3681 connectés
  Traitement Audio
  Que pensez-vous du Kenwood KDC-M6021G ?
n°377496
amdman
Hell was full, so I came back
Posté le 09-12-2002 à 16:39:19  profilanswer
Moi je le trouve plutôt pas mal mais je ne sais pas ce qu'il vaut.
http://www.justkenwood.co.uk/images/kdcm6021g_xl.jpg
Audio Features
- 4 x 50 watts max. output power
- 2 RCA preouts, 1.8 Volts
- Separated tone control: Bass/Mid/Treble
- Loudness control
- Source volume offset
- Source tone memory
- System Q
Tuner Features
- 24 presets: 18 FM, 6 MW/LW
- Radio Data System
- K3I, clean reception tuner
- Auto memory
- Seek up/down
- Local Seek
- FM Stereo/Mono
- Tuning mode : Auto1/Auto2/Manual
- DAB reception with optional unit KTC-9090DAB
CD Features
- CD-R/RW ready
- CD-Text ready
- MP3 decoder built-in
- 8 times over-sampling
- 1 bit D/A converter
- S/N ratio: 96 dB
- Dynamic range: 95 dB
- Channel separation: 90 dB
- 0-bit mute
Changer Features
- Dual changer control + AUX
- CD-Text with compatible units
- Disc Name Preset System with compatible units
- Disc & Track repeat
- Disc & Track scan
- Disc & Magazine random play
General Features
- Metallic grey finish
- Flip down TDF with removable faceplate
- Protection case for faceplate
- Code protection
- Multi colour LCD display
- 5 x 7 DOT, 8 characters
- White LED display illumination
- Selectable key illumination (red or green)
- 24 hours clock
- Memory calendar
- Auto Dimmer
- 2 way telephone mute
- GSM H/F unit
- OEM display out
- Wired remote out
- External option control
- All off select (20/40/60 min.)
- Built-in fuse/coil
- Remote control optional
ONKYO PR-SC885P / CAYIN 2x D1205.1A / FOCAL Chorus 726S + 706S + CC700S / VELODYNE SPL-1200R / SONY VPL-HW40ES / LUMENE Embassy II 240C INSTALL HC
n°377515
barnabe
Posté le 09-12-2002 à 17:02:22  profilanswer
Esthétiquement c'est pas du tout mon truc, mais alors pas du tout. La boite de nuit dans la caisse...
(les designers z'ont fumé ou quoi?....:D)
n°377771
amdman
Posté le 09-12-2002 à 22:12:22  profilanswer
[:belgarion_cer]
n°378145
amdman
Posté le 10-12-2002 à 16:17:00  profilanswer
Bon heu  :whistle:
n°378160
captainsyl​ver
J'achete du moment que c donné
Posté le 10-12-2002 à 16:51:46  profilanswer
Il est superbe et marche tres bien
Surement l'un des meilleurs autoradios mp3 actuel a ce nivo de prix la
n°378463
oirom
Posté le 11-12-2002 à 01:13:45  profilanswer
Le KDC-M6021G, une très bonne référence.
http://www.autoradio.mp3.ms
n°378521
hiwill
Posté le 11-12-2002 à 10:34:23  profilanswer
Kenwood est une référence dans ctte gamme de prix.
G le KDC MP6090 depuis 1 an 1/2 et aucun reproche à lui faire.
faut être habituer aux menus et aux petites touches...
le 6021 est son remplaçant : C surtout la partie ampli et le design qui changent
il peux aussi recevoir un chargeur ...
un must
n°378587
amdman
Posté le 11-12-2002 à 12:10:58  profilanswer
De fait il est vraiment trop bien. Je viens de l'acheter pour 300 ?. En plus il tient bien les chocs :)
n°385461
amdman
Posté le 24-12-2002 à 17:19:13  profilanswer
Je suis étonné qu'il lise les ID3tag V2.
Sinon pour le reste il lit les tag 1, affiche le nom du répertoire, de l'album, du titre du mp3 en cours, on sait faire défiller le titre automatiquement en activant dans les options. Le design est trop bien et il ne saute pas du tout.
Vraiment un bon produit.
n°387768
captainsyl​ver
Posté le 29-12-2002 à 03:34:25  profilanswer
 ou tu l'as eu a ce prix ?
n°388286
amdman
Posté le 29-12-2002 à 22:55:43  profilanswer
Il y avait une promo chez cora à 300 ? au lieu de 450.
n°388974
doubletrou​ble
Posté le 30-12-2002 à 20:18:19  profilanswer
t'as pas de gout amd.  :lol:
à 350 euros, tu peut avoir un alpine avec chargeur (le must d'apres le magazine hors série compact :sol:
n°389474
amdman
Posté le 31-12-2002 à 17:00:00  profilanswer
Les alpine sont moches, c à gerber. Un design de merde.
  Traitement Audio
Que pensez vous de l'ampli Denon avr 1803 ?Que pensez-vous des enceintes inprise 5100 5.1 de creative labs? Merci
Qu'en pensez vous ? (cinéma-maison)Vous pensez quoi des JmLab Chorus 706 ?
que pensez vous du denon 1603que pensez vous de ceci ??
Que pensez vous de mon matos home cinema???que pensez vous des kits ...
Vous pensez koi de ces kits?quand pensez vous?
Plus de sujets relatifs à : Que pensez-vous du Kenwood KDC-M6021G ?
