2690 connectés
  HTML/CSS
  W3C : comment valider un page contenant un objet Flash ?
 Page :   1  2
Page Précédente
n°818944
fafane84
Posté le 10-08-2004 à 14:12:24  profilanswer
Salut à tous  :hello:
je voudrais valider ma page aux normes W3C HTML 4.01 Transitional, mais j'ai un problème avec les animations Flash figurant sur mes pages.
Je ne sais pas comment le résoudre, j'ai été voir l'aide pour le HTML 4.01 Transitional sur le site du W3C mais il est en anglais et je n'ai rien compris.
Merci d'avance pour votre aide.
Vous trouverez ci-dessous les erreurs de validation :
File:  C:\Perso\Mon Site Internet\DivX Tutos\bsplayer086.html
Encoding:  iso-8859-1
Doctype:  HTML 4.01 Transitional
Errors:  13
This page is not Valid HTML 4.01 Transitional!
Below are the results of attempting to parse this document with an SGML parser.
1. Line 36, column 394: there is no attribute "SRC"
...m name=quality value=high><embed src="menu_accordion.swf" width="130" height=
You have used the attribute named above in your document, but the document type you are using does not support that attribute for this element. This error is often caused by incorrect use of the "Strict" document type with a document that uses frames (e.g. you must use the "Transitional" document type to get the "target" attribute), or by using vendor proprietary extensions such as "marginheight" (this is usually fixed by using CSS to achieve the desired effect instead).
This error may also result if the element itself is not supported in the document type you are using, as an undefined element will have no supported attributes; in this case, see the element-undefined error message for further information.
How to fix: check the spelling and case of the element and attribute, (Remember XHTML is all lower-case) and/or check that they are both allowed in the chosen document type, and/or use CSS instead of this attribute.
2. Line 36, column 421: there is no attribute "WIDTH"
...embed src="menu_accordion.swf" width="130" height="229" hspace="10" vspace="0
3. Line 36, column 434: there is no attribute "HEIGHT"
...nu_accordion.swf" width="130" height="229" hspace="10" vspace="0" quality=hig
4. Line 36, column 447: there is no attribute "HSPACE"
...swf" width="130" height="229" hspace="10" vspace="0" quality=high pluginspage
5. Line 36, column 459: there is no attribute "VSPACE"
...130" height="229" hspace="10" vspace="0" quality=high pluginspage="http://www
6. Line 36, column 471: there is no attribute "QUALITY"
..."229" hspace="10" vspace="0" quality=high pluginspage="http://www.macromedia.
7. Line 36, column 488: there is no attribute "PLUGINSPAGE"
... vspace="0" quality=high pluginspage="http://www.macromedia.com/shockwave/dow
8. Line 36, column 581: there is no attribute "TYPE"
...P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" scale="e
9. Line 36, column 619: there is no attribute "SCALE"
...application/x-shockwave-flash" scale="exactfit"></embed></object></div>
10. Line 36, column 629: element "EMBED" undefined
...n/x-shockwave-flash" scale="exactfit"></embed></object></div>
You have used the element named above in your document, but the document type you are using does not define an element of that name. This error is often caused by incorrect use of the "Strict" document type with a document that uses frames (e.g. you must use the "Frameset" document type to get the "<frameset>" element), or by using vendor proprietary extensions such as "<spacer>" or "<marquee>" (this is usually fixed by using CSS to achieve the desired effect instead).
11. Line 37, column 592: there is no attribute "BGCOLOR"
...plication/x-shockwave-flash" bgcolor="#E9EAEC"></embed></object></div>
12.Line 37, column 601: element "EMBED" undefined
.../x-shockwave-flash" bgcolor="#E9EAEC"></embed></object></div>
13. Line 38, column 548: element "EMBED" undefined
...kwave-flash" width="550" height="100"></embed></object></div>
 [:fafane84]
Mon Topic de Vente Hardware
n°818946
Mr Mala
Posté le 10-08-2004 à 14:14:57  profilanswer
Je pense que ça a déjà été discuté ici
http://forum.hardware.fr/hardwarefr/Programmation/sujet-55574-1.htm ...
