7719 connectés
  HiFi & Home Cinema
  Infinity TSS-750.Qui connait ?
n°558743
biloba84
Arbre aux 40 écus
Posté le 19-12-2003 à 21:05:29  profilanswer
Bonsoir , qui connait ce pack d' enceintes "Infinity TSS-750" qui m' a fait forte impression esthétiquement cette a-m:p .Et avec un ampli Yamaha 440, qu' est-ce que cela donnerait ?
n°559237
biloba84
Arbre aux 40 écus
Posté le 21-12-2003 à 12:06:02  profilanswer
[img] Home Cinema Systems
TSS-750  PRODUCTS IN THIS SERIES
 -- Choose One -- TS-STANDTSS-450TSS-750
TSS-750PLT (Larger View)
Total Solutions? TSS-750
The Infinity Total Solutions?
TSS-750 is a complete multichannel music and home theater loudspeaker system featuring proprietary MMD? drivers. With their compact and versatile design, the satellite speakers can be placed virtually anywhere ? on shelves, or mounted on a wall using the included braket. The center channel can easily be placed on top of, or on a shelf below, the television. The powered subwoofer delivers the bass impact and excitement for your favorite music and movie soundtracks. The satellites and center channel feature extruded and brushed aluminum enclosures. Available in platinum and charcoal finishes.
Larger View
Product Specifications
RESOURCES:
Owner's Manual (PDF)
PRODUCT SPECIFICATIONS
Satellite
Frequency Range:  120Hz ? 20,000Hz (+/?3db)
Recommended Power Amplifier Range:  10 ? 100 watts
Sensitivity:  88dB
Nominal Impedance:  8 ohms
Crossover Frequency:  3500Hz, 24dB/octave
Midrange Driver:  3-1/2" MMD?, magnetically shielded
High-Frequency Driver:  3/4" MMD?, magnetically shielded
Dimensions
(H x W x D):  6" x 4-1/8" x 4-3/8"
(152mm x 105mm x 111mm)
Weight:  2.8 lb (1.3kg)
Center Channel
Frequency Range:  120Hz ? 20,000Hz (+/?3dB)
Recommended Power Amplifier Range:  10 ? 125 watts
Sensitivity (2.83V @ 1m):  89dB
Midrange Driver:  Dual 3-1/2" MMD?, magnetically shielded
Dimensions
(H x W x D):  4-1/8" x 9-1/4" x 4-3/8"
(105mm x 235mm x 111mm)
Weight:  4.5 lb (2.0kg)
Subwoofer
Frequency Range:  34Hz ? 150Hz (+/?3dB)
Amplifier Power Output:  150 watts RMS, 500 watts peak
Low-Frequency Driver:  10" MMD?
Crossover Frequency:  50Hz - 150Hz, 24dB/octave
continuously variable
Dimensions
(H x W x D):  16-3/4" x 10-3/4" x 15-3/4"
(425mm x 273mm x 400mm)
Weight:  28 lb (12.7kg)  [/img]
© Harman International Industries, Incorporated
n°559238
biloba84
Arbre aux 40 écus
Posté le 21-12-2003 à 12:06:52  profilanswer
je vais essayer de vous envoyer la photo
n°559249
biloba84
Arbre aux 40 écus
Posté le 21-12-2003 à 12:26:20  profilanswer
http://www.infinitysystems.com/homeaudio/large.aspx?prod=TSS-750CHR&tss=tss750plt
n°559256
biloba84
Arbre aux 40 écus
Posté le 21-12-2003 à 12:54:39  profilanswer
Désolé je n'v ai pas encore trouvé le moyen de vous envoyer la photo :ange: .Mais d' après la fiche technique, est-ce-que ça devrait bien aller avec le Yamaha 440 (ampli) :??:
SVP, je suis complétement pommé  :cry:  :sweat:
MERCI :jap:
n°559272
kaltan1
Posté le 21-12-2003 à 13:47:25  profilanswer
http://www.infinitysystems.com/homeaudio/images/products_large/tss-750plt.jpg
n°559289
biloba84
Arbre aux 40 écus
Posté le 21-12-2003 à 14:14:41  profilanswer
merci !
n°559407
biloba84
Arbre aux 40 écus
Posté le 21-12-2003 à 20:37:44  profilanswer
[:angel_dooglas] , ben alors personne n'a d'avis ? :heink:
n°559909
biloba84
Arbre aux 40 écus
Posté le 22-12-2003 à 21:00:59  profilanswer
Eh ben, je ne pensais pas avoir posé une question piège !?
ne me reste-t-il plus que le suicide ?[:aldark]
n°560675
kaltan1
Posté le 24-12-2003 à 16:02:23  profilanswer
j'ai des enceintes infinity dans ma caisse et ca déchire bien donc ca devrait pas être du bidon :)
n°560722
ZoltanII
Posté le 24-12-2003 à 17:18:35  profilanswer
moi je l'ais entendu a la fnac faut etre bien devant si tu veux ressentir les basses ( qui etait a fond je precise ) sinon la qualité du son sa va, mais c'est un kit pour les piece de moin de 18m² !
n°560973
biloba84
Arbre aux 40 écus
Posté le 25-12-2003 à 17:24:23  profilanswer
Merci à vous !!:jap:
  HiFi & Home Cinema
qui connait le casque (Hi-Fi) TEKUNI avec 6 canaux ?[Compression] Howto XviD quand on connait déjà et seulement DivX ?!?
philips hdd 100, quelqu'un connait ?Quelqu'un connait un encodeur de mp3 => mp3pro (pas wav=>mp3pro)
Qui connait le logiciel SonicMyDVD ????enceinte Infinity de 6 Ohms ??
Kit Infinity + Ampi Yamaha?Qulqu'un connaît www.cinesnap.com ?
qui connait le KISS DP1000?Un logiciel d'authoring DVD : qui en connait un bon ?
Plus de sujets relatifs à : Infinity TSS-750.Qui connait ?
