5641 connectés
Sujet : comment dezonner ce dvd pionneer SCSI DVD-303S
qqpanpan up
qqpanpan up
qqpanpan arf
 g po çà moi :/  ya marké 303r2
groux Bon, tu touches à rien les pioneer 6x (303 et 303S) sont RPC-1 donc multi-zones d'origine. La seule chose à faire est de ne pas enlever le jumper qui se trouve à l'arrière du lecteur.
qqpanpan up
qqpanpan up
qqpanpan si kelkin pouver m aider jai une carte scsi  390 et SCSI DVD-303S
, DVD-U03S FIRMWARE UPGRADE Version:  2.0 RPC-1
This upgrade should NOT be applied to any other model DVD-ROM drive.
PROCEDURE
1. Set the SCSI ID on the drive to ID=0
    Turn ON the PC.
    Edit your Config.sys file to include an ASPI manager for the SCSI card so this loades when the system is in DOS mode.
    Re-Boot the PC
2. If Windows 95/98 is used, quit Windows mode and re-boot into MS-DOS mode by selecting the Start menu on Windows 95/98.
3. Make sure there is no disc in the drive unit  before the  firmware upgrade is executed.
4. Execute the UP303.BAT file.
5. The current version number of the firmware will be shown and the new firmware will be uploaded.
6. When the DOS prompt returns reboot the computer by powering OFF then ON.
Do not turn OFF the PC while upgrade is executed or the firmware upgrade will fail. Retry upgrade procedure from 4 through 6 if the firmware upgrade is fails.
Apply power cycle (OFF/ON) if the firmware upgrade fails.
IMPORTANT:
The upgrade will not function and permanent failure of the drive could occur unless the drive is connected as per point 1.