Vas jetter un coup d'oeil ...
n°818951
masklinn
Posté le 10-08-2004 à 14:20:26  profilanswer
je remet la version "valide qui marche" du script (je ne l'avais pas mise sur le thread linké):
Code :
  1. <?xml version="1.0" encoding="UTF-8"?>
  2.   <!DOCTYPE html
  3.        PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
  4.       "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
  5.   <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
  6.     <head>
  7.       <title>Flash test</title>
  8.     </head>
  9.     <body>
  10.       <p>Animation flash</p>
  11.       <p>
  12.           <object type="application/x-shockwave-flash" width="550" height="400" id="foo" data="foo.swf">
  13.               <param name="allowScriptAccess" value="sameDomain" />
  14.               <param name="movie" value="foo.swf" />
  15.               <param name="quality" value="high" />
  16.               <param name="bgcolor" value="#ffffff" />
  17.           </object>
  18.       </p>
  19.       <p>Fin animation flash</p>
  20.     </body>
  21.   </html>
l'"inconvénient" de cette méthode est que la fonction MSIE permettant de cliquer sur l'animation quand on a pas le plugin flash (pour l'installer) ne fonctionne pas, le conseil est alors de créer une animation "sacrificielle" vide (1 image et 10 par 10) avec les attributs classid et codebase, Gecko n'en tiendra pas compte et ca permettra aux gens utilisant IE d'avoir la fonction dispo
n°819002
fafane84
Posté le 10-08-2004 à 14:59:59  profilanswer
Merci pour vos réponses
J'ai fais comme çà :
<div id="menuV" style="position:absolute; left:2%; top:240px; width:150px; height:335px; z-index:6">
 <object type="application/x-shockwave-flash" width="130" height="229" hspace="10" vspace="0" data="menu_accordion.swf">
  <param name="movie" value="menu_accordion.swf" />
  <param name="quality" value=high />
 </object>
</div>
Mais çà ne marche pas, mon animation n'est plus visible sous Internet Explorer.
n°819005
Jubijub
Parce que je le VD bien
Posté le 10-08-2004 à 15:03:18  profilanswer
y te manque des guillemets (mais c pas le problème)
sinon data et movie pointent pas sur le même flash (contrairement à l'exemple de masklinn)
Jubi Photos : Flickr - 500px
n°819006
masklinn
Posté le 10-08-2004 à 15:05:00  profilanswer
pourquoi mettre des hspace et vspace?
t'as testé avec l'animation en dehors du div?
ton animation "de base" est elle bien générée/créée/enregistrée en 229*130?
tu as oublié l'id
heu normalement si, data est pour Gecko et movie pour MSIE si je me souviens bien de mes tests
Code :
  2.     <!DOCTYPE html
  6.       <head>
  8.       </head>
  9.       <body>
  11.         <p><div id="menuV" style="position:absolute; left:2%; top:240px; width:150px; height:335px; z-index:6">
  12.             <object type="application/x-shockwave-flash" width="130" height="229" id="foo" data="foo.swf" hspace="10" vspace="0">
  17.             </object>
  18.             </div>
  19.         </p>
  20.         <p>Fin animation flash</p>
  21.       </body>
  22.     </html>
fonctionne chez moi, en local (par contre le position:absolute change la mise en page ;))
fichier flash utilisé -> http://img43.exs.cx/my.php?loc=img43&image=foo.swf
meerdenis oublié de tester avec MSIE, je fais ca de suite
après test, pas de problème sous MSIE 6.0.2800.1106 SP1
Message édité par masklinn le 10-08-2004 à 15:16:07
n°819017
fafane84
Posté le 10-08-2004 à 15:15:25  profilanswer
tu as oublié l'id
J'ai fais çà :
<object type="application/x-shockwave-flash" width="130" height="229" id="menu_accordion" data="menu_accordion.swf">
 </object>
Et çà ne marche toujours pas.
