9935 connectés
  HiFi & Home Cinema
  Soft-clipping ?
Soft-clipping ?
n°1097818
verbalkint
Posté le 27-06-2006 à 11:32:33  profilanswer
Sur les amplis Nad, il y a un "soft-clipping"... c'est quoi ? :heink:
n°1097849
muzah
Bal Musette @ HFR depuis 1997
Posté le 27-06-2006 à 12:37:36  profilanswer
C'est un système d'écrétage propre à NAD.
NAD Soft Clipping
Any amplifier that is overdriven (asked to generate levels beyond its undistorted capabilities) will produce distortion (clipping). The result is not only very harsh sound but often damage to speakers — especially tweeters. The selectable "Soft Clipping" feature on NAD amplifiers gently transforms the music waveform as the point of clipping approaches, resulting in much clearer reproduction and simultaneous protection of speakers. One very valuable time to consider using the soft clipping option is during a party. As more and more people crowd into a room, and create more and more background noise, it is all too easy to keep setting the volume higher without realizing just how high you have turned it up. Switching in Soft Clipping will greatly reduce the chance of damage. Nothing, however, can absolutely guarantee protection against cranking volume up and leaving it there for a prolonged period. So it is best to use Soft Clipping as temporary protection until you can get to the volume control to set loudness at a more reasonable point.
n°1098063
Trias
0% VCS, 0% prod, 100% pony
Posté le 27-06-2006 à 22:06:12  profilanswer
En gros c'est une technique d'écrétage progressif, comme le dit muzah. C'est à dire que le sommet de l'onde sonore (la crête) est progressivement rabotée, mais ici en fonction des capacités maximales des enceintes en plus de celles de l'ampli. :)
POur y avoir goûté, lorsque cela s'active ce n'est généralement pas plaisant... :whistle:
KEF – Certains pensent. D'autres croient. Qui pensez vous qu'il faille croire ? – SC2 #HFR #Pony
n°1099442
Aarkann
http://www.framasoft.net/
Posté le 01-07-2006 à 15:21:50  profilanswer
Une sécurité en  somme pour le matériel. (pas pour les oreilles)
Perso, j ai déjà poussé très occasionnellement à un niveau qui donne envie de sortir de la pièce et seulement avec un C320, et je n'avait pas encore atteint le niveau pour que celà se déclenche.
Alors t en fait pas, ya de la marge ...
n°1099477
nottwintur​boyet
Posté le 01-07-2006 à 16:40:56  profilanswer
Il y a aussi les modules Ice-Power qui ont un circuit de soft-clipping eux aussi, c'est ici en page 19:
http://www.icepower.bang-olufsen.c [...] et_1-4.pdf
A+
  HiFi & Home Cinema
  Soft-clipping ?
Quel soft pour Convertir de DVD en Divx, Xvid ou WMV9....Retirer la signature du soft SUPER mise en overlay lors de l'encodage
Quel soft pour lire les DVD ?soft pour recadrer une video
Existe-it un soft qui centralise les radios internet ?quel soft pour compil mp3
Soft stable pour montage vidéo + Gravure DVDCherche soft tout simple pour convertir des Mp3 en mp3
rm > mp3 : quel soft ?cherche soft pour détecter modifications de scène ds vidéo
Plus de sujets relatifs à : Soft-clipping ?
