23:48:44  profilanswer
arf
 g po çà moi :/  ya marké 303r2
n°113237
qqpanpan
Posté le 25-08-2001 à 13:39:58  profilanswer
up
Lecture DVDQuel soft pour lire les DVD
COBRA vient de sortir en DVD !!!Power DVD 3.0 et TNT2ultra : mauvais mélange!
Rippez-vous les bonus de vos DVD ?connaisez vous un site ki test les lecteurs DVD de salon ?
Meilleur programme DVDPblm son sur DVD
Pionner DVD-RQuand est-ce qu'on pourra copier un DVD ?
Plus de sujets relatifs à : comment dezonner ce dvd pionneer SCSI DVD-303S