Mon animation fait bien 229*130.
n°819018
masklinn
Posté le 10-08-2004 à 15:16:42  profilanswer
files ton animation stp
n°819048
fafane84
Posté le 10-08-2004 à 15:38:55  profilanswer
Je ne peux pas  :(
Mon animation n'est pas en ligne.
De plus je suis au boulot et j'ai un acces restreint à Internet.
n°819087
masklinn
Posté le 10-08-2004 à 15:58:21  profilanswer
balance la sur http://www.imageshack.us pour la stocker
n°819187
fafane84
Posté le 10-08-2004 à 16:33:15  profilanswer
Cà y est j'ai réussi  :sol:
Il suffisait tout simplement d'enlever la balise <enbed>, comme çà :
<div>
  <object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,29,0" width="550" height="100">
   <param name="movie" value="spot.swf">
   <param name=quality value=high>
  </object>
</div>
C'est visible sur Internet Explorer et c'est validé en HTML 4.01 transitional par le W3C.
Encore merci de vous être penchés sur mon cas.
 [:fafane84]
n°819205
masklinn
Posté le 10-08-2004 à 16:46:40  profilanswer
ya jamais eu de balise embed dans le code que tu m'as filé -_-
ca sera pas visible avec un seul navigateur non MSIE
n°819207
fastclemmy
(re-)Dictateur en plastique
Posté le 10-08-2004 à 16:48:16  profilanswer
n°819909
fafane84
Posté le 11-08-2004 à 08:08:06  profilanswer
Si, si, au début dans mon tout 1er post, regardes les erreurs de validation.
Mais après effectivement je l'avais retirée de mon code, conformement à tes instructions.
Il faut savoir que le code d'origine a été fait avec Dreamweaver MX 2004 (version d'évaluation) et que lorsque l'on insère un objet Flash il crée une balise <object> et <embed> comme çà :
<object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,29,0" width="130" height="229" hspace="10" vspace="0">
   <param name="movie" value="menu_accordion.swf">
 <embed src="menu_accordion.swf" width="130" height="229" hspace="10" vspace="0" quality=high pluginspage="http://www.macromedia.com/shockwave/download/index.cgi?P1_Prod_Version=ShockwaveFlash" type="application/x-shockwave-flash" scale="exactfit">
 </embed>
</object
Ah bon ?
Mince moi qui croyait que la validation du W3C était pour qu'il y ait un maximum de compatibilité.
Mais alors comment faire puisque c'est la balise <embed> qui pose problème ?  :cry:
n°819955
masklinn
Posté le 11-08-2004 à 09:26:49  profilanswer
J'ai pas regardé les erreurs, j'ai regardé le code :) (ayant déjà eu affaire à ce problème je voyais globalement d'où ca pouvait venir)
 </embed>
</object
oui, l'export FlashMX fait pareil, du code pourri
Ah bon ?
La validation W3C vérifie l'existence de champs/balises/attributs valides uniquement (+ la présence de tous ceux qui sont nécessaires), pas toujours la validité des valeurs des attributs
Je t'ai donné la solution: laisse <embed \> en dehors de ca (balise inexistante dans les specs w3c) et dans <object> retire les attributs:
c'est une perversion dédiée à IE d'attributs de la balise <object> qui ne sont pas censés servir à ca, ce qui fait qu'en lisant ce code Moz/Fox ne peut pas parser l'objet et ne l'affiche donc pas
n°819994
fafane84
Posté le 11-08-2004 à 10:01:31  profilanswer
Oui mais si je me conforme à tes instructions çà marche dans Mozilla mais plus dans IE
   <object type="application/x-shockwave-flash" width="130" height="229" hspace="10" vspace="0" data="menu_accordion.swf" >
   <param name=quality value=high />
   </object>
</div>
Message édité par fafane84 le 11-08-2004 à 10:02:21
n°820007
masklinn
Posté le 11-08-2004 à 10:22:22  profilanswer
c'est pour ca que je te demande ton code + ton animation, chez moi ca marche
n°820012
fafane84
Posté le 11-08-2004 à 10:27:36  profilanswer
J'irais à midi dans un cybercafé uploader les fichiers sur mon site.
