2015 connectés
  Traitement Audio
  Problème de son AC3 avec VLC
n°1350942
DrDooM
Posté le 13-01-2008 à 21:39:51  profilanswer
Salut à tous,
J'ai une carte mère Asus P5E avec sortie SPDIF et lorsque j'utilise VLC (en activant la sortie SPDIF dans ses options), le son est saccadé (un sample de 100ms environ qui se répète 10 fois).
Dans le log de VLC j'ai ceci :
a52: A/52 channels:6 samplerate:48000 bitrate:640000
main debug: looking for audio output module: 3 candidates
aout_directx debug: OpenAudio
aout_directx debug: found device: Primary Sound Driver
aout_directx debug: found device: Digital Output Device (SPDIF) (High Definition Audio Device)
aout_directx debug: found device: Speakers (High Definition Audio Device)
aout_directx debug: device supports 5.1 channels
aout_directx debug: device supports 4 channels
aout_directx debug: device supports 2 channels
aout_directx debug: device supports 1 channel
aout_directx debug: device supports A/52 over S/PDIF
aout_directx debug: creating DirectSoundThread
main debug: thread 4380 (DirectSound Notification Thread) created at priority 15 (directx.c:372)
main debug: using audio output module "aout_directx"
main debug: output 'spdi' 48000 Hz 3F2R/LFE frame=1536 samples/6144 bytes
main debug: mixer 'a52 ' 48000 Hz 3F2R/LFE frame=1536 samples/6144 bytes
main debug: filter(s) 'a52 '->'spdi' 48000 Hz->48000 Hz 3F2R/LFE->3F2R/LFE
aout_directx debug: DirectSoundThread ready
main debug: looking for audio filter module: 24 candidates
main debug: using audio filter module "a52tospdif"
main debug: found a filter for the whole conversion
main debug: looking for audio mixer module: 3 candidates
main debug: using audio mixer module "spdif_mixer"
main debug: input 'a52 ' 48000 Hz 3F2R/LFE frame=1536 samples/2560 bytes
main debug: audio output is too slow (-106000), trashing 32000us
main debug: audio output is too slow (-202000), trashing 32000us
main debug: audio output is too slow (-298000), trashing 32000us
main debug: audio output is too slow (433000), trashing 32000us
main debug: audio output is too slow (401000), trashing 32000us
main debug: audio output is too slow (369000), trashing 32000us
main debug: audio output is too slow (337000), trashing 32000us
main debug: audio output is too slow (305000), trashing 32000us
J'ai vu que des personnes avaient ce souci sous linux mais là je suis sous Vista et j'ai également testé sous XP.
Y aurait-il une option que j'aurais raté? Un correctif?
Merci d'avance pour vos réponses ;)
Message édité par DrDooM le 13-01-2008 à 21:40:06
n°1360042
DrDooM
Posté le 30-01-2008 à 00:11:49  profilanswer
up
n°1361403
babatche06
Posté le 01-02-2008 à 16:49:18  profilanswer
Salut, j'ai le même problème que toi
j'ai trouver une solution en utilisant mais média player classic pour lire des DIVX HD avec piste son dolby ou des DVD pour le DTS
En espérant que cela t'aide
A+
n°1361410
DrDooM
Posté le 01-02-2008 à 16:53:37  profilanswer
en fait j'ai trouvé la solution, mais ça saccade encore un peu,
The "clean one":  8)
Settings-->Preferences-->Audio-->Output modules
Check the "Advanced options"-checkbox
Switch from "DirectX output" to "Win32 waveOut extension output" in the drop-down-box.
Save the settings and restart VLC.
Voilà!
The "dirty one": :?
Install VLC version 8.2 in a temporary folder.
Copy "libaout_directx_plugin.dll" in the "plugin"-folder.
Switch to the corresponding folder of VCL version 8.6a.
Make a backup of this "libaout_directx_plugin.dll".
Paste.
Voilà!
  Traitement Audio
problème de double son (casque et HP)[Problème] Samsung LE37S86BDX, paramètres video
Probleme de televiseurProbleme televiseur
Carte TV non reconnue par VLCprobleme 8654 avec divx
probleme desactivation barres vertes vu-metre plasma panaproblème de son sur dvd
problème avec Toshiba RDXV 47Problème Yamaha RX V661
Plus de sujets relatifs à : Problème de son AC3 avec VLC
