4709 connectés
  enceintes pc avec caisson 50-80w rms mini
n°304951
thieuma
Posté le 24-07-2002 à 00:52:45  profilanswer
je cherche d enceintes pc avec un caison 50W rms minimum (2.1 suffit)
n°304954
hacker
.: Swiss & Trance 4 Ever :.
Posté le 24-07-2002 à 00:58:54  profilanswer
http://www.logitech.ch/lang/images/0/68.gif
Logitech® Z-560
4.1 configuration ? 400 Watts ? THX® Certified
Part Number 970055-0914
 > larger view
  The truly epic sound system
Superior, five-piece THX®-Certified Audio System features powered subwoofer and four satellite speakers
400-RMS watts of awesome power for DVDs, music, and PC games
20 cm. diameter "long-throw" subwoofer with wood enclosure, delivers thunderous bass performance for the ultimate audio experience
Ultra-wide bandwidth, phase-aligned satellite driver technology captures distortion-free tones across the full spectrum of sounds
SoundTouch? Control Centre with separate controls for volume, fader, and bass. Headphone socket included
Patented M3D? technology delivers realistic surround sound for intense gaming pleasure and fine quality music reproduction from standard two-channel stereo sound sources
Home stereo style connectors use standard speaker wire so you can place the speakers anywhere you choose
Package contents:
Z-560 subwoofer
4 satellite speakers
SoundTouch? control center
All necessary cords and cables
User's guide
Full product support
2-year guarantee
Specifications:
THX® certified
Total power output: 400 watts RMS - Subwoofer: 188 watts RMS - Satellites: 212 watts RMS (4 x 53 W)
Frequency response: 35 Hz - 20 kHz
Signal-to-noise ratio: > 100 dB (A)
Input impedance: 10,000 ohms
Maximum SPL: 114 dB
Satellites: high excursion, ultra-wide bandwidth driver with aluminium phase plug
Subwoofer: large displacement 20 cm driver in solid wood enclosure
Amplifier: true linear power amplifier with massive toroidal power supply
Connectors: pro audio multi-junction speaker wire connectors, 3.5 mm headphone jack, front & rear channel inputs
THX® advantages:
Few computer speaker systems meet the rigid standards for unparalleled THX® quality sound. To qualify for THX® certification, speakers must provide:
The ability to hear the full dynamic range, from the softest whisper to the loudest explosion, without distortion
Enveloping surround sound and better sound localization
Unsurpassed dialog intelligibility, allowing you to fully understand what is being spoken
Smooth frequency response over the entire range
Wide frequency range covering the lowest to the highest audible sounds
(¯`·._  My websites: www.DeeJer.fr.st | www.cs-osg.net ¯`·._)            Swiss rulezzz [:fadimor]
n°304956
thieuma
Posté le 24-07-2002 à 01:11:53  profilanswer
1700F  :eek2:
un truc similaire genre 2 fois moins puissant en 2.1 et 2 fois moins cher  :)
n°304959
hacker
Posté le 24-07-2002 à 01:13:51  profilanswer
Thieuma a écrit a écrit :
1700F  :eek2:
bin je vois pas quel autre système aurait un caisson de basse qui fait plus de 50 w rms... :/
n°304962
Ninipc
Réalisé sans trucage
Posté le 24-07-2002 à 01:15:42  profilanswer
ckoi l'intérêt?
n°304964
thieuma
Posté le 24-07-2002 à 01:20:16  profilanswer
bah je veux pouvoir entendre les basses de mes mp3  :)
kan je vois le caisson d atp3, ça me fait penser à un tweeter  :D
n°304968
taz77e
Posté le 24-07-2002 à 01:49:33  profilanswer
  G les logitech Z 340, le caisson ne fait que 20 w rms mais ca tarte largement assez pour faire trembler tes vitres, c de la folie.