-> index.html (page où est située l'animation)
-> animation flash (menu accordion.swf)
Dis exactement ce qu'il te faut car du boulot je ne pourrais plus uploader.
As-tu besoin des fichiers .fla ?
n°820067
masklinn
Posté le 11-08-2004 à 11:00:26  profilanswer
normalement je ne devrais pas avoir besoin du fichier *.fla non, mais si c'est pas plus difficile à fournir met le avec, juste au cas ou :)
n°820204
fafane84
Posté le 11-08-2004 à 12:31:07  profilanswer
Voilà çà y est :
http://divxtutos.site.voila.fr/index.html
Et tien toi bien je l'ai essayé sur IE 6 au cybercafé et bien çà fonctionne !!!  :pt1cable:   :??:   :pt1cable:
Je n'y comprend rien, de retour au boulot çà ne marche pas  :fou:
Au boulot je n'ai pas IE 6 mais IE 5.5, est-ce du à çà ?
Y-a-t-il une option spécifique à cochée dans IE 5.5 ?
Peux-tu me confirmer que chez cela fonctionne.
n°820206
Mr Mala
Posté le 11-08-2004 à 12:37:41  profilanswer
Je me suis permis d'aller voir ton truc ...
Ici, j'ai IE 5.0 et ça fonctionne nickel ...
n°820207
fafane84
Posté le 11-08-2004 à 12:43:04  profilanswer
Tu as très bien fait, donc j'en conclus que c'est mon IE 5.5 qui déconne et non le code.
Mais comment résoudre çà ???  :cry:
n°820212
masklinn
Posté le 11-08-2004 à 12:47:05  profilanswer
Avec Firefox 0.9.3 comme avec IE6 SP1 ca fonctionne NP (macromedia flash player 7)
J'ai pas d'IE 5.x dispo donc je peux pas tester
PS: il te reste 2 erreurs pour que ca soit valide HTML 4.01 transitionnal, il faut que tu ajoutes 'type="text/javascript"' à tes tags '<script language='javascript'>' (lignes 146&147)
Tu es sur d'avoir Flash Player 7 installé sur IE au boulot?
n°820223
Mr Mala
Posté le 11-08-2004 à 12:57:16  profilanswer
Effectivement, pour complêter le post de Masklinn, j'ai le plugin flash7 !
n°820235
fafane84
Posté le 11-08-2004 à 13:10:11  profilanswer
Oui puisque je peux ouvrir mon fichier .swf avec IE 5.5
n°820246
masklinn
Posté le 11-08-2004 à 13:22:48  profilanswer
daytaysay alors
faudrait tester la page chez d'autres personnes, mais bon sta faute si t'as IE5.5 :o
n°820254
fafane84
Posté le 11-08-2004 à 13:37:16  profilanswer
Masklinn a écrit :
daytaysay alors
C'est chez les autres çà marche  :fou:
En tout cas merci pour tout  :hello:
n°821052
fafane84
Posté le 12-08-2004 à 08:19:53  profilanswer
Cà commence vraiment à me saoûler  :fou:
J'y comprend rien, quand je cliques ici : http://divxtutos.site.voila.fr/index.html, les animations Flash sont invisibles sous IE (voir post plus haut) à la place il y a une fenêtre blanche avec une barre de défilement grisée qui apparait.
A noter que lorsque je change le code et que je quand je remets :
à la place de :
<object type="application/x-shockwave-flash" width="550" height="100" data=spot.swf>
elles réapparaissent.
Donc il ne s'agit pas d'un problème de lecteur Flash.
De plus sur un autre ordi de la même config que le mien (collegue de travail) le problème ne se pose pas.
Tous les options d'Internet Eplorer sont identiques.
Alors d'où peut provenir le problème ???
