3493 connectés
  HTML/CSS
  Problème sur IE mais pas sur Firefox
n°1777308
a-ntrax
Posté le 25-08-2008 à 17:13:41  profilanswer
Bonjour, voilà j'ai créé un page html. Sur firefox tout s'aligne parfaitement sauf que sur IE il y a des espaces entre chaque images de haut en bas.
Voici le index.html:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
       "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<title>inox multigaming - since 2008 - www.inox-gaming.eu - coming soon</title>
</head>
<body bgcolor="#000000" leftmargin="0" topmargin="0" marginwidth="0" marginheight="0" align="center" link="#000000" vlink="#000000" alink="#000000">
<style type="text/css">
body{
background-color: #000000;
font-family:verdana, Arial, Sans-serif;
font-size:10px;
color:#FFFFFF;
a:link{
font-size:10px;
color:#FFFFFF;
text-decoration:none;
a:visited{
font-size:10px;
color:#FFFFFF;
a:hover{
font-size:10px;
color:#00FF00;
a:active{
font-size:10px;
color:#FFFFFF;
</style>
 <center><img src="/img/intro/wscs.png" border="0"></center> </br>
 <center><img src="/img/intro/bor1.png" border="0"><a href="http://4d-crea.com"><img src="/img/intro/sponsor1.png" border="0"></a><img src="/img/intro/med1.png" border="0"></center> </br>
 <center><img src="/img/intro/bor2.png" border="0"><a href="#"><img src="/img/intro/sponsor2.png" border="0"></a><img src="/img/intro/med2.png" border="0"></center> </br>
 <center><img src="/img/intro/bar3.png" border="0"></center> </br>
 <center><img src="/img/intro/bor4.png" border="0"><a href="mailto:contact@inox-gaming.eu"><img src="/img/intro/contact4.png" border="0"></a><img src="/img/intro/med4.png" border="0"></center> </br>
 <center><img src="/img/intro/bar5.png" border="0"></center> </br>
 <center><img src="/img/intro/bor7.png" border="0"><a href="/irc/inox-gaming.html"><img src="/img/intro/irc7.png" border="0"></a><img src="/img/intro/med7.png" border="0"></center> </br>
 <center><img src="/img/intro/bar8.png" border="0"><a href="mailto:webmaster@inox-gaming.eu"><img src="/img/intro/webmaster8.png" border="0"></center> </br>
 <center><a href="#"><img src="/img/intro/cpr9www.png" border="0"></a></center> </br>
</body>
</html>
Si vous pouviez trouver la solution pour avoir le même résultat que sa soit sur IE ou sur Firefox sa serait génial.
a++
n°1777315
a-ntrax
Posté le 25-08-2008 à 17:25:15  profilanswer
n°1777322
mIRROR
Chevreuillobolchévik
Posté le 25-08-2008 à 17:36:55  profilanswer
la reponse est simple mais tu as de trop grosses lacunes en html
les balises center c est n importe quoi et le logo découpé aussi
pour le bloc sponsors ca devrait pas etre des images mais un background
« The enemy is the gramophone mind, whether or not one agrees with the record that is being played at the moment. » — George Orwell
n°1777338
David Bori​ng
Posté le 25-08-2008 à 18:06:33  profilanswer
Et pour info, avec un tel html, tu n'auras aucune existence pour les moteurs de recherche. Ton site est vide de contenu.
Affiche le sans image dans firefox, tu vas te marrer !
n°1777340
a-ntrax
Posté le 25-08-2008 à 18:15:45  profilanswer
Bonjour, je ne dit pas que je suis un bon en html, loin de la mais j'aurais voulu savoir si il y avais un solution à sa. Je ne m'y connais pas en programmation html donc a vous de voir si sa vous tente de m'aider.
n°1777342
mIRROR
Posté le 25-08-2008 à 18:18:24  profilanswer
je te l ai dit y a une solution qui marche tres bien mais dans ton cas c est mieux de revoir la structure de ton code et ca ira tout seul
n°1777490
a-ntrax
Posté le 25-08-2008 à 23:13:06  profilanswer
Refaire la structure pas de problème. Juste besoin d'un peu plus d'infos.
n°1777496
mIRROR
Posté le 25-08-2008 à 23:41:53  profilanswer
bah pour commencer relis mon premier post ca sera un debut
n°1777742
a-ntrax
Posté le 26-08-2008 à 14:56:49  profilanswer
C'est bon, j'ai trouvé un solution. Merci quand même. Tchao
  HTML/CSS
Problème de superposition de texte sur imageproblème de AND et OR dans mon select
Problème .hproblème fichier C
Probleme de library[Résolu] Problème UTF8, l'espace magique.
probleme de compilationComment attaquer le probleme php/mysql + chrono ?
probleme menu deroulant IE/firefoxProblème d'affichage de tableau : vertical Firefox / Horizontal IE
Plus de sujets relatifs à : Problème sur IE mais pas sur Firefox