n°305021
thieuma
Posté le 24-07-2002 à 09:05:18  profilanswer
moué, 20Wrms, ça doit pas te hérisser le poil  :D
n°305084
scott
none
Posté le 24-07-2002 à 10:42:50  profilanswer
tinkiete 20wrms ca bouge bieng ...
ha c djeun'z tjrs a chercher la puissance lol
Tu sais, faut pas avoir peur... Google est ton ami. :)
n°305102
thieuma
Posté le 24-07-2002 à 11:11:13  profilanswer
pourtant, le caisson d atp3 fait 15wrms et ça tape vraiment ke dalle :sweat:
n°305106
hacker
Posté le 24-07-2002 à 11:16:19  profilanswer
http://www.etronicsonline.com/compspeakers/ATP3.jpg :??:
n°305111
thieuma
Posté le 24-07-2002 à 11:20:50  profilanswer
vi, 15 ou 18wrms le caisson je crois
sur les atp5 c déjà mieux (45Wrms) mais pas encore assez et g po besoin de 4 satellites :D
n°305158
taz77e
Posté le 24-07-2002 à 12:33:02  profilanswer
  G été vraiment surpris par ce petit systeme, et pourtant g un bon système hifi à coté (500W rms).
  Je peux te promettre que je suis loin d'etre à fond au niveau du réglage du caisson. Logitech utilise un system qui soit disant produit 2 fois plus de basses qu'un caisson claissique. Si tu peux écoutes les ou dezmandes à d'autres personnes qui en ont!
n°305184
thieuma
Posté le 24-07-2002 à 13:06:38  profilanswer
http://www.centre-informatique.fr/pages/pages_zoom/images/LOG-EZ340.jpg
c celle là ?
elles sont à 400F à coté de chez moua :p
n°305230
taz77e
Posté le 24-07-2002 à 13:49:26  profilanswer
 je les ai payé 360 frs et je peux te promettre que pour ce prix, c hallucinant!! :ouch:  :ouch:
  Je les adore!
n°305234
thieuma
Posté le 24-07-2002 à 13:50:38  profilanswer
bon, dès ke g le temps, v les ht alors :)
n°305237
taz77e
Posté le 24-07-2002 à 13:54:54  profilanswer
Ahhhh!!!! :D  préviens moi quand tu les auras et que tu les écouteras!!! :bounce:  :bounce:
  Pour ce prix là, c nickel!
Message édité par taz77e le 24-07-2002 à 13:55:26
n°305247
thieuma
Posté le 24-07-2002 à 14:02:37  profilanswer
v voir si je peux tester avant d'ht  :D
n°305249
taz77e
Posté le 24-07-2002 à 14:03:17  profilanswer
  Vi, tu sera pas déçu! :D
n°305370
taz77e
Posté le 24-07-2002 à 15:55:04  profilanswer
Alors?
n°307070
thieuma
Posté le 27-07-2002 à 10:41:12  profilanswer
http://a333.g.akamai.net/f/333/7719/10d/213.41.118.85/images/photos/00/00/14/48/ME0000144813_2.jpg
sinon, y'a ça, vous en pensez koi ?
caisson 100wrms  :p
n°307075
pierrotlem​aboule
Posté le 27-07-2002 à 11:05:03  profilanswer
http://a333.g.akamai.net/f/333/771 [...] 4813_2.jpg
caisson 100wrms  :p
excellent j'ai son predecesseur a la maison les altec acs48 80wrms :D
sinon la teleco avec fil :/
sinon il y a aussi yamaha qui a un syst d'1 puissance de 80w rms en 2.1 :)
mon topic de vente
n°307122
sgaloup
Posté le 27-07-2002 à 13:10:08  profilanswer
caisson 100wrms  :p
je les ai et jpe te dire que ca deboite bien!!!!
n°307134
thieuma
Posté le 27-07-2002 à 13:43:28  profilanswer
sgaloup >>>
on peut régler le son ke pour la télécommande ou par les enceintes aussi ?
y'a une prise pour brancher un casque ?