Quelqu'un aurait-il une idée ???
n°821087
masklinn
Posté le 12-08-2004 à 09:33:17  profilanswer
t'es maudit :o
faut faire démarabouter ton internet explorer :o
ou changer de browser :o
n°821118
pierre6020
Posté le 12-08-2004 à 09:55:47  profilanswer
Il est encore temps de sauver ton ame :
http://www.mozilla-europe.org/fr/products/firefox/
n°821247
fafane84
Posté le 12-08-2004 à 11:34:20  profilanswer
Masklinn a écrit :
t'es maudit :o
 :lol:  :lol:  :lol:  :lol:  :lol:  :lol:
Oui bien sur mais je ne peux pas car c'est le PC de mon boulot et chez moi çà fonctionne  :pt1cable: .
n°821332
masklinn
Posté le 12-08-2004 à 12:24:07  profilanswer
on s'en fout que ce soit le pécé de ton boulot, moi j'ai bien installé firefox comme un chacal au boulot :o
n°821338
pierre6020
Posté le 12-08-2004 à 12:32:36  profilanswer
+1 c'est ca ou je reste chez moi :)
n°821475
fafane84
Posté le 12-08-2004 à 14:31:02  profilanswer
Cà y est c'est fait  ;)
n°821478
pierre6020
Posté le 12-08-2004 à 14:33:43  profilanswer
Aaaaaaaahhhh! :)
n°821600
fastclemmy
Posté le 12-08-2004 à 15:56:56  profilanswer
Cela dit, en regardant le lien que je vous ai filé plus haut vous verrez le cheminement exact pour arriver à une page valide XHTML contenant du Flash...
http://incongru.webdynamit.net/XhtmlEtFlash
n°821611
masklinn
Posté le 12-08-2004 à 16:04:51  profilanswer
en même temps si tu veux voir tout le cheminement autant aller  à la source [:itm]
n°821895
torpe23
Posté le 12-08-2004 à 22:19:04  profilanswer
Petite remarque sur le site de fafane84:
"accueil" ça s'écrit "accueil" et non "acceuil".
n°822043
fafane84
Posté le 13-08-2004 à 08:13:00  profilanswer
Oh là là oui c'est exact  :(
Je ne m'étais pas gouré dans le titre de la page mais là il faut dire qu'elle est belle cette faute d'autant que depuis le temps que je bosse sur ce site je ne m'en été toujours pas aperçu.
Heureusement ce n'était qu'un site provisoire, je corrige ma page en "local" pour le prochain upload.
Merci torpe23 pour cette intervention pertinente.
 [:fafane84]
n°1863740
karpediem
Posté le 19-03-2009 à 17:55:54  profilanswer
Bonjour @ toutezéatous,
Ce post est un peu vieux, mais je l'ai retrouvé en cherchant une réponse à mon pb... ça prouve que je cherche bien ;o))
Voici la déclaration de mon animation dans ma page web :
<object type="application/x-shockwave-flash" data="media/france2" width="170" height="170" align="middle" id="france_loc">
<param name="movie" value="media/france2.swf" />
</object>
Cette animation lit un fichier XML Tout se passe bien lorsque je suis sur FF. En revanche, sue IE, au 1er appel de ma page, l'animation se charge, elle est visible, mais ne lit pas le fichier XML. Pour que ça se fasse, il faut que je rafraichisse ma page et là, tout fonctionne correctement.
Sur FF la lecture du XML se fait dès le 1er appel...
Pensez-vous que quelque chose merdouille dans l'appel de mon anim dans ma page php ?
Merci pour vos idées et excellente journée !!
 Page :   1  2
Page Précédente
  HTML/CSS
Signet dans une entete ou pied de page wordValider un formualire automatiquement par php ou javascript
[PHP] Return d'un objet qui foire 2 css pour un un même média d'une page web
page casserInserer un chat sur une page Wanadoo.fr
[Flash] Faire défiler du texte avec le mulot....Faire uen courbe a partir d'un fichier plat sur une page web ?
Espacement de cellule valide au W3CPq ma popup change ma page principale ???
Plus de sujets relatifs à : W3C : comment valider un page contenant un objet Flash ?