n°307164
thieuma
Posté le 27-07-2002 à 15:27:02  profilanswer
:bounce:
n°307214
sgaloup
Posté le 27-07-2002 à 17:21:08  profilanswer
tout se fais sur la telecommande , rien sur le Hp sur la telec ya le volume + bouton on off , derrier le caisson ya une sorte de volume pour regler c caisson ,pour le cask je crois pas kil y en a sur les 621 je ne suis pas sur , jai pas le caisson sous les yeux je pe pas te dire , mais je crois que ca y est sur les 641 en facade meme.Deja les 621 c  :sol: si tu ve vraiment investir prends les 641 le caison est deux fois plus gros, deja avec les 621 je fais trembler ma chambre alors avevc le 641 [:t3xla] .Franchement pour 140? ca vaut le coup surtout pour des Hps pour PC.Juste un defaut c ke le volume se fait par palier c'est numerique.
Message édité par sgaloup le 27-07-2002 à 17:26:43
n°307217
sgaloup
Posté le 27-07-2002 à 17:23:08  profilanswer
Imagine 100 watts RMS! Alors que les autres font que 20.
n°307220
sgaloup
Posté le 27-07-2002 à 17:25:52  profilanswer
Jai aussi les ATP3 , les ATP3 C du caca a cote de puissances des 621, Pour dire les ATP3 TAPENT plus mais sont pas assez puissant kan tu monte le volume ca crash , alors que les 621 c'est un vrai caisson ca tremble comme les vraies caissons et tu pe mettre FORT  :ouch: sans PB.
ACHETE TU REGRETTERA PAS.
Message édité par sgaloup le 27-07-2002 à 17:28:33
n°307235
HedgeHog
Posté le 27-07-2002 à 17:53:51  profilanswer
et pourquoi pas lui ?http://www.hardware.fr/medias/photos_news/00/04/IMG0004789_1.jpg
n°307237
HedgeHog
Posté le 27-07-2002 à 17:58:02  profilanswer
As-tu entendu parler du ATP4 ?? plus puissant que le ATP3 http://www.hardware.fr/medias/photos_news/00/04/IMG0004574.jpg
n°307257
thieuma
Posté le 27-07-2002 à 18:53:43  profilanswer
le truc de 20wrms tape plus ke celui de 100 ?  :??:
parce ke moua, je veux juste un truc ki tape....
n°307270
sgaloup
Posté le 27-07-2002 à 19:44:53  profilanswer
ouais les ATP3 tapent plus a meme niveau mais les 621 sont beaucoup mieux , c'est pas le meme genre de basses , prends les 621 les ATP3 ca a rien a voir.
n°307273
sgaloup
Posté le 27-07-2002 à 19:45:44  profilanswer
c'est juste un pc ta pa besoin d'un Home cinema.
n°307276
thieuma
Posté le 27-07-2002 à 19:50:25  profilanswer
bas tu me dis ke les atp3 tapent plus mais g un pote ki en a et je trouve ke ça tape vraiment ke dalle....
genre c pas le truc ki te hérisse le poil  ;)
n°307281
sgaloup
Posté le 27-07-2002 à 20:12:52  profilanswer
lol les 621 c mieux c tout ca tape bien voila tu pe ecouter 5 fois plus fort que les atp3 , je te dis les atp3 c du caca a cote.
n°307652
thieuma
Posté le 28-07-2002 à 22:31:54  profilanswer
lol
Dilemne pour placer ses enceintes 5.1 !!Enceintes Altec 621 avec CMI8738/C3DX
excusez moi de vous déranger, quelles enceintes me conseillez vous ?Problème avec mon lecteur mini-disc
Je cherche une mini chaine pour 300? environspack enceintes sony SSFCR400. bien ou pas ?
Heureux possesseurs d'enceintes B&W, faites vous connaitre !Disposotion Caisson de basse !
Mini acceleration en lisant un divxEnceintes TRUST
Plus de sujets relatifs à : enceintes pc avec caisson 50-80w rms mini
